angassic
No wireless interfaces found - Raspberry Pi Zero W
Thu Sep 07, 2017 7:58 am
Hello guys,
I come here with my last breath to ask for your help. I've been trying to solve this problem for 10 hours now, without stopping. I have browsed the whole forum, this and many others, several attempts to change the settings, commands, six different images installed, three SD cards with different speeds, but nothing solved, I'm starting to think that it is a hardware problem.
I have a Raspberry Pi Zero W V1.1 ($ cat/proc/cpuinfo tells me that too). It has the WiFi chip BCM2835. I have already tried to make all possible changes in the interface and wpa_supplicant files, without effect. I do not get any data on the existence of the wlan0 network in any command I execute, this includes:
 ifconfig, iwconfig, ifconfig -a, ifdown / ifup wlan0
All with sudo.
All of them return information to me that the wlan0 interface is not configured, does not exist, does not support or is not working. I am using a standard Samsung 5V 2A charger, so power is not the problem. It works perfectly except the WiFi interface.
I have already used the following images:
  • Raspbian Stretch, with desktop and lite version, both updated: August 2017
    Release date: 2017-08-16
    Kernel version: 4.9
  • PiBakery, with the default WiFi settings for my network
  • Raspbian Jessie, June 21, 2017 version
I have also tried to use two phones with Bluetooth Tethering, Internet over USB and AD-Hoc.
Here the result of some commands (sorry for the bad quality images):
The configuration of the interface and wpa_supplicant files is very simple because I have given up trying to change advanced settings, if not the simplest ones work.
I had already managed to make the WiFi network work with the Jessie version, but currently neither with it the wlan interface works. Unless I'm lucky enough for my Rasp. having been struck by a cosmic ray, there is nothing that could have damaged it, since I have kept it well guarded since the last use.
Please, if anyone can help me, I'll be very grateful. Thanks for the attention and sorry for the long post.
angassic
Re: No wireless interfaces found - Raspberry Pi Zero W
Fri Sep 08, 2017 8:13 pm
Please, I have not received any answers so far and I have not been able to solve it myself, I appreciate any help! Thank you.
I was able to connect via SSH-USB, using a pre-configured SD card I set up with Jessie, and I also did not succeed in any attempt to configure WiFi. I got access to log journalctl, which shows that there are errors in wpa_supplicant configuration during boot. It also seems to be related to the following error:
sudo ifup wlan0
wpa_supplicant: /sbin/wpa_supplicant daemon failed to start
run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
Failed to bring up wlan0.
Using a magnifying glass in front of my phone's camera, I found a mark on the upper side of the WiFi / Bluetooth chip. But bluetooth works, WiFi does not:
More images: http://imgur.com/a/sass7
Journalctl:
pi@raspberrypi:/etc/wpa_supplicant $ sudo journalctl
-- Logs begin at Wed 2017-07-05 19:17:28 UTC, end at Wed 2017-07-05 19:40:06 UTC
Jul 05 19:17:28 raspberrypi systemd-journal[111]: Runtime journal is using 4.0M
Jul 05 19:17:28 raspberrypi kernel: Booting Linux on physical CPU 0x0
Jul 05 19:17:28 raspberrypi kernel: Linux version 4.9.35+ (dc4@dc4-XPS13-9333) (
Jul 05 19:17:28 raspberrypi kernel: CPU: ARMv6-compatible processor [410fb767] r
Jul 05 19:17:28 raspberrypi kernel: CPU: PIPT / VIPT nonaliasing data cache, VIP
Jul 05 19:17:28 raspberrypi kernel: OF: fdt:Machine model: Raspberry Pi Zero W R
Jul 05 19:17:28 raspberrypi kernel: cma: Reserved 8 MiB at 0x1b400000
Jul 05 19:17:28 raspberrypi kernel: Memory policy: Data cache writeback
Jul 05 19:17:28 raspberrypi kernel: On node 0 totalpages: 114688
Jul 05 19:17:28 raspberrypi kernel: free_area_init_node: node 0, pgdat c0914874,
Jul 05 19:17:28 raspberrypi kernel:   Normal zone: 1008 pages used for memmap
Jul 05 19:17:28 raspberrypi kernel:   Normal zone: 0 pages reserved
Jul 05 19:17:28 raspberrypi kernel:   Normal zone: 114688 pages, LIFO batch:31
Jul 05 19:17:28 raspberrypi kernel: pcpu-alloc: s0 r0 d32768 u32768 alloc=1*3276
Jul 05 19:17:28 raspberrypi kernel: pcpu-alloc: [0] 0
Jul 05 19:17:28 raspberrypi kernel: Built 1 zonelists in Zone order, mobility gr
Jul 05 19:17:28 raspberrypi kernel: Kernel command line: 8250.nr_uarts=0 bcm2708
Jul 05 19:17:28 raspberrypi kernel: PID hash table entries: 2048 (order: 1, 8192
Jul 05 19:17:28 raspberrypi kernel: Dentry cache hash table entries: 65536 (orde
Jul 05 19:17:28 raspberrypi kernel: Inode-cache hash table entries: 32768 (order
Jul 05 19:17:28 raspberrypi kernel: Memory: 435940K/458752K available (5946K ker
lines 1-23...skipping...
-- Logs begin at Wed 2017-07-05 19:17:28 UTC, end at Wed 2017-07-05 19:40:06 UTC. --
Jul 05 19:17:28 raspberrypi systemd-journal[111]: Runtime journal is using 4.0M (max allowed 21.7M, trying to leave 32.5M free of 212.9M available ? current limit 21.7M
Jul 05 19:17:28 raspberrypi kernel: Linux version 4.9.35+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1014 Fri Jun 30 14:3
Jul 05 19:17:28 raspberrypi kernel: CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Jul 05 19:17:28 raspberrypi kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Jul 05 19:17:28 raspberrypi kernel: OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
Jul 05 19:17:28 raspberrypi kernel: free_area_init_node: node 0, pgdat c0914874, node_mem_map db010000
Jul 05 19:17:28 raspberrypi kernel: pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Jul 05 19:17:28 raspberrypi kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 113680
Jul 05 19:17:28 raspberrypi kernel: Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:A6
Jul 05 19:17:28 raspberrypi kernel: PID hash table entries: 2048 (order: 1, 8192 bytes)
Jul 05 19:17:28 raspberrypi kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Jul 05 19:17:28 raspberrypi kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Jul 05 19:17:28 raspberrypi kernel: Memory: 435940K/458752K available (5946K kernel code, 489K rwdata, 1948K rodata, 400K init, 734K bss, 14620K reserved, 8192K cma-res
