carriba
Contact: ICQ
Re: No Wifi connection to Pi Zero W after Raspbian update
Fri Feb 09, 2018 3:42 pm
MrEngman wrote:
Fri Feb 09, 2018 2:43 pm
So it seems disabling IPV6 fixed the problem.
I’ve disabled IPv6 as well now, with the following set of commands on my Raspberry Pi 1 B+:
sudo sed -i 's/$/ ipv6.disable=1/' /boot/cmdline.txt
sudo cp /etc/modprobe.d/ipv6.conf /etc/modprobe.d/ipv6.bak
sudo sh -c 'cat > /etc/modprobe.d/ipv6.conf' << EOF
alias net-pf-10 off
alias ipv6 off
options ipv6 disable_ipv6=1
blacklist ipv6
EOF
sudo sh -c 'cat >> /etc/dhcpcd.conf' << EOF
ipv4only
noipv6
nodhcp6
EOF
sudo sh -c 'cat >> /etc/sysctl.conf' << EOF
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.eth0.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
EOF
sudo sed -i 's/^\(use-ipv6=\).*/\1no/' /etc/avahi/avahi-daemon.conf
Shutdown the OS, and inserted the same SD card on my Raspberry Pi Zero W. Powered it on, and the same observations: Green LED flickering, and stays permanently lit.
No access with SSH via Wifi, and cannot find the Raspberry Pi Zero W with my Wifi radar application. Thus, unplugged it from its power source.
Removing the SD card from the Raspberry Pi Zero W device and inserting it into the Raspberry Pi 1 B+ device, I’m able to find the following “/var/log/syslog” entries (only the relevant ones):
Feb  9 15:14:18 raspberrypi kernel: [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:9E:23:52 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=e7f04ac3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet logo.nologo plymouth.ignore-serial-consoles ipv6.disable=1
Feb  9 15:14:18 raspberrypi kernel: [    0.268121] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-02-07 17:35
Feb  9 15:14:22 raspberrypi dhcpcd[284]: wlan0: waiting for carrier
Feb  9 15:14:22 raspberrypi dhcpcd[284]: wlan0: carrier acquired
Feb  9 15:14:22 raspberrypi dhcpcd[284]: wlan0: carrier lost
No meaningful entries though that may point to an IPv6 issue. IMHO, firmware &/or kernel issue may be most likely to be the case based on the previous logs provided.
pcmanbob
Fri Feb 09, 2018 3:45 pm
I assume you are trying to connect to a routers wifi , have you tried looking at the routers web / setup page for connected devices ?
if you are not willing to just post the contents of your /var/log/syslog regardless of if you think there is anything useful in there, then I don't see how we can help as we have no data to work with.
we need some thing to compare to a working pi log........................
edit..........
I have just flashed a spare SD card with raspbian stretch lite 2017-11-29 enable ssh and added wpa-supplicant booted ok.
changed user password only
did sudo apt-get update ok
did sudo apt-get upgrade
list of files to be updated
Calculating upgrade... Done
The following packages will be upgraded:
base-files bind9-host bluez-firmware curl dbus firmware-atheros
firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek
iproute2 libbind9-140 libcurl3 libcurl3-gnutls libdbus-1-3 libdns-export162
libdns162 libicu57 libisc-export160 libisc160 libisccc140 libisccfg140
liblwres141 libpython2.7-minimal libpython2.7-stdlib libsqlite3-0
libssl1.0.2 libtasn1-6 libxml2 openssh-client openssh-server
openssh-sftp-server pi-bluetooth python2.7 python2.7-minimal
raspberrypi-sys-mods raspi-config rsync sensible-utils ssh tzdata
41 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 32.9 MB of archives.
After this operation, 97.3 kB disk space will be freed.
Do you want to continue? [Y/n]
all ok
rebooted still connects and accessible on my network using wifi, so unless you pi zero is some how different it must be due to some interaction between your pi zero and your router/wifi access point.
carriba
Contact: ICQ
Fri Feb 09, 2018 3:58 pm
pcmanbob wrote:
Fri Feb 09, 2018 3:35 pm
carriba wrote:
Fri Feb 09, 2018 3:22 pm
pcmanbob wrote:
Fri Feb 09, 2018 3:15 pm
So does your log file stop at the line
Feb  9 14:29:32 raspberrypi dhcpcd[268]: wlan0: deleting address fe80::a43f:84bf:ab99:1d32
if not post what comes after for the same boot date/time.
Pertaining to "dhcpcd" and "kernel" messages, yes. Other logs entries are intact and the same.
if you post the log in its entirety for the boot relating to this date/time Feb 9 14:29:32 then we can compare it to our logs to see if we can find what's different other wise we are just guessing, we need data to work with..............
Here the entire "/var/log/syslog" file when booting it up without any updates and without any NTP synchronisation (1st part):
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] Linux version 4.9.59+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1047 Sun Oct 29 11:47:10 GMT 2017
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] cma: Reserved 8 MiB at 0x1b400000
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] Memory policy: Data cache writeback
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] On node 0 totalpages: 114688
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] free_area_init_node: node 0, pgdat c0914e10, node_mem_map db010000
Nov 29 02:56:34 raspberrypi kernel: [    0.000000]   Normal zone: 1008 pages used for memmap
Nov 29 02:56:34 raspberrypi kernel: [    0.000000]   Normal zone: 0 pages reserved
Nov 29 02:56:34 raspberrypi kernel: [    0.000000]   Normal zone: 114688 pages, LIFO batch:31
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] pcpu-alloc: [0] 0
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 113680
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:9E:23:52 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=e7f04ac3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] Memory: 435944K/458752K available (5950K kernel code, 491K rwdata, 1948K rodata, 396K init, 725K bss, 14616K reserved, 8192K cma-reserved)
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] Virtual kernel memory layout:
Nov 29 02:56:34 raspberrypi kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Nov 29 02:56:34 raspberrypi kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Nov 29 02:56:34 raspberrypi kernel: [    0.000000]     vmalloc : 0xdc800000 - 0xff800000   ( 560 MB)
Nov 29 02:56:34 raspberrypi kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
Nov 29 02:56:34 raspberrypi kernel: [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
Nov 29 02:56:34 raspberrypi kernel: [    0.000000]       .text : 0xc0008000 - 0xc05d7a48   (5951 kB)
Nov 29 02:56:34 raspberrypi kernel: [    0.000000]       .init : 0xc0841000 - 0xc08a4000   ( 396 kB)
Nov 29 02:56:34 raspberrypi kernel: [    0.000000]       .data : 0xc08a4000 - 0xc091ef48   ( 492 kB)
Nov 29 02:56:34 raspberrypi kernel: [    0.000000]        .bss : 0xc091ef48 - 0xc09d4648   ( 726 kB)
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Nov 29 02:56:34 raspberrypi kernel: [    0.000000] NR_IRQS:16 nr_irqs:16 16
Nov 29 02:56:34 raspberrypi kernel: [    0.000031] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
Nov 29 02:56:34 raspberrypi kernel: [    0.000063] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
Nov 29 02:56:34 raspberrypi kernel: [    0.000155] bcm2835: system timer (irq = 27)
Nov 29 02:56:34 raspberrypi kernel: [    0.000617] Console: colour dummy device 80x30
Nov 29 02:56:34 raspberrypi kernel: [    0.000642] console [tty1] enabled
Nov 29 02:56:34 raspberrypi kernel: [    0.000668] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Nov 29 02:56:34 raspberrypi kernel: [    0.060315] pid_max: default: 32768 minimum: 301
Nov 29 02:56:34 raspberrypi kernel: [    0.060743] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Nov 29 02:56:34 raspberrypi kernel: [    0.060760] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Nov 29 02:56:34 raspberrypi kernel: [    0.062007] Disabling memory control group subsystem
Nov 29 02:56:34 raspberrypi kernel: [    0.062145] CPU: Testing write buffer coherency: ok
Nov 29 02:56:34 raspberrypi kernel: [    0.062203] ftrace: allocating 21715 entries in 64 pages
Nov 29 02:56:34 raspberrypi kernel: [    0.180468] Setting up static identity map for 0x8200 - 0x8238
Nov 29 02:56:34 raspberrypi kernel: [    0.182462] devtmpfs: initialized
Nov 29 02:56:34 raspberrypi kernel: [    0.192315] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Nov 29 02:56:34 raspberrypi kernel: [    0.192734] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Nov 29 02:56:34 raspberrypi kernel: [    0.192761] futex hash table entries: 256 (order: -1, 3072 bytes)
Nov 29 02:56:34 raspberrypi kernel: [    0.194034] pinctrl core: initialized pinctrl subsystem
Nov 29 02:56:34 raspberrypi kernel: [    0.195478] NET: Registered protocol family 16
Nov 29 02:56:34 raspberrypi kernel: [    0.198024] DMA: preallocated 1024 KiB pool for atomic coherent allocations
Nov 29 02:56:34 raspberrypi kernel: [    0.207697] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Nov 29 02:56:34 raspberrypi kernel: [    0.207713] hw-breakpoint: maximum watchpoint size is 4 bytes.
Nov 29 02:56:34 raspberrypi kernel: [    0.207816] Serial: AMBA PL011 UART driver
Nov 29 02:56:34 raspberrypi kernel: [    0.210709] bcm2835-mbox 2000b880.mailbox: mailbox enabled
Nov 29 02:56:34 raspberrypi kernel: [    0.211457] uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
Nov 29 02:56:34 raspberrypi kernel: [    0.261343] bcm2835-dma 20007000.dma: DMA legacy API manager at dc80d000, dmachans=0x1
Nov 29 02:56:34 raspberrypi kernel: [    0.264243] usbcore: registered new interface driver usbfs
Nov 29 02:56:34 raspberrypi kernel: [    0.264362] usbcore: registered new interface driver hub
Nov 29 02:56:34 raspberrypi kernel: [    0.264561] usbcore: registered new device driver usb
Nov 29 02:56:34 raspberrypi kernel: [    0.270534] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-10-24 17:09
Nov 29 02:56:34 raspberrypi kernel: [    0.272561] clocksource: Switched to clocksource timer
Nov 29 02:56:34 raspberrypi kernel: [    0.326668] VFS: Disk quotas dquot_6.6.0
Nov 29 02:56:34 raspberrypi kernel: [    0.326789] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Nov 29 02:56:34 raspberrypi kernel: [    0.327109] FS-Cache: Loaded
Nov 29 02:56:34 raspberrypi kernel: [    0.327465] CacheFiles: Loaded
Nov 29 02:56:34 raspberrypi kernel: [    0.346830] NET: Registered protocol family 2
Nov 29 02:56:34 raspberrypi kernel: [    0.348170] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
Nov 29 02:56:34 raspberrypi kernel: [    0.348260] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Nov 29 02:56:34 raspberrypi kernel: [    0.348354] TCP: Hash tables configured (established 4096 bind 4096)
Nov 29 02:56:34 raspberrypi kernel: [    0.348453] UDP hash table entries: 256 (order: 0, 4096 bytes)
Nov 29 02:56:34 raspberrypi kernel: [    0.348479] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Nov 29 02:56:34 raspberrypi kernel: [    0.348791] NET: Registered protocol family 1
Nov 29 02:56:34 raspberrypi kernel: [    0.349537] RPC: Registered named UNIX socket transport module.
Nov 29 02:56:34 raspberrypi kernel: [    0.349549] RPC: Registered udp transport module.
Nov 29 02:56:34 raspberrypi kernel: [    0.349554] RPC: Registered tcp transport module.
Nov 29 02:56:34 raspberrypi kernel: [    0.349558] RPC: Registered tcp NFSv4.1 backchannel transport module.
Nov 29 02:56:34 raspberrypi kernel: [    0.350811] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
Nov 29 02:56:34 raspberrypi kernel: [    0.353373] workingset: timestamp_bits=14 max_order=17 bucket_order=3
Nov 29 02:56:34 raspberrypi kernel: [    0.374042] FS-Cache: Netfs 'nfs' registered for caching
Nov 29 02:56:34 raspberrypi kernel: [    0.375786] NFS: Registering the id_resolver key type
Nov 29 02:56:34 raspberrypi kernel: [    0.375833] Key type id_resolver registered
Nov 29 02:56:34 raspberrypi kernel: [    0.375840] Key type id_legacy registered
Nov 29 02:56:34 raspberrypi kernel: [    0.380296] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Nov 29 02:56:34 raspberrypi kernel: [    0.380660] io scheduler noop registered
Nov 29 02:56:34 raspberrypi kernel: [    0.380674] io scheduler deadline registered (default)
Nov 29 02:56:34 raspberrypi kernel: [    0.381142] io scheduler cfq registered
Nov 29 02:56:34 raspberrypi kernel: [    0.387110] BCM2708FB: allocated DMA memory 5b500000
Nov 29 02:56:34 raspberrypi kernel: [    0.387171] BCM2708FB: allocated DMA channel 0 @ dc80d000
Nov 29 02:56:34 raspberrypi kernel: [    0.395447] Console: switching to colour frame buffer device 82x26
Nov 29 02:56:34 raspberrypi kernel: [    0.403110] bcm2835-rng 20104000.rng: hwrng registered
Nov 29 02:56:34 raspberrypi kernel: [    0.403273] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
Nov 29 02:56:34 raspberrypi kernel: [    0.404221] vc-sm: Videocore shared memory driver
Nov 29 02:56:34 raspberrypi kernel: [    0.428794] brd: module loaded
Nov 29 02:56:34 raspberrypi kernel: [    0.441211] loop: module loaded
Nov 29 02:56:34 raspberrypi kernel: [    0.441234] Loading iSCSI transport class v2.0-870.
Nov 29 02:56:34 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/e7f04ac3-01...
Nov 29 02:56:34 raspberrypi systemd-fsck[169]: fsck.fat 4.1 (2017-01-24)
Nov 29 02:56:34 raspberrypi systemd-fsck[169]: /dev/mmcblk0p1: 146 files, 42656/83705 clusters
Nov 29 02:56:34 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/e7f04ac3-01.
Nov 29 02:56:34 raspberrypi systemd[1]: Mounting /boot...
Nov 29 02:56:34 raspberrypi systemd[1]: Mounted /boot.
Nov 29 02:56:34 raspberrypi systemd[1]: Reached target Local File Systems.
Nov 29 02:56:34 raspberrypi systemd[1]: Starting Commit a transient machine-id on disk...
Nov 29 02:56:34 raspberrypi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Nov 29 02:56:34 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
Nov 29 02:56:34 raspberrypi systemd[1]: Starting Set console font and keymap...
Nov 29 02:56:34 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
Nov 29 02:56:34 raspberrypi systemd[1]: Starting Raise network interfaces...
Nov 29 02:56:34 raspberrypi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Nov 29 02:56:34 raspberrypi systemd[1]: Started Commit a transient machine-id on disk.
Nov 29 02:56:34 raspberrypi systemd[1]: Started Set console font and keymap.
Nov 29 02:56:34 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Nov 29 02:56:34 raspberrypi systemd[1]: Started Preprocess NFS configuration.
Nov 29 02:56:34 raspberrypi systemd[1]: Reached target NFS client services.
Nov 29 02:56:34 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
Nov 29 02:56:34 raspberrypi systemd[1]: Reached target Remote File Systems.
Nov 29 02:56:34 raspberrypi systemd[1]: Starting Network Time Synchronization...
Nov 29 02:56:34 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Nov 29 02:56:34 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Nov 29 02:56:34 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Nov 29 02:56:34 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
Nov 29 02:56:34 raspberrypi systemd[1]: Started Network Time Synchronization.
Nov 29 02:56:34 raspberrypi systemd[1]: Reached target System Time Synchronized.
Nov 29 02:56:34 raspberrypi systemd[1]: Reached target System Initialization.
Nov 29 02:56:34 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
Nov 29 02:56:34 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Nov 29 02:56:34 raspberrypi systemd[1]: apt-daily.timer: Adding 9h 52min 9.602171s random time.
Nov 29 02:56:34 raspberrypi systemd[1]: Started Daily apt download activities.
Nov 29 02:56:34 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 11min 50.543755s random time.
Nov 29 02:56:34 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Nov 29 02:56:34 raspberrypi systemd[1]: Reached target Timers.
Nov 29 02:56:34 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Nov 29 02:56:34 raspberrypi systemd[1]: Reached target Sockets.
Nov 29 02:56:34 raspberrypi systemd[1]: Reached target Basic System.
Nov 29 02:56:34 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Nov 29 02:56:34 raspberrypi systemd[1]: Starting Regenerate SSH host keys...
Nov 29 02:56:34 raspberrypi systemd[1]: Starting LSB: Resize the root filesystem to fill partition...
Nov 29 02:56:34 raspberrypi systemd[1]: Starting Copy user wpa_supplicant.conf...
Nov 29 02:56:34 raspberrypi systemd[1]: Starting LSB: Autogenerate and use a swap file...
Nov 29 02:56:34 raspberrypi systemd[1]: Started D-Bus System Message Bus.
Nov 29 02:56:34 raspberrypi dd[240]: 1+0 records in
Nov 29 02:56:34 raspberrypi dd[240]: 1+0 records out
Nov 29 02:56:34 raspberrypi dd[240]: 4096 bytes (4.1 kB, 4.0 KiB) copied, 0.357634 s, 11.5 kB/s
Nov 29 02:56:34 raspberrypi systemd[1]: Started Regular background program processing daemon.
Nov 29 02:56:34 raspberrypi systemd[1]: Starting Login Service...
Nov 29 02:56:34 raspberrypi cron[277]: (CRON) INFO (pidfile fd = 3)
Nov 29 02:56:34 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Nov 29 02:56:34 raspberrypi cron[277]: (CRON) INFO (Running @reboot jobs)
Nov 29 02:56:34 raspberrypi systemd[1]: Starting Check for v3d driver...
Nov 29 02:56:34 raspberrypi systemd[1]: Starting System Logging Service...
