ltlklr
Playing a video with a ultrasonic senzor
Sun Mar 24, 2019 11:59 am
I need to play a video with a ultrasonic sensor.
But I also have a button to play the second video and a button to stop the video.
I'm using omxplayer.
I already have code to use buttons, but I don't have the code for the ultrasonic sensor
Here is my current code:
#!/usr/bin/python
import RPi.GPIO as GPIO
import os
import sys
from subprocess import Popen
import time
GPIO.setmode(GPIO.BCM)
GPIO.setup(17, GPIO.IN, pull_up_down=GPIO.PUD_UP) # Playaj edukativni video
GPIO.setup(18, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(27, GPIO.IN, pull_up_down=GPIO.PUD_UP)
movie1 = ("/home/pi/Ja.mp4")
movie2 = ("/home/pi/Ja2.mp4")
last_state1 = True
last_state2 = True
input_state1 = True
input_state2 = True
quit_video = True
player = False
while True:
    #Read states of inputs
    input_state1 = GPIO.input(17)
    quit_video = GPIO.input(27)
    #If GPIO(17) is shorted to Ground
    if input_state1 != last_state1:
        if (player and not input_state1):
            os.system('killall omxplayer.bin')
            omxc = Popen(['omxplayer', '-b', movie1])
            player = True
        elif not input_state1:
            player = True
    #GPIO(27) to close omxplayer manually - used during debug
    if quit_video == False:
        player = False
    #Set last_input states
    last_state1 = input_state1
    last_state2 = input_state2
[moderator: please next time add your code tags yourself!]
B.Goode
Re: Playing a video with a ultrasonic senzor
Sun Mar 24, 2019 12:14 pm
Maybe there is more than one model of ultrasonic sensor? It would help to be specific.
The gpiozero Python library has support for the common hc-sr04 sensor - https://gpiozero.readthedocs.io/en/stab ... or-hc-sr04
There are many other examples of using this sensor available: many are poorly implemented and unreliable.
ltlklr
Sun Mar 24, 2019 12:23 pm
I have the HC-sr04
pcmanbob
Mon Mar 25, 2019 2:34 pm
To connect your HC-SR04 ( assuming 5v version of sensor ) to the pi you need to level shift the 5v output of the sensor down to the 3.3v required by the pi gpio using 2 resistors connected like this.
then this code will trigger the sensor and read the range returned.
#!/usr/bin/python
# Import required Python libraries
import time
# Use BCM GPIO references
# instead of physical pin numbers
GPIO.setwarnings(False)
# Define GPIO to use on Pi
GPIO_TRIGGER = 23
GPIO_ECHO    = 24
# Set pins as output and input
GPIO.setup(GPIO_TRIGGER,GPIO.OUT)  # Trigger
GPIO.setup(GPIO_ECHO,GPIO.IN)      # Echo
# Set trigger to False (Low)
GPIO.output(GPIO_TRIGGER, False)
print "Ultrasonic Measurement"
# Allow module to settle
time.sleep(0.5)
# Send 10us pulse to trigger
GPIO.output(GPIO_TRIGGER, True)
time.sleep(0.00001)
start = time.time()
while GPIO.input(GPIO_ECHO)==0:
  start = time.time()
while GPIO.input(GPIO_ECHO)==1:
  stop = time.time()
# Calculate pulse length
elapsed = stop-start
# Distance pulse travelled in that time is time
# multiplied by the speed of sound (cm/s)
distancet = elapsed * 34300
# That was the distance there and back so halve the value
distance = distancet / 2
print "Distance :", distance
print "Elaspsed time :", elapsed
# Reset GPIO settings
GPIO.cleanup()