Jul 05 19:17:28 raspberrypi kernel: Virtual kernel memory layout:
                                        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                                        fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                                        vmalloc : 0xdc800000 - 0xff800000   ( 560 MB)
                                        lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
                                        modules : 0xbf000000 - 0xc0000000   (  16 MB)
                                          .text : 0xc0008000 - 0xc05d6bbc   (5947 kB)
                                          .init : 0xc0840000 - 0xc08a4000   ( 400 kB)
                                          .data : 0xc08a4000 - 0xc091e728   ( 490 kB)
                                           .bss : 0xc091e728 - 0xc09d5f28   ( 734 kB)
Jul 05 19:17:28 raspberrypi kernel: SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Jul 05 19:17:28 raspberrypi kernel: NR_IRQS:16 nr_irqs:16 16
Jul 05 19:17:28 raspberrypi kernel: sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
Jul 05 19:17:28 raspberrypi kernel: clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
Jul 05 19:17:28 raspberrypi kernel: bcm2835: system timer (irq = 27)
Jul 05 19:17:28 raspberrypi kernel: Console: colour dummy device 80x30
Jul 05 19:17:28 raspberrypi kernel: console [tty1] enabled
Jul 05 19:17:28 raspberrypi kernel: Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Jul 05 19:17:28 raspberrypi kernel: pid_max: default: 32768 minimum: 301
Jul 05 19:17:28 raspberrypi kernel: Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
lines 1-43
Jul 05 19:17:28 raspberrypi kernel: Mountpoint-cache hash table entries: 1024 (o
Jul 05 19:17:28 raspberrypi kernel: Disabling cpuset control group subsystem
Jul 05 19:17:28 raspberrypi kernel: CPU: Testing write buffer coherency: ok
Jul 05 19:17:28 raspberrypi kernel: ftrace: allocating 21712 entries in 64 pages
Jul 05 19:17:28 raspberrypi kernel: Setting up static identity map for 0x8200 -
Jul 05 19:17:28 raspberrypi kernel: devtmpfs: initialized
Jul 05 19:17:28 raspberrypi kernel: VFP support v0.3: implementor 41 architectur
Jul 05 19:17:28 raspberrypi kernel: clocksource: jiffies: mask: 0xffffffff max_c
Jul 05 19:17:28 raspberrypi kernel: futex hash table entries: 256 (order: -1, 30
Jul 05 19:17:28 raspberrypi kernel: pinctrl core: initialized pinctrl subsystem
Jul 05 19:17:28 raspberrypi kernel: NET: Registered protocol family 16
Jul 05 19:17:28 raspberrypi kernel: DMA: preallocated 1024 KiB pool for atomic c
Jul 05 19:17:28 raspberrypi kernel: hw-breakpoint: found 6 breakpoint and 1 watc
Jul 05 19:17:28 raspberrypi kernel: hw-breakpoint: maximum watchpoint size is 4
Jul 05 19:17:28 raspberrypi kernel: Serial: AMBA PL011 UART driver
Jul 05 19:17:28 raspberrypi kernel: bcm2835-mbox 2000b880.mailbox: mailbox enabl
Jul 05 19:17:28 raspberrypi kernel: uart-pl011 20201000.serial: could not find p
Jul 05 19:17:28 raspberrypi kernel: bcm2835-dma 20007000.dma: DMA legacy API man
Jul 05 19:17:28 raspberrypi kernel: SCSI subsystem initialized
Jul 05 19:17:28 raspberrypi kernel: usbcore: registered new interface driver usb
Jul 05 19:17:28 raspberrypi kernel: usbcore: registered new interface driver hub
Jul 05 19:17:28 raspberrypi kernel: usbcore: registered new device driver usb
Jul 05 19:17:28 raspberrypi kernel: raspberrypi-firmware soc:firmware: Attached
Jul 05 19:17:28 raspberrypi kernel: clocksource: Switched to clocksource timer
Jul 05 19:17:28 raspberrypi kernel: VFS: Disk quotas dquot_6.6.0
Jul 05 19:17:28 raspberrypi kernel: VFS: Dquot-cache hash table entries: 1024 (o
Jul 05 19:17:28 raspberrypi kernel: FS-Cache: Loaded
Jul 05 19:17:28 raspberrypi kernel: CacheFiles: Loaded
Jul 05 19:17:28 raspberrypi kernel: NET: Registered protocol family 2
Jul 05 19:17:28 raspberrypi kernel: TCP established hash table entries: 4096 (or
Jul 05 19:17:28 raspberrypi kernel: TCP bind hash table entries: 4096 (order: 2,
Jul 05 19:17:28 raspberrypi kernel: TCP: Hash tables configured (established 409
Jul 05 19:17:28 raspberrypi kernel: UDP hash table entries: 256 (order: 0, 4096
Jul 05 19:17:28 raspberrypi kernel: UDP-Lite hash table entries: 256 (order: 0,
Jul 05 19:17:28 raspberrypi kernel: RPC: Registered named UNIX socket transport
Jul 05 19:17:28 raspberrypi kernel: RPC: Registered udp transport module.
Jul 05 19:17:28 raspberrypi kernel: RPC: Registered tcp transport module.
Jul 05 19:17:28 raspberrypi kernel: RPC: Registered tcp NFSv4.1 backchannel tran
Jul 05 19:17:28 raspberrypi kernel: hw perfevents: enabled with armv6_1176 PMU d
Jul 05 19:17:28 raspberrypi kernel: workingset: timestamp_bits=14 max_order=17 b
Jul 05 19:17:28 raspberrypi kernel: FS-Cache: Netfs 'nfs' registered for caching
Jul 05 19:17:28 raspberrypi kernel: NFS: Registering the id_resolver key type
Jul 05 19:17:28 raspberrypi kernel: Key type id_resolver registered
Jul 05 19:17:28 raspberrypi kernel: Key type id_legacy registered
Jul 05 19:17:28 raspberrypi kernel: Block layer SCSI generic (bsg) driver versio
Jul 05 19:17:28 raspberrypi kernel: io scheduler noop registered
Jul 05 19:17:28 raspberrypi kernel: io scheduler deadline registered (default)
Jul 05 19:17:28 raspberrypi kernel: io scheduler cfq registered
Jul 05 19:17:29 raspberrypi kernel: BCM2708FB: allocated DMA memory 5b500000
Jul 05 19:17:29 raspberrypi kernel: BCM2708FB: allocated DMA channel 0 @ dc80d00
Jul 05 19:17:29 raspberrypi kernel: Console: switching to colour frame buffer de
Jul 05 19:17:29 raspberrypi kernel: bcm2835-rng 20104000.rng: hwrng registered
Jul 05 19:17:29 raspberrypi kernel: vc-cma: Videocore CMA driver
Jul 05 19:17:29 raspberrypi kernel: vc-cma: vc_cma_base      = 0x00000000
Jul 05 19:17:29 raspberrypi kernel: vc-cma: vc_cma_size      = 0x00000000 (0 MiB
Jul 05 19:17:29 raspberrypi kernel: vc-cma: vc_cma_initial   = 0x00000000 (0 MiB
Jul 05 19:17:29 raspberrypi kernel: vc-mem: phys_addr:0x00000000 mem_base=0x1ec0
Jul 05 19:17:29 raspberrypi kernel: brd: module loaded
Jul 05 19:17:29 raspberrypi kernel: loop: module loaded
Jul 05 19:17:29 raspberrypi kernel: Loading iSCSI transport class v2.0-870.
