mighty2361
How can I create a new user
Sat Mar 16, 2013 12:23 pm
Hello!
I have a raspberry pi model B with raspbian operating system. I am new to linux and I don't know how to create new users and move them to other groups. Can somebody help me create a new user which has admin permissions? (I can only use command line, because I don't have any spare monitors - I just used one to set up ssh and am now using PuTTY on my Windows computer) Thank you!
joan
Re: How can I create a new user
Sat Mar 16, 2013 2:37 pm
Have a look at adduser.
man adduser for the manual
sudo adduser user to actually add a user
sudo adduser user group to add a user to a group
Add an entry in /etc/sudoers similar to the pi entry to allow them administration privileges.
mighty2361
Sat Mar 16, 2013 2:50 pm
joan wrote:Have a look at adduser.
Thank you!
amacater
Mon Mar 18, 2013 12:20 pm
It may also help to login as the original pi user and use the groups command to find out what groups pi is in.
as pi
sudo su -
useradd foo [adds a new user foo, prompts for password and user details]
adduser foo cdrom [adds user foo to group cdrom - repeat for all groups that pi has for the new user]
exit out of that.
Try logging in as the new user - check that the password works.
Login as pi, sudo su - and then run
visudo
which allows you to edit the /etc/sudoers file. Either add a line exactly matching the one for pi or change the name pi to the name of your new user that you have just created.
userdel -r will remove any user and their home directory.
yv1hx
Location: Now an expatriate, originally from Zulia, Venezuela
Contact: Website Skype
Wed Jul 31, 2013 4:56 pm
Is important to note that the user standard configuration files are placed in /etc/skel and are copied to the new user home directory upon the creation.
Good luck!
Marco-Luis
Telecom Specialist (Now Available for Hire!)
http://www.meteoven.org
http://twitter.com/yv1hx
bfesser
Fri Nov 01, 2013 1:51 am
An informative page on /etc/skel:
http://www.linfo.org/etc_skel.html
Benfll
Sat Feb 15, 2014 6:37 pm
When I do this the users are deleted on every reboot. How can I fix this!? :x Forget that, I was using sudo useradd benjamin instead of sudo adduser benjamin. :oops: Image
Raspruss
Sat Feb 15, 2014 7:14 pm
One of the most useful commands to know is apropos. It will tell you what manual entries contain the keyword you specify. You then can use the man command to read the available documentation for the particular command (as noted by the poster replying to you above).
So, for example, you could have done apropos user and one of the gajillion answers would have pointed you to the correct man[ual] pages to read.
thegamingmineblox
Tue Dec 29, 2015 1:41 pm
How i can make him have adminstrator priveleges
SkyRise
Tue Dec 29, 2015 2:48 pm
As mentioned by amacater above:
visudo
toohoo
Mon Mar 19, 2018 5:54 am
as pi
sudo su -
.. Does not ask for password and details. Could I do something wrong on this?
Tanks
---[ Thomas Hofmann - @heroold - Dorfen, Bavaria, DE ]---