Nov 29 02:56:34 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Nov 29 02:56:34 raspberrypi kernel: [    0.442130] usbcore: registered new interface driver smsc95xx
Nov 29 02:56:34 raspberrypi kernel: [    0.442159] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Nov 29 02:56:34 raspberrypi kernel: [    0.670533] Core Release: 2.80a
Nov 29 02:56:34 raspberrypi kernel: [    0.670561] Setting default values for core params
Nov 29 02:56:34 raspberrypi kernel: [    0.670599] Finished setting default values for core params
Nov 29 02:56:34 raspberrypi kernel: [    0.871003] Using Buffer DMA mode
Nov 29 02:56:34 raspberrypi kernel: [    0.871016] Periodic Transfer Interrupt Enhancement - disabled
Nov 29 02:56:34 raspberrypi kernel: [    0.871021] Multiprocessor Interrupt Enhancement - disabled
Nov 29 02:56:34 raspberrypi kernel: [    0.871031] OTG VER PARAM: 0, OTG VER FLAG: 0
Nov 29 02:56:34 raspberrypi kernel: [    0.871120] Dedicated Tx FIFOs mode
Nov 29 02:56:34 raspberrypi kernel: [    0.871689] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xdb514000 dma = 0x5b514000 len=9024
Nov 29 02:56:34 raspberrypi kernel: [    0.871716] FIQ FSM acceleration enabled for :
Nov 29 02:56:34 raspberrypi kernel: [    0.871716] Non-periodic Split Transactions
Nov 29 02:56:34 raspberrypi kernel: [    0.871716] Periodic Split Transactions
Nov 29 02:56:34 raspberrypi kernel: [    0.871716] High-Speed Isochronous Endpoints
Nov 29 02:56:34 raspberrypi kernel: [    0.871716] Interrupt/Control Split Transaction hack enabled
Nov 29 02:56:34 raspberrypi kernel: [    0.871727] dwc_otg: Microframe scheduler enabled
Nov 29 02:56:34 raspberrypi kernel: [    0.871807] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc0451694
Nov 29 02:56:34 raspberrypi kernel: [    0.871820] WARN::hcd_init_fiq:460: FIQ ASM at 0xc0451970 length 36
Nov 29 02:56:34 raspberrypi kernel: [    0.871846] WARN::hcd_init_fiq:486: MPHI regs_base at 0xdc8a5000
Nov 29 02:56:34 raspberrypi kernel: [    0.871916] dwc_otg 20980000.usb: DWC OTG Controller
Nov 29 02:56:34 raspberrypi kernel: [    0.871976] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
Nov 29 02:56:34 raspberrypi kernel: [    0.872095] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
Nov 29 02:56:34 raspberrypi kernel: [    0.872149] Init: Port Power? op_state=1
Nov 29 02:56:34 raspberrypi kernel: [    0.872154] Init: Power Port (0)
Nov 29 02:56:34 raspberrypi kernel: [    0.872515] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Nov 29 02:56:34 raspberrypi kernel: [    0.872531] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 29 02:56:34 raspberrypi kernel: [    0.872626] usb usb1: Product: DWC OTG Controller
Nov 29 02:56:34 raspberrypi kernel: [    0.872640] usb usb1: Manufacturer: Linux 4.9.59+ dwc_otg_hcd
Nov 29 02:56:34 raspberrypi kernel: [    0.872650] usb usb1: SerialNumber: 20980000.usb
Nov 29 02:56:34 raspberrypi kernel: [    0.873818] hub 1-0:1.0: USB hub found
Nov 29 02:56:34 raspberrypi kernel: [    0.873908] hub 1-0:1.0: 1 port detected
Nov 29 02:56:34 raspberrypi kernel: [    0.874823] dwc_otg: FIQ enabled
Nov 29 02:56:34 raspberrypi kernel: [    0.874833] dwc_otg: NAK holdoff enabled
Nov 29 02:56:34 raspberrypi kernel: [    0.874839] dwc_otg: FIQ split-transaction FSM enabled
Nov 29 02:56:34 raspberrypi kernel: [    0.874860] Module dwc_common_port init
Nov 29 02:56:34 raspberrypi kernel: [    0.875362] usbcore: registered new interface driver usb-storage
Nov 29 02:56:34 raspberrypi kernel: [    0.875819] mousedev: PS/2 mouse device common for all mice
Nov 29 02:56:34 raspberrypi kernel: [    0.877487] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
Nov 29 02:56:34 raspberrypi kernel: [    0.877998] bcm2835-cpufreq: min=700000 max=1000000
Nov 29 02:56:34 raspberrypi kernel: [    0.878655] sdhci: Secure Digital Host Controller Interface driver
Nov 29 02:56:34 raspberrypi kernel: [    0.878663] sdhci: Copyright(c) Pierre Ossman
Nov 29 02:56:34 raspberrypi kernel: [    0.879131] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
Nov 29 02:56:34 raspberrypi kernel: [    0.881576] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
Nov 29 02:56:34 raspberrypi kernel: [    0.881749] sdhci-pltfm: SDHCI platform and OF driver helper
Nov 29 02:56:34 raspberrypi kernel: [    0.882255] ledtrig-cpu: registered to indicate activity on CPUs
Nov 29 02:56:34 raspberrypi kernel: [    0.882402] hidraw: raw HID events driver (C) Jiri Kosina
Nov 29 02:56:34 raspberrypi kernel: [    0.882783] usbcore: registered new interface driver usbhid
Nov 29 02:56:34 raspberrypi kernel: [    0.882790] usbhid: USB HID core driver
Nov 29 02:56:34 raspberrypi kernel: [    0.884051] vchiq: vchiq_init_state: slot_zero = 0xdb580000, is_master = 0
Nov 29 02:56:34 raspberrypi kernel: [    0.885921] [vc_sm_connected_init]: start
Nov 29 02:56:34 raspberrypi kernel: [    0.895384] [vc_sm_connected_init]: end - returning 0
Nov 29 02:56:34 raspberrypi kernel: [    0.895874] Initializing XFRM netlink socket
Nov 29 02:56:34 raspberrypi kernel: [    0.895914] NET: Registered protocol family 17
Nov 29 02:56:34 raspberrypi kernel: [    0.896069] Key type dns_resolver registered
Nov 29 02:56:34 raspberrypi kernel: [    0.897955] registered taskstats version 1
Nov 29 02:56:34 raspberrypi kernel: [    0.907074] uart-pl011 20201000.serial: cts_event_workaround enabled
Nov 29 02:56:34 raspberrypi kernel: [    0.907221] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
Nov 29 02:56:34 raspberrypi kernel: [    0.909667] sdhost: log_buf @ db513000 (5b513000)
Nov 29 02:56:34 raspberrypi kernel: [    0.982648] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Nov 29 02:56:34 raspberrypi kernel: [    0.985230] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
Nov 29 02:56:34 raspberrypi kernel: [    0.985247] mmc-bcm2835 20300000.mmc: DMA channel allocated
Nov 29 02:56:34 raspberrypi kernel: [    1.015501] random: fast init done
Nov 29 02:56:34 raspberrypi kernel: [    1.060001] mmc0: host does not support reading read-only switch, assuming write-enable
Nov 29 02:56:34 raspberrypi kernel: [    1.062074] mmc0: new high speed SDHC card at address b368
Nov 29 02:56:34 raspberrypi kernel: [    1.062781] of_cfs_init
Nov 29 02:56:34 raspberrypi kernel: [    1.062921] of_cfs_init: OK
Nov 29 02:56:34 raspberrypi kernel: [    1.064502] mmcblk0: mmc0:b368 NCard 14.9 GiB
Nov 29 02:56:34 raspberrypi kernel: [    1.071285]  mmcblk0: p1 p2
Nov 29 02:56:34 raspberrypi kernel: [    1.084358] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Nov 29 02:56:34 raspberrypi kernel: [    1.086633] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Nov 29 02:56:34 raspberrypi kernel: [    1.087844] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Nov 29 02:56:34 raspberrypi kernel: [    1.087930] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Nov 29 02:56:34 raspberrypi kernel: [    1.089324] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Nov 29 02:56:34 raspberrypi kernel: [    1.089505] devtmpfs: mounted
Nov 29 02:56:34 raspberrypi kernel: [    1.090793] Freeing unused kernel memory: 396K
Nov 29 02:56:34 raspberrypi kernel: [    1.090802] This architecture does not have kernel memory protection.
Nov 29 02:56:34 raspberrypi kernel: [    1.094594] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Nov 29 02:56:34 raspberrypi kernel: [    1.203738] mmc1: new high speed SDIO card at address 0001
Nov 29 02:56:34 raspberrypi kernel: [    1.785832] NET: Registered protocol family 10
Nov 29 02:56:34 raspberrypi kernel: [    1.821016] ip_tables: (C) 2000-2006 Netfilter Core Team
Nov 29 02:56:34 raspberrypi kernel: [    3.339897] i2c /dev entries driver
Nov 29 02:56:34 raspberrypi kernel: [    5.092721] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Nov 29 02:56:34 raspberrypi kernel: [    7.994064] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
Nov 29 02:56:34 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
Nov 29 02:56:34 raspberrypi kernel: [    9.043158] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
Nov 29 02:56:34 raspberrypi kernel: [    9.077482] usbcore: registered new interface driver brcmfmac
Nov 29 02:56:34 raspberrypi kernel: [    9.420354] brcmfmac: Firmware version = wl0: Aug  7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
Nov 29 02:56:34 raspberrypi kernel: [    9.421489] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.41 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-08-07 00:37:47
Nov 29 02:56:34 raspberrypi kernel: [   13.574589] uart-pl011 20201000.serial: no DMA platform data
Nov 29 02:56:34 raspberrypi systemd-udevd[143]: Process '/sbin/crda' failed with exit code 249.
Nov 29 02:56:34 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
Nov 29 02:56:34 raspberrypi liblogging-stdlog:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="284" x-info="http://www.rsyslog.com"] start
Nov 29 02:56:34 raspberrypi thd[286]: Found socket passed from systemd
Nov 29 02:56:34 raspberrypi avahi-daemon[285]: Found user 'avahi' (UID 108) and group 'avahi' (GID 112).
Nov 29 02:56:34 raspberrypi avahi-daemon[285]: Successfully dropped root privileges.
Nov 29 02:56:34 raspberrypi avahi-daemon[285]: avahi-daemon 0.6.32 starting up.
Nov 29 02:56:34 raspberrypi avahi-daemon[285]: Successfully called chroot().
Nov 29 02:56:34 raspberrypi avahi-daemon[285]: Successfully dropped remaining capabilities.
Nov 29 02:56:34 raspberrypi avahi-daemon[285]: No service file found in /etc/avahi/services.
Nov 29 02:56:34 raspberrypi systemd[1]: Started Check for v3d driver.
Nov 29 02:56:34 raspberrypi avahi-daemon[285]: Network interface enumeration completed.
Nov 29 02:56:34 raspberrypi systemd[1]: Started System Logging Service.
Nov 29 02:56:34 raspberrypi avahi-daemon[285]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 2643690600.
Nov 29 02:56:34 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
Nov 29 02:56:34 raspberrypi systemd[1]: Started Copy user wpa_supplicant.conf.
Nov 29 02:56:35 raspberrypi dphys-swapfile[248]: Starting dphys-swapfile swapfile setup ...
Nov 29 02:56:35 raspberrypi resize2fs_once[242]: Starting resize2fs_once:resize2fs 1.43.4 (31-Jan-2017)
Nov 29 02:56:35 raspberrypi kernel: [   15.852120] EXT4-fs (mmcblk0p2): resizing filesystem from 1189376 to 3899648 blocks
Nov 29 02:56:35 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Nov 29 02:56:35 raspberrypi systemd[1]: Started Login Service.
Nov 29 02:56:35 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Nov 29 02:56:35 raspberrypi raspi-config[280]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
Nov 29 02:56:35 raspberrypi raspi-config[280]:  No. Switching to ondemand scaling governor.
Nov 29 02:56:35 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Nov 29 02:56:38 raspberrypi systemd[1]: Started Raise network interfaces.
Nov 29 02:56:39 raspberrypi kernel: [   19.925203] Bluetooth: Core ver 2.22
Nov 29 02:56:39 raspberrypi kernel: [   19.925325] NET: Registered protocol family 31
Nov 29 02:56:39 raspberrypi kernel: [   19.925332] Bluetooth: HCI device and connection manager initialized
Nov 29 02:56:39 raspberrypi kernel: [   19.925354] Bluetooth: HCI socket layer initialized
Nov 29 02:56:39 raspberrypi kernel: [   19.925367] Bluetooth: L2CAP socket layer initialized
Nov 29 02:56:39 raspberrypi kernel: [   19.925407] Bluetooth: SCO socket layer initialized
Nov 29 02:56:39 raspberrypi kernel: [   20.267186] Bluetooth: HCI UART driver ver 2.3
Nov 29 02:56:39 raspberrypi kernel: [   20.267201] Bluetooth: HCI UART protocol H4 registered
Nov 29 02:56:39 raspberrypi kernel: [   20.267206] Bluetooth: HCI UART protocol Three-wire (H5) registered
Nov 29 02:56:39 raspberrypi kernel: [   20.267344] Bluetooth: HCI UART protocol Broadcom registered
Nov 29 02:56:39 raspberrypi btuart[239]: bcm43xx_init
Nov 29 02:56:39 raspberrypi btuart[239]: Flash firmware /lib/firmware/BCM43430A1.hcd
Nov 29 02:56:40 raspberrypi btuart[239]: Set BDADDR UART: b8:27:eb:34:89:f8
Nov 29 02:56:40 raspberrypi btuart[239]: Set Controller UART speed to 3000000 bit/s
Nov 29 02:56:40 raspberrypi btuart[239]: Device setup complete
Nov 29 02:56:40 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
Nov 29 02:56:40 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
Nov 29 02:56:40 raspberrypi systemd[1]: Starting Bluetooth service...
Nov 29 02:56:40 raspberrypi dhcpcd[327]: dev: loaded udev
Nov 29 02:56:40 raspberrypi dhcpcd[327]: forked to background, child pid 355
Nov 29 02:56:40 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Nov 29 02:56:40 raspberrypi systemd[1]: Reached target Network.
Nov 29 02:56:40 raspberrypi systemd[1]: Starting Permit User Sessions...
Nov 29 02:56:40 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
Nov 29 02:56:41 raspberrypi systemd[1]: Started Permit User Sessions.
Nov 29 02:56:41 raspberrypi systemd[1]: Starting Light Display Manager...
Nov 29 02:56:41 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
Nov 29 02:56:41 raspberrypi systemd[1]: Starting Terminate Plymouth Boot Screen...
Nov 29 02:56:41 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
Nov 29 02:56:43 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 149 (plymouthd).
Nov 29 02:56:43 raspberrypi systemd[1]: Started Terminate Plymouth Boot Screen.
Nov 29 02:56:43 raspberrypi bluetoothd[352]: Bluetooth daemon 5.43
Nov 29 02:56:43 raspberrypi systemd[1]: Started Hold until boot process finishes up.
Nov 29 02:56:43 raspberrypi bluetoothd[352]: Starting SDP server
Nov 29 02:56:43 raspberrypi dhcpcd-run-hooks[382]: wlan0: starting wpa_supplicant
Nov 29 02:56:43 raspberrypi kernel: [   23.807902] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Nov 29 02:56:43 raspberrypi kernel: [   23.807915] Bluetooth: BNEP filters: protocol multicast
Nov 29 02:56:43 raspberrypi kernel: [   23.807943] Bluetooth: BNEP socket layer initialized
Nov 29 02:56:43 raspberrypi systemd[1]: Started Bluetooth service.
Nov 29 02:56:43 raspberrypi bluetoothd[352]: Bluetooth management interface 1.14 initialized
Nov 29 02:56:43 raspberrypi bluetoothd[352]: Failed to obtain handles for "Service Changed" characteristic
Nov 29 02:56:43 raspberrypi dbus[251]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Nov 29 02:56:43 raspberrypi systemd[1]: Started BluezALSA proxy.
Nov 29 02:56:43 raspberrypi systemd[1]: Started Getty on tty1.
Nov 29 02:56:43 raspberrypi systemd[1]: Reached target Login Prompts.
Nov 29 02:56:43 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
Nov 29 02:56:44 raspberrypi bluetoothd[352]: Sap driver initialization failed.
Nov 29 02:56:44 raspberrypi systemd[1]: Starting Hostname Service...
Nov 29 02:56:44 raspberrypi bluetoothd[352]: sap-server: Operation not permitted (1)
Nov 29 02:56:44 raspberrypi systemd[1]: Reached target Bluetooth.
Nov 29 02:56:44 raspberrypi dphys-swapfile[248]: want /var/swap=100MByte, generating swapfile ... of 100MBytes
Nov 29 02:56:45 raspberrypi kernel: [   25.317870] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SSFS
Nov 29 02:56:45 raspberrypi dphys-swapfile[248]: done.
Nov 29 02:56:45 raspberrypi systemd[1]: Started LSB: Autogenerate and use a swap file.
Nov 29 02:56:45 raspberrypi bluetoothd[352]: Endpoint registered: sender=:1.4 path=/A2DP/SBC/Source/1
Nov 29 02:56:45 raspberrypi bluetoothd[352]: Endpoint registered: sender=:1.4 path=/A2DP/SBC/Sink/1
Nov 29 02:56:45 raspberrypi dbus[251]: [system] Successfully activated service 'org.freedesktop.hostname1'
Nov 29 02:56:45 raspberrypi systemd[1]: Started Hostname Service.