Jul 05 19:17:29 raspberrypi kernel: usbcore: registered new interface driver sms
Jul 05 19:17:29 raspberrypi kernel: dwc_otg: version 3.00a 10-AUG-2012 (platform
Jul 05 19:17:29 raspberrypi kernel: dwc_otg: FIQ enabled
Jul 05 19:17:29 raspberrypi kernel: dwc_otg: NAK holdoff enabled
Jul 05 19:17:29 raspberrypi kernel: dwc_otg: FIQ split-transaction FSM enabled
Jul 05 19:17:29 raspberrypi kernel: Module dwc_common_port init
Jul 05 19:17:29 raspberrypi kernel: usbcore: registered new interface driver usb
Jul 05 19:17:29 raspberrypi kernel: mousedev: PS/2 mouse device common for all m
Jul 05 19:17:29 raspberrypi kernel: bcm2835-wdt 20100000.watchdog: Broadcom BCM2
Jul 05 19:17:29 raspberrypi kernel: bcm2835-cpufreq: min=700000 max=1000000
Jul 05 19:17:29 raspberrypi kernel: sdhci: Secure Digital Host Controller Interf
lines 93-115
Jul 05 19:17:29 raspberrypi kernel: BCM2708FB: allocated DMA channel 0 @ dc80d000
Jul 05 19:17:29 raspberrypi kernel: Console: switching to colour frame buffer device 82x26
Jul 05 19:17:29 raspberrypi kernel: vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
Jul 05 19:17:29 raspberrypi kernel: vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
Jul 05 19:17:29 raspberrypi kernel: vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
Jul 05 19:17:29 raspberrypi kernel: usbcore: registered new interface driver smsc95xx
Jul 05 19:17:29 raspberrypi kernel: dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Jul 05 19:17:29 raspberrypi kernel: usbcore: registered new interface driver usb-storage
Jul 05 19:17:29 raspberrypi kernel: mousedev: PS/2 mouse device common for all mice
Jul 05 19:17:29 raspberrypi kernel: bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
Jul 05 19:17:29 raspberrypi kernel: sdhci: Secure Digital Host Controller Interface driver
Jul 05 19:17:29 raspberrypi kernel: sdhci: Copyright(c) Pierre Ossman
Jul 05 19:17:29 raspberrypi kernel: sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
Jul 05 19:17:29 raspberrypi kernel: mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
Jul 05 19:17:29 raspberrypi kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Jul 05 19:17:29 raspberrypi kernel: ledtrig-cpu: registered to indicate activity on CPUs
Jul 05 19:17:29 raspberrypi kernel: hidraw: raw HID events driver (C) Jiri Kosina
Jul 05 19:17:29 raspberrypi kernel: usbcore: registered new interface driver usbhid
Jul 05 19:17:29 raspberrypi kernel: usbhid: USB HID core driver
Jul 05 19:17:29 raspberrypi kernel: vchiq: vchiq_init_state: slot_zero = 0xdb580000, is_master = 0
Jul 05 19:17:29 raspberrypi kernel: Initializing XFRM netlink socket
Jul 05 19:17:29 raspberrypi kernel: NET: Registered protocol family 17
Jul 05 19:17:29 raspberrypi kernel: Key type dns_resolver registered
Jul 05 19:17:29 raspberrypi kernel: registered taskstats version 1
Jul 05 19:17:29 raspberrypi kernel: vc-sm: Videocore shared memory driver
Jul 05 19:17:29 raspberrypi kernel: [vc_sm_connected_init]: start
Jul 05 19:17:29 raspberrypi kernel: [vc_sm_connected_init]: end - returning 0
Jul 05 19:17:29 raspberrypi kernel: 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
Jul 05 19:17:29 raspberrypi kernel: sdhost: log_buf @ db510000 (5b510000)
Jul 05 19:17:29 raspberrypi kernel: mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Jul 05 19:17:29 raspberrypi kernel: mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
Jul 05 19:17:29 raspberrypi kernel: mmc-bcm2835 20300000.mmc: DMA channel allocated
Jul 05 19:17:29 raspberrypi kernel: random: fast init done
Jul 05 19:17:29 raspberrypi kernel: mmc0: host does not support reading read-only switch, assuming write-enable
Jul 05 19:17:29 raspberrypi kernel: of_cfs_init
Jul 05 19:17:29 raspberrypi kernel: of_cfs_init: OK
Jul 05 19:17:29 raspberrypi kernel: Waiting for root device /dev/mmcblk0p2...
Jul 05 19:17:29 raspberrypi kernel: mmc0: new high speed SDHC card at address 59b4
Jul 05 19:17:29 raspberrypi kernel: mmcblk0: mmc0:59b4 NCard 7.36 GiB
Jul 05 19:17:29 raspberrypi kernel:  mmcblk0: p1 p2
Jul 05 19:17:29 raspberrypi kernel: EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
Jul 05 19:17:29 raspberrypi kernel: EXT4-fs (mmcblk0p2): write access will be enabled during recovery
Jul 05 19:17:29 raspberrypi kernel: EXT4-fs (mmcblk0p2): recovery complete
Jul 05 19:17:29 raspberrypi kernel: EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jul 05 19:17:29 raspberrypi kernel: VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Jul 05 19:17:29 raspberrypi kernel: devtmpfs: mounted
Jul 05 19:17:29 raspberrypi kernel: Freeing unused kernel memory: 400K (c0840000 - c08a4000)
Jul 05 19:17:29 raspberrypi kernel: This architecture does not have kernel memory protection.
Jul 05 19:17:29 raspberrypi systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
Jul 05 19:17:29 raspberrypi systemd[1]: Detected architecture 'arm'.
Jul 05 19:17:29 raspberrypi kernel: NET: Registered protocol family 10
Jul 05 19:17:29 raspberrypi systemd[1]: Inserted module 'ipv6'
Jul 05 19:17:29 raspberrypi systemd[1]: Set hostname to <raspberrypi>.
Jul 05 19:17:29 raspberrypi systemd[1]: Initializing machine ID from random generator.
Jul 05 19:17:29 raspberrypi systemd[1]: Installed transient /etc/machine-id file.
Jul 05 19:17:29 raspberrypi systemd[1]: Cannot add dependency job for unit regenerate_ssh_host_keys.service, ignoring: Unit regenerate_ssh_host_keys.service failed to l
Jul 05 19:17:29 raspberrypi systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file
Jul 05 19:17:29 raspberrypi systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
Jul 05 19:17:29 raspberrypi systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Jul 05 19:17:29 raspberrypi kernel: 20980000.usb supply vusb_d not found, using dummy regulator
Jul 05 19:17:29 raspberrypi kernel: 20980000.usb supply vusb_a not found, using dummy regulator
Jul 05 19:17:29 raspberrypi kernel: dwc2 20980000.usb: EPs: 8, dedicated fifos, 4080 entries in SPRAM
Jul 05 19:17:29 raspberrypi kernel: dwc2 20980000.usb: DWC OTG Controller
Jul 05 19:17:29 raspberrypi kernel: dwc2 20980000.usb: new USB bus registered, assigned bus number 1
Jul 05 19:17:29 raspberrypi kernel: dwc2 20980000.usb: irq 33, io mem 0x00000000
Jul 05 19:17:29 raspberrypi kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jul 05 19:17:29 raspberrypi kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 05 19:17:29 raspberrypi kernel: usb usb1: Product: DWC OTG Controller
Jul 05 19:17:29 raspberrypi kernel: usb usb1: Manufacturer: Linux 4.9.35+ dwc2_hsotg
Jul 05 19:17:29 raspberrypi kernel: usb usb1: SerialNumber: 20980000.usb
Jul 05 19:17:29 raspberrypi kernel: hub 1-0:1.0: USB hub found
Jul 05 19:17:29 raspberrypi kernel: hub 1-0:1.0: 1 port detected
Jul 05 19:17:29 raspberrypi kernel: using random self ethernet address
Jul 05 19:17:29 raspberrypi kernel: using random host ethernet address
Jul 05 19:17:29 raspberrypi systemd-udevd[113]: starting version 215
Jul 05 19:17:29 raspberrypi kernel: usb0: HOST MAC 2a:06:cc:e4:93:97
Jul 05 19:17:29 raspberrypi kernel: usb0: MAC fa:48:07:66:1b:09
Jul 05 19:17:29 raspberrypi kernel: g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
Jul 05 19:17:29 raspberrypi kernel: g_ether gadget: g_ether ready
Jul 05 19:17:29 raspberrypi kernel: dwc2 20980000.usb: bound driver g_ether
Jul 05 19:17:29 raspberrypi systemd-journal[111]: Journal started
Jul 05 19:17:28 raspberrypi systemd-modules-load[103]: Inserted module 'dwc2'
Jul 05 19:17:28 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
Jul 05 19:17:28 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
Jul 05 19:17:29 raspberrypi systemd[1]: Started udev Kernel Device Manager.
Jul 05 19:17:29 raspberrypi systemd[1]: Starting Copy rules generated while the root was ro...
Jul 05 19:17:29 raspberrypi systemd[1]: Starting LSB: Set preliminary keymap...
Jul 05 19:17:29 raspberrypi systemd-modules-load[103]: Inserted module 'g_ether'
Jul 05 19:17:29 raspberrypi systemd[1]: Started Load Kernel Modules.
