heres a screenshot of my system that uses LXDE, listed below are the 2 files used with LXPANEL, note the code required to get an "apps list" (custom second menu button).
Note that the Atari symbol is made from placing an actual ST logo over the top of an upside down RPI logo, otherwise it would look even less like and Atari logo than it already does.
Note also that the top menu is a second menu button with a custom entries (found out howto by accident), similar to the Accessories menu on an ST (it is not dynamic)
(click the above thumbnail image for 1360x768 screenshot)
both of the following are in the attachment
this is the
top menu bar panel (~/.config/lxpanel/_default_panel_dir_/panels/panel.top)
# lxpanel <profile> config file. Manually editing is not recommended.
# Use preference dialog in lxpanel to adjust config when you can.
Global {
edge=top
allign=left
margin=0
widthtype=percent
width=100
height=32
transparent=0
tintcolor=#000000
alpha=0
autohide=0
heightwhenhidden=2
setdocktype=1
setpartialstrut=1
usefontcolor=0
fontsize=12
fontcolor=#ffffff
usefontsize=0
background=0
backgroundfile=/home/pi/.themes/PiAra/gtk-2.0/Menu-Menubar/PiAra-menubar-top.png
iconsize=30
Plugin {
type=space
Config {
Size=2
Plugin {
type=menu
Config {
image=/usr/share/raspberrypi-artwork/raspitr-pa.png
item {
name=Run...
command=run
image=gnome-run
separator {
item {
name=Calculator
image=galculator
action=galculator
item {
name=GrafX2
image=grafx2
action=grafx2
item {
name=Text Editor
image=accessories-text-editor
action=x-editor
item {
name=Downloader
image=uget-iconf
action=uget-gtk %u
item {
name=Web Browser
image=chromium-browser
action=chromium-browser %U
separator {
item {
name=Ark
image=ark
action=ark -caption %c %U
item {
name=Xarchiver
action=xarchiver
separator {
item {
name=LXterminal
image=terminal
action=lxterminal
item {
name=Root Terminal
image=gksu-root-terminal
action=gksu /usr/bin/x-terminal-emulator
item {
name=UXterm
image=xterm-color
action=uxterm
separator {
item {
name=Shutdown...
command=logout
image=gnome-logout
Plugin {
type=topmenu_lxpanel
Config {
Plugin {
type=space
Config {
Size=2
Plugin {
type=tray
Config {
Plugin {
type=space
Config {
Size=2
Plugin {
type=dhcpcdui
Config {
Plugin {
type=dclock
Config {
ClockFmt=%k:%M
TooltipFmt=%A %x
BoldFont=0
IconOnly=0
CenterText=0
this is the
bottom menu bar panel (~/.config/lxpanel/_default_panel_dir_/panels/panel.bot)
Global {
edge=bottom
allign=left
margin=0
widthtype=percent
width=100
height=32
transparent=0
tintcolor=#000000
alpha=0
autohide=0
heightwhenhidden=2
setdocktype=1
setpartialstrut=1
usefontcolor=0
fontsize=12
fontcolor=#ffffff
usefontsize=0
background=0
backgroundfile=/home/pi/.themes/PiAra/gtk-2.0/Menu-Menubar/PiAra-menubar-bottom.png
iconsize=30
Plugin {
type=space
Config {
Size=2
Plugin {
type=menu
Config {
name=Menu
image=/usr/share/raspberrypi-artwork/raspitr.png
system {
separator {
item {
name=Run...
image=gnome-run
command=run
separator {
item {
name=Shutdown...
image=gnome-logout
command=logout
Plugin {
type=space
Config {
Size=8
Plugin {
type=wincmd
Config {
image=/usr/share/lxpanel/images/gnome-fs-desktop.png
Button1=iconify
Button2=shade
Toggle=0
Plugin {
type=space
Config {
Size=8
Plugin {
type=launchbar
Config {
Button {
id=/usr/share/raspi-ui-overrides/applications/lxterminal.desktop
Button {
id=/usr/share/raspi-ui-overrides/applications/pcmanfm.desktop
Button {
id=/usr/share/applications/lxde-x-www-browser.desktop
Button {
id=/usr/share/applications/wolfram-mathematica.desktop
Button {
id=/usr/share/applications/wolfram-language.desktop
Plugin {
type=space
Config {
Size=8
Plugin {
type=taskbar
expand=1
Config {
tooltips=1
IconsOnly=0
ShowAllDesks=0
UseMouseWheel=1
UseUrgencyHint=1
FlatButton=0
MaxTaskWidth=200
spacing=1
GroupedTasks=0
Plugin {
type=space
Config {
Size=2
Plugin {
type=ejecter
Config {
Plugin {
type=volumealsa
Config {
Plugin {
type=cpu
Config {
ShowPercent=1
Foreground=#a9a9a9a9a9a9
Background=#d3d3d3d3d3d3
Yes I have tweeked the standard (bottom) panel file to include the "clear desktop" with a custom image
Hope someone finds these useful
Cheers
Paul
