AXES
pi 4 wifi/ethernet question
Tue Jul 27, 2021 8:32 am
Hello. I got a pi 4, had to install headless, it has taken me two days to get the desktop environment on my laptop to show wifi connections.
I have also got the pi desktop environment on my ipad via vnc. But this is all through ethernet, I can see my phones wifi hotspot and connect on pi desktop but I cannot solely use the wifi.
If for instance I disconnect ethernet cable from pi, connect my ipad to mobile hotspot and, assuming my pi has also stayed connected to the hotspot, because I cant see the desktop anymore, try and connect to the pi desktop through vnc on my ipad it doesn't work....
Same happens if I try vnc between pc and pi on mobile hotspot..
What am I missing?
She feels his other hand slipping down her waist as it reaches her skirt she grasps his hand, not yet she moans, moving his hand away June can’t believe it as she wantonly tugs at his uniform shirt pulling it off him, then undoing the belt on his trousers, she can see the bulge in them already. Stepping back out of reach Jake slowly undoes the belt and trousers letting them fall to the floor, kicking them away he stands in a tight pair of boxer shorts his arousal plain to see. live sex cams
Dropping to her knees June reaches out and strokes the outline of Jake’s cock making him gasp this time. Unable to resist she pulls his boxers down releasing his stiff shaft, and grasps it stroking slowly at first then a little faster, ‘I don’t want to cum yet’ he gasps but June smiles wickedly and replies ‘aren’t you meant to do whatever you can to please your guests she says just before engulfing the head with her lips sucking hard eliciting a moan from Jake. Slowly June works her way down his shaft circling her tongue as she does, pulling almost all the way off his cock she looks up at him as she slips her tongue under the foreskin running it round and round the head tasting his pre cum. free sex chat
After a few minutes of her teasing his cock, Jake tries to grasp her head but June pulls away slipping out of his reach. Standing she turns her back on him and slowly slips her skirt down revealing her firm bottom, looking over her shoulder she grins naughtily, ‘now it’s your turn I want you to use my pussy but with your tongue and fingers’ she whispers as she turns round to face him. June stands as Jake looks at her naked body, she feels her pussy start to dampen, ‘Well she asks?’ moving her legs apart slightly with an unspoken invitation. As if released from a trance Jake steps closer and slowly kneels in front of her, looking up as he does he sees June bite her lip, almost in nervous anticipation. He reaches a hand towards her and with just his fingertips runs them round her pussy lips. live sex chat
jbudd
Re: pi 4 wifi/ethernet question
Tue Jul 27, 2021 2:20 pm
Have you set the wi-fi country? No doubt it can be done from the desktop but I either use sudo raspi-config or sudo nano /etc/wpa_supplicant/wpa_supplicant.conf and insert a line country=GB
The IP address for the WiFi connection will be different from the Ethernet.