Jul 05 19:17:29 raspberrypi systemd[1]: Started Copy rules generated while the root was ro.
Jul 05 19:17:29 raspberrypi kernel: dwc2 20980000.usb: new device is high-speed
Jul 05 19:17:29 raspberrypi systemd-fsck[83]: e2fsck 1.43.3 (04-Sep-2016)
Jul 05 19:17:29 raspberrypi systemd-fsck[83]: Superblock last mount time is in the future.
Jul 05 19:17:29 raspberrypi systemd-fsck[83]: (by less than a day, probably due to the hardware clock being incorrectly set)
Jul 05 19:17:29 raspberrypi systemd-fsck[83]: /dev/mmcblk0p2: clean, 35993/451232 files, 312934/1917440 blocks
Jul 05 19:17:29 raspberrypi kernel: dwc2 20980000.usb: new address 2
Jul 05 19:17:29 raspberrypi systemd[1]: Mounting Configuration File System...
Jul 05 19:17:29 raspberrypi fake-hwclock[86]: Wed  5 Jul 19:17:28 UTC 2017
Jul 05 19:17:29 raspberrypi systemd[1]: Starting Apply Kernel Variables...
Jul 05 19:17:29 raspberrypi systemd[1]: Mounted FUSE Control File System.
Jul 05 19:17:29 raspberrypi systemd[1]: Mounted Configuration File System.
Jul 05 19:17:29 raspberrypi systemd[1]: Started Apply Kernel Variables.
Jul 05 19:17:30 raspberrypi kernel: gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
Jul 05 19:17:30 raspberrypi keyboard-setup[117]: Setting preliminary keymap...done.
Jul 05 19:17:30 raspberrypi systemd[1]: Started LSB: Set preliminary keymap.
Jul 05 19:17:30 raspberrypi systemd[1]: Starting Show Plymouth Boot Screen...
Jul 05 19:17:30 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
Jul 05 19:17:31 raspberrypi systemd[1]: Received SIGRTMIN+20 from PID 171 (plymouthd).
Jul 05 19:17:31 raspberrypi systemd[1]: Started Show Plymouth Boot Screen.
Jul 05 19:17:31 raspberrypi systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Jul 05 19:17:31 raspberrypi systemd[1]: Starting Paths.
Jul 05 19:17:31 raspberrypi systemd[1]: Reached target Paths.
Jul 05 19:17:31 raspberrypi systemd[1]: Starting Forward Password Requests to Plymouth Directory Watch.
Jul 05 19:17:31 raspberrypi systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Jul 05 19:17:31 raspberrypi kernel: EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Jul 05 19:17:31 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
Jul 05 19:17:31 raspberrypi systemd[1]: Started Various fixups to make systemd work better on Debian.
Jul 05 19:17:31 raspberrypi systemd[1]: Starting Load/Save Random Seed...
Jul 05 19:17:31 raspberrypi systemd[1]: Starting Local File Systems (Pre).
Jul 05 19:17:31 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
Jul 05 19:17:31 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/461f79d8-01.
Jul 05 19:17:31 raspberrypi systemd[1]: Started Load/Save Random Seed.
Jul 05 19:17:31 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/461f79d8-01...
Jul 05 19:17:32 raspberrypi systemd-fsck[183]: fsck.fat 3.0.27 (2014-11-12)
Jul 05 19:17:32 raspberrypi systemd-fsck[183]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Jul 05 19:17:32 raspberrypi systemd-fsck[183]: Automatically removing dirty bit.
Jul 05 19:17:32 raspberrypi systemd-fsck[183]: Free cluster summary wrong (39807 vs. really 39806)
Jul 05 19:17:32 raspberrypi systemd-fsck[183]: Auto-correcting.
Jul 05 19:17:32 raspberrypi systemd-fsck[183]: Performing changes.
Jul 05 19:17:32 raspberrypi systemd-fsck[183]: /dev/mmcblk0p1: 145 files, 42838/82644 clusters
Jul 05 19:17:32 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/461f79d8-01.
Jul 05 19:17:32 raspberrypi systemd[1]: Mounting /boot...
Jul 05 19:17:32 raspberrypi systemd[1]: Mounted /boot.
Jul 05 19:17:32 raspberrypi systemd[1]: Starting Local File Systems.
Jul 05 19:17:32 raspberrypi systemd[1]: Reached target Local File Systems.
Jul 05 19:17:32 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
Jul 05 19:17:32 raspberrypi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Jul 05 19:17:32 raspberrypi systemd[1]: Starting Remote File Systems.
Jul 05 19:17:32 raspberrypi systemd[1]: Reached target Remote File Systems.
Jul 05 19:17:32 raspberrypi systemd[1]: Starting Trigger Flushing of Journal to Persistent Storage...
Jul 05 19:17:32 raspberrypi systemd[1]: Starting LSB: Prepare console...
Jul 05 19:17:32 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Jul 05 19:17:32 raspberrypi systemd[1]: Starting LSB: Raise network interfaces....
Jul 05 19:17:32 raspberrypi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Jul 05 19:17:32 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Jul 05 19:17:33 raspberrypi raspi-config[199]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
Jul 05 19:17:33 raspberrypi raspi-config[199]: No. Switching to ondemand scaling governor.
Jul 05 19:17:33 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Jul 05 19:17:33 raspberrypi kbd[197]: Setting console screen modes.
Jul 05 19:17:33 raspberrypi systemd-journal[111]: Runtime journal is using 4.0M (max allowed 21.7M, trying to leave 32.5M free of 212.8M available ? current limit 21.7M
Jul 05 19:17:33 raspberrypi systemd[1]: Started Trigger Flushing of Journal to Persistent Storage.
Jul 05 19:17:33 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Jul 05 19:17:33 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Jul 05 19:17:33 raspberrypi systemd[1]: Starting Sound Card.
Jul 05 19:17:33 raspberrypi systemd[1]: Reached target Sound Card.
Jul 05 19:17:33 raspberrypi kbd[197]: setterm: $TERM is not defined.
Jul 05 19:17:33 raspberrypi systemd[1]: Started LSB: Prepare console.
Jul 05 19:17:33 raspberrypi systemd[1]: Starting LSB: Set console font and keymap...
Jul 05 19:17:34 raspberrypi wpa_supplicant[324]: Successfully initialized wpa_supplicant
Jul 05 19:17:34 raspberrypi console-setup[254]: Setting up console font and keymap...done.
Jul 05 19:17:34 raspberrypi systemd[1]: Started LSB: Set console font and keymap.
Jul 05 19:17:35 raspberrypi wpa_supplicant[324]: Could not read interface wlan0 flags: No such device
Jul 05 19:17:35 raspberrypi wpa_supplicant[324]: nl80211: Driver does not support authentication/association or connect commands
Jul 05 19:17:35 raspberrypi wpa_supplicant[324]: WEXT: Could not set interface 'wlan0' UP
Jul 05 19:17:35 raspberrypi wpa_supplicant[324]: wlan0: Failed to initialize driver interface
Jul 05 19:17:35 raspberrypi networking[200]: Configuring network interfaces.../etc/network/if-pre-up.d/wpasupplicant: 120: /etc/network/if-pre-up.d/wpasupplicant: canno
Jul 05 19:17:35 raspberrypi networking[200]: run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
Jul 05 19:17:35 raspberrypi networking[200]: Failed to bring up wlan0.
Jul 05 19:17:35 raspberrypi networking[200]: done.
Jul 05 19:17:35 raspberrypi systemd[1]: Started LSB: Raise network interfaces..
Jul 05 19:17:35 raspberrypi systemd[1]: Starting System Initialization.
Jul 05 19:17:35 raspberrypi systemd[1]: Reached target System Initialization.
Jul 05 19:17:35 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack Activation Socket.