Nov 29 02:56:45 raspberrypi kernel: [   26.082634] Bluetooth: RFCOMM TTY layer initialized
Nov 29 02:56:45 raspberrypi kernel: [   26.082671] Bluetooth: RFCOMM socket layer initialized
Nov 29 02:56:45 raspberrypi kernel: [   26.082703] Bluetooth: RFCOMM ver 1.11
Nov 29 02:56:46 raspberrypi kernel: [   26.732632] random: crng init done
Nov 29 02:56:46 raspberrypi kernel: [   26.953253] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Nov 29 02:56:46 raspberrypi kernel: [   26.953270] brcmfmac: power management disabled
Nov 29 02:56:47 raspberrypi ssh-keygen[300]: ssh-keygen: generating new host keys: RSA DSA ECDSA ED25519
Nov 29 02:56:47 raspberrypi kernel: [   28.054642] EXT4-fs (mmcblk0p2): resized to 2621440 blocks
Nov 29 02:56:48 raspberrypi systemctl[412]: Removed /etc/systemd/system/multi-user.target.wants/regenerate_ssh_host_keys.service.
Nov 29 02:56:48 raspberrypi systemd[1]: Reloading.
Nov 29 02:56:49 raspberrypi systemd[1]: apt-daily.timer: Adding 3h 6min 50.272459s random time.
Nov 29 02:56:49 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 31min 650.364ms random time.
Nov 29 02:56:49 raspberrypi dhcpcd[355]: wlan0: waiting for carrier
Nov 29 02:56:49 raspberrypi dhcpcd[355]: wlan0: carrier acquired
Nov 29 02:56:49 raspberrypi systemd[1]: Started Regenerate SSH host keys.
Nov 29 02:56:50 raspberrypi systemd[1]: Starting Turn on SSH if /boot/ssh is present...
Nov 29 02:56:52 raspberrypi dhcpcd[355]: DUID 00:01:00:01:21:b0:de:74:b8:27:eb:cb:76:07
Nov 29 02:56:52 raspberrypi dhcpcd[355]: wlan0: IAID eb:cb:76:07
Nov 29 02:56:52 raspberrypi dhcpcd[355]: wlan0: adding address fe80::a43f:84bf:ab99:1d32
Nov 29 02:56:52 raspberrypi dhcpcd[355]: wlan0: carrier lost
Nov 29 02:56:52 raspberrypi dhcpcd[355]: wlan0: deleting address fe80::a43f:84bf:ab99:1d32
Nov 29 02:57:06 raspberrypi kernel: [   46.333680] EXT4-fs (mmcblk0p2): resized to 3670016 blocks
Nov 29 02:57:13 raspberrypi kernel: [   53.586299] EXT4-fs (mmcblk0p2): resized filesystem to 3899648
Nov 29 02:57:22 raspberrypi resize2fs_once[242]: Filesystem at /dev/mmcblk0p2 is mounted on /; on-line resizing required
Nov 29 02:57:22 raspberrypi resize2fs_once[242]: old_desc_blocks = 1, new_desc_blocks = 1
Nov 29 02:57:22 raspberrypi resize2fs_once[242]: The filesystem on /dev/mmcblk0p2 is now 3899648 (4k) blocks long.
Nov 29 02:57:22 raspberrypi lightdm[366]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Nov 29 02:57:23 raspberrypi lightdm[366]: Could not enumerate user data directory /var/lib/lightdm/data: Error opening directory '/var/lib/lightdm/data': No such file or directory
Nov 29 02:57:23 raspberrypi systemd[1]: Reloading.
Nov 29 02:57:25 raspberrypi systemd[1]: apt-daily.timer: Adding 1h 35min 54.294968s random time.
Nov 29 02:57:25 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 6min 38.438872s random time.
Nov 29 02:57:25 raspberrypi systemd[1]: Started Light Display Manager.
Nov 29 02:57:26 raspberrypi systemd[1]: Reloading.
Nov 29 02:57:26 raspberrypi resize2fs_once[242]: .
Nov 29 02:57:27 raspberrypi systemd[1]: apt-daily.timer: Adding 7h 32min 53.854089s random time.
Nov 29 02:57:27 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 3min 41.185945s random time.
Nov 29 02:57:27 raspberrypi systemd[1]: Created slice User Slice of pi.
Nov 29 02:57:27 raspberrypi systemd[1]: Starting User Manager for UID 1000...
Nov 29 02:57:27 raspberrypi systemd[1]: Started Session c1 of user pi.
Nov 29 02:57:28 raspberrypi systemd[491]: Starting D-Bus User Message Bus Socket.
Nov 29 02:57:28 raspberrypi systemd[491]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Nov 29 02:57:28 raspberrypi systemd[491]: Reached target Timers.
Nov 29 02:57:28 raspberrypi systemd[491]: Listening on GnuPG cryptographic agent and passphrase cache.
Nov 29 02:57:28 raspberrypi systemd[491]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Nov 29 02:57:28 raspberrypi systemd[491]: Listening on GnuPG cryptographic agent (access for web browsers).
Nov 29 02:57:28 raspberrypi systemd[491]: Reached target Paths.
Nov 29 02:57:29 raspberrypi systemd[491]: Listening on D-Bus User Message Bus Socket.
Nov 29 02:57:29 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Nov 29 02:57:29 raspberrypi systemd[491]: Reached target Sockets.
Nov 29 02:57:29 raspberrypi systemd[491]: Reached target Basic System.
Nov 29 02:57:29 raspberrypi systemd[491]: Reached target Default.
Nov 29 02:57:29 raspberrypi systemd[491]: Startup finished in 864ms.
Nov 29 02:57:29 raspberrypi lightdm[507]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Nov 29 02:57:29 raspberrypi systemd[1]: Started User Manager for UID 1000.
Nov 29 02:57:29 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Nov 29 02:57:29 raspberrypi systemd[1]: Started Turn on SSH if /boot/ssh is present.
Nov 29 02:57:29 raspberrypi systemd[1]: Reached target Multi-User System.
Nov 29 02:57:29 raspberrypi systemd[1]: Reached target Graphical Interface.
Nov 29 02:57:29 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Nov 29 02:57:29 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Nov 29 02:57:30 raspberrypi systemd[1]: Started Session c2 of user pi.
Nov 29 02:57:30 raspberrypi lightdm[366]: Error opening audit socket: Protocol not supported
Nov 29 02:57:30 raspberrypi kernel: [   70.654854] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Nov 29 02:57:30 raspberrypi dhcpcd[355]: wlan0: carrier acquired
Nov 29 02:57:30 raspberrypi systemd[491]: Started D-Bus User Message Bus.
Nov 29 02:57:30 raspberrypi dhcpcd[355]: wlan0: IAID eb:cb:76:07
Nov 29 02:57:30 raspberrypi dhcpcd[355]: wlan0: adding address fe80::26c6:2f1b:ecd0:ca9e
Nov 29 02:57:30 raspberrypi dhcpcd[355]: wlan0: soliciting an IPv6 router
Nov 29 02:57:31 raspberrypi dhcpcd[355]: wlan0: soliciting a DHCP lease
Nov 29 02:57:31 raspberrypi dhcpcd[355]: wlan0: offered 192.168.0.31 from 192.168.0.254
Nov 29 02:57:31 raspberrypi dhcpcd[355]: wlan0: probing address 192.168.0.31/24
Nov 29 02:57:31 raspberrypi avahi-daemon[285]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::26c6:2f1b:ecd0:ca9e.
Nov 29 02:57:31 raspberrypi avahi-daemon[285]: New relevant interface wlan0.IPv6 for mDNS.
Nov 29 02:57:31 raspberrypi avahi-daemon[285]: Registering new address record for fe80::26c6:2f1b:ecd0:ca9e on wlan0.*.
Nov 29 02:57:34 raspberrypi dbus-daemon[542]: Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service'
Nov 29 02:57:34 raspberrypi systemd[491]: Starting Virtual filesystem service...
Nov 29 02:57:34 raspberrypi dbus-daemon[542]: Successfully activated service 'org.gtk.vfs.Daemon'
Nov 29 02:57:34 raspberrypi systemd[491]: Started Virtual filesystem service.
Nov 29 02:57:34 raspberrypi kernel: [   75.232708] fuse init (API version 7.26)
Nov 29 02:57:35 raspberrypi systemd[1]: Mounting FUSE Control File System...
Nov 29 02:57:35 raspberrypi systemd[1]: Mounted FUSE Control File System.
Nov 29 02:57:35 raspberrypi dhcpcd[355]: wlan0: leased 192.168.0.31 for 864000 seconds
Nov 29 02:57:35 raspberrypi avahi-daemon[285]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.31.
Nov 29 02:57:35 raspberrypi dhcpcd[355]: wlan0: adding route to 192.168.0.0/24
Nov 29 02:57:35 raspberrypi dhcpcd[355]: wlan0: adding default route via 192.168.0.254
Nov 29 02:57:35 raspberrypi avahi-daemon[285]: New relevant interface wlan0.IPv4 for mDNS.
Nov 29 02:57:35 raspberrypi avahi-daemon[285]: Registering new address record for 192.168.0.31 on wlan0.IPv4.
Nov 29 02:57:37 raspberrypi dbus[251]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
Nov 29 02:57:37 raspberrypi systemd[1]: Starting Authorization Manager...
Nov 29 02:57:38 raspberrypi polkitd[721]: started daemon version 0.105 using authority implementation `local' version `0.105'
Nov 29 02:57:38 raspberrypi dbus[251]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Nov 29 02:57:38 raspberrypi systemd[1]: Started Authorization Manager.
Nov 29 02:57:44 raspberrypi dhcpcd[355]: wlan0: no IPv6 Routers available
Nov 29 02:57:51 raspberrypi dbus-daemon[542]: Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service'
Nov 29 02:57:51 raspberrypi systemd[491]: Starting Virtual filesystem service - disk device monitor...
Nov 29 02:57:51 raspberrypi dbus[251]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
Nov 29 02:57:51 raspberrypi systemd[1]: Starting Disk Manager...
Nov 29 02:57:51 raspberrypi udisksd[759]: udisks daemon version 2.1.8 starting
Nov 29 02:57:52 raspberrypi dbus[251]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Nov 29 02:57:52 raspberrypi systemd[1]: Started Disk Manager.
Nov 29 02:57:52 raspberrypi udisksd[759]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Nov 29 02:57:53 raspberrypi dbus-daemon[542]: Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Nov 29 02:57:53 raspberrypi systemd[491]: Started Virtual filesystem service - disk device monitor.
Nov 29 02:57:54 raspberrypi dbus-daemon[542]: Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service'
Nov 29 02:57:54 raspberrypi systemd[491]: Starting Virtual filesystem service - digital camera monitor...
Nov 29 02:57:54 raspberrypi dbus-daemon[542]: Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Nov 29 02:57:54 raspberrypi systemd[491]: Started Virtual filesystem service - digital camera monitor.
Nov 29 02:57:54 raspberrypi dbus-daemon[542]: Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service'
Nov 29 02:57:54 raspberrypi systemd[491]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Nov 29 02:57:54 raspberrypi dbus-daemon[542]: Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Nov 29 02:57:54 raspberrypi systemd[491]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Nov 29 02:57:54 raspberrypi dbus-daemon[542]: Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service'
Nov 29 02:57:54 raspberrypi systemd[491]: Starting Virtual filesystem service - Apple File Conduit monitor...
Nov 29 02:57:54 raspberrypi gvfs-afc-volume-monitor[781]: Volume monitor alive
Nov 29 02:57:54 raspberrypi dbus-daemon[542]: Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Nov 29 02:57:54 raspberrypi systemd[491]: Started Virtual filesystem service - Apple File Conduit monitor.
Nov 29 02:57:54 raspberrypi dbus-daemon[542]: Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service'
Nov 29 02:57:54 raspberrypi systemd[491]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
Nov 29 02:57:55 raspberrypi dbus-daemon[542]: Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
Nov 29 02:57:55 raspberrypi systemd[491]: Started Virtual filesystem service - GNOME Online Accounts monitor.
Nov 29 02:58:02 raspberrypi systemd[1]: resize2fs_once.service: Start operation timed out. Terminating.
Nov 29 02:58:02 raspberrypi systemd[1]: Failed to start resize2fs_once.service.
Nov 29 02:58:02 raspberrypi systemd[1]: Startup finished in 1.504s (kernel) + 1min 41.264s (userspace) = 1min 42.768s.
Nov 29 02:58:02 raspberrypi systemd[1]: resize2fs_once.service: Unit entered failed state.
Nov 29 02:58:02 raspberrypi systemd[1]: resize2fs_once.service: Failed with result 'timeout'.
Fri Feb 09, 2018 4:04 pm
Are you able to connect the Zero W to a TV/Monitor and keyboard, or get console access via the UART or USB-to-Serial ?
A USB-to-Ethernet adapter and a hard-wired connection may also work but probably preferable to not alter the network characteristics.
Having interactive access to the Zero W when booted but not connected will allow the issue to be better investigated than it being a black box one can only investigate by swapping SD cards and looking at logs. Logs only reveal what happened, not what is going on.
That's a little safer too as I am guessing you are having to just pull the power if you don't have access and a means to issue a proper shutdown.
carriba
Contact: ICQ
Fri Feb 09, 2018 4:05 pm
Here the entire "/var/log/syslog" file after NTP synchronisation and OS packages installation (2nd part and follows directly the 1st part from my previous post - no gaps):
Feb  9 12:57:39 raspberrypi systemd[491]: Time has been changed
Feb  9 12:57:39 raspberrypi systemd[1]: Time has been changed
Feb  9 12:57:39 raspberrypi systemd[1]: apt-daily.timer: Adding 8h 56min 29.740439s random time.
Feb  9 12:57:39 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 54min 53.614208s random time.
Feb  9 12:57:39 raspberrypi systemd-timesyncd[205]: Synchronized to time server 193.200.43.105:123 (2.debian.pool.ntp.org).
Feb  9 13:00:30 raspberrypi systemd[1]: Started Session c3 of user pi.
Feb  9 13:10:56 raspberrypi systemd[1]: Starting Cleanup of Temporary Directories...
Feb  9 13:10:56 raspberrypi systemd[1]: Started Cleanup of Temporary Directories.
Feb  9 13:17:01 raspberrypi CRON[916]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Feb  9 13:52:40 raspberrypi dbus[251]: [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service'
Feb  9 13:52:40 raspberrypi systemd[1]: Starting PackageKit Daemon...
Feb  9 13:52:40 raspberrypi PackageKit: daemon start
Feb  9 13:52:40 raspberrypi dbus[251]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Feb  9 13:52:40 raspberrypi systemd[1]: Started PackageKit Daemon.
Feb  9 13:57:57 raspberrypi systemd[1]: Reloading.
Feb  9 13:57:58 raspberrypi systemd[1]: apt-daily.timer: Adding 6h 14min 49.286199s random time.
Feb  9 13:57:58 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 57min 18.604032s random time.
Feb  9 13:58:51 raspberrypi systemd[1]: Reloading.
Feb  9 13:58:52 raspberrypi systemd[1]: apt-daily.timer: Adding 7h 39min 32.041793s random time.
Feb  9 13:58:52 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 40min 25.537537s random time.
Feb  9 13:59:08 raspberrypi systemd[1]: Reloading.
Feb  9 13:59:10 raspberrypi systemd[1]: apt-daily.timer: Adding 1h 39min 32.266044s random time.
Feb  9 13:59:10 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 18.759845s random time.
Feb  9 14:01:19 raspberrypi systemd[1]: Reloading.
Feb  9 14:01:20 raspberrypi systemd[1]: apt-daily.timer: Adding 6h 18min 36.028031s random time.
Feb  9 14:01:20 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 23.333810s random time.
Feb  9 14:01:20 raspberrypi systemd[1]: Reloading.
Feb  9 14:01:22 raspberrypi systemd[1]: apt-daily.timer: Adding 4h 58min 54.758684s random time.
Feb  9 14:01:22 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 20min 9.925487s random time.
Feb  9 14:01:22 raspberrypi systemd[1]: Reloading.
Feb  9 14:01:23 raspberrypi systemd[1]: apt-daily.timer: Adding 8h 15min 28.806022s random time.
Feb  9 14:01:23 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 20min 5.515781s random time.
Feb  9 14:01:23 raspberrypi systemd[1]: Reloading.
Feb  9 14:01:24 raspberrypi systemd[1]: apt-daily.timer: Adding 11h 32min 6.233690s random time.
Feb  9 14:01:24 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 36min 52.139697s random time.
Feb  9 14:01:25 raspberrypi systemd[1]: Reloading.
Feb  9 14:01:26 raspberrypi systemd[1]: apt-daily.timer: Adding 26min 56.687410s random time.
Feb  9 14:01:26 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 52min 59.073500s random time.
Feb  9 14:01:26 raspberrypi systemd[1]: Reloading.
Feb  9 14:01:27 raspberrypi systemd[1]: apt-daily.timer: Adding 11h 52min 53.203552s random time.
Feb  9 14:01:27 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 39min 18.906354s random time.
Feb  9 14:01:27 raspberrypi systemd[1]: Reloading.
Feb  9 14:01:28 raspberrypi systemd[1]: apt-daily.timer: Adding 36min 58.984756s random time.
Feb  9 14:01:28 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 4min 22.204763s random time.
Feb  9 14:01:29 raspberrypi systemd[1]: Reloading.
Feb  9 14:01:30 raspberrypi systemd[1]: apt-daily.timer: Adding 5h 15min 35.544596s random time.
Feb  9 14:01:30 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 52min 32.276043s random time.
Feb  9 14:01:30 raspberrypi systemd[1]: Reloading.
Feb  9 14:01:32 raspberrypi systemd[1]: apt-daily.timer: Adding 1h 57min 48.518078s random time.
Feb  9 14:01:32 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 38min 23.118097s random time.
Feb  9 14:01:36 raspberrypi systemd[1]: Reloading.
Feb  9 14:01:37 raspberrypi systemd[1]: apt-daily.timer: Adding 4h 14min 15.135772s random time.
Feb  9 14:01:37 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 13min 15.384137s random time.
Feb  9 14:04:19 raspberrypi systemd[1]: Reloading.
