This works brilliantly! I hate to ask, but do you know what the calculations would be for Fahrenheit? Thanks!yuusou wrote: I quite liked your script, so I decided to clean it up a little:Code: Select all
#!/bin/bash cpuTemp0=$(cat /sys/class/thermal/thermal_zone0/temp) cpuTemp1=$(($cpuTemp0/1000)) cpuTemp2=$(($cpuTemp0/100)) cpuTempM=$(($cpuTemp2 % $cpuTemp1)) gpuTemp0=$(/opt/vc/bin/vcgencmd measure_temp) gpuTemp0=${gpuTemp0//\'/º} gpuTemp0=${gpuTemp0//temp=/} echo CPU Temp: $cpuTemp1"."$cpuTempM"ºC" echo GPU Temp: $gpuTemp0
Re: [Tutorial] Show RPI's Temperature with a command.
The basic formula is:This works brilliantly! I hate to ask, but do you know what the calculations would be for Fahrenheit? Thanks!
F = 1.8 * C + 32
E.g., 1.8 * 100 = 180 and 180 + 32 = 212
BTW, I think doing this in shell is weird. Yes, the previous poster gets "ain't I slick!" points for being able to do this kind of stuff in shell, but it's a lot more fluid in AWK.
You can have some of our spare rain if you want. Expecting another 30-40mm today....and we are in the dry part of the country.AndyD wrote:I think that is reasonable. Is your Raspberry Pi working hard? It is around 30°C in my house at the moment and my Raspberry Pis are idle and running at 55.1°C and 55.6°C. It is going to 44°C today (again) looking forward to a cool change tonight after 5 very hot days.phoenixDownunder wrote:temp=64.3'C Is that a bit high? Ambient is 44C here
So I'd like to get the CPU temp from "/sys/class/thermal/thermal_zone0/temp" and have it display in Fahrenheit. Since you can't multiply decimals in shell scripts, any idea how to do that?Joe Schmoe wrote: The basic formula is:
F = 1.8 * C + 32
I don't have my Pi up and running ATM, so I can't test this, but I think it would be like:So I'd like to get the CPU temp from "/sys/class/thermal/thermal_zone0/temp" and have it display in Fahrenheit. Since you can't multiply decimals in shell scripts, any idea how to do that?
gawk '{print "Temp in degrees Fahrenheit is:",$1/1000 * 1.8 + 32}' /sys/class/thermal/thermal_zone0/temp
WOW, that's spot on! I had to change "gawk" to "awk," but that's perfect...simple and elegant. Thank you!Joe Schmoe wrote:
If you don't have gawk on your system, you should fix this ASAP. For some stupid reason, Debian (including Debian-derived systems like Raspbian) use "mask" as the default AWK. This even though GAWK is the GNU AWK and the rest (modulo any other exceptions which may exist) of the "normal" (utility) software on a Linux system is the GNU versions of things. Anyway, nothing against "mask", but gawk is much better and you'll be glad you did.I had to change "gawk" to "awk,"
And its only an "apt-get install" away…
Why not using this command here to display temperature:
Result:
awk '{printf("\nrPI Temperature = %.1f °C\n\n",$1/1e3)}' /sys/class/thermal/thermal_zone0/temp
- rPI Temperature = 55.1 °C
Anyone have thoughts on making this available via a web interface easily? I'm running Volumio on my Pi right now and would to be able just hit 192.168.1.XX:2000 or something and easily see the temp. Even slicker would be embedding it right into the existing Volumio UI.
- default_user8
There is a web app in the pi store that does that and more, it's called Raspberry Pi Web agent.
Two heads are better than one, unless one's a goat head.
That looks slick, but I'm having trouble with the Pi Store. Can it not be run via terminal on SSH? Installing Volumio means I can't access the standard GUI, at least as far as I know. Or, can the webagent be installed without Pi Store?
How do you type the degree sign?ionut wrote:Result:Code: Select all
If you wish in this world to advance, your merits you're bound to enhance.
You must stir it and stump it and blow your own trumpet, or trust me you haven't a chance.
Ruddigore, G&S
Ruddigore, G&S
Good question.How do you type the degree sign?
But observe:
$ gawk 'BEGIN {s=sprintf("%c%cC",0302,0260);print s}'
°C
Actually, on my m/c it is:
But what I was getting at is how can you type the degree sign using the keyboard so that it appears in a post like this?
awk 'BEGIN {s=sprintf("%cC",0176);print s}'
Ruddigore, G&S
Ruddigore, G&S
On my laptop (running Debian Wheezy with xfce), I use Shift+AltGr+0 to get the "°" character. That's either Shift key, the Right Alt button and the Zero key. I guess something similar should work on the Pi, but I run all mine headless.TideMan wrote: But what I was getting at is how can you type the degree sign using the keyboard so that it appears in a post like this?
- BlackberryTart
I made a shell script that shows Celsius and Fahrenheit. It requires bc. The formatting is sorta ugly, though. Here is the code:
Here is the output:
#!/bin/bash
milcel=$(cat /sys/class/thermal/thermal_zone0/temp)
echo "CPU Temperature:"
echo
echo "scale=3;$milcel/1000" | bc
echo "°C"
echo
echo "scale=3;(($milcel/1000)*(9/5))+32" | bc
echo "°F"
CPU Temperature:
36.856
°C
98.340
°F
Blackberry tarts are sort of like raspberry pies, but they are more purple and sour.
Any way to set this sensor to check temp every 5 minutes, and shut down if the pi gets too hot?
Could internal temp be displayed on Piglow? (Cool=no lights on, very hot=all lights on bright)
- DougieLawson
Yes, but it's 100% pointless. Nobody has ever had an undamaged Pi running at 85°C (the point at which the processor slows until the temp comes down).RepublicanSwag wrote:Any way to set this sensor to check temp every 5 minutes, and shut down if the pi gets too hot?