Jul 05 19:17:35 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Jul 05 19:17:35 raspberrypi systemd[1]: Starting D-Bus System Message Bus Socket.
Jul 05 19:17:35 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Jul 05 19:17:35 raspberrypi systemd[1]: Starting Sockets.
Jul 05 19:17:35 raspberrypi systemd[1]: Reached target Sockets.
Jul 05 19:17:35 raspberrypi systemd[1]: Starting Daily Cleanup of Temporary Directories.
Jul 05 19:17:35 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
Jul 05 19:17:35 raspberrypi systemd[1]: Starting Timers.
Jul 05 19:17:35 raspberrypi systemd[1]: Reached target Timers.
Jul 05 19:17:35 raspberrypi systemd[1]: Started Manage Sound Card State (restore and store).
Jul 05 19:17:35 raspberrypi systemd[1]: Starting Restore Sound Card State...
Jul 05 19:17:35 raspberrypi systemd[1]: Starting Basic System.
Jul 05 19:17:35 raspberrypi systemd[1]: Reached target Basic System.
Jul 05 19:17:35 raspberrypi systemd[1]: Starting Regular background program processing daemon...
Jul 05 19:17:35 raspberrypi systemd[1]: Started Regular background program processing daemon.
Jul 05 19:17:35 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Jul 05 19:17:35 raspberrypi systemd[1]: Started Turn on SSH if /boot/ssh is present.
Jul 05 19:17:35 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Jul 05 19:17:35 raspberrypi systemd[1]: Starting Login Service...
Jul 05 19:17:35 raspberrypi systemd[1]: Started getty on tty2-tty6 if dbus and logind are not available.
Jul 05 19:17:35 raspberrypi systemd[1]: Starting LSB: Autogenerate and use a swap file...
Jul 05 19:17:35 raspberrypi cron[357]: (CRON) INFO (pidfile fd = 3)
Jul 05 19:17:35 raspberrypi cron[357]: (CRON) INFO (Running @reboot jobs)
 ESCOC
cant
.done.
s: No such device
s: No such device
s: No such device
0' UP
interface
etwork/if-pre-up.d/wpasupplicant: 120: /etc/network/if-pre-up.d/wpasupplicant: cannot create /dev/stderr: No such device or address
Socket.
ion Socket.
ies.
es.
 store).
ng daemon...
g daemon.
d by UART...
le...
 ESCOD
Jul 05 19:17:35 raspberrypi dhcpcd[360]: version 6.7.1 starting
Jul 05 19:17:35 raspberrypi dhcpcd[360]: dev: loaded udev
Jul 05 19:17:35 raspberrypi systemd[1]: Starting LSB: triggerhappy hotkey daemon...
Jul 05 19:17:35 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Jul 05 19:17:35 raspberrypi systemd[1]: Starting D-Bus System Message Bus...
Jul 05 19:17:35 raspberrypi dhcpcd[360]: usb0: adding address fe80::1ca5:7a3e:f6e7:afdd
Jul 05 19:17:35 raspberrypi systemd[1]: Started D-Bus System Message Bus.
Jul 05 19:17:35 raspberrypi avahi-daemon[367]: Found user 'avahi' (UID 105) and group 'avahi' (GID 110).
Jul 05 19:17:35 raspberrypi dphys-swapfile[362]: Starting dphys-swapfile swapfile setup ...
Jul 05 19:17:35 raspberrypi avahi-daemon[367]: Successfully dropped root privileges.
Jul 05 19:17:36 raspberrypi avahi-daemon[367]: avahi-daemon 0.6.31 starting up.
Jul 05 19:17:36 raspberrypi kernel: uart-pl011 20201000.serial: no DMA platform data
Jul 05 19:17:36 raspberrypi triggerhappy[364]: Error opening '/dev/input/event*': No such file or directory
Jul 05 19:17:36 raspberrypi avahi-daemon[367]: Successfully called chroot().
Jul 05 19:17:36 raspberrypi avahi-daemon[367]: Successfully dropped remaining capabilities.
Jul 05 19:17:36 raspberrypi avahi-daemon[367]: No service file found in /etc/avahi/services.
Jul 05 19:17:36 raspberrypi avahi-daemon[367]: Network interface enumeration completed.
Jul 05 19:17:36 raspberrypi avahi-daemon[367]: Registering HINFO record with values 'ARMV6L'/'LINUX'.
Jul 05 19:17:36 raspberrypi avahi-daemon[367]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 326764406.
Jul 05 19:17:36 raspberrypi dbus[370]: [system] Successfully activated service 'org.freedesktop.systemd1'
Jul 05 19:17:36 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Jul 05 19:17:36 raspberrypi systemd[1]: Starting System Logging Service...
Jul 05 19:17:36 raspberrypi systemd[1]: Started Restore Sound Card State.
Jul 05 19:17:36 raspberrypi systemd[1]: Started LSB: triggerhappy hotkey daemon.
Jul 05 19:17:36 raspberrypi dphys-swapfile[362]: want /var/swap=100MByte, checking existing: keeping it
Jul 05 19:17:36 raspberrypi systemd[1]: Started System Logging Service.
Jul 05 19:17:36 raspberrypi systemd-logind[361]: New seat seat0.
Jul 05 19:17:36 raspberrypi systemd[1]: Started Login Service.
Jul 05 19:17:36 raspberrypi kernel: Adding 102396k swap on /var/swap.  Priority:-1 extents:5 across:200700k SSFS
Jul 05 19:17:36 raspberrypi dphys-swapfile[362]: done.
Jul 05 19:17:36 raspberrypi systemd[1]: Started LSB: Autogenerate and use a swap file.
Jul 05 19:17:36 raspberrypi avahi-daemon[367]: Joining mDNS multicast group on interface usb0.IPv6 with address fe80::1ca5:7a3e:f6e7:afdd.
Jul 05 19:17:36 raspberrypi avahi-daemon[367]: New relevant interface usb0.IPv6 for mDNS.
Jul 05 19:17:36 raspberrypi avahi-daemon[367]: Registering new address record for fe80::1ca5:7a3e:f6e7:afdd on usb0.*.
Jul 05 19:17:36 raspberrypi dhcpcd[360]: usb0: waiting for carrier
Jul 05 19:17:36 raspberrypi kernel: IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
Jul 05 19:17:40 raspberrypi kernel: Bluetooth: Core ver 2.22
Jul 05 19:17:40 raspberrypi kernel: NET: Registered protocol family 31
Jul 05 19:17:40 raspberrypi kernel: Bluetooth: HCI device and connection manager initialized
Jul 05 19:17:40 raspberrypi kernel: Bluetooth: HCI socket layer initialized
Jul 05 19:17:40 raspberrypi kernel: Bluetooth: L2CAP socket layer initialized
Jul 05 19:17:40 raspberrypi kernel: Bluetooth: SCO socket layer initialized
Jul 05 19:17:40 raspberrypi kernel: Bluetooth: HCI UART driver ver 2.3
Jul 05 19:17:40 raspberrypi kernel: Bluetooth: HCI UART protocol H4 registered
Jul 05 19:17:40 raspberrypi kernel: Bluetooth: HCI UART protocol Three-wire (H5) registered
Jul 05 19:17:40 raspberrypi kernel: Bluetooth: HCI UART protocol Broadcom registered
Jul 05 19:17:40 raspberrypi btuart[358]: bcm43xx_init
Jul 05 19:17:40 raspberrypi btuart[358]: Flash firmware /lib/firmware/BCM43430A1.hcd
Jul 05 19:17:40 raspberrypi btuart[358]: Set Controller UART speed to 3000000 bit/s
Jul 05 19:17:40 raspberrypi btuart[358]: Device setup complete
Jul 05 19:17:40 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
Jul 05 19:17:40 raspberrypi systemd[1]: Starting system-systemd\x2drfkill.slice.