Feb  9 14:04:20 raspberrypi systemd[1]: apt-daily.timer: Adding 7h 45min 17.055579s random time.
Feb  9 14:04:20 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 3min 28.549243s random time.
Feb  9 14:04:21 raspberrypi systemd[1]: Reloading.
Feb  9 14:04:22 raspberrypi systemd[1]: apt-daily.timer: Adding 6h 10min 34.147219s random time.
Feb  9 14:04:22 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 51min 33.974232s random time.
Feb  9 14:04:23 raspberrypi systemd[1]: Reloading.
Feb  9 14:04:24 raspberrypi systemd[1]: apt-daily.timer: Adding 1h 5min 55.698188s random time.
Feb  9 14:04:24 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 51min 40.405266s random time.
Feb  9 14:04:25 raspberrypi systemd[1]: Reloading.
Feb  9 14:04:26 raspberrypi systemd[1]: apt-daily.timer: Adding 3h 55min 41.041549s random time.
Feb  9 14:04:26 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 2min 50.964204s random time.
Feb  9 14:04:30 raspberrypi systemd[1]: Reloading.
Feb  9 14:04:31 raspberrypi systemd[1]: apt-daily.timer: Adding 10h 14min 50.060982s random time.
Feb  9 14:04:31 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 8min 34.368592s random time.
Feb  9 14:04:47 raspberrypi systemd[1]: Reloading.
Feb  9 14:04:48 raspberrypi systemd[1]: apt-daily.timer: Adding 8h 20min 68.715ms random time.
Feb  9 14:04:48 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 20min 13.087552s random time.
Feb  9 14:08:14 raspberrypi systemd[1]: Reloading.
Feb  9 14:08:16 raspberrypi systemd[1]: apt-daily.timer: Adding 7h 26min 52.194833s random time.
Feb  9 14:08:18 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 19min 13.083669s random time.
Feb  9 14:08:22 raspberrypi systemd[1]: Reloading.
Feb  9 14:08:23 raspberrypi systemd[1]: apt-daily.timer: Adding 9h 42min 10.501469s random time.
Feb  9 14:08:23 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 46min 43.348049s random time.
Feb  9 14:08:31 raspberrypi dbus[251]: [system] Reloaded configuration
Feb  9 14:09:09 raspberrypi systemd[1]: Reloading.
Feb  9 14:09:10 raspberrypi systemd[1]: apt-daily.timer: Adding 6h 44min 48.409776s random time.
Feb  9 14:09:10 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 7min 11.350279s random time.
Feb  9 14:09:10 raspberrypi systemd[1]: Reloading.
Feb  9 14:09:12 raspberrypi systemd[1]: apt-daily.timer: Adding 2h 49min 38.220256s random time.
Feb  9 14:09:12 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 50min 57.957154s random time.
Feb  9 14:09:12 raspberrypi systemd[1]: Stopping OpenBSD Secure Shell server...
Feb  9 14:09:12 raspberrypi systemd[1]: Stopped OpenBSD Secure Shell server.
Feb  9 14:09:12 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Feb  9 14:09:13 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Feb  9 14:17:01 raspberrypi CRON[20281]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Feb  9 14:29:10 raspberrypi systemd[1]: Stopping Session c2 of user pi.
Feb  9 14:29:10 raspberrypi systemd[1]: Unmounting RPC Pipe File System...
Feb  9 14:29:10 raspberrypi systemd[1]: Stopped target Graphical Interface.
Feb  9 14:29:10 raspberrypi systemd[1]: Stopping BluezALSA proxy...
Feb  9 14:29:10 raspberrypi systemd[1]: Stopping Session c3 of user pi.
Feb  9 14:29:10 raspberrypi systemd[1]: Stopping PackageKit Daemon...
Feb  9 14:29:10 raspberrypi systemd[1]: Stopping Session c1 of user pi.
Feb  9 14:29:10 raspberrypi systemd[1]: Stopped target Timers.
Feb  9 14:29:10 raspberrypi systemd[1]: Stopped target Bluetooth.
Feb  9 14:29:10 raspberrypi systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Feb  9 14:29:10 raspberrypi systemd[1]: Stopping User Manager for UID 1000...
Feb  9 14:29:10 raspberrypi systemd[1]: Stopping Light Display Manager...
Feb  9 14:29:10 raspberrypi systemd[1]: Stopped target Multi-User System.
Feb  9 14:29:10 raspberrypi systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
Feb  9 14:29:28 raspberrypi systemd-modules-load[105]: Inserted module 'i2c_dev'
Feb  9 14:29:28 raspberrypi fake-hwclock[92]: Fri  9 Feb 14:29:18 UTC 2018
Feb  9 14:29:28 raspberrypi systemd-fsck[102]: e2fsck 1.43.4 (31-Jan-2017)
Feb  9 14:29:28 raspberrypi systemd[1]: Mounted Configuration File System.
Feb  9 14:29:28 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
Feb  9 14:29:28 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
Feb  9 14:29:28 raspberrypi systemd-fsck[102]: rootfs: clean, 143033/965760 files, 1209376/3899648 blocks
Feb  9 14:29:28 raspberrypi systemd[1]: Started File System Check on Root Device.
Feb  9 14:29:28 raspberrypi systemd[1]: Started Apply Kernel Variables.
Feb  9 14:29:28 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
Feb  9 14:29:28 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
Feb  9 14:29:28 raspberrypi systemd[1]: Starting Load/Save Random Seed...
Feb  9 14:29:28 raspberrypi systemd[1]: Starting udev Coldplug all Devices...
Feb  9 14:29:28 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
Feb  9 14:29:28 raspberrypi systemd[1]: Started udev Kernel Device Manager.
Feb  9 14:29:28 raspberrypi systemd[1]: Started Load/Save Random Seed.
Feb  9 14:29:28 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
Feb  9 14:29:28 raspberrypi systemd[1]: Started Set the console keyboard layout.
Feb  9 14:29:28 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
Feb  9 14:29:28 raspberrypi systemd[1]: Started udev Coldplug all Devices.
Feb  9 14:29:28 raspberrypi systemd[1]: Starting Show Plymouth Boot Screen...
Feb  9 14:29:28 raspberrypi systemd[1]: Started Show Plymouth Boot Screen.
Feb  9 14:29:28 raspberrypi systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Feb  9 14:29:28 raspberrypi systemd[1]: Reached target Encrypted Volumes.
Feb  9 14:29:28 raspberrypi systemd[1]: Reached target Paths.
Feb  9 14:29:28 raspberrypi systemd[1]: Received SIGRTMIN+20 from PID 151 (plymouthd).
Feb  9 14:29:28 raspberrypi systemd[1]: Found device /dev/serial1.
Feb  9 14:29:28 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/e7f04ac3-01.
Feb  9 14:29:28 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/e7f04ac3-01...
Feb  9 14:29:28 raspberrypi systemd-fsck[170]: fsck.fat 4.1 (2017-01-24)
Feb  9 14:29:28 raspberrypi systemd-fsck[170]: /dev/mmcblk0p1: 152 files, 42765/83705 clusters
Feb  9 14:29:28 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/e7f04ac3-01.
Feb  9 14:29:28 raspberrypi systemd[1]: Mounting /boot...
Feb  9 14:29:28 raspberrypi systemd[1]: Mounted /boot.
Feb  9 14:29:28 raspberrypi systemd[1]: Reached target Local File Systems.
Feb  9 14:29:28 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
Feb  9 14:29:28 raspberrypi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Feb  9 14:29:28 raspberrypi systemd[1]: Starting Set console font and keymap...
Feb  9 14:29:28 raspberrypi systemd[1]: Starting Raise network interfaces...
Feb  9 14:29:28 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
Feb  9 14:29:28 raspberrypi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Feb  9 14:29:28 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Feb  9 14:29:28 raspberrypi systemd[1]: Started Set console font and keymap.
Feb  9 14:29:28 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Feb  9 14:29:28 raspberrypi systemd[1]: Starting Network Time Synchronization...
Feb  9 14:29:28 raspberrypi systemd[1]: Started Preprocess NFS configuration.
Feb  9 14:29:28 raspberrypi systemd[1]: Reached target NFS client services.
Feb  9 14:29:28 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
Feb  9 14:29:28 raspberrypi systemd[1]: Reached target Remote File Systems.
Feb  9 14:29:28 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Feb  9 14:29:28 raspberrypi systemd[1]: Started Network Time Synchronization.
Feb  9 14:29:28 raspberrypi systemd[1]: Reached target System Initialization.
Feb  9 14:29:28 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Feb  9 14:29:28 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Feb  9 14:29:28 raspberrypi systemd[1]: Listening on triggerhappy.socket.
Feb  9 14:29:28 raspberrypi systemd[1]: Reached target Sockets.
Feb  9 14:29:28 raspberrypi systemd[1]: Reached target Basic System.
Feb  9 14:29:28 raspberrypi systemd[1]: Started D-Bus System Message Bus.
Feb  9 14:29:28 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Feb  9 14:29:28 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Feb  9 14:29:28 raspberrypi systemd[1]: Starting Check for v3d driver...
Feb  9 14:29:28 raspberrypi systemd[1]: Starting LSB: Autogenerate and use a swap file...
Feb  9 14:29:28 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Feb  9 14:29:28 raspberrypi avahi-daemon[232]: Found user 'avahi' (UID 108) and group 'avahi' (GID 112).
Feb  9 14:29:28 raspberrypi avahi-daemon[232]: Successfully dropped root privileges.
Feb  9 14:29:28 raspberrypi systemd[1]: Starting System Logging Service...
Feb  9 14:29:28 raspberrypi avahi-daemon[232]: avahi-daemon 0.6.32 starting up.
Feb  9 14:29:28 raspberrypi avahi-daemon[232]: Successfully called chroot().
Feb  9 14:29:28 raspberrypi avahi-daemon[232]: Successfully dropped remaining capabilities.
Feb  9 14:29:28 raspberrypi avahi-daemon[232]: No service file found in /etc/avahi/services.
Feb  9 14:29:28 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Feb  9 14:29:28 raspberrypi avahi-daemon[232]: Network interface enumeration completed.
Feb  9 14:29:28 raspberrypi avahi-daemon[232]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 3872557626.
Feb  9 14:29:28 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
Feb  9 14:29:28 raspberrypi systemd[1]: Started Regular background program processing daemon.
Feb  9 14:29:28 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
Feb  9 14:29:28 raspberrypi cron[256]: (CRON) INFO (pidfile fd = 3)
Feb  9 14:29:28 raspberrypi thd[252]: Found socket passed from systemd
Feb  9 14:29:28 raspberrypi systemd[1]: Starting Login Service...
Feb  9 14:29:28 raspberrypi liblogging-stdlog:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="243" x-info="http://www.rsyslog.com"] start
Feb  9 14:29:28 raspberrypi systemd[1]: Reached target System Time Synchronized.
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] Linux version 4.9.79+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1091 Tue Feb 6 12:58:13 GMT 2018
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] cma: Reserved 8 MiB at 0x1b400000
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] Memory policy: Data cache writeback
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] On node 0 totalpages: 114688
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] free_area_init_node: node 0, pgdat c091ae38, node_mem_map db010000
Feb  9 14:29:28 raspberrypi kernel: [    0.000000]   Normal zone: 1008 pages used for memmap
Feb  9 14:29:28 raspberrypi kernel: [    0.000000]   Normal zone: 0 pages reserved
Feb  9 14:29:28 raspberrypi kernel: [    0.000000]   Normal zone: 114688 pages, LIFO batch:31
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] pcpu-alloc: [0] 0
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 113680
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:9E:23:52 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=e7f04ac3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] Memory: 435920K/458752K available (5960K kernel code, 491K rwdata, 1952K rodata, 404K init, 725K bss, 14640K reserved, 8192K cma-reserved)
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] Virtual kernel memory layout:
Feb  9 14:29:28 raspberrypi kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Feb  9 14:29:28 raspberrypi kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Feb  9 14:29:28 raspberrypi kernel: [    0.000000]     vmalloc : 0xdc800000 - 0xff800000   ( 560 MB)
Feb  9 14:29:28 raspberrypi kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
Feb  9 14:29:28 raspberrypi kernel: [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
Feb  9 14:29:28 raspberrypi kernel: [    0.000000]       .text : 0xc0008000 - 0xc05da250   (5961 kB)
Feb  9 14:29:28 raspberrypi kernel: [    0.000000]       .init : 0xc0845000 - 0xc08aa000   ( 404 kB)
Feb  9 14:29:28 raspberrypi kernel: [    0.000000]       .data : 0xc08aa000 - 0xc0924f88   ( 492 kB)
Feb  9 14:29:28 raspberrypi kernel: [    0.000000]        .bss : 0xc0924f88 - 0xc09da688   ( 726 kB)
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Feb  9 14:29:28 raspberrypi kernel: [    0.000000] NR_IRQS:16 nr_irqs:16 16
Feb  9 14:29:28 raspberrypi kernel: [    0.000030] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
Feb  9 14:29:28 raspberrypi kernel: [    0.000060] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
Feb  9 14:29:28 raspberrypi kernel: [    0.000149] bcm2835: system timer (irq = 27)
Feb  9 14:29:28 raspberrypi kernel: [    0.000623] Console: colour dummy device 80x30
Feb  9 14:29:28 raspberrypi kernel: [    0.000648] console [tty1] enabled
Feb  9 14:29:28 raspberrypi kernel: [    0.000674] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Feb  9 14:29:28 raspberrypi kernel: [    0.060305] pid_max: default: 32768 minimum: 301
Feb  9 14:29:28 raspberrypi kernel: [    0.060731] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Feb  9 14:29:28 raspberrypi kernel: [    0.060748] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Feb  9 14:29:28 raspberrypi kernel: [    0.061971] Disabling memory control group subsystem
Feb  9 14:29:28 raspberrypi kernel: [    0.062103] CPU: Testing write buffer coherency: ok
Feb  9 14:29:28 raspberrypi kernel: [    0.062164] ftrace: allocating 21725 entries in 64 pages
Feb  9 14:29:28 raspberrypi kernel: [    0.178074] Setting up static identity map for 0x8200 - 0x8238
Feb  9 14:29:28 raspberrypi kernel: [    0.180031] devtmpfs: initialized
Feb  9 14:29:28 raspberrypi kernel: [    0.189209] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Feb  9 14:29:28 raspberrypi kernel: [    0.189620] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Feb  9 14:29:28 raspberrypi kernel: [    0.189646] futex hash table entries: 256 (order: -1, 3072 bytes)
Feb  9 14:29:28 raspberrypi kernel: [    0.190901] pinctrl core: initialized pinctrl subsystem
Feb  9 14:29:28 raspberrypi kernel: [    0.192319] NET: Registered protocol family 16
Feb  9 14:29:28 raspberrypi kernel: [    0.194876] DMA: preallocated 1024 KiB pool for atomic coherent allocations
Feb  9 14:29:28 raspberrypi kernel: [    0.204609] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Feb  9 14:29:28 raspberrypi kernel: [    0.204625] hw-breakpoint: maximum watchpoint size is 4 bytes.
Feb  9 14:29:28 raspberrypi kernel: [    0.204728] Serial: AMBA PL011 UART driver
Feb  9 14:29:28 raspberrypi kernel: [    0.207532] bcm2835-mbox 2000b880.mailbox: mailbox enabled
Feb  9 14:29:28 raspberrypi kernel: [    0.208372] uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
Feb  9 14:29:28 raspberrypi kernel: [    0.255632] bcm2835-dma 20007000.dma: DMA legacy API manager at dc80d000, dmachans=0x1
Feb  9 14:29:28 raspberrypi kernel: [    0.258331] SCSI subsystem initialized
Feb  9 14:29:28 raspberrypi kernel: [    0.258595] usbcore: registered new interface driver usbfs
Feb  9 14:29:28 raspberrypi kernel: [    0.258713] usbcore: registered new interface driver hub
Feb  9 14:29:28 raspberrypi kernel: [    0.258920] usbcore: registered new device driver usb
Feb  9 14:29:28 raspberrypi kernel: [    0.268137] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-02-07 17:35
Feb  9 14:29:28 raspberrypi kernel: [    0.270111] clocksource: Switched to clocksource timer
Feb  9 14:29:28 raspberrypi kernel: [    0.324009] VFS: Disk quotas dquot_6.6.0
Feb  9 14:29:28 raspberrypi kernel: [    0.324126] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Feb  9 14:29:28 raspberrypi kernel: [    0.324432] FS-Cache: Loaded
Feb  9 14:29:28 raspberrypi kernel: [    0.324784] CacheFiles: Loaded
Feb  9 14:29:28 raspberrypi kernel: [    0.343823] NET: Registered protocol family 2
Feb  9 14:29:28 raspberrypi kernel: [    0.345157] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
Feb  9 14:29:28 raspberrypi kernel: [    0.345247] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Feb  9 14:29:28 raspberrypi kernel: [    0.345342] TCP: Hash tables configured (established 4096 bind 4096)
Feb  9 14:29:28 raspberrypi kernel: [    0.345442] UDP hash table entries: 256 (order: 0, 4096 bytes)
Feb  9 14:29:28 raspberrypi kernel: [    0.345469] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Feb  9 14:29:28 raspberrypi kernel: [    0.345775] NET: Registered protocol family 1
Feb  9 14:29:28 raspberrypi kernel: [    0.346510] RPC: Registered named UNIX socket transport module.
Feb  9 14:29:28 raspberrypi kernel: [    0.346521] RPC: Registered udp transport module.
Feb  9 14:29:28 raspberrypi kernel: [    0.346525] RPC: Registered tcp transport module.
Feb  9 14:29:28 raspberrypi kernel: [    0.346530] RPC: Registered tcp NFSv4.1 backchannel transport module.
