Saulius2006
Can't get installed Samsung C410 printer
Thu Aug 25, 2016 8:27 pm
I'm beginner with Linux and Raspberry Pi.
Everything that I managed to install or get working is by Google.
I have Samsun c410w series printer, which I'm trying to set up for CUPS
I have downloaded printer drivers from Samsung official page,
by trying to install I had "armhf" error.
After some research I found out that "package_utils" need to amend 59 line.
Drivers installed with no error - CUPS also working
when I add a printer no error appears, by trying to Print-Test page the print job will be stopped.
Please cloud someone advise me step by step how to install and set up the printer.
Screen Shot 2016-08-25 at 10.07.28 PM.png (29.16 KiB) Viewed 1932 times
fruitoftheloom
Re: Can't get installed Samsung C410 printer
Fri Aug 26, 2016 7:24 am
The Samsung Unified Drivers only support x86 & ARMEL (Soft FLoat)
They do not support ARMHF which is what you require:
http://www.bchemnet.com/suldr
Saulius2006
Tue Aug 30, 2016 6:19 am
I tried to follow with provided instructions but I can't get work.
I have downloaded the supported drivers manually from the list. But unfortunately I receive the same error. The drivers give 'armhf' error if I will change it in 'package_utils' line 59 from 'arm' to 'armhf' it seems that installation went with no errors but after checking the Test page on cups the jobs status are 'stopped'
fruitoftheloom
Tue Aug 30, 2016 3:33 pm
Saulius2006 wrote:I tried to follow with provided instructions but I can't get work.
As already stated ARMHF is not supported :?
pi-anazazi
Tue Aug 30, 2016 3:54 pm
Kind regards
anazazi
Saulius2006
Wed Aug 31, 2016 9:34 am
I checked on article regarding armel or armhf.
I also checked on the forum http://www.bchemnet.com/suldr/
And it seems that Samsung drivers are supported and can be used only by armel.
Can some suggest is there is a way to change the settings from armhf to armel ?
fruitoftheloom
Wed Aug 31, 2016 9:54 am
Saulius2006 wrote:Hi,
It is not just a change from ARMEL / Soft Float to ARMHF / Hard Float in settings.
It is the actual Operating System which needs to be Soft Float, which Raspbian Wheezy & Jessie ARE NOT..
As far as I am aware the only recent Linux Distro which was compiled for Soft Float was Slackware, but that considerably different from Raspbian, so you would need to undertake considerable work to get the Unified Driver to actually function.
IMO go out and buy a HP Printer supported by HPLIP:
http://hplipopensource.com/hplip-web/su ... index.html
honzikf
Contact: Skype Twitter
Tue Oct 20, 2020 8:06 pm
I have used Splix driver.
Installed using
sudo apt install printer-driver-splix
Configured as IPP printer
ipp://youraddress/ipp/printer
As a driver for our printer is not there I have used CLP-315 driver.
It works in both color and monochrome.
Have a nice day!
Jan
Return to “Beginners”