Jul 05 19:17:40 raspberrypi systemd[1]: Created slice system-systemd\x2drfkill.slice.
Jul 05 19:17:40 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status of rfkill0...
Jul 05 19:17:40 raspberrypi systemd[1]: Starting Bluetooth service...
Jul 05 19:17:40 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status of rfkill0.
Jul 05 19:17:40 raspberrypi bluetoothd[455]: Bluetooth daemon 5.23
Jul 05 19:17:40 raspberrypi systemd[1]: Started Bluetooth service.
Jul 05 19:17:40 raspberrypi systemd[1]: Starting Bluetooth.
Jul 05 19:17:40 raspberrypi bluetoothd[455]: Starting SDP server
Jul 05 19:17:40 raspberrypi systemd[1]: Reached target Bluetooth.
Jul 05 19:17:40 raspberrypi kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Jul 05 19:17:40 raspberrypi kernel: Bluetooth: BNEP filters: protocol multicast
Jul 05 19:17:40 raspberrypi kernel: Bluetooth: BNEP socket layer initialized
Jul 05 19:17:40 raspberrypi dbus[370]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Jul 05 19:17:40 raspberrypi bluetoothd[455]: Bluetooth management interface 1.14 initialized
Jul 05 19:17:40 raspberrypi bluetoothd[455]: Sap driver initialization failed.
Jul 05 19:17:40 raspberrypi bluetoothd[455]: sap-server: Operation not permitted (1)
Jul 05 19:17:40 raspberrypi systemd[1]: Starting Hostname Service...
Jul 05 19:17:41 raspberrypi systemd-hostnamed[459]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install ns
Jul 05 19:17:41 raspberrypi dbus[370]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jul 05 19:17:41 raspberrypi systemd[1]: Started Hostname Service.
Jul 05 19:18:06 raspberrypi dhcpcd[360]: timed out
Jul 05 19:18:06 raspberrypi dhcpcd[360]: forked to background, child pid 460
Jul 05 19:18:06 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Jul 05 19:18:06 raspberrypi systemd[1]: Starting Network.
Jul 05 19:18:06 raspberrypi systemd[1]: Reached target Network.
Jul 05 19:18:06 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Jul 05 19:18:06 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Jul 05 19:18:06 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
Jul 05 19:18:06 raspberrypi systemd[1]: Starting Network is Online.
Jul 05 19:18:06 raspberrypi systemd[1]: Reached target Network is Online.
Jul 05 19:18:06 raspberrypi systemd[1]: Starting LSB: Start NTP daemon...
Jul 05 19:18:06 raspberrypi systemd[1]: Starting Permit User Sessions...
Jul 05 19:18:07 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
Jul 05 19:18:07 raspberrypi systemd[1]: Started Permit User Sessions.
Jul 05 19:18:07 raspberrypi systemd[1]: Starting Terminate Plymouth Boot Screen...
Jul 05 19:18:07 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
Jul 05 19:18:07 raspberrypi sshd[461]: Server listening on 0.0.0.0 port 22.
Jul 05 19:18:07 raspberrypi sshd[461]: Server listening on :: port 22.
Jul 05 19:18:07 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 171 (plymouthd).
Jul 05 19:18:07 raspberrypi systemd[1]: Started Terminate Plymouth Boot Screen.
Jul 05 19:18:07 raspberrypi ntpd[477]: ntpd [email protected] Mon Jul 25 22:35:28 UTC 2016 (1)
Jul 05 19:18:07 raspberrypi systemd[1]: Started Hold until boot process finishes up.
Jul 05 19:18:07 raspberrypi ntp[463]: Starting NTP server: ntpd.
Jul 05 19:18:07 raspberrypi ntpd[481]: proto: precision = 1.000 usec
Jul 05 19:18:07 raspberrypi systemd[1]: Started LSB: Start NTP daemon.
Jul 05 19:18:07 raspberrypi ntpd[481]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Jul 05 19:18:07 raspberrypi ntpd[481]: Listen and drop on 1 v6wildcard :: UDP 123
Jul 05 19:18:07 raspberrypi ntpd[481]: Listen normally on 2 lo 127.0.0.1 UDP 123
Jul 05 19:18:07 raspberrypi ntpd[481]: Listen normally on 3 lo ::1 UDP 123
Jul 05 19:18:07 raspberrypi ntpd[481]: peers refreshed
Jul 05 19:18:07 raspberrypi ntpd[481]: Listening on routing socket on fd #20 for interface updates
Jul 05 19:18:07 raspberrypi ntpd[481]: Deferring DNS for 0.debian.pool.ntp.org 1
Jul 05 19:18:07 raspberrypi ntpd[481]: Deferring DNS for 1.debian.pool.ntp.org 1
Jul 05 19:18:07 raspberrypi ntpd[481]: Deferring DNS for 2.debian.pool.ntp.org 1
Jul 05 19:18:07 raspberrypi ntpd[481]: Deferring DNS for 3.debian.pool.ntp.org 1
Jul 05 19:18:07 raspberrypi ntpd[482]: signal_no_reset: signal 17 had flags 4000000
Jul 05 19:18:07 raspberrypi systemd[1]: Starting Getty on tty1...
Jul 05 19:18:07 raspberrypi systemd[1]: Started Getty on tty1.
Jul 05 19:18:07 raspberrypi systemd[1]: Starting Login Prompts.
Jul 05 19:18:07 raspberrypi systemd[1]: Reached target Login Prompts.
Jul 05 19:18:07 raspberrypi systemd[1]: Starting Multi-User System.
Jul 05 19:18:07 raspberrypi systemd[1]: Reached target Multi-User System.
Jul 05 19:18:07 raspberrypi systemd[1]: Starting Graphical Interface.
Jul 05 19:18:07 raspberrypi systemd[1]: Reached target Graphical Interface.
Jul 05 19:18:07 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Jul 05 19:18:07 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Jul 05 19:18:07 raspberrypi systemd[1]: Startup finished in 1.484s (kernel) + 41.026s (userspace) = 42.510s.
This part is interesting:
I do not use any WiFi dongle, it's the original chip.
DaveHarper
Fri Sep 08, 2017 9:30 pm
I also had no WiFi on a unit I bought sometime back but didn't try until last night. Figuring I just got a bad unit I bought another one locally today only to have the same problem with it. I did some digging and found a post where somebody recommended PiBakery. It runs on either Windows or Mac and you use it to configure an image ahead of time (including the network SSID and password). I tried it and it worked - I now have WiFi up and going on both units.
Dave
angassic
Sat Sep 09, 2017 2:41 am
Dave
Thanks for answering.
I already used PiBackery, without success anyway. I found new information in the boot logs:
Using the modinfo command I got this results:
pi@raspberrypi:~ $ modinfo brcmfmac
filename:       /lib/modules/4.9.28+/kernel/drivers/net/wireless/broadcom/brcm80211/brcmfmac/brcmfmac.ko
license:        Dual BSD/GPL
description:    Broadcom 802.11 wireless LAN fullmac driver.
