For the case I'm making, I wanted an integrated USB hub (need the power for WiFi etc). The stock USB socket would have stuck out too much. So thought I'd replace it with a PCB header. I am taking power through a USB B socket and splitting it off to the Pi and the Hub.
http://imgur.com/a/PDI3v
Everything seems to work, I initially tested with a keyboard and mouse. I managed to transfer a 1.2Gb file in 05:25, which compared well to an original PI. So did'nt find any speed issues.
I had a nagging thought going to work this morning, and just wanted to check. Is there likly to be any potential problems (long term) with this that I have'nt considered?
Re: I replaced the USB connector on my PI.
Neatoliverjenkins wrote:http://imgur.com/a/PDI3v
Wouldn't think so. After all that's how the "front" USB ports on a typical PC case connect to the motherboard.I had a nagging thought going to work this morning, and just wanted to check. Is there likly to be any potential problems (long term) with this that I have'nt considered?
I think you may have invalidated your warranty though
Yup! Warranty is toast!AndrewS wrote:Neatoliverjenkins wrote:http://imgur.com/a/PDI3v
But nice job nevertheless. If it works, it works, and I don't see any possible issues (Proviso. I could be wrong. It's happened before)
That is one way too solve that out sticking USB
Looks great.
Looks great.
RPi forum : custom cases
Shapeways: picases
Thingiverse : 3D printer case - Pi Lego blocks
Cheap 3D printed case : http://www.raspberrypi.org/phpBB3/viewt ... =40&t=6104
Shapeways: picases
Thanks for the feedback. With sharing one PSU. I've a concern that plugging in or removing USB devices could cause a spike in voltage or something. I wonder if adding in a voltage regulator might be an idea or not. However I'm basing all that on ignorance, so thought I'd check.
Should not be any problems. You should have carried the other port out as well. I have an NZXT I case hub that would be perfect for your type of modification.
Good job
Good job
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
If you don't mind me asking, would you mind explaining the pictures more in depth? What's powering what, etc. The purple board you have for the new USB slots, was that custom made? Same question about your case too.
I think the official raspberry pi foundation should do it like this.
Looks to me like the purple board is just a 'regular' disassembled USB hub, and he's probably using the standard "single PSU powering both the hub and raspi via a home-made power splitter cable" setup
It does look like a stripped hub. He also built a little splitter board so he can power both, RasPi and Hub, from one PSU using an USB A connector. That way he does not use up one of the USB ports to power the RasPi. Looks good in the case. Is that a Radio Shack project case?
http://www.youtube.com/watch?v=_YTzP7wWDEw
and
http://www.raspberrypi.org/phpBB3/viewt ... =40&t=8715
yes it's a stripped hub
http://www.maplin.co.uk/cerulian-4-port ... hub-513850
and
Covfefe
Covfefe
Looks good. I'm suprised more cases aren't being done like this actually - bringing out all the connectors to a single location (prob at the back, maybe 1 USB at the front) like a small set top box.
Possibly because people aren't yet willing to take a soldering iron to their Pi while there's still such a long waiting list?Crook wrote:Looks good. I'm suprised more cases aren't being done like this actually - bringing out all the connectors to a single location (prob at the back, maybe 1 USB at the front) like a small set top box.
I am very tempted but waiting until I can get a second or third RasPi.AndrewS wrote:Possibly because people aren't yet willing to take a soldering iron to their Pi while there's still such a long waiting list?Crook wrote:Looks good. I'm suprised more cases aren't being done like this actually - bringing out all the connectors to a single location (prob at the back, maybe 1 USB at the front) like a small set top box.
I was more thinking about extension cables being used internally, so a USB Hub, HDMI extension cable, with any type of power port you want converting to a scavenged microusb connector, that kind of thing.
I did eye them up but the price was just too much to justify for myself, but I'm cheap
The other problem is that extension leads tend to be quite long, so they'd need to be coiled up and add extra bulk to any case. Unless you cannibalised them to make them shorter, which is extra faffCrook wrote:I was more thinking about extension cables being used internally, so a USB Hub, HDMI extension cable, with any type of power port you want converting to a scavenged microusb connector, that kind of thing.
Hey, this is a RPi, it's all faff
Yep, that's my thinking. Although I do have two pi's (my wife bought one and I got one) so I do have a backup - unless she notices the swap ;-0AndrewS wrote: Possibly because people aren't yet willing to take a soldering iron to their Pi while there's still such a long waiting list?
Has she "accessorized" hers yet?
Its a soldering iron, drill and dremel in reality. I've put some further instructions here http://oliverjenkins.com/blog/changing- ... aspberrypiAndrewS wrote: Possibly because people aren't yet willing to take a soldering iron to their Pi while there's still such a long waiting list?
if anyone is interested.
Very nice. This is similar to what I want to do, however I want to have access to both USB ports, so I would need a dual 4 pin header. It seems like the spacing of the pins on the USB connector is *almost* .1 inch, however they aren't quite the same as they seem to follow the spacing on the USB-A connector which has the two center conductors slightly closer together. Also it looks like the holes in the PCB might be slightly too small for a standard header connector like the one used for the GPIO. I need to be sure I have a part that will work before I remove the connector and make the board useless.
Thankyou @oliverjenkins: That is a pretty good article. It looks like you could put another USB into your board from the bottom. You would have to find a USB femal connector to do it. You could run that out the side of your case for a keyboard or mouse (or wireless combo for both) and lose one less port on your hub.
From me too ... Thank you @oliverjenkins very much for this brave step and all the details.
I stumbled on this thread after suffering with the existing loose onboard USB sockets for days ... my USB device frequently loses connection when moved even a millimeter using the standard USB sockets. Cross-checking with other sockets on other PCs it seems most USB sockets exhibit this loosness BUT without losing connection.
So with this mod I can locate my USB device anywhere and not worry about connection to the RPi.
If it's any help, de-soldering a tricky item may be helped by heating in stages using heat-resistant wedges, no de-soldering tools required.
Start with a thin (blunt!) razor blade wedged gently but firmly between the 'board and the connector.
Add heat to all the solder points - the connector will disengage slightly. Add heat to all the solder points again.
Move the thin (blunt!) razor blade gently but firmly towards the center of the board.
Add heat to all the solder points - the connector will again disengage slightly. Add heat to all the solder points again.
Repeat until the job is done. (You may need to add more THIN wedges as you go.)
Then it's time for the de-soldering tools (I prefer wicks rather than vacuum pumps but it's a personal preference.)
Again, thanks @oliverjenkins for taking the lead on this.
PS as the RPi uses one PCB takeoff for both existing USB ports if this header is connected to e.g., a 2-way hub it does the same job - there is no need for a second onboard header.
Now waiting for a similar article on replacing the micro-USB power supply header with something more universal - like a couple of copper pins or a connector block like http://www.cosam.org/images/a1200t/connector_block.jpg
Very good thread. Should write up a tutorial for all of us noobs
Not sure what you mean? The data pins from the two USB ports connect to 4 separate pins on the LAN9512 hub chip.Ray_GTI-R wrote:PS as the RPi uses one PCB takeoff for both existing USB ports if this header is connected to e.g., a 2-way hub it does the same job - there is no need for a second onboard header.
