I am brand new to the world of Pi, and want to build a handheld RetroPie.
I ordered a TFT, but the one I have seems to have the drivers built into the kernel making it unusable for this project.
The unit is a Waveshare 3.2inch, and here is some discussion on the drivers being built into the kernel issue https://github.com/notro/rpi-firmware/issues/6
So, is anyone able to recommend similar sized TFT that I will be able to use without proprietary kernels, so I can get cracking with my first project?
Re: Picking a TFT to work with a RetroPie Project?
I just got started with an A+ and the WaveShare 3.2 that I got from eBay. This worked for me:
https://github.com/notro/fbtft/wiki
The instructions are all here, but it took me awhile to understand what it all meant.
Enter:
sudo raspi-config
This will "expand the file system". Apparently not necessary if you're running NOOBS.
Enter:
sudo nano /usr/share/X11/xorg.conf.d/99-fbturbo.conf
There's a line in here that refers to "fb0" - apparently the HDMI monitor - and should be changed to fb1.
Enter:
sudo nano /etc/modprobe.d/raspi-blacklist.conf
There is a line in this file that disables spi:
blacklist spi-bcm2708
Comment it out:
# blacklist spi-bcm2708
Enter:
sudo REPO_URI=https://github.com/notro/rpi-firmware rpi-update
This will download and install the loadable drivers.
Enter:
sudo reboot
To load all the new drivers.
Enter:
sudo modprobe fbtft_device name=waveshare32b
To actually load the fbtft driver after the reboot.
Enter:
sudo modprobe spi-bcm2708
To load the spi driver.
Enter:
FRAMEBUFFER=/dev/fb1 startx
To run the XServer on fb1.
At this point the Raspberry Pi wallpaper appeared on the screen, along with a menu, etc., and the mouse attached through USB was active.
This all happened mere minutes before I read your post, so all the steps listed above may not be necessary. But that's what I did, and, by golly, it worked!
All of this is possible because of the work of notro, to whom we owe a great debt. Thanks!
Enter:
sudo raspi-config
Enter:
Enter:
Comment it out:
Enter:
Enter:
sudo reboot
Enter:
Enter:
Enter:
Unless the screen (interface) has HDMI or Composite inputs then no.
There are 3.5" HDMI monitors made for professional video cameras but they are quite expensive.
OK, first, Thank you!gknight4 wrote: There's a line in here that refers to "fb0" - apparently the HDMI monitor - and should be changed to fb1.
I did this and it worked, but when i restarted the pi it went back to the screen not working.......is there a way to save these setting so I don't have to type all this when ever I switch on the pi?
Yes, the modules that are loaded with 'sudo modprobe' in the 'recipe' above can be added to the file /etc/modules.peps1 wrote:OK, first, Thank you!gknight4 wrote: There's a line in here that refers to "fb0" - apparently the HDMI monitor - and should be changed to fb1.
Edit the file with
sudo nano /etc/modules
spi-bcm2708
Gr.
Dirk.
Thank you,
I have added:
spi-bcm2708
to the sudo nano /etc/modules
But when I reboot I just get a blank black screen on the TFT and have to pug in my monitor to see it has booted into Emulation Station.
But, to get anything on the TFT, I have F4 out of Emulation Station into Shell, and type FRAMEBUFFER=/dev/fb1 startx to bring up anything, and that only bring up Raspbian? desktop not the GUI for Emulation Station.
So........still need it boot into Emulation Station, and show on the TFT by default.
Thank you all for your help so far
I have added:
spi-bcm2708
I'm trying to get a SainSmart St7735 working with my Pi. I'm following the steps but I don't have a /dev/fb1 directory. Just /dev/fb0. Should I have both if its installed properly?
peps1:
First, I'd suggest that you get a network connection working, and then make sure that you can ssh to the pi, so that you have command line access from another computer. Then install:
apt-get install tightvncserver
so that you can use the GUI from another computer. Now you should be able to do just about anything *without* having real access to the console.
As DirkS explained, adding
to /etc/modules means that you don't have to do the modprobe thing each time. The spi module doesn't seem to need to be explicitly loaded.
To run startx automatically, I followed the instructions here:
http://elinux.org/RPi_Debian_Auto_Login
Namely:
sudo nano /etc/rc.local
Scroll to the bottom and add the following above exit 0:
su -l pi -c startx
This seems to run X without any intervention.
Now my pi a+ automatically boots to the gui, with the usb keyboard and mouse active on the WaveShare 3.2 TFT. Pretty cool!
Namely:
su -l pi -c startx
If you're not familiar with the WaveShare, its available from eBay for 18.99 with free shipping, as:
3.2" TFT LCD Module Touch Screen Monitor Display for Raspberry Pi B/B+ dll
Has anyone been able to get the touch screen working?
The board comes with a CD that has a 4GB image that can be copied to an SD Card and the pi can run off of it. It shows a desktop, and *does* have a working touchscreen interface. Unfortunately, it seems buggy, and incompletely implemented. The method of making it work as described above seems to have a lot more future to it.
Can anybody suggest where I'm going wrong?? My Linux troubleshooting chops are not very good. I'm trying to figure out whats not installed. The firmware update installs. I'm using sudo modprobe fbtft_device name=flexfb because I have a SainSmart 1.8 ST7735. The command executes so I know the fbtft module is loaded. However, I don't have a /dev/fb1. I'm not sure if thats a hardware or software issue. Does anyone have any troubleshooting tips?
Thank you gknight4,gknight4 wrote:peps1:
Had a play with PuTTY lastnight, but will download tightvncserver onto the pie as having access to the GUI will be very handy!