author:         Broadcom Corporation
firmware:       brcm/brcmfmac4356-sdio.bin
firmware:       brcm/brcmfmac4354-sdio.bin
firmware:       brcm/brcmfmac43455-sdio.bin
firmware:       brcm/brcmfmac43430-sdio.bin
firmware:       brcm/brcmfmac4339-sdio.bin
firmware:       brcm/brcmfmac43362-sdio.bin
firmware:       brcm/brcmfmac4335-sdio.bin
firmware:       brcm/brcmfmac43341-sdio.bin
firmware:       brcm/brcmfmac43340-sdio.bin
firmware:       brcm/brcmfmac4334-sdio.bin
firmware:       brcm/brcmfmac4330-sdio.bin
firmware:       brcm/brcmfmac4329-sdio.bin
firmware:       brcm/brcmfmac43241b5-sdio.bin
firmware:       brcm/brcmfmac43241b4-sdio.bin
firmware:       brcm/brcmfmac43241b0-sdio.bin
firmware:       brcm/brcmfmac43143-sdio.bin
firmware:       brcm/brcmfmac43569.bin
firmware:       brcm/brcmfmac43242a.bin
firmware:       brcm/brcmfmac43236b.bin
firmware:       brcm/brcmfmac43143.bin
srcversion:     32719E9550C45B1D194E05E
alias:          usb:v0A5Cp0BDCd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v043Ep3101d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v13B1p0039d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0A5CpBD27d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0A5CpBD1Fd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0A5CpBD17d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0A5CpBD1Ed*dc*dsc*dp*ic*isc*ip*in*
alias:          sdio:c*v02D0d4356*
alias:          sdio:c*v02D0d4354*
alias:          sdio:c*v02D0d4345*
alias:          sdio:c*v02D0dA9A6*
alias:          sdio:c*v02D0d4339*
alias:          sdio:c*v02D0d4335*
alias:          sdio:c*v02D0dA962*
alias:          sdio:c*v02D0dA94D*
alias:          sdio:c*v02D0dA94C*
alias:          sdio:c*v02D0d4334*
alias:          sdio:c*v02D0d4330*
alias:          sdio:c*v02D0d4329*
alias:          sdio:c*v02D0d4324*
alias:          sdio:c*v02D0dA887*
depends:        brcmutil,cfg80211
intree:         Y
vermagic:       4.9.28+ mod_unload modversions ARMv6 p2v8
parm:           txglomsz:Maximum tx packet chain size [SDIO] (int)
parm:           debug:Level of debug output (int)
parm:           p2pon:Enable legacy p2p management functionality (int)
parm:           feature_disable:Disable features (int)
parm:           alternative_fw_path:Alternative firmware path (string)
parm:           fcmode:Mode of firmware signalled flow control (int)
parm:           roamoff:Do not use internal roaming engine (int)
And in journalctl I found these errors:
Jun 21 10:17:39 raspberrypi wpa_supplicant[1225]: Successfully initialized wpa_supplicant
Jun 21 10:17:39 raspberrypi wpa_supplicant[1225]: Could not read interface wlan0 flags: No such device
Jun 21 10:17:39 raspberrypi wpa_supplicant[1225]: nl80211: Driver does not support authentication/association or connect commands
Jun 21 10:17:39 raspberrypi wpa_supplicant[1225]: WEXT: Could not set interface 'wlan0' UP
Jun 21 10:17:39 raspberrypi wpa_supplicant[1225]: wlan0: Failed to initialize driver interface
Jun 21 10:11:21 raspberrypi kernel: brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x08000, err: -110
Jun 21 10:11:21 raspberrypi kernel: brcmfmac: brcmf_chip_recognition: chip backplane type 15 is not supported
Jun 21 10:11:21 raspberrypi kernel: brcmfmac: brcmf_sdio_probe_attach: brcmf_chip_attach failed!
Jun 21 10:11:21 raspberrypi kernel: brcmfmac: brcmf_sdio_probe: brcmf_sdio_probe_attach failed
Jun 21 10:11:21 raspberrypi kernel: brcmfmac: brcmf_ops_sdio_probe: F2 error, probe failed -19...
Jun 21 10:11:21 raspberrypi kernel: usbcore: registered new interface driver brcmfmac
I have no experience with Raspbian and I am a beginner in Linux, and I am also a beginner in the area of Raspberry Pi's, I do not know how to solve this error, because it seems that the error level is very low, lower than the operating system itself. It may be defective firmware/driver or the chip itself is physically damaged. I do not know what to try anymore.
Sat Sep 09, 2017 4:11 pm
Dave
That shouldn't be a problem now with 2017-09-07 Stretch. The RPF folks should have fixed it.
bodge99
Sat Sep 09, 2017 10:15 pm
Hello All,
I've had similar problems on a pi zero w running headless.. The wifi would not come up at all.
It appears that wpa_supplicant can die (in daemon mode) if problems are caused by something in wpa_supplicant.conf.
In my particular case, following the recommended procedures didn't work at all. I'm suspicious that some sort of interaction with a component of systemd is the cause of this.. Just a guess as I've had many other weird problems on systemd machines.
In my particular case it turned out that the wifi encryption settings on my router were not quite "as advertised". When I had finally cracked the problem, I then experimented with wifi on several other home routers. Most worked as expected, but a few "big brand names" didn't.
My personal solution which works with every router wifi that I've tried is this:
Edit your wpa_supplicant to something like this:
country=GB
    update_config=1
    network={
        ssid="pitest"
        psk="pizeropsk"
        proto=WPA2 # also try proto=WPA here if wpa_supplicant returns errors (running non-daemon mode).
        key_mgmt=WPA-PSK
        pairwise=TKIP
        group=TKIP
Obviously you'll need your own ssid and psk settings.
Save the file and reboot. I've found a couple of routers that when set to WPA need proto=WPA2 and one that needed proto=WPA when set to WPA2.
Another way of testing wifi without altering your wpa_supplicant follows in the next post.
bodge99
Sat Sep 09, 2017 10:38 pm
Raspberry Pi wifi connection experiments:
Hi All,
I've been attempting to set up a Raspberry Pi Zero W to run headless for use as a networked door spy hole webcam.
It will be connected to a modified USB webcam which I've fitted inside one of the larger sized spy hole viewers.
I'm using Raspian Stretch lite and have had the usual wifi connection problems.
I've experimented with this on a few different spare home routers that have been set up as wifi access points (i.e. connected to the cabled network only). DHCP is disabled on each one and the device IP address is changed so it doesn't conflict with my broadband router or anything else on the network. This allows me to experiment and make changes that don't affect anyone online elsewhere in the house.
I've tested wifi connectivity on a few different models of wifi routers.
Including:- BT home hubs, a couple of Netgears, an Asus and two no-name Chinese models plus a few others that I can't remember the names of.
The specific router wifi encryption settings are not always as clear as they could be. I've even found a couple of naming errors. I think that some of the problems that some folk have been having are down to their specific encryption settings.
See below for a quick description of how to test.
Here is a collection of the working wpa_supplicant.conf files. These are for various encryption types/settings :-
Obviously, you'll need to replace the ssid and psk entries with your own.
(1) and (2) work with the older routers (I've ignored WEP totally).
(3) and (4) are only present on my newer kit.
(1) WPA-PSK TKIP cipher/encryption.
    country=GB
    update_config=1
    network={
        ssid="pitest"
        psk="pizeropsk"
        proto=WPA # also try proto=WPA2 here if wpa_supplicant returns errors.
        key_mgmt=WPA-PSK
        pairwise=TKIP
        group=TKIP
(2) WPA2-PSK TKIP cipher/encryption
    country=GB
    update_config=1
    network={
        ssid="pitest"
        psk="pizeropsk"
        proto=WPA2 # also try proto=WPA here if wpa_supplicant returns errors.
        key_mgmt=WPA-PSK
        pairwise=TKIP
        group=TKIP
(3) WPA2-PSK AES-CCMP cipher/encryption.
    country=GB
    update_config=1
    network={
        ssid="pitest"
        psk="pizeropsk"
        proto=RSN
        key_mgmt=WPA-PSK
        pairwise=CCMP
        group=CCMP
(4) WPA/WPA2-PSK (mixed mode) TKIP/AES cipher/encryption.
    update_config=1
    network={
        ssid="pitest"
        psk="pizeropsk"
        proto=RSN
        key_mgmt=WPA-PSK
        pairwise=CCMP
        group=TKIP
I don't use the "update_config=1" on other linux systems (headless etc.) but it is stated as required here.
Testing procedure:
Run all commands as root. i.e. use sudo su to gain elevated status.
