RDK
Using GPIO on Pi B+
Sat May 14, 2016 3:37 pm
I've been experimenting with GPIO on a Raspberry Pi v2. Both Python code and command line commands are working. I just tried to do this on one of my Raspberry Pi B+ units and have run into a problem. My simple Python program runs and does not give any errors, however when I try to run "sudo gpio readall outputs" from a command line I get this error message "sudo: gpio: command not found". I assume that means that some parts of the GPIO system which are on the Raspberry Pi v2 by default are not on the Raspberry Pi B+?
What additional functionality do I need to install? Also, are the GPIO, BMC and physical pins the same on the Raspberry Pi B+ as on the Raspberry Pi v2?
Thanks...RDK
joan
Re: Using GPIO on Pi B+
Sat May 14, 2016 3:46 pm
The pins and GPIO on the Pis with the 40 pin expansion header are identical.
You don't need sudo to run gpio, it is set uid root.
If it's not found then it's not installed (perhaps your Pi B+ has an out of date version of Raspbian or you have purged the package - try sudo apt-get install wiringpi).
RDK
Sat May 14, 2016 4:05 pm
OK, I ran the install command and got the following error:
$ sudo apt-get install wiringpi
Reading package lists... Done
Building dependency tree
Package wiringpi is not available, but is referred to by another package.
E: Package 'wiringpi' has no installation candidate
I'm running Raspbian Wheezy on the Raspberry Pi B+, but Jessie on the Raspberry Pi v2.
As I write this I'm running the
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
commands on the Raspberry Pi B+.....RDK
FTrevorGowen
Sat May 14, 2016 4:20 pm
RDK wrote: ...
sudo apt-get update
IIRC, wiringPi was never "pre-installed"** with Wheezy and there's no "simple way" to "upgrade" Wheezy to Jessie (there's an old thread with specific instructions, but whether they're still valid IDK).
Trev.
** ie. it had to be installed as per the (original) instructions on the wiringPi website. At some point it became installable via apt-get, only from the "Jessie" repository (but I could be wrong).
RDK
Sat May 14, 2016 4:38 pm
Oops. I did not mean to say I was going to do
. I want to keep this unit on Wheezy for the time being.
WiringPi installed successfully this time. Thanks to all.....RDK