Feb  9 14:29:28 raspberrypi kernel: [    0.347764] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
Feb  9 14:29:28 raspberrypi kernel: [    0.350226] workingset: timestamp_bits=14 max_order=17 bucket_order=3
Feb  9 14:29:28 raspberrypi kernel: [    0.369585] FS-Cache: Netfs 'nfs' registered for caching
Feb  9 14:29:28 raspberrypi kernel: [    0.371395] NFS: Registering the id_resolver key type
Feb  9 14:29:28 raspberrypi kernel: [    0.371441] Key type id_resolver registered
Feb  9 14:29:28 raspberrypi kernel: [    0.371448] Key type id_legacy registered
Feb  9 14:29:28 raspberrypi kernel: [    0.375834] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Feb  9 14:29:28 raspberrypi kernel: [    0.376207] io scheduler noop registered
Feb  9 14:29:28 raspberrypi kernel: [    0.376221] io scheduler deadline registered (default)
Feb  9 14:29:28 raspberrypi kernel: [    0.376651] io scheduler cfq registered
Feb  9 14:29:28 raspberrypi kernel: [    0.382646] BCM2708FB: allocated DMA memory 5b500000
Feb  9 14:29:28 raspberrypi kernel: [    0.382705] BCM2708FB: allocated DMA channel 0 @ dc80d000
Feb  9 14:29:28 raspberrypi kernel: [    0.390875] Console: switching to colour frame buffer device 82x26
Feb  9 14:29:28 raspberrypi kernel: [    0.398429] bcm2835-rng 20104000.rng: hwrng registered
Feb  9 14:29:28 raspberrypi kernel: [    0.398593] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
Feb  9 14:29:28 raspberrypi kernel: [    0.399539] vc-sm: Videocore shared memory driver
Feb  9 14:29:28 raspberrypi kernel: [    0.423960] brd: module loaded
Feb  9 14:29:28 raspberrypi kernel: [    0.436138] loop: module loaded
Feb  9 14:29:28 raspberrypi kernel: [    0.436160] Loading iSCSI transport class v2.0-870.
Feb  9 14:29:28 raspberrypi kernel: [    0.437039] usbcore: registered new interface driver smsc95xx
Feb  9 14:29:28 raspberrypi kernel: [    0.437068] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Feb  9 14:29:28 raspberrypi kernel: [    0.665426] Core Release: 2.80a
Feb  9 14:29:28 raspberrypi kernel: [    0.665451] Setting default values for core params
Feb  9 14:29:28 raspberrypi kernel: [    0.665490] Finished setting default values for core params
Feb  9 14:29:28 raspberrypi kernel: [    0.865877] Using Buffer DMA mode
Feb  9 14:29:28 raspberrypi kernel: [    0.865890] Periodic Transfer Interrupt Enhancement - disabled
Feb  9 14:29:28 raspberrypi kernel: [    0.865895] Multiprocessor Interrupt Enhancement - disabled
Feb  9 14:29:28 raspberrypi kernel: [    0.865904] OTG VER PARAM: 0, OTG VER FLAG: 0
Feb  9 14:29:28 raspberrypi kernel: [    0.865993] Dedicated Tx FIFOs mode
Feb  9 14:29:28 raspberrypi kernel: [    0.866588] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xdb514000 dma = 0x5b514000 len=9024
Feb  9 14:29:28 raspberrypi kernel: [    0.866616] FIQ FSM acceleration enabled for :
Feb  9 14:29:28 raspberrypi kernel: [    0.866616] Non-periodic Split Transactions
Feb  9 14:29:28 raspberrypi kernel: [    0.866616] Periodic Split Transactions
Feb  9 14:29:28 raspberrypi kernel: [    0.866616] High-Speed Isochronous Endpoints
Feb  9 14:29:28 raspberrypi kernel: [    0.866616] Interrupt/Control Split Transaction hack enabled
Feb  9 14:29:28 raspberrypi kernel: [    0.866627] dwc_otg: Microframe scheduler enabled
Feb  9 14:29:28 raspberrypi kernel: [    0.866710] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc04534d8
Feb  9 14:29:28 raspberrypi kernel: [    0.866723] WARN::hcd_init_fiq:460: FIQ ASM at 0xc04537b4 length 36
Feb  9 14:29:28 raspberrypi kernel: [    0.866748] WARN::hcd_init_fiq:486: MPHI regs_base at 0xdc8a5000
Feb  9 14:29:28 raspberrypi kernel: [    0.866819] dwc_otg 20980000.usb: DWC OTG Controller
Feb  9 14:29:28 raspberrypi kernel: [    0.866882] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
Feb  9 14:29:28 raspberrypi kernel: [    0.867001] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
Feb  9 14:29:28 raspberrypi kernel: [    0.867055] Init: Port Power? op_state=1
Feb  9 14:29:28 raspberrypi kernel: [    0.867062] Init: Power Port (0)
Feb  9 14:29:28 raspberrypi kernel: [    0.867420] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Feb  9 14:29:28 raspberrypi kernel: [    0.867437] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb  9 14:29:28 raspberrypi kernel: [    0.867448] usb usb1: Product: DWC OTG Controller
Feb  9 14:29:28 raspberrypi kernel: [    0.867458] usb usb1: Manufacturer: Linux 4.9.79+ dwc_otg_hcd
Feb  9 14:29:28 raspberrypi kernel: [    0.867467] usb usb1: SerialNumber: 20980000.usb
Feb  9 14:29:28 raspberrypi kernel: [    0.868614] hub 1-0:1.0: USB hub found
Feb  9 14:29:28 raspberrypi kernel: [    0.868701] hub 1-0:1.0: 1 port detected
Feb  9 14:29:28 raspberrypi kernel: [    0.869588] dwc_otg: FIQ enabled
Feb  9 14:29:28 raspberrypi kernel: [    0.869596] dwc_otg: NAK holdoff enabled
Feb  9 14:29:28 raspberrypi kernel: [    0.869603] dwc_otg: FIQ split-transaction FSM enabled
Feb  9 14:29:28 raspberrypi kernel: [    0.869623] Module dwc_common_port init
Feb  9 14:29:28 raspberrypi kernel: [    0.870215] usbcore: registered new interface driver usb-storage
Feb  9 14:29:28 raspberrypi kernel: [    0.870688] mousedev: PS/2 mouse device common for all mice
Feb  9 14:29:28 raspberrypi kernel: [    0.872342] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
Feb  9 14:29:28 raspberrypi kernel: [    0.872853] bcm2835-cpufreq: min=700000 max=1000000
Feb  9 14:29:28 raspberrypi kernel: [    0.873484] sdhci: Secure Digital Host Controller Interface driver
Feb  9 14:29:28 raspberrypi kernel: [    0.873493] sdhci: Copyright(c) Pierre Ossman
Feb  9 14:29:28 raspberrypi kernel: [    0.873957] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
Feb  9 14:29:28 raspberrypi kernel: [    0.876368] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
Feb  9 14:29:28 raspberrypi kernel: [    0.876532] sdhci-pltfm: SDHCI platform and OF driver helper
Feb  9 14:29:28 raspberrypi kernel: [    0.877021] ledtrig-cpu: registered to indicate activity on CPUs
Feb  9 14:29:28 raspberrypi kernel: [    0.877168] hidraw: raw HID events driver (C) Jiri Kosina
Feb  9 14:29:28 raspberrypi kernel: [    0.877448] usbcore: registered new interface driver usbhid
Feb  9 14:29:28 raspberrypi kernel: [    0.877455] usbhid: USB HID core driver
Feb  9 14:29:28 raspberrypi kernel: [    0.878649] vchiq: vchiq_init_state: slot_zero = 0xdb580000, is_master = 0
Feb  9 14:29:28 raspberrypi kernel: [    0.880481] [vc_sm_connected_init]: start
Feb  9 14:29:28 raspberrypi kernel: [    0.889922] [vc_sm_connected_init]: end - returning 0
Feb  9 14:29:28 raspberrypi kernel: [    0.890501] Initializing XFRM netlink socket
Feb  9 14:29:28 raspberrypi kernel: [    0.890545] NET: Registered protocol family 17
Feb  9 14:29:28 raspberrypi kernel: [    0.890704] Key type dns_resolver registered
Feb  9 14:29:28 raspberrypi kernel: [    0.892577] registered taskstats version 1
Feb  9 14:29:28 raspberrypi kernel: [    0.901540] uart-pl011 20201000.serial: cts_event_workaround enabled
Feb  9 14:29:28 raspberrypi kernel: [    0.901683] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
Feb  9 14:29:28 raspberrypi kernel: [    0.904095] sdhost: log_buf @ db513000 (5b513000)
Feb  9 14:29:28 raspberrypi kernel: [    0.980184] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Feb  9 14:29:28 raspberrypi kernel: [    0.982764] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
Feb  9 14:29:28 raspberrypi kernel: [    0.982781] mmc-bcm2835 20300000.mmc: DMA channel allocated
Feb  9 14:29:28 raspberrypi kernel: [    1.012401] random: fast init done
Feb  9 14:29:28 raspberrypi kernel: [    1.057501] mmc0: host does not support reading read-only switch, assuming write-enable
Feb  9 14:29:28 raspberrypi kernel: [    1.059566] mmc0: new high speed SDHC card at address b368
Feb  9 14:29:28 raspberrypi kernel: [    1.060336] of_cfs_init
Feb  9 14:29:28 raspberrypi kernel: [    1.060463] of_cfs_init: OK
Feb  9 14:29:28 raspberrypi kernel: [    1.061926] mmcblk0: mmc0:b368 NCard 14.9 GiB
Feb  9 14:29:28 raspberrypi kernel: [    1.068864]  mmcblk0: p1 p2
Feb  9 14:29:28 raspberrypi kernel: [    1.082921] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Feb  9 14:29:28 raspberrypi kernel: [    1.085624] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Feb  9 14:29:28 raspberrypi kernel: [    1.085714] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Feb  9 14:29:28 raspberrypi kernel: [    1.086438] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Feb  9 14:29:28 raspberrypi kernel: [    1.087241] devtmpfs: mounted
Feb  9 14:29:28 raspberrypi kernel: [    1.088538] Freeing unused kernel memory: 404K
Feb  9 14:29:28 raspberrypi kernel: [    1.088546] This architecture does not have kernel memory protection.
Feb  9 14:29:28 raspberrypi kernel: [    1.089381] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Feb  9 14:29:28 raspberrypi kernel: [    1.093424] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Feb  9 14:29:28 raspberrypi kernel: [    1.198518] mmc1: new high speed SDIO card at address 0001
Feb  9 14:29:28 raspberrypi kernel: [    1.797089] NET: Registered protocol family 10
Feb  9 14:29:28 raspberrypi kernel: [    1.812844] ip_tables: (C) 2000-2006 Netfilter Core Team
Feb  9 14:29:28 raspberrypi kernel: [    3.951753] i2c /dev entries driver
Feb  9 14:29:28 raspberrypi kernel: [    5.292970] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Feb  9 14:29:28 raspberrypi kernel: [    8.143273] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
Feb  9 14:29:28 raspberrypi kernel: [    9.140580] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
Feb  9 14:29:28 raspberrypi kernel: [    9.157161] usbcore: registered new interface driver brcmfmac
Feb  9 14:29:28 raspberrypi kernel: [    9.570566] brcmfmac: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
Feb  9 14:29:28 raspberrypi kernel: [    9.571650] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
Feb  9 14:29:28 raspberrypi systemd[1]: apt-daily.timer: Adding 8h 59min 32.551919s random time.
Feb  9 14:29:28 raspberrypi dhcpcd[249]: dev: loaded udev
Feb  9 14:29:28 raspberrypi systemd[1]: Started Daily apt download activities.
Feb  9 14:29:28 raspberrypi dhcpcd[249]: no valid interfaces found
Feb  9 14:29:28 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 40min 44.207896s random time.
Feb  9 14:29:28 raspberrypi cron[256]: (CRON) INFO (Running @reboot jobs)
Feb  9 14:29:28 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Feb  9 14:29:28 raspberrypi dhcpcd[249]: forked to background, child pid 268
Feb  9 14:29:28 raspberrypi systemd[1]: Reached target Timers.
Feb  9 14:29:28 raspberrypi systemd[1]: Started System Logging Service.
Feb  9 14:29:28 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
Feb  9 14:29:28 raspberrypi systemd[1]: Started Check for v3d driver.
Feb  9 14:29:28 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Feb  9 14:29:28 raspberrypi kernel: [   14.082578] uart-pl011 20201000.serial: no DMA platform data
Feb  9 14:29:29 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Feb  9 14:29:29 raspberrypi systemd[1]: Started Login Service.
Feb  9 14:29:29 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Feb  9 14:29:29 raspberrypi dphys-swapfile[236]: Starting dphys-swapfile swapfile setup ...
Feb  9 14:29:29 raspberrypi raspi-config[233]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
Feb  9 14:29:29 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
Feb  9 14:29:29 raspberrypi raspi-config[233]:  No. Switching to ondemand scaling governor.
Feb  9 14:29:29 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Feb  9 14:29:29 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
Feb  9 14:29:29 raspberrypi dphys-swapfile[236]: want /var/swap=100MByte, checking existing: keeping it
Feb  9 14:29:30 raspberrypi systemd[1]: Started Raise network interfaces.
Feb  9 14:29:30 raspberrypi systemd[1]: Reached target Network.
Feb  9 14:29:30 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Feb  9 14:29:30 raspberrypi systemd[1]: Starting Permit User Sessions...
Feb  9 14:29:30 raspberrypi systemd[1]: Reached target Network is Online.
Feb  9 14:29:30 raspberrypi systemd-udevd[134]: Process '/sbin/crda' failed with exit code 249.
Feb  9 14:29:30 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
Feb  9 14:29:30 raspberrypi systemd[1]: Starting Daily apt download activities...
Feb  9 14:29:30 raspberrypi dhcpcd-run-hooks[335]: wlan0: starting wpa_supplicant
Feb  9 14:29:30 raspberrypi kernel: [   15.984994] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SSFS
Feb  9 14:29:30 raspberrypi dphys-swapfile[236]: done.
Feb  9 14:29:30 raspberrypi systemd[1]: Started LSB: Autogenerate and use a swap file.
Feb  9 14:29:30 raspberrypi systemd[1]: Started Permit User Sessions.
Feb  9 14:29:30 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
Feb  9 14:29:30 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
Feb  9 14:29:30 raspberrypi systemd[1]: Starting Light Display Manager...
Feb  9 14:29:30 raspberrypi systemd[1]: Starting Terminate Plymouth Boot Screen...
Feb  9 14:29:31 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 151 (plymouthd).
Feb  9 14:29:31 raspberrypi systemd[1]: Started Hold until boot process finishes up.
Feb  9 14:29:31 raspberrypi systemd[1]: Started Terminate Plymouth Boot Screen.
Feb  9 14:29:31 raspberrypi systemd[1]: Started Getty on tty1.
Feb  9 14:29:31 raspberrypi systemd[1]: Reached target Login Prompts.
Feb  9 14:29:31 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Feb  9 14:29:31 raspberrypi kernel: [   17.185928] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Feb  9 14:29:31 raspberrypi kernel: [   17.185948] brcmfmac: power management disabled
Feb  9 14:29:32 raspberrypi dhcpcd[268]: wlan0: waiting for carrier
Feb  9 14:29:32 raspberrypi dhcpcd[268]: wlan0: carrier acquired
Feb  9 14:29:32 raspberrypi lightdm[357]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Feb  9 14:29:32 raspberrypi dhcpcd[268]: DUID 00:01:00:01:21:b0:de:74:b8:27:eb:cb:76:07
Feb  9 14:29:32 raspberrypi dhcpcd[268]: wlan0: IAID eb:cb:76:07
Feb  9 14:29:32 raspberrypi dhcpcd[268]: wlan0: adding address fe80::a43f:84bf:ab99:1d32
Feb  9 14:29:32 raspberrypi dhcpcd[268]: wlan0: carrier lost
Feb  9 14:29:32 raspberrypi systemd[1]: Started Light Display Manager.
Feb  9 14:29:32 raspberrypi dhcpcd[268]: wlan0: deleting address fe80::a43f:84bf:ab99:1d32
Feb  9 14:29:33 raspberrypi kernel: [   18.630234] Bluetooth: Core ver 2.22
Feb  9 14:29:33 raspberrypi kernel: [   18.630381] NET: Registered protocol family 31
Feb  9 14:29:33 raspberrypi kernel: [   18.630388] Bluetooth: HCI device and connection manager initialized
Feb  9 14:29:33 raspberrypi kernel: [   18.630411] Bluetooth: HCI socket layer initialized
Feb  9 14:29:33 raspberrypi kernel: [   18.630424] Bluetooth: L2CAP socket layer initialized
Feb  9 14:29:33 raspberrypi kernel: [   18.630462] Bluetooth: SCO socket layer initialized
Feb  9 14:29:33 raspberrypi kernel: [   18.658138] Bluetooth: HCI UART driver ver 2.3
Feb  9 14:29:33 raspberrypi kernel: [   18.658155] Bluetooth: HCI UART protocol H4 registered
Feb  9 14:29:33 raspberrypi kernel: [   18.658160] Bluetooth: HCI UART protocol Three-wire (H5) registered
Feb  9 14:29:33 raspberrypi kernel: [   18.658322] Bluetooth: HCI UART protocol Broadcom registered
Feb  9 14:29:33 raspberrypi btuart[241]: bcm43xx_init
Feb  9 14:29:33 raspberrypi btuart[241]: Flash firmware /lib/firmware/BCM43430A1.hcd
Feb  9 14:29:33 raspberrypi btuart[241]: Set BDADDR UART: b8:27:eb:34:89:f8
Feb  9 14:29:33 raspberrypi btuart[241]: Set Controller UART speed to 3000000 bit/s
Feb  9 14:29:33 raspberrypi btuart[241]: Device setup complete
Feb  9 14:29:33 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
Feb  9 14:29:33 raspberrypi systemd[1]: Starting Bluetooth service...