Don't bother messing with the current wpa_supplicant.conf file yet. Just use a temporary test file in a test directory.
I used test.conf in temporary directory. (e.g. mkdir ~/r . Full path is /home/pi/r/test.conf )
Check your router settings for your wifi settings (if possible).
Create the test.conf in /home/pi/r
One way of doing this is as follows:-
Move to the test directory.
  cd r
  nano ./test.conf
Add the required entries from above, with your SSID and PSK. Now Ctrl-x, then y and finally the enter key to save the file.
Kill the current wpa_supplicant (if running). This releases wlan0 (the onboard wifi) properly for testing purposes. Alternatively, you can test using a USB wifi dongle. This is normally seen as wlan1 if your pi has onboard wifi.
Open a terminal (or login to a virtual terminal), become Root, cd to ~/r (/home/pi/r) and enter the following... N.B. Text within braces is a comment for you.. don't enter this.
  wpa_cli -i wlan0 terminate {kill the background (daemon) wpa_supplicant.}
  wpa_supplicant -c /home/pi/r/test.conf -i wlan0 {or -i wlan1 if using a dongle on a wifi enabled Pi.}
If your terminal response contains the following:- ....
wlan0: SME: Trying to authenticate with xx:xx:xx:xx:xx:xx (SSID='pitest' freq=xxxx MHz)
wlan0: Trying to associate with xx:xx:xx:xx:xx:xx (SSID='pitest' freq=xxxx MHz)
wlan0: Associated with xx:xx:xx:xx:xx:xx
wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
wlan0: CTRL-EVENT-DISCONNECTED bssid=xx:xx:xx:xx:xx:xx reason=3 locally_generated=1
wlan0: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="pitest" auth_failures=1 duration=10 reason=WRONG_KEY
.... Then this indicates that your Pi is talking to your wifi router/AP but that there is a misconfiguration in your test.conf . Use Ctrl-c to kill the process and return to a terminal prompt.
Modify your config file and retry.
If your terminal response is...
wlan0: Trying to associate with xx:xx:xx:xx:xx:xx ('SSID='pitest' freq=xxxx Mhz)
wlan0: WPA: Key negotiation completed with xx:xx:xx:xx:xx:xx [PTK=TKIP GTK=TKIP]
wlan0: CTRL-EVENT-CONNECTED - Connection to xx:xx:xx:xx:xx:xx completed [id=0 id_str=]
...with no terminal prompt returned (wpa_supplicant is currently not running as a daemon), then your test.conf is correct. Wifi access should now be possible.
Open another terminal (or move to another virtual terminal with Ctrl+alt+F(x), e.g. Ctrl+alt+F2 for the second virtual terminal.). Now try pinging your router.
Mine is on 192.168.1.1 , so if: ...
 ping 192.168.1.1
... returns something like:
 PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
 64 bytes from 192.168.1.1: icm_seq=1 ttl=64 time=2.89 ms
..... etc. then all is well.
Use Ctrl-c to kill the process.
Now move to your previous virtual terminal and kill the wpa_supplicant process (Ctrl+c).
Now backup the existing wpa_supplicant.conf and copy the test.conf to this location, named as wpa_supplicant.conf
From within ~/r .
 cp /etc/wpa_supplicant/wpa_supplicant.conf /etc/wpa-supplicant/wpa_supplicant.confLAST
 cp ./test.conf /etc/wpa_supplicant/wpa_supplicant.conf
Now restart your Pi. If all is well, your Pi will connect to Wifi.
I hope that this is of use to someone...
angassic
Sun Sep 10, 2017 10:27 pm
Thanks bodge99, your post is very good, it will probably help other people with encryption problems between routers and Pi's. Unfortunately I think I'm correct about the driver problem, since the answer I got was this:
pi@raspberrypi:~/r $ sudo wpa_supplicant -c /home/pi/r/test.conf -i wlan0
I tried with the four modifications you posted but did not change the final answer. Thank you very much for the post!
redevill
Thu Dec 07, 2017 9:52 pm
Having this same issue. Does anyone have a solution? I have tried the settings bodge99 suggests, that match my router to no effect.
tjk031
Fri Dec 08, 2017 4:22 am
I'm experiencing the exact same issue as well the past couple of days. Any ideas?
dzuliani
Wed Feb 21, 2018 5:22 pm
Hello, the same issue to me. I was working with some pi zero modules that were working at the beginning. I touched them a lot of times to insert inside a box and sometime I've experienced an electrostatic discharge (I felt it on my fingers). I think this is the cause of the disappeared module. In my opinion the discharge has burned the wifi chipset.
JustaLiriK
Fri Jun 22, 2018 11:12 pm
For some reason / magic wpa_supplicant won't trigger Wi-Fi in desktop mode on my pi zero w, while it works OK when I boot in terminal.
Did your issue happened in headless mode?
Ssh, USB-gadget ssh and terminal works OK for me.
Codez comme Da Vincy
steberna
Fri Jun 29, 2018 2:50 pm
I've got the same problem with my raspberry pi zero W, I've tried many fresh installation but no one working and tells me that there are no interfaces for both bluetooth and Wifi.
Has anyone solved the problem?
journactl tells me the following problems
Jun 27 01:48:19 raspberrypi kernel: snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
Jun 27 01:48:23 raspberrypi avahi-daemon[200]: No service file found in /etc/avahi/services.
Jun 27 01:48:23 raspberrypi systemd[1]: Failed to start dhcpcd on all interfaces.
Jun 27 01:48:23 raspberrypi systemd[1]: dhcpcd.service: Failed with result 'exit-code'.
Jun 27 01:48:53 raspberrypi systemd[1]: hciuart.service: Control process exited, code=exited status=1
Jun 27 01:48:53 raspberrypi systemd[1]: Failed to start Configure Bluetooth Modems connected by UART.
Jun 27 01:48:53 raspberrypi systemd[1]: hciuart.service: Unit entered failed state.
Jun 27 01:48:53 raspberrypi systemd[1]: hciuart.service: Failed with result 'exit-code'.
there is also no serial0 in dev
steve310
Sat Nov 24, 2018 9:00 pm
I have what appears to be the same problem on my new Pi Zero W, and I have a workaround that works for me:
1. Edit /etc/wpa-supplicant/wpa-supplicant.conf and simply remove the lines with key-mgmt=...
2. Reboot the Pi
If the wpa-supplicant has the correct SSID and PSK values then you should see that you are connected to WiFi.
3. Update your system using the usual package update... sudo apt-get update, then sudo apt-get upgrade
4. Finally, correct your /etc/wpa-supplicant/wpa-supplicant.conf and restore the correct key-mgmt entry. key_mgmt=WPA-PSK in my case
Apologies in advance for any typos as I'm hurriedly capturing this workaround. Hopefully it is the same problem as others are experiencing.
For info, if of any interest:
As per common network setup steps; I've already updated /etc/wpa-supplicant/wpa-supplicant.conf to include my access point, and also edited /etc/dhcpcd.conf to set a static IP address. Details not included here.
Despite the UI saying that there is no wireless interface, if I execute sudo iwlist wlan0 scan I can see that the Pi WiFi interface is able to see all of my (2.4GHz) WiFi access point(s.) So the WiFi interface is in fact available to iwlist, but the supplicant isn't able to connect - presumably due to stopping when objecting to WPA-PSK key management.
By manually starting the supplicant using this:
wpa_supplicant -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf -Dwext
I saw that the key_mgmt of WPA-PSK was being rejected and caused the supplicant to give up.
The Pi Zero W was built from a NOOBS SD card.
lucifier77
Thu Nov 28, 2019 9:33 pm
I have facing a similar issue, this looks like a common problem with PI Zero W.
I have installed a desktop version and the network/interfaces shows disabled. Please suggest if you have any alternatives to solve this issue?
