thagrol
STICKY: Running A Program At Start UP A Beginner's Guide
Wed Jun 23, 2021 2:51 pm
Number four in an occasional series.
boot.zip
(169.63 KiB) Downloaded 400 times
Also on github: https://github.com/thagrol/Guides
neilgl
Re: Running A Program At Start UP A Beginner's Guide
Wed Jun 23, 2021 3:40 pm
Excellent stuff, thanks.
deepo
Wed Jun 23, 2021 6:51 pm
That's good work!
katesimon123
Wed Jun 23, 2021 7:52 pm
Good one, will test it out !!!
RonR
Wed Jun 23, 2021 8:25 pm
A && B || C : Do A, if A succeeds do B. If A failed do C
I believe this should be:
A && B || C : Do A, if A succeeds do B. If A or B failed do C
root@FreePBX:~# true && true || echo "!"
root@FreePBX:~# true && false || echo "!"
root@FreePBX:~# false && true || echo "!"
root@FreePBX:~# false && false || echo "!"
thagrol
Wed Jun 23, 2021 9:28 pm
Probably. Feel free to open an issue in my github.
bls
Wed Jun 23, 2021 9:40 pm
This is great, thagrol!
Pi tools:
Quickly and easily build customized-just-for-you SSDs/SD Cards: https://github.com/gitbls/sdm
Easily run and manage your network's DHCP/DNS servers on a Pi: https://github.com/gitbls/ndm
Easy and secure strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
strantor
Re: STICKY: Running A Program At Start UP A Beginner's Guide
Thu Jul 08, 2021 7:20 pm
Very well put together and extremely helpful. Thank you so much for this resource! It got me where I needed to be in minutes, after wasting hours trying to follow other advice.
Sun Aug 15, 2021 7:39 am
Why do you think it needs sudo? What root privileges does it need? Or do you have a bad case of sudoitis?
Why do you have a space between /usr/bin and /bash - that's never going to work sudo or not?
thagrol
Sun Aug 15, 2021 10:07 am
I'm guessing because
-c vtnumber
Use the given VT number and not the first available. Note you must have write access to the supplied VT for this to work.
which the pi user won't have unless logged in on tty2
thagrol
Sun Aug 15, 2021 10:23 am
DoubleD wrote:
Sun Aug 15, 2021 12:15 am
sudo /usr/bin /bash -c '/usr/bin/openvt -c 2 -f -s -- /home.pi/{mybashscriptfile}.sh'
I'd remove the space between /usr/bin and /bash. Actually I'd skip /usr/bin/bash -c and just call openvt with the correct path. On my system its in /bin not /usr/bin.
And replace "/home.pi" with "/home/pi"
Given that it's a bad idea to run your script as root, try something like this:
sudo /bin/openvt -c 2 -f -s -- sudo -u pi -i /home/pi/{mybashscriptfile}.sh
If that works as desired, run it from a systemd service, root's crontab, or rc.local. In all cases the first sudo should be omitted.
DoubleD
Wed Sep 01, 2021 2:29 pm
-c vtnumber
The space was a typo. Sudo because it would not work unless I used sudo
I think you are correct about VT but I just reconfig the pi to boot cli and used .profile to kick it off
thagrol
Wed Sep 01, 2021 3:24 pm
There are better ways. You know that will try to start your script at every login, even over ssh?