Feb  9 14:29:33 raspberrypi systemd[1]: Reached target Multi-User System.
Feb  9 14:29:33 raspberrypi bluetoothd[416]: Bluetooth daemon 5.43
Feb  9 14:29:33 raspberrypi systemd[1]: Started Bluetooth service.
Feb  9 14:29:33 raspberrypi systemd[1]: Started BluezALSA proxy.
Feb  9 14:29:33 raspberrypi bluetoothd[416]: Starting SDP server
Feb  9 14:29:33 raspberrypi systemd[1]: Reached target Graphical Interface.
Feb  9 14:29:33 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Feb  9 14:29:33 raspberrypi kernel: [   19.369064] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Feb  9 14:29:33 raspberrypi kernel: [   19.369077] Bluetooth: BNEP filters: protocol multicast
Feb  9 14:29:33 raspberrypi kernel: [   19.369104] Bluetooth: BNEP socket layer initialized
Feb  9 14:29:33 raspberrypi bluetoothd[416]: Bluetooth management interface 1.14 initialized
Feb  9 14:29:33 raspberrypi dbus[230]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Feb  9 14:29:33 raspberrypi bluetoothd[416]: Failed to obtain handles for "Service Changed" characteristic
Feb  9 14:29:33 raspberrypi bluetoothd[416]: Sap driver initialization failed.
Feb  9 14:29:33 raspberrypi bluetoothd[416]: sap-server: Operation not permitted (1)
Feb  9 14:29:34 raspberrypi bluetoothd[416]: Endpoint registered: sender=:1.6 path=/A2DP/SBC/Source/1
Feb  9 14:29:34 raspberrypi bluetoothd[416]: Endpoint registered: sender=:1.6 path=/A2DP/SBC/Sink/1
Feb  9 14:29:34 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Feb  9 14:29:34 raspberrypi kernel: [   19.790260] Bluetooth: RFCOMM TTY layer initialized
Feb  9 14:29:34 raspberrypi kernel: [   19.790297] Bluetooth: RFCOMM socket layer initialized
Feb  9 14:29:34 raspberrypi kernel: [   19.790334] Bluetooth: RFCOMM ver 1.11
Feb  9 14:29:34 raspberrypi systemd[1]: Starting Hostname Service...
Feb  9 14:29:34 raspberrypi systemd[1]: Reached target Bluetooth.
Feb  9 14:29:34 raspberrypi dbus[230]: [system] Successfully activated service 'org.freedesktop.hostname1'
Feb  9 14:29:34 raspberrypi systemd[1]: Started Hostname Service.
Feb  9 14:29:37 raspberrypi systemd[1]: Created slice User Slice of pi.
Feb  9 14:29:37 raspberrypi systemd[1]: Starting User Manager for UID 1000...
Feb  9 14:29:37 raspberrypi systemd[1]: Started Session c1 of user pi.
Feb  9 14:29:38 raspberrypi systemd[446]: Listening on GnuPG cryptographic agent (access for web browsers).
Feb  9 14:29:38 raspberrypi systemd[446]: Reached target Timers.
Feb  9 14:29:38 raspberrypi systemd[446]: Reached target Paths.
Feb  9 14:29:38 raspberrypi systemd[446]: Starting D-Bus User Message Bus Socket.
Feb  9 14:29:38 raspberrypi systemd[446]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Feb  9 14:29:38 raspberrypi systemd[446]: Listening on GnuPG cryptographic agent and passphrase cache.
Feb  9 14:29:38 raspberrypi systemd[446]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Feb  9 14:29:38 raspberrypi systemd[446]: Listening on D-Bus User Message Bus Socket.
Feb  9 14:29:38 raspberrypi systemd[446]: Reached target Sockets.
Feb  9 14:29:38 raspberrypi systemd[446]: Reached target Basic System.
Feb  9 14:29:38 raspberrypi systemd[446]: Reached target Default.
Feb  9 14:29:38 raspberrypi systemd[446]: Startup finished in 687ms.
Feb  9 14:29:38 raspberrypi systemd[1]: Started User Manager for UID 1000.
Feb  9 14:29:39 raspberrypi lightdm[468]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Feb  9 14:29:39 raspberrypi systemd[1]: Started Session c2 of user pi.
Feb  9 14:29:40 raspberrypi lightdm[357]: Error opening audit socket: Protocol not supported
Feb  9 14:29:40 raspberrypi systemd[446]: Started D-Bus User Message Bus.
Feb  9 14:29:41 raspberrypi systemd[1]: Started Daily apt download activities.
Feb  9 14:29:41 raspberrypi systemd[1]: apt-daily.timer: Adding 2h 56min 30.154317s random time.
Feb  9 14:29:41 raspberrypi systemd[1]: apt-daily.timer: Adding 1h 43min 58.085224s random time.
Feb  9 14:29:41 raspberrypi systemd[1]: Starting Daily apt upgrade and clean activities...
Feb  9 14:29:47 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Feb  9 14:29:47 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 57min 26.855266s random time.
Feb  9 14:29:47 raspberrypi systemd[1]: Startup finished in 1.500s (kernel) + 31.372s (userspace) = 32.872s.
Feb  9 14:29:Feb  9 14:29:20 raspberrypi systemd-modules-load[107]: Inserted module 'i2c_dev'
Feb  9 14:29:20 raspberrypi fake-hwclock[115]: Fri  9 Feb 14:29:18 UTC 2018
Feb  9 14:29:20 raspberrypi systemd[1]: Time has been changed
Feb  9 14:29:20 raspberrypi systemd[1]: Started Restore / save the current clock.
Feb  9 14:29:20 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
Feb  9 14:29:20 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
Feb  9 14:29:20 raspberrypi systemd-fsck[117]: e2fsck 1.43.4 (31-Jan-2017)
Feb  9 14:29:20 raspberrypi systemd-fsck[117]: Superblock last mount time is in the future.
Feb  9 14:29:20 raspberrypi systemd-fsck[117]: #011(by less than a day, probably due to the hardware clock being incorrectly set)
Feb  9 14:29:20 raspberrypi systemd-fsck[117]: rootfs: clean, 143379/965760 files, 1209441/3899648 blocks
Feb  9 14:29:20 raspberrypi systemd[1]: Started File System Check on Root Device.
Feb  9 14:29:20 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
Feb  9 14:29:20 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
Feb  9 14:29:20 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
Feb  9 14:29:20 raspberrypi systemd[1]: Starting Load/Save Random Seed...
Feb  9 14:29:20 raspberrypi systemd[1]: Starting udev Coldplug all Devices...
Feb  9 14:29:20 raspberrypi systemd[1]: Started udev Kernel Device Manager.
Feb  9 14:29:20 raspberrypi systemd[1]: Started Load/Save Random Seed.
Feb  9 14:29:20 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
Feb  9 14:29:20 raspberrypi systemd[1]: Started Set the console keyboard layout.
Feb  9 14:29:20 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
Feb  9 14:29:20 raspberrypi systemd[1]: Started udev Coldplug all Devices.
Feb  9 14:29:20 raspberrypi systemd[1]: Starting Show Plymouth Boot Screen...
Feb  9 14:29:20 raspberrypi systemd[1]: Started Show Plymouth Boot Screen.
Feb  9 14:29:20 raspberrypi systemd[1]: Reached target Paths.
Feb  9 14:29:20 raspberrypi systemd[1]: Reached target Encrypted Volumes.
Feb  9 14:29:20 raspberrypi systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Feb  9 14:29:20 raspberrypi systemd[1]: Found device /dev/ttyAMA0.
Feb  9 14:29:20 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/e7f04ac3-01.
Feb  9 14:29:20 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/e7f04ac3-01...
Feb  9 14:29:20 raspberrypi mtp-probe: checking bus 1, device 3: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1"
Feb  9 14:29:20 raspberrypi mtp-probe: bus: 1, device: 3 was not an MTP device
Feb  9 14:29:20 raspberrypi systemd-fsck[226]: fsck.fat 4.1 (2017-01-24)
Feb  9 14:29:20 raspberrypi systemd-fsck[226]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Feb  9 14:29:20 raspberrypi systemd-fsck[226]:  Automatically removing dirty bit.
Feb  9 14:29:20 raspberrypi systemd-fsck[226]: Performing changes.
Feb  9 14:29:20 raspberrypi systemd-fsck[226]: /dev/mmcblk0p1: 152 files, 42765/83705 clusters
Feb  9 14:29:20 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/e7f04ac3-01.
Feb  9 14:29:20 raspberrypi systemd[1]: Mounting /boot...
Feb  9 14:29:20 raspberrypi systemd[1]: Mounted /boot.
Feb  9 14:29:20 raspberrypi systemd[1]: Reached target Local File Systems.
Feb  9 14:29:20 raspberrypi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Feb  9 14:29:20 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
Feb  9 14:29:20 raspberrypi systemd[1]: Starting Set console font and keymap...
Feb  9 14:29:20 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
Feb  9 14:29:20 raspberrypi systemd[1]: Starting Raise network interfaces...
Feb  9 14:29:20 raspberrypi systemd[1]: Started Preprocess NFS configuration.
Feb  9 14:29:20 raspberrypi systemd[1]: Reached target NFS client services.
Feb  9 14:29:20 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
Feb  9 14:29:20 raspberrypi systemd[1]: Reached target Remote File Systems.
Feb  9 14:29:20 raspberrypi systemd[1]: Started Set console font and keymap.
Feb  9 14:29:20 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Feb  9 14:29:20 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Feb  9 14:29:20 raspberrypi systemd[1]: Starting Network Time Synchronization...
Feb  9 14:29:20 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Feb  9 14:29:20 raspberrypi systemd[1]: Started Network Time Synchronization.
Feb  9 14:29:20 raspberrypi systemd[1]: Reached target System Time Synchronized.
Feb  9 14:29:20 raspberrypi systemd[1]: Received SIGRTMIN+20 from PID 208 (plymouthd).
Feb  9 14:29:20 raspberrypi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Feb  9 14:29:20 raspberrypi systemd[1]: Reached target System Initialization.
Feb  9 14:29:20 raspberrypi systemd[1]: apt-daily.timer: Adding 7h 24min 41.546744s random time.
Feb  9 14:29:20 raspberrypi systemd[1]: Started Daily apt download activities.
Feb  9 14:29:20 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 47min 44.251394s random time.
Feb  9 14:29:20 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Feb  9 14:29:20 raspberrypi systemd[1]: Listening on triggerhappy.socket.
Feb  9 14:29:20 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Feb  9 14:29:20 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
Feb  9 14:29:20 raspberrypi systemd[1]: Reached target Timers.
Feb  9 14:29:20 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Feb  9 14:29:20 raspberrypi systemd[1]: Reached target Sockets.
Feb  9 14:29:20 raspberrypi systemd[1]: Reached target Basic System.
Feb  9 14:29:20 raspberrypi systemd[1]: Started Regular background program processing daemon.
Feb  9 14:29:20 raspberrypi systemd[1]: Starting System Logging Service...
Feb  9 14:29:20 raspberrypi systemd[1]: Starting LSB: Autogenerate and use a swap file...
Feb  9 14:29:20 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Feb  9 14:29:20 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Feb  9 14:29:20 raspberrypi systemd[1]: Starting Check for v3d driver...
Feb  9 14:29:20 raspberrypi systemd[1]: Started D-Bus System Message Bus.
Feb  9 14:29:20 raspberrypi cron[297]: (CRON) INFO (Running @reboot jobs)
Feb  9 14:29:20 raspberrypi dhcpcd[300]: dev: loaded udev
The line "Feb 9 14:29:20 raspberrypi dhcpcd[300]: dev: loaded udev" is the last line before powering off the device due to inactivity; no access to device with Wifi.
MrEngman
Re: No Wifi connection to Pi Zero W after Raspbian update
Fri Feb 09, 2018 4:14 pm
carriba wrote:
Fri Feb 09, 2018 3:05 pm
Removing the SD card from the Raspberry Pi Zero W device and inserting it into the Raspberry Pi 1 B+ device, I’m able to find the following “/var/log/syslog” entries:
So, here I'm stuck to move further :-(
I fixed my Pi 0 W by disabling IPV6. Your log appears to show wlan0 being assigned an IPV6 address at which point the carrier is then lost.
Have you tried disabling IPV6?
EDIT: missed your previous post so you have disabled IPV6.
carriba
Contact: ICQ
Fri Feb 09, 2018 4:24 pm
pcmanbob wrote:
Fri Feb 09, 2018 3:45 pm
rebooted still connects and accessible on my network using wifi, so unless you pi zero is some how different it must be due to some interaction between your pi zero and your router/wifi access point.
To be more precise: it is a Raspberry Pi Zero WH, the same version as the original W, but has the GPIO headers already soldered on it (just bought it 2 weeks ago) and it has been working just fine before the OS packages updates yesterday.
Fri Feb 09, 2018 4:38 pm
Hmmm. Works ...
Nov 29 02:56:40 raspberrypi dhcpcd[327]: dev: loaded udev
Nov 29 02:56:40 raspberrypi dhcpcd[327]: forked to background, child pid 355
Fails ...
ShiftPlusOne
Fri Feb 09, 2018 5:46 pm
I wonder if there's some race condition between udev and dhcpcd.
Does wifi come up if you run 'sudo systemctl restart dhcpcd'?
Fri Feb 09, 2018 6:09 pm
Digging further into it, it seems the IP assignments coincides with the kernel seeing an ADDRCONF(NETDEV_CHANGE) event after whatever it does initially. When it works ...
Nov 29 02:56:43 raspberrypi dhcpcd-run-hooks[382]: wlan0: starting wpa_supplicant
Nov 29 02:56:46 raspberrypi kernel: [   26.953253] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Nov 29 02:56:49 raspberrypi dhcpcd[355]: wlan0: waiting for carrier
Nov 29 02:56:49 raspberrypi dhcpcd[355]: wlan0: carrier acquired
Nov 29 02:56:52 raspberrypi dhcpcd[355]: DUID 00:01:00:01:21:b0:de:74:b8:27:eb:cb:76:07
Nov 29 02:56:52 raspberrypi dhcpcd[355]: wlan0: IAID eb:cb:76:07
Nov 29 02:56:52 raspberrypi dhcpcd[355]: wlan0: adding address fe80::a43f:84bf:ab99:1d32
Nov 29 02:56:52 raspberrypi dhcpcd[355]: wlan0: carrier lost
Nov 29 02:56:52 raspberrypi dhcpcd[355]: wlan0: deleting address fe80::a43f:84bf:ab99:1d32
  48 seconds later
Nov 29 02:57:30 raspberrypi kernel: [   70.654854] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Nov 29 02:57:30 raspberrypi dhcpcd[355]: wlan0: carrier acquired
Nov 29 02:57:30 raspberrypi dhcpcd[355]: wlan0: IAID eb:cb:76:07
Nov 29 02:57:30 raspberrypi dhcpcd[355]: wlan0: adding address fe80::26c6:2f1b:ecd0:ca9e
Nov 29 02:57:30 raspberrypi dhcpcd[355]: wlan0: soliciting an IPv6 router
Nov 29 02:57:31 raspberrypi dhcpcd[355]: wlan0: soliciting a DHCP lease
Nov 29 02:57:31 raspberrypi dhcpcd[355]: wlan0: offered 192.168.0.31 from 192.168.0.254
  more dhcpcd not shown
When it doesn't work, when 'no valid interfaces found', that ADDRCONF(NETDEV_CHANGE) event never arrives and nor does dhcpcd do anything more until it later reloads udev.
  20 seconds later
So 'no interfaces found' would seem to be the key to me.
Note that when it doesn't work, and that last dhcpcd[300] appears, that's a different PID than earlier on. Not sure what's launching or forking there and couldn't see anyting in the full log related to it.
carriba
Contact: ICQ
Fri Feb 09, 2018 6:34 pm
Thank you for your elaborations, and they do seem to make sense here.
I had a look into the "/var/log/kern.log" file pertaining to kernel etries, and I noticed certain transitions taking place.
Using a fresh Raspbian Stretch image (the one from November 2017), the relevant entries show:
After the OS packages update, I only see one line:
Feb  9 11:45:37 raspberryp kernel: [   17.902183] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Maybe this gives a hint...
Fri Feb 09, 2018 6:37 pm
Could be. There's a whole load of things going on with udev in the one which fails.
Works ...
Nov 29 02:56:34 raspberrypi systemd-udevd[143]: Process '/sbin/crda' failed with exit code 249.
Nov 29 02:57:31 raspberrypi dhcpcd[355]: wlan0: probing address 192.168.0.31/24
Nov 29 02:57:35 raspberrypi dhcpcd[355]: wlan0: leased 192.168.0.31 for 864000 seconds
Nov 29 02:57:35 raspberrypi dhcpcd[355]: wlan0: adding route to 192.168.0.0/24
Nov 29 02:57:35 raspberrypi dhcpcd[355]: wlan0: adding default route via 192.168.0.254
Fails ...
carriba
Contact: ICQ
Fri Feb 09, 2018 6:39 pm
Need to get console access via the GPIO pins using a USB-to-Serial.
Need to look into my drawer, if I find these bits again. It's been a long time that I have used the device's console access.
Will have a look during the weekend... (I think I need to disable BT serial, right?)
ShiftPlusOne
Fri Feb 09, 2018 6:55 pm
No, but you might have to add enable_uart=1 to config.txt. Not sure if that's only required on the pi 3 or zerow as well.
macmpi
Mon Feb 12, 2018 1:05 pm
carriba wrote:
Thu Feb 08, 2018 2:10 pm
Question: What have the Raspbian Stretch packages updates done today to my device?
The change to Predictable interface name if you were on Jessie before...(see this. Default can be modified)
Would properly setting CRDA help?
(REGDOMAIN=xx in /etc/default/crda, with xx code from this list)
Mon Feb 12, 2018 4:29 pm
Possibly but it works even with that failure. I recall I get that failure as well yet all works for me. It seems to be whether the first time that failure occurs comes before dhcpcd starts or later. "No valid interfaces" is reported by dhcpcd when it comes later.
