yakuzah
Problems with ap-get update. Please Help
Tue Dec 10, 2013 11:09 am
Hi There, I appear to be experiencing issues with 'apt-get update' and I can't put my finger on why and need someone's help please?
My Pi appears to be working fine, I have plenty of space on my SD Card, and connectivity to the internet and local network is working.
Would anyone let me know how I fix this please? I have limited knowledge of Linux.
here is some information on my PI.
df -k
Filesystem 1K-blocks Used Available Use% Mounted on
rootfs 30616076 2463580 26890056 9% /
/dev/root 30616076 2463580 26890056 9% /
devtmpfs 216108 0 216108 0% /dev
tmpfs 44876 1248 43628 3% /run
tmpfs 5120 0 5120 0% /run/lock
tmpfs 89740 0 89740 0% /run/shm
/dev/mmcblk0p1 57288 18536 38752 33% /boot
/dev/sda1 961433632 46505080 866090476 6% /mnt/usb
ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:16:c3:dd
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2894 errors:0 dropped:0 overruns:0 frame:0
TX packets:1955 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:376645 (367.8 KiB) TX bytes:365212 (356.6 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:38 errors:0 dropped:0 overruns:0 frame:0
TX packets:38 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2395 (2.3 KiB) TX bytes:2395 (2.3 KiB)
tun0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:192.168.10.1 P-t-P:192.168.10.2 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
apt-get update error:-
sudo apt-get update
Get:1 http://raspberrypi.collabora.com wheezy Release.gpg [836 B]
Hit http://raspberrypi.collabora.com wheezy Release
Get:2 http://mirrordirector.raspbian.org wheezy Release.gpg [490 B]
Get:3 http://archive.raspberrypi.org wheezy Release.gpg [490 B]
Hit http://archive.raspberrypi.org wheezy Release
Hit http://mirrordirector.raspbian.org wheezy Release
Ign http://raspberrypi.collabora.com wheezy Release
Hit http://raspberrypi.collabora.com wheezy/rpi armhf Packages
Ign http://archive.raspberrypi.org wheezy Release
Ign http://mirrordirector.raspbian.org wheezy Release
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en_GB
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Fetched 1,816 B in 1s (1,175 B/s)
not a reference at /usr/bin/apt-show-versions line 266
W: GPG error: http://raspberrypi.collabora.com wheezy Release: The following signatures were invalid: BADSIG ED4BF9140C50B1C5 Collabora Raspbian Archive Signing Key <daniels@collabora.com>
W: GPG error: http://archive.raspberrypi.org wheezy Release: The following signatures were invalid: BADSIG 82B129927FA3303E Raspberry Pi Archive Signing Key
W: GPG error: http://mirrordirector.raspbian.org wheezy Release: The following signatures were invalid: BADSIG 9165938D90FDDD2E Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>
E: Problem executing scripts APT::Update::Post-Invoke-Success 'test -x /usr/bin/apt-show-versions || exit 0 ; apt-show-versions -i'
E: Sub-process returned an error code
yakuzah
Re: Problems with ap-get update. Please Help
Tue Dec 10, 2013 3:01 pm
Hi All, I managed to find the answer myself, but wanted to post here just in case anyone else experiences this issues.
sudo apt-get install aptitude
sudo aptitude -o Acquire::http::No-Cache=True -o Acquire::BrokenProxy=true update
sudo apt-get clean
cd /var/lib/apt
sudo mv lists lists.old
sudo mkdir -p lists/partial
sudo apt-get clean
sudo apt-get update
b13sch
Thu Dec 26, 2013 9:11 pm
Danke
bosschaert
Fri Jul 17, 2015 1:05 pm
I experienced this issue today, and the solution still works. Thanks!
mrSystem
Mon Apr 03, 2017 4:41 pm
Confirming - solution still works in April 2017!
Thanks and best!