Thank you for this, the only issue is I don't want to automatically boot into the Debian desktop environment (though this is really handy to know how to do!).gknight4 wrote:As DirkS explained, adding
Namely:
su -l pi -c startx
The image I'm using on the SD card is RetroPie by default boots into a program called 'Emulation Station', so you can boot right into paying video games with nothing but a USB controller plugged in, bypassing the desktop environment.
Is there a way I can still do this, but having the output on the TFT?
You may want to start your own thread, as your SainSmart 1.8 is different to the WaveShare 3.2 being discussed here.savall21 wrote: Can anybody suggest where I'm going wrong??
Edit to add:
Its quite strange, when my Pi is connected to an external monitor via HDMI and power up its show 'emulation station' (witch is good, as I want to to boot into this, Just on the TFT), BUT..... the TFT is black.
When I also connect to the Pi via VNC from my PC I see the Debian? desktop environment (LXDE?), but also cant quit out of it?
Every time I click on the red power-button on the bottom right it just gives me the logout or cancel option, but fails to log out if I click log out, so am unable to get back to shell?
So guess my questions are, why is the HDMI showing what I want the TFT to show, and why do I see a totally different environment when also connected via VNC?
There is a problem getting framebuffer devices (such as the small screens with notro's kernel / drivers) working with RetroPie / Emulationstation.
See for example http://www.raspberrypi.org/forums/viewt ... 28&t=88431
This suggests the use of fbcp (https://github.com/tasanakorn/rpi-fbcp).
Gr.
Dirk.
Gr.
Dirk.
Thanks Dirk,DirkS wrote: This suggests the use of fbcp (https://github.com/tasanakorn/rpi-fbcp).
How would I go about using installing something from github onto Pi?
Would I just type:
or
or something totally different?
sudo apt-get install rpi-fbcp
sudo REPO_URI=https://github.com/tasanakorn/rpi-fbcp
- DougieLawson
Hi,peps1 wrote:Would I just type:
orCode: Select all
or something totally different?Code: Select all
I've got the exact same screen as you on its way to me, and I'm intending to use it with retropie as well. Just curious if rpi-fbcp fixed your issues?
I got it working by following this guide: https://github.com/watterott/RPi-Displa ... he-display
But man, it's slow.
Is there any way to use a screen like this at a reasonable framerate (i.e fast enough to run emulators on)?
But man, it's slow.
Does your spi_bcm2708 module has DMA support?
You can check it with
If not then you can use our script for updating:
https://github.com/watterott/RPi-Displa ... -8-bit-spi
modinfo -F parm spi_bcm2708
Hi, I am creating a hand held RetroPie project. I have the LCD screen working, but only with 'fbcp', which I have running from rc.local.
The issue I have is, this means the emulator runs via framebuffer /dev/fd0 (the HDMI port) as primary and fbcp = FrameBufferCopy is duplicating the buffer from the HDMI to /dev/fb1 (the LCD GPIO port). At first glace, my screen seems slow.
Can I not switch the FRAMEBUFFER somewhere at boot up, allowing 'emulationstation' to run on /dev/fd1 as primary without the need to load fbcp?
Example?:
vi /etc/rc.local
...add lines somewhere...
export FRAMEBUFFER=/dev/fb1
export SDL_FBDEV=/dev/fb1
Many thanks
Example?:
vi /etc/rc.local
Many thanks
Crush your enemies. See them driven before you. Hear the lamentations of their women!
Exact same problem, my waveshare 3,5 screen is working with retropie but image is slow and games unplayble.
But the problem is allready here with the raspbian image made for the LCD,
I'm not far to conclude that this screen just sucks
this works beautiful for ada fruit 3.5 tft
sudo raspi-config
expand filesystem
disable overscan
force audio to 3.5mm
advanced options >> enable Device Tree
advanced options >> enable SPI >> load SPI kernel module by default
sudo reboot
sudo nano /boot/cmdline.txt ---> put this at the end on the same line fbcon=map:10
cd
curl -SLs https://apt.adafruit.com/add-pin | sudo bash
sudo apt-get install raspberrypi-bootloader
y
sudo apt-get -y install adafruit-pitft-helper
sudo adafruit-pitft-helper -t 35r ( speed 4800000 fps 60 ) later on change in /coot/config.txt
console on display? no
gpio 23 as on off button?
This is the over lay to produce image
sudo apt-get install cmake
git clone https://github.com/tasanakorn/rpi-fbcp
cd rpi-fbcp/
mkdir build
cd build/
cmake ..
make
sudo mkdir /usr/local/bin
sudo install fbcp /usr/local/bin/fbcp
Instead of using the asplashscreen fix I added the boot function for fbcp to
on its own on the second line before emulationstation is called.
sudo nano /etc/profile.d/10-emulationstation.sh
then add this
/usr/local/bin/fbcp &
To stop the cursor or blinking screen sense your there are overlapping
Con2fbmap 1 0
Add this above exit 0
/boot/config.txt
sudo nano /boot/config.txt
hdmi_force_hotplug=1
hdmi_cvt=320 240 60 1 0 0 0
hdmi_group=2
hdmi_mode=87
dtoverlay=pitft35r,rotate=90,speed=80000000,fps=60
This is for function get_all_modes
sudo nano /opt/retropie/supplementary/runcommand/runcommand.sh
Add the following lines to the script:
mode_new = "DMT-87"
return
sudo nano restart
sudo raspi-config
expand filesystem
disable overscan
sudo reboot
cd
y
cd rpi-fbcp/
mkdir build
cd build/
cmake ..
make
then add this
Con2fbmap 1 0
/boot/config.txt
hdmi_group=2
hdmi_mode=87
mode_new = "DMT-87"
return
sudo nano restart
