Canedje
nfs-kernel-server not always start at startup
Wed Nov 23, 2016 8:33 pm
It looks like that after a reboot the nfs-kernel-server not always starting up.
I do have two RPI's (RPI1 and RPI3)
I conclude this because I do try to mount this RPI1 to RPI3 in /etc/fstab. at RPI1 sometimes mounting is not working.
Also df -h gives then no results (not able to show df -h because the mounting is not made??)
I have to break the df -h command with CTRL-C
sudo mount -a is also not working
If I do start the nfs kernel at RPI3 by the command :
sudo /etc/init.d/nfs-kernel-server restart
the mount at RPI1 is working again and I can do df -h after rebooting.
The strangepart is that the command: sudo systemctl status nfs-kernel-server on RPI3 says it is running:
Even before restarting. But I still have to restart it to make it running properly for RPI1 to mount.
● nfs-kernel-server.service - LSB: Kernel NFS server support
   Loaded: loaded (/etc/init.d/nfs-kernel-server)
   Active: active (exited) since wo 2016-11-23 21:51:29 CET; 1min 50s ago
nov 23 21:51:28 raspberrypi-3 systemd[1]: Starting LSB: Kernel NFS server support...
nov 23 21:51:29 raspberrypi-3 nfs-kernel-server[529]: Exporting directories for NFS kernel daemon...exportfs: No options for /home/ewh 192.168.2.202: suggest 192.168.2.202(sync) to avoid warning
nov 23 21:51:29 raspberrypi-3 nfs-kernel-server[529]: exportfs: /etc/exports [1]: Neither 'subtree_check' or 'no_subtree_check' specified for export "192.168.2.202:/home/ewh".
nov 23 21:51:29 raspberrypi-3 nfs-kernel-server[529]: Assuming default behaviour ('no_subtree_check').
nov 23 21:51:29 raspberrypi-3 nfs-kernel-server[529]: NOTE: this default has changed since nfs-utils version 1.0.x
nov 23 21:51:29 raspberrypi-3 nfs-kernel-server[529]: .
nov 23 21:51:29 raspberrypi-3 nfs-kernel-server[529]: Starting NFS kernel daemon: nfsd
nov 23 21:51:29 raspberrypi-3 nfs-kernel-server[529]: Not starting: portmapper is not running ... (warning).
nov 23 21:51:29 raspberrypi-3 systemd[1]: Started LSB: Kernel NFS server support.
How do I know sure that the nfs-kernel-server is starting at starup at every time?
Canedje
Re: nfs-kernel-server not always start at startup
Thu Nov 24, 2016 7:14 am
No one a hint?
Thu Nov 24, 2016 7:32 am
The clue is in this line
The problem is that the portmapper (prcbind) starts after the nfs-kernel-server, where it whould start before.
There seems to be a solution here viewtopic.php?f=28&t=149002&p=980161
Canedje
Thu Nov 24, 2016 8:04 am
Thanks.
I didn't read that warning :oops:
I will try that tonight after work!
Canedje
Thu Nov 24, 2016 4:28 pm
It looks like working.
Thanks again!
