jdb
Re: USB 2.0 Dropped frames
Tue Nov 05, 2019 1:20 pm
Responded via email.
Rockets are loud.
https://astro-pi.org
sargsyanga
Wed Jun 17, 2020 5:49 pm
Hi.
I am experiencing similar problem with Isochronous transfers. Was there a solution to this problem? If yes, can you please share the code so I can try the fix on my end?
Thank you
SaraYang
Thu Mar 18, 2021 7:02 am
I am have similar problem with USB Isochronous transfers. My problem is that when I changed bInterval value fram 2 to 1. audio frames drop happend. Do you have solved the problem? could you give me some suggestions, thank you very much.
static struct usb_endpoint_descriptor hs_epout_desc = {
	.bLength = USB_DT_ENDPOINT_SIZE,
	.bDescriptorType = USB_DT_ENDPOINT,
	.bmAttributes = 0x05,//USB_ENDPOINT_XFER_ISOC ,//| USB_ENDPOINT_SYNC_ADAPTIVE,
	.wMaxPacketSize = cpu_to_le16(1024),
----.bInterval = 2,
+++.bInterval = 1,
Return to “Compute Module”