#!/usr/bin/python
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(17, GPIO.OUT)
while True:
try:
tFile = open('/sys/class/thermal/thermal_zone0/temp')
temp = float(tFile.read())
tempC = temp/1000
if tempC > 43.5:
GPIO.output(17, 1)
print "HOT"
else:
GPIO.output(17, 0)
print "COLD"
except:
tFile.close()
GPIO.cleanup()
exit
I know this post is a bit old but it's the first result on google for Raspberry Pi CPU temp so I thought this would be the place to post it.
Below is a python script based off m0rgo's post but injects the data into a mysql database, handy to monitor Pi temp over time or just because you like data
Just change the mysql username, password and host to suit.
And this is the bash script which runs the python file which I've added to crontab:
And finally the mysql statement to create the table:
Hope this is helpful to somebody
#!/bin/python
#script to read a file and extract a number
import time
import MySQLdb
fo = open("sysTemp") # Open a file
str = fo.read(); #read characters in sysTemp and hold them as 'str'
fo.close() #close opened file
print(str) # print string to check
temp1=str[5:9] #chop out required characters
temp2=eval(temp1) #convert string into number
#connect to database
db = MySQLdb.connect(host="host",user="user",passwd="password",db="temps")
curs=db.cursor()
#insert into database
try:
curs.execute ("INSERT INTO doorbellpi (id, tdate, ttime, temperature) VALUES (NULL, CURRENT_DATE(), NOW(), %s) """, (temp1))
db.commit()
except db.Error, e:
print "Error %d: %s" % (e.args[0],e.args[1])
db.rollback()
db.close()
#!/bin/bash
#get system temperarure and save as 'sysTemp'
/opt/vc/bin/vcgencmd measure_temp > sysTemp
# this creates a file called sysTemp in current directory
python tempsys.py
CREATE TABLE doorbellpi (id MEDIUMINT NOT NULL AUTO_INCREMENT, tdate DATE, ttime TIME, temperature NUMERIC, PRIMARY KEY (id));
A few things I noticed in your code.
Writing a file just to read it again straight away is nasty. If you've going to do that at least use /dev/shm so you don't wear out the SD card.
AFAIK python doesn't live in /bin on the Pi. I'd adjust the path, chmod +x the file and ditch the launcher script.
str is a function, so over-loading it with a variable is a bad idea.
Your parsing will fail at temperatures at or above 100 and below 10 degrees (though granted, that'll probably be the least of your problems at that point).
eval is a _really_ _bad_ idea. avoid it if you can.
try this:
try this:
#!/usr/bin/python
import subprocess
import MySQLdb
temp_str = subprocess.check_output(('/opt/vc/bin/vcgencmd','measure_temp'))
temp = float(temp_str.split('=')[1].split("'")[0])
# databas stuff here...
Thanks for that sprinkmeier I'm rather new to Python so the string/number handling code was from earlier in this thread rather than creating my own.
Your code neatens it up a lot
import time
import MySQLdb
import subprocess
#pull cpu temp
curs=db.cursor()
try:
curs.execute ("INSERT INTO doorbellpi (id, tdate, ttime, temperature) VALUES (NULL, CURRENT_DATE(), NOW(), %s) """, (temp))
db.commit()
except db.Error, e:
db.rollback()
db.close()
I have my Pi overclocked to 49.2 GHz using Liquid Nitrogen as a cooler!
Thanks for the code ! I just used it and corrected a few mysql related bugs / quirks :
First, the temperature column needs to have a precision and scale specified with its NUMERIC type, or it will default to a 0 scale and truncate after the decimal point. NUMERIC(4,1) is enough even if you get your Pi close to fried ARM temperature as it goes from -999.9 to +999.9
MySQL NOW() function return both the current date and time, so you'll get a warning message telling you that data for this column has been truncated if you use it with a TIME type. You should replace it with CURRENT_TIME() or CURTIME().
Last, my version of MySQLdb (1.2.5) returned an error regarding temp type, it seems to expect a tuple so (temp,) rather than (temp).
CREATE TABLE whatever (id MEDIUMINT NOT NULL AUTO_INCREMENT, tdate DATE, ttime TIME, temperature NUMERIC(4,1), PRIMARY KEY (id));
curs.execute ("INSERT INTO whatever (id, tdate, ttime, temperature) VALUES (NULL, CURDATE(), CURTIME(), %s) """, (temp1,))
BlackberryTart wrote:I made a shell script that shows Celsius and Fahrenheit. It requires bc. The formatting is sorta ugly, though. Here is the code:Here is the output:Code: Select all
#!/bin/bash milcel=$(cat /sys/class/thermal/thermal_zone0/temp) echo "CPU Temperature:" echo echo "scale=3;$milcel/1000" | bc echo "°C" echo echo "scale=3;(($milcel/1000)*(9/5))+32" | bc echo "°F"
CPU Temperature: 36.856 °C 98.340 °F
I modified your script so that the Celsius and Fahrenheit labels are displayed on the same line as the temperature. To do this, the output of bc was stored in a variable. This might be useful for someone looking to store temperature values inside a variable.
#!/bin/bash
echo
ctemp=$(echo "scale=3;$milcel/1000" | bc)
echo $ctemp "°C"
echo
ftemp=$(echo "scale=3;(($milcel/1000)*(9/5))+32" | bc)
echo $ftemp "°F"
CPU Temperature:
48.692 °C
119.645 °F
I also use this command quite often to monitor my raspberry pi. But I made the process more efficient. I created a shell script that continually runs the temp command, so I can always know the temp. Simply make a for loop. Simply type Ctrl + c to exit.
while : do /opt/vc/bin/vcgencmd measure_temp done