Works ...
Fails ...
That may however be coincidence rather causality. I don't have a clue on that. But I suspect it may be what led ShiftPlusOne to wonder if there were a race condition between udev and dhcpcd.
HawaiianPi
Mon Feb 12, 2018 6:04 pm
I just tested my Pi Zero W again with a freshly imaged SD card (2017-11-29 Raspbian Stretch Desktop).
This time I only did a sudo apt-get update && sudo apt-get upgrade -y (I usually dist-upgrade), but I still have no problems connecting to WiFi after the upgrade and reboot. The only packages held back seem to be related to wolfram-engine, so nothing that would affect wireless, but it was the only thing the OP was doing different, so I gave it a shot.
My Pi Zero W is unmolested (no pre-soldered header), which is a difference that shouldn't matter, unless something happened to the OP's Pi0W while the header was being installed. Although I can't imagine why physical damage would only affect an upgraded OS. ¯\_(ツ)_/¯
Edit:
Just to be thorough I tested it with Raspbian Stretch Lite as well. Same result. No trouble with wireless after an update/upgrade/reboot (dist-upgrade adds nothing to Lite at this time).
Tested running completely headless (nothing connected other than the PSU).
Raspberry Pi Zero W V1.1, purchased from Adafruit 2017-01-08
Raspbian Stretch OS 2017-11-29 (Desktop and Lite)
Silicon Power Elite 16GB MicroSDHC UHS-1 Memory Card Limited Edition (SP016GBSTHBU1V20BS)
AC adapter model: FY0501000 5.25VDC/1A (Adafruit?)
Hapurs RPi Raspberry Pi A+ B B+ Micro USB Cable with ON / OFF Switch
Router: ASUS RT-AC66R router with latest firmware (3.0.0.4.380_8120)
Main PC: Lenovo Yoga 2 Pro
OS: Windows 10 Home (x64) version 1709, build 16299.192 (Fall Creators Update)
SSH connection via Windows Subsystem for Linux (ssh pi@IP.address.of.Pi0W)
IP address found using Fing on my Android smartphone.
Have you tried rebooting your router (don't really know what else to suggest)?
JacobRask
Tue Feb 13, 2018 11:19 am
As I announced in my earlier post ('Thu Feb 08, 2018 4:14 pm') I'm suffering from the same issue regarding lack of WiFi-connection to/from my rPi-ZW.
What I then thought was irrelevant to mention, but now seems to maybe be of importance, is that just before I updated/upgraded Raspbian, I actually soldered GPIO pin headers to the board...
My unit is/was the normal rPi-ZW model without GPIO-headers, but as I need access to GPIOs, and in addition - from a 90 degree angle - I soldered a 2x20 90-degree pin header to the board.
I'll say my soldering skills should be sufficient; I'm experienced and I have a fairly steady hand :-)
Whether I have provided heat for too long to one or more of the solder pads, and maybe damaged one/some of the nearby components, I'm not sure of.
Or if the angled pin headers, in any way, can cause WiFi damaging interference or Faraday conditions (highly unlikely), I'm not aware of either.
I've tried disabling IPv6 (following carriba's instructions), but result is the same;
ifconfig returns info about only interfaces 'eth0' and 'lo'.
I have ordered some rPi-ZWs that hopefully will arrive today. I intend to redo my actions in small steps and monitor the differences along the way.
Tue Feb 13, 2018 1:43 pm
I would suspect that was more coincidence than causal. Especially if you soldered the headers on, then connected via WiFi, upgraded, and lost WiFi after that.
carriba
Contact: ICQ
Tue Feb 13, 2018 2:53 pm
I actually have the Raspberry Pi Zero WH (bought 2 weeks ago), with the GPIO headers already fabricated on the board. Doubt that mechanical add-ons will impact the device's operational behaviour...
carriba
Contact: ICQ
Tue Feb 13, 2018 3:53 pm
Today, I bought a brand new microSD card and have flashed the Raspbian Stretch image of November 2017. And see there, I can reproduce the problem: with fresh new image, Wifi connection works with a Raspbery Pi Zero W; after an OS package update done today, no Wifi access, sic!
In the following posts, I will paste the relevant log files and steps undertaken so that you see how I come up to this siutation. Here the lists of posts:
1/ Contents of the /var/log/syslog after 1st boot of Raspbian (based on the November 2017 image).
2/ Contents of the /var/log/kern.log after 1st boot of Raspbian (based on the November 2017 image), followed by a listing of the OS packages updated.
3/ Contents of the /var/log/syslog after a reboot & 2nd boot of Raspbian (after OS packages update).
4/ Contents of the /var/log/kern.log after reboot & 2nd boot of Raspbian (after OS packages update).
And here the contents of the /var/log/syslog after 1st boot of Raspbian (based on the November 2017 image):
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] Linux version 4.9.59+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1047 Sun Oct 29 11:47:10 GMT 2017
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] cma: Reserved 8 MiB at 0x1b400000
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] Memory policy: Data cache writeback
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] On node 0 totalpages: 114688
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] free_area_init_node: node 0, pgdat c0914e10, node_mem_map db010000
Nov 29 02:56:33 raspberrypi kernel: [    0.000000]   Normal zone: 1008 pages used for memmap
Nov 29 02:56:33 raspberrypi kernel: [    0.000000]   Normal zone: 0 pages reserved
Nov 29 02:56:33 raspberrypi kernel: [    0.000000]   Normal zone: 114688 pages, LIFO batch:31
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] pcpu-alloc: [0] 0
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 113680
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:9E:23:52 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait net.ifnames=0 biosdevname=0 logo.nologo plymouth.ignore-serial-consoles
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] Memory: 435944K/458752K available (5950K kernel code, 491K rwdata, 1948K rodata, 396K init, 725K bss, 14616K reserved, 8192K cma-reserved)
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] Virtual kernel memory layout:
Nov 29 02:56:33 raspberrypi kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Nov 29 02:56:33 raspberrypi kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Nov 29 02:56:33 raspberrypi kernel: [    0.000000]     vmalloc : 0xdc800000 - 0xff800000   ( 560 MB)
Nov 29 02:56:33 raspberrypi kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
Nov 29 02:56:33 raspberrypi kernel: [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
Nov 29 02:56:33 raspberrypi kernel: [    0.000000]       .text : 0xc0008000 - 0xc05d7a48   (5951 kB)
Nov 29 02:56:33 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
Nov 29 02:56:33 raspberrypi systemd-udevd[129]: Network interface NamePolicy= disabled on kernel command line, ignoring.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Load/Save Random Seed...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting udev Coldplug all Devices...
Nov 29 02:56:33 raspberrypi systemd[1]: Started Load/Save Random Seed.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
Nov 29 02:56:33 raspberrypi systemd[1]: Started udev Kernel Device Manager.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Set the console keyboard layout.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
Nov 29 02:56:33 raspberrypi systemd[1]: Started udev Coldplug all Devices.
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Show Plymouth Boot Screen...
Nov 29 02:56:33 raspberrypi systemd[1]: Received SIGRTMIN+20 from PID 149 (plymouthd).
Nov 29 02:56:33 raspberrypi systemd[1]: Started Show Plymouth Boot Screen.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Encrypted Volumes.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Paths.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Nov 29 02:56:33 raspberrypi systemd[1]: Found device /dev/serial1.
Nov 29 02:56:33 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/7b7fce4f-01.
Nov 29 02:56:33 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/7b7fce4f-01...
Nov 29 02:56:33 raspberrypi systemd-fsck[172]: fsck.fat 4.1 (2017-01-24)
Nov 29 02:56:33 raspberrypi systemd-fsck[172]: /dev/mmcblk0p1: 146 files, 42656/83705 clusters
Nov 29 02:56:33 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/7b7fce4f-01.
Nov 29 02:56:33 raspberrypi systemd[1]: Mounting /boot...
Nov 29 02:56:33 raspberrypi systemd[1]: Mounted /boot.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Local File Systems.
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Set console font and keymap...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Commit a transient machine-id on disk...
Nov 29 02:56:33 raspberrypi kernel: [    0.000000]       .init : 0xc0841000 - 0xc08a4000   ( 396 kB)
Nov 29 02:56:33 raspberrypi kernel: [    0.000000]       .data : 0xc08a4000 - 0xc091ef48   ( 492 kB)
Nov 29 02:56:33 raspberrypi kernel: [    0.000000]        .bss : 0xc091ef48 - 0xc09d4648   ( 726 kB)
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Nov 29 02:56:33 raspberrypi kernel: [    0.000000] NR_IRQS:16 nr_irqs:16 16
Nov 29 02:56:33 raspberrypi kernel: [    0.000031] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
Nov 29 02:56:33 raspberrypi kernel: [    0.000076] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
Nov 29 02:56:33 raspberrypi kernel: [    0.000176] bcm2835: system timer (irq = 27)
Nov 29 02:56:33 raspberrypi kernel: [    0.000648] Console: colour dummy device 80x30
Nov 29 02:56:33 raspberrypi kernel: [    0.001440] console [tty1] enabled
Nov 29 02:56:33 raspberrypi kernel: [    0.001496] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Nov 29 02:56:33 raspberrypi kernel: [    0.060364] pid_max: default: 32768 minimum: 301
Nov 29 02:56:33 raspberrypi kernel: [    0.060831] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Nov 29 02:56:33 raspberrypi kernel: [    0.060903] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Nov 29 02:56:33 raspberrypi kernel: [    0.062199] Disabling memory control group subsystem
Nov 29 02:56:33 raspberrypi kernel: [    0.062408] CPU: Testing write buffer coherency: ok
Nov 29 02:56:33 raspberrypi kernel: [    0.062511] ftrace: allocating 21715 entries in 64 pages
Nov 29 02:56:33 raspberrypi kernel: [    0.180835] Setting up static identity map for 0x8200 - 0x8238
Nov 29 02:56:33 raspberrypi kernel: [    0.182903] devtmpfs: initialized
Nov 29 02:56:33 raspberrypi kernel: [    0.192859] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Nov 29 02:56:33 raspberrypi kernel: [    0.193377] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Nov 29 02:56:33 raspberrypi kernel: [    0.193478] futex hash table entries: 256 (order: -1, 3072 bytes)
Nov 29 02:56:33 raspberrypi kernel: [    0.194786] pinctrl core: initialized pinctrl subsystem
Nov 29 02:56:33 raspberrypi kernel: [    0.196304] NET: Registered protocol family 16
Nov 29 02:56:33 raspberrypi kernel: [    0.198937] DMA: preallocated 1024 KiB pool for atomic coherent allocations
Nov 29 02:56:33 raspberrypi kernel: [    0.208697] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Nov 29 02:56:33 raspberrypi kernel: [    0.208791] hw-breakpoint: maximum watchpoint size is 4 bytes.
Nov 29 02:56:33 raspberrypi kernel: [    0.208929] Serial: AMBA PL011 UART driver
Nov 29 02:56:33 raspberrypi kernel: [    0.211870] bcm2835-mbox 2000b880.mailbox: mailbox enabled
Nov 29 02:56:33 raspberrypi kernel: [    0.212699] uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
Nov 29 02:56:33 raspberrypi kernel: [    0.262642] bcm2835-dma 20007000.dma: DMA legacy API manager at dc80d000, dmachans=0x1
Nov 29 02:56:33 raspberrypi kernel: [    0.265388] SCSI subsystem initialized
Nov 29 02:56:33 raspberrypi kernel: [    0.265716] usbcore: registered new interface driver usbfs
Nov 29 02:56:33 raspberrypi kernel: [    0.265888] usbcore: registered new interface driver hub
Nov 29 02:56:33 raspberrypi kernel: [    0.266130] usbcore: registered new device driver usb
Nov 29 02:56:33 raspberrypi kernel: [    0.270895] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-10-24 17:09
Nov 29 02:56:33 raspberrypi kernel: [    0.273029] clocksource: Switched to clocksource timer
Nov 29 02:56:33 raspberrypi kernel: [    0.327248] VFS: Disk quotas dquot_6.6.0
Nov 29 02:56:33 raspberrypi kernel: [    0.327452] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Nov 29 02:56:33 raspberrypi kernel: [    0.327826] FS-Cache: Loaded
Nov 29 02:56:33 raspberrypi kernel: [    0.328234] CacheFiles: Loaded
Nov 29 02:56:33 raspberrypi kernel: [    0.347644] NET: Registered protocol family 2
Nov 29 02:56:33 raspberrypi kernel: [    0.349067] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
Nov 29 02:56:33 raspberrypi kernel: [    0.349226] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Nov 29 02:56:33 raspberrypi kernel: [    0.349360] TCP: Hash tables configured (established 4096 bind 4096)
Nov 29 02:56:33 raspberrypi kernel: [    0.349496] UDP hash table entries: 256 (order: 0, 4096 bytes)
Nov 29 02:56:33 raspberrypi kernel: [    0.349563] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Nov 29 02:56:33 raspberrypi kernel: [    0.349923] NET: Registered protocol family 1
Nov 29 02:56:33 raspberrypi kernel: [    0.350733] RPC: Registered named UNIX socket transport module.
Nov 29 02:56:33 raspberrypi kernel: [    0.350810] RPC: Registered udp transport module.
Nov 29 02:56:33 raspberrypi kernel: [    0.350849] RPC: Registered tcp transport module.
Nov 29 02:56:33 raspberrypi kernel: [    0.350885] RPC: Registered tcp NFSv4.1 backchannel transport module.
Nov 29 02:56:33 raspberrypi kernel: [    0.352198] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
Nov 29 02:56:33 raspberrypi kernel: [    0.354880] workingset: timestamp_bits=14 max_order=17 bucket_order=3
Nov 29 02:56:33 raspberrypi kernel: [    0.375624] FS-Cache: Netfs 'nfs' registered for caching
Nov 29 02:56:33 raspberrypi kernel: [    0.377454] NFS: Registering the id_resolver key type
Nov 29 02:56:33 raspberrypi kernel: [    0.377564] Key type id_resolver registered
Nov 29 02:56:33 raspberrypi kernel: [    0.377608] Key type id_legacy registered
Nov 29 02:56:33 raspberrypi kernel: [    0.382095] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Nov 29 02:56:33 raspberrypi kernel: [    0.382564] io scheduler noop registered
Nov 29 02:56:33 raspberrypi kernel: [    0.382629] io scheduler deadline registered (default)
Nov 29 02:56:33 raspberrypi kernel: [    0.383251] io scheduler cfq registered
Nov 29 02:56:33 raspberrypi kernel: [    0.389165] BCM2708FB: allocated DMA memory 5b500000
Nov 29 02:56:33 raspberrypi kernel: [    0.389298] BCM2708FB: allocated DMA channel 0 @ dc80d000
Nov 29 02:56:33 raspberrypi kernel: [    0.397591] Console: switching to colour frame buffer device 82x26
Nov 29 02:56:33 raspberrypi kernel: [    0.409204] bcm2835-rng 20104000.rng: hwrng registered
Nov 29 02:56:33 raspberrypi kernel: [    0.412736] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
Nov 29 02:56:33 raspberrypi kernel: [    0.420400] vc-sm: Videocore shared memory driver
Nov 29 02:56:33 raspberrypi kernel: [    0.448392] brd: module loaded
Nov 29 02:56:33 raspberrypi kernel: [    0.464326] loop: module loaded
Nov 29 02:56:33 raspberrypi kernel: [    0.467600] Loading iSCSI transport class v2.0-870.
Nov 29 02:56:33 raspberrypi kernel: [    0.471669] usbcore: registered new interface driver smsc95xx
Nov 29 02:56:33 raspberrypi kernel: [    0.475131] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Nov 29 02:56:33 raspberrypi kernel: [    0.706946] Core Release: 2.80a
Nov 29 02:56:33 raspberrypi kernel: [    0.710376] Setting default values for core params
Nov 29 02:56:33 raspberrypi kernel: [    0.713791] Finished setting default values for core params
Nov 29 02:56:33 raspberrypi kernel: [    0.917508] Using Buffer DMA mode
Nov 29 02:56:33 raspberrypi kernel: [    0.920729] Periodic Transfer Interrupt Enhancement - disabled
Nov 29 02:56:33 raspberrypi kernel: [    0.923961] Multiprocessor Interrupt Enhancement - disabled
Nov 29 02:56:33 raspberrypi kernel: [    0.927199] OTG VER PARAM: 0, OTG VER FLAG: 0
Nov 29 02:56:33 raspberrypi kernel: [    0.930456] Dedicated Tx FIFOs mode
Nov 29 02:56:33 raspberrypi kernel: [    0.934325] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xdb514000 dma = 0x5b514000 len=9024
Nov 29 02:56:33 raspberrypi kernel: [    0.940827] FIQ FSM acceleration enabled for :
Nov 29 02:56:33 raspberrypi kernel: [    0.940827] Non-periodic Split Transactions
Nov 29 02:56:33 raspberrypi kernel: [    0.940827] Periodic Split Transactions
Nov 29 02:56:33 raspberrypi kernel: [    0.940827] High-Speed Isochronous Endpoints
Nov 29 02:56:33 raspberrypi kernel: [    0.940827] Interrupt/Control Split Transaction hack enabled
Nov 29 02:56:33 raspberrypi kernel: [    0.956927] dwc_otg: Microframe scheduler enabled
Nov 29 02:56:33 raspberrypi kernel: [    0.957063] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc0451694
Nov 29 02:56:33 raspberrypi kernel: [    0.960442] WARN::hcd_init_fiq:460: FIQ ASM at 0xc0451970 length 36
Nov 29 02:56:33 raspberrypi kernel: [    0.963732] WARN::hcd_init_fiq:486: MPHI regs_base at 0xdc8a5000
Nov 29 02:56:33 raspberrypi kernel: [    0.967077] dwc_otg 20980000.usb: DWC OTG Controller
Nov 29 02:56:33 raspberrypi kernel: [    0.970286] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
Nov 29 02:56:33 raspberrypi kernel: [    0.973617] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
Nov 29 02:56:33 raspberrypi kernel: [    0.976836] Init: Port Power? op_state=1
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Raise network interfaces...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
Nov 29 02:56:33 raspberrypi systemd[1]: Started Set console font and keymap.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Commit a transient machine-id on disk.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Preprocess NFS configuration.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target NFS client services.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Remote File Systems.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Network Time Synchronization...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Nov 29 02:56:33 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Network Time Synchronization.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target System Time Synchronized.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target System Initialization.
Nov 29 02:56:33 raspberrypi systemd[1]: Listening on triggerhappy.socket.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
Nov 29 02:56:33 raspberrypi systemd[1]: apt-daily.timer: Adding 9h 41min 39.545783s random time.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Daily apt download activities.
Nov 29 02:56:33 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 40min 52.889776s random time.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Timers.
Nov 29 02:56:33 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Nov 29 02:56:33 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Sockets.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Basic System.
Nov 29 02:56:33 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting LSB: Resize the root filesystem to fill partition...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Regenerate SSH host keys...
Nov 29 02:56:33 raspberrypi systemd[1]: Started Regular background program processing daemon.
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Check for v3d driver...
Nov 29 02:56:33 raspberrypi cron[241]: (CRON) INFO (pidfile fd = 3)
Nov 29 02:56:33 raspberrypi systemd[1]: Starting LSB: Autogenerate and use a swap file...
Nov 29 02:56:33 raspberrypi cron[241]: (CRON) INFO (Running @reboot jobs)
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Login Service...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Copy user wpa_supplicant.conf...
Nov 29 02:56:33 raspberrypi dd[239]: 1+0 records in
Nov 29 02:56:33 raspberrypi dd[239]: 1+0 records out
Nov 29 02:56:33 raspberrypi dd[239]: 4096 bytes (4.1 kB, 4.0 KiB) copied, 0.402791 s, 10.2 kB/s
Nov 29 02:56:33 raspberrypi systemd[1]: Started D-Bus System Message Bus.
Nov 29 02:56:33 raspberrypi dbus[263]: [system] Successfully activated service 'org.freedesktop.systemd1'
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting System Logging Service...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
Nov 29 02:56:33 raspberrypi thd[274]: Found socket passed from systemd
Nov 29 02:56:33 raspberrypi avahi-daemon[272]: Found user 'avahi' (UID 108) and group 'avahi' (GID 112).
Nov 29 02:56:33 raspberrypi avahi-daemon[272]: Successfully dropped root privileges.
Nov 29 02:56:33 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
Nov 29 02:56:33 raspberrypi avahi-daemon[272]: avahi-daemon 0.6.32 starting up.
Nov 29 02:56:33 raspberrypi liblogging-stdlog:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="273" x-info="http://www.rsyslog.com"] start
Nov 29 02:56:33 raspberrypi systemd[1]: Started Check for v3d driver.
Nov 29 02:56:33 raspberrypi avahi-daemon[272]: Successfully called chroot().
Nov 29 02:56:33 raspberrypi avahi-daemon[272]: Successfully dropped remaining capabilities.
Nov 29 02:56:33 raspberrypi avahi-daemon[272]: No service file found in /etc/avahi/services.
Nov 29 02:56:33 raspberrypi avahi-daemon[272]: Network interface enumeration completed.
Nov 29 02:56:33 raspberrypi avahi-daemon[272]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 1870407412.
Nov 29 02:56:33 raspberrypi kernel: [    0.979989] Init: Power Port (0)
Nov 29 02:56:33 raspberrypi kernel: [    0.983507] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Nov 29 02:56:33 raspberrypi kernel: [    0.986776] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 29 02:56:33 raspberrypi kernel: [    0.989933] usb usb1: Product: DWC OTG Controller
Nov 29 02:56:33 raspberrypi kernel: [    0.993161] usb usb1: Manufacturer: Linux 4.9.59+ dwc_otg_hcd
Nov 29 02:56:33 raspberrypi kernel: [    0.996377] usb usb1: SerialNumber: 20980000.usb
Nov 29 02:56:33 raspberrypi kernel: [    1.000714] hub 1-0:1.0: USB hub found
Nov 29 02:56:33 raspberrypi kernel: [    1.004055] hub 1-0:1.0: 1 port detected
Nov 29 02:56:33 raspberrypi kernel: [    1.008027] dwc_otg: FIQ enabled
Nov 29 02:56:33 raspberrypi kernel: [    1.008038] dwc_otg: NAK holdoff enabled
Nov 29 02:56:33 raspberrypi kernel: [    1.008043] dwc_otg: FIQ split-transaction FSM enabled
Nov 29 02:56:33 raspberrypi kernel: [    1.008063] Module dwc_common_port init
Nov 29 02:56:33 raspberrypi kernel: [    1.008567] usbcore: registered new interface driver usb-storage
Nov 29 02:56:33 raspberrypi kernel: [    1.012240] mousedev: PS/2 mouse device common for all mice
Nov 29 02:56:33 raspberrypi kernel: [    1.017284] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
Nov 29 02:56:33 raspberrypi kernel: [    1.021089] bcm2835-cpufreq: min=700000 max=1000000
Nov 29 02:56:33 raspberrypi kernel: [    1.024941] sdhci: Secure Digital Host Controller Interface driver
Nov 29 02:56:33 raspberrypi kernel: [    1.028102] sdhci: Copyright(c) Pierre Ossman
Nov 29 02:56:33 raspberrypi kernel: [    1.031635] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
Nov 29 02:56:33 raspberrypi kernel: [    1.037487] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
Nov 29 02:56:33 raspberrypi kernel: [    1.040966] sdhci-pltfm: SDHCI platform and OF driver helper
Nov 29 02:56:33 raspberrypi kernel: [    1.044951] ledtrig-cpu: registered to indicate activity on CPUs
Nov 29 02:56:33 raspberrypi kernel: [    1.048512] hidraw: raw HID events driver (C) Jiri Kosina
Nov 29 02:56:33 raspberrypi kernel: [    1.052128] usbcore: registered new interface driver usbhid
Nov 29 02:56:33 raspberrypi kernel: [    1.055553] usbhid: USB HID core driver
Nov 29 02:56:33 raspberrypi kernel: [    1.060187] vchiq: vchiq_init_state: slot_zero = 0xdb580000, is_master = 0
Nov 29 02:56:33 raspberrypi kernel: [    1.065690] [vc_sm_connected_init]: start
Nov 29 02:56:33 raspberrypi kernel: [    1.076314] [vc_sm_connected_init]: end - returning 0
Nov 29 02:56:33 raspberrypi kernel: [    1.080362] Initializing XFRM netlink socket
Nov 29 02:56:33 raspberrypi kernel: [    1.083901] NET: Registered protocol family 17
Nov 29 02:56:33 raspberrypi kernel: [    1.087440] Key type dns_resolver registered
Nov 29 02:56:33 raspberrypi kernel: [    1.092628] registered taskstats version 1
Nov 29 02:56:33 raspberrypi kernel: [    1.105171] uart-pl011 20201000.serial: cts_event_workaround enabled
Nov 29 02:56:33 raspberrypi kernel: [    1.108748] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
Nov 29 02:56:33 raspberrypi kernel: [    1.118074] sdhost: log_buf @ db513000 (5b513000)
Nov 29 02:56:33 raspberrypi kernel: [    1.193110] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Nov 29 02:56:33 raspberrypi kernel: [    1.199361] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
Nov 29 02:56:33 raspberrypi kernel: [    1.202994] mmc-bcm2835 20300000.mmc: DMA channel allocated
Nov 29 02:56:33 raspberrypi kernel: [    1.236321] random: fast init done
Nov 29 02:56:33 raspberrypi kernel: [    1.280262] mmc0: host does not support reading read-only switch, assuming write-enable
Nov 29 02:56:33 raspberrypi kernel: [    1.287446] of_cfs_init
Nov 29 02:56:33 raspberrypi kernel: [    1.290999] of_cfs_init: OK
Nov 29 02:56:33 raspberrypi kernel: [    1.298914] mmc0: new high speed SDHC card at address 0001
Nov 29 02:56:33 raspberrypi kernel: [    1.306097] mmcblk0: mmc0:0001 00000 29.8 GiB
Nov 29 02:56:33 raspberrypi kernel: [    1.311926]  mmcblk0: p1 p2
Nov 29 02:56:33 raspberrypi kernel: [    1.324853] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Nov 29 02:56:33 raspberrypi kernel: [    1.331158] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Nov 29 02:56:33 raspberrypi kernel: [    1.337886] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Nov 29 02:56:33 raspberrypi kernel: [    1.341469] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Nov 29 02:56:33 raspberrypi kernel: [    1.346360] devtmpfs: mounted
Nov 29 02:56:33 raspberrypi kernel: [    1.349917] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Nov 29 02:56:33 raspberrypi kernel: [    1.354749] Freeing unused kernel memory: 396K
Nov 29 02:56:33 raspberrypi kernel: [    1.358184] This architecture does not have kernel memory protection.
Nov 29 02:56:33 raspberrypi kernel: [    1.365247] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Nov 29 02:56:33 raspberrypi kernel: [    1.480524] mmc1: new high speed SDIO card at address 0001
Nov 29 02:56:33 raspberrypi kernel: [    1.959343] NET: Registered protocol family 10
Nov 29 02:56:33 raspberrypi kernel: [    1.991413] ip_tables: (C) 2000-2006 Netfilter Core Team
Nov 29 02:56:33 raspberrypi kernel: [    4.067118] i2c /dev entries driver
Nov 29 02:56:33 raspberrypi kernel: [    5.438357] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Nov 29 02:56:33 raspberrypi kernel: [    8.180713] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
Nov 29 02:56:33 raspberrypi kernel: [    9.182081] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
Nov 29 02:56:33 raspberrypi kernel: [    9.202354] usbcore: registered new interface driver brcmfmac
Nov 29 02:56:33 raspberrypi kernel: [    9.579758] brcmfmac: Firmware version = wl0: Aug  7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
Nov 29 02:56:33 raspberrypi kernel: [    9.580988] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.41 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-08-07 00:37:47
Nov 29 02:56:33 raspberrypi kernel: [   13.498498] uart-pl011 20201000.serial: no DMA platform data
Nov 29 02:56:33 raspberrypi systemd[1]: Started System Logging Service.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Copy user wpa_supplicant.conf.
Nov 29 02:56:35 raspberrypi raspi-config[232]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
Nov 29 02:56:35 raspberrypi dphys-swapfile[248]: Starting dphys-swapfile swapfile setup ...
Nov 29 02:56:35 raspberrypi raspi-config[232]:  No. Switching to ondemand scaling governor.
Nov 29 02:56:35 raspberrypi resize2fs_once[238]: Starting resize2fs_once:resize2fs 1.43.4 (31-Jan-2017)
Nov 29 02:56:35 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Nov 29 02:56:35 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Nov 29 02:56:35 raspberrypi systemd[1]: Started Login Service.
Nov 29 02:56:35 raspberrypi kernel: [   16.066076] EXT4-fs (mmcblk0p2): resizing filesystem from 1189376 to 7803392 blocks
Nov 29 02:56:35 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Nov 29 02:56:35 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Nov 29 02:56:35 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
Nov 29 02:56:35 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
Nov 29 02:56:36 raspberrypi systemd[1]: Started Raise network interfaces.
Nov 29 02:56:36 raspberrypi dhcpcd[321]: dev: loaded udev
Nov 29 02:56:36 raspberrypi dhcpcd[321]: forked to background, child pid 339
Nov 29 02:56:36 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Nov 29 02:56:36 raspberrypi systemd[1]: Reached target Network.
Nov 29 02:56:36 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
Nov 29 02:56:36 raspberrypi systemd[1]: Starting Permit User Sessions...
Nov 29 02:56:37 raspberrypi systemd[1]: Started Permit User Sessions.
Nov 29 02:56:37 raspberrypi systemd[1]: Starting Light Display Manager...
Nov 29 02:56:37 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
Nov 29 02:56:37 raspberrypi systemd[1]: Starting Terminate Plymouth Boot Screen...
Nov 29 02:56:37 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
Nov 29 02:56:37 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 149 (plymouthd).
Nov 29 02:56:37 raspberrypi systemd[1]: Started Terminate Plymouth Boot Screen.
Nov 29 02:56:37 raspberrypi systemd[1]: Started Hold until boot process finishes up.
Nov 29 02:56:37 raspberrypi systemd[1]: Started Getty on tty1.
Nov 29 02:56:37 raspberrypi systemd[1]: Reached target Login Prompts.
Nov 29 02:56:37 raspberrypi kernel: [   18.403411] Bluetooth: Core ver 2.22
Nov 29 02:56:37 raspberrypi kernel: [   18.403561] NET: Registered protocol family 31
Nov 29 02:56:37 raspberrypi kernel: [   18.403569] Bluetooth: HCI device and connection manager initialized
Nov 29 02:56:37 raspberrypi kernel: [   18.408224] Bluetooth: HCI socket layer initialized
Nov 29 02:56:37 raspberrypi kernel: [   18.408248] Bluetooth: L2CAP socket layer initialized
Nov 29 02:56:37 raspberrypi kernel: [   18.408295] Bluetooth: SCO socket layer initialized
Nov 29 02:56:37 raspberrypi kernel: [   18.520665] Bluetooth: HCI UART driver ver 2.3
Nov 29 02:56:37 raspberrypi kernel: [   18.520681] Bluetooth: HCI UART protocol H4 registered
Nov 29 02:56:37 raspberrypi kernel: [   18.520686] Bluetooth: HCI UART protocol Three-wire (H5) registered
Nov 29 02:56:37 raspberrypi kernel: [   18.520826] Bluetooth: HCI UART protocol Broadcom registered
Nov 29 02:56:37 raspberrypi btuart[233]: bcm43xx_init
Nov 29 02:56:37 raspberrypi btuart[233]: Flash firmware /lib/firmware/BCM43430A1.hcd
Nov 29 02:56:37 raspberrypi btuart[233]: Set BDADDR UART: b8:27:eb:34:89:f8
Nov 29 02:56:37 raspberrypi btuart[233]: Set Controller UART speed to 3000000 bit/s
Nov 29 02:56:37 raspberrypi btuart[233]: Device setup complete
Nov 29 02:56:37 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
Nov 29 02:56:38 raspberrypi systemd[1]: Starting Bluetooth service...
Nov 29 02:56:39 raspberrypi systemd-udevd[140]: Process '/sbin/crda' failed with exit code 249.
Nov 29 02:56:39 raspberrypi bluetoothd[373]: Bluetooth daemon 5.43
Nov 29 02:56:39 raspberrypi systemd[1]: Started Bluetooth service.
Nov 29 02:56:39 raspberrypi systemd[1]: Started BluezALSA proxy.
Nov 29 02:56:39 raspberrypi dhcpcd-run-hooks[378]: wlan0: starting wpa_supplicant
Nov 29 02:56:39 raspberrypi bluetoothd[373]: Starting SDP server
Nov 29 02:56:39 raspberrypi dphys-swapfile[248]: want /var/swap=100MByte, generating swapfile ... of 100MBytes
Nov 29 02:56:39 raspberrypi kernel: [   20.218696] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Nov 29 02:56:39 raspberrypi kernel: [   20.218709] Bluetooth: BNEP filters: protocol multicast
Nov 29 02:56:39 raspberrypi kernel: [   20.218734] Bluetooth: BNEP socket layer initialized
Nov 29 02:56:39 raspberrypi bluetoothd[373]: Bluetooth management interface 1.14 initialized
Nov 29 02:56:39 raspberrypi bluetoothd[373]: Failed to obtain handles for "Service Changed" characteristic
Nov 29 02:56:39 raspberrypi dbus[263]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Nov 29 02:56:39 raspberrypi kernel: [   20.360449] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SSFS
Nov 29 02:56:39 raspberrypi dphys-swapfile[248]: done.
Nov 29 02:56:39 raspberrypi bluetoothd[373]: Sap driver initialization failed.
Nov 29 02:56:39 raspberrypi bluetoothd[373]: sap-server: Operation not permitted (1)
Nov 29 02:56:39 raspberrypi systemd[1]: Started LSB: Autogenerate and use a swap file.
Nov 29 02:56:40 raspberrypi systemd[1]: Starting Hostname Service...
Nov 29 02:56:40 raspberrypi systemd[1]: Reached target Bluetooth.
Nov 29 02:56:40 raspberrypi bluetoothd[373]: Endpoint registered: sender=:1.4 path=/A2DP/SBC/Source/1
Nov 29 02:56:40 raspberrypi bluetoothd[373]: Endpoint registered: sender=:1.4 path=/A2DP/SBC/Sink/1
Nov 29 02:56:40 raspberrypi dbus[263]: [system] Successfully activated service 'org.freedesktop.hostname1'
Nov 29 02:56:40 raspberrypi systemd[1]: Started Hostname Service.
Nov 29 02:56:40 raspberrypi kernel: [   21.293141] Bluetooth: RFCOMM TTY layer initialized
Nov 29 02:56:40 raspberrypi kernel: [   21.293178] Bluetooth: RFCOMM socket layer initialized
Nov 29 02:56:40 raspberrypi kernel: [   21.293210] Bluetooth: RFCOMM ver 1.11
Nov 29 02:56:40 raspberrypi kernel: [   21.466013] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Nov 29 02:56:40 raspberrypi kernel: [   21.466031] brcmfmac: power management disabled
Nov 29 02:56:40 raspberrypi kernel: [   21.471626] random: crng init done
Nov 29 02:56:42 raspberrypi dhcpcd[339]: wlan0: waiting for carrier
Nov 29 02:56:42 raspberrypi dhcpcd[339]: wlan0: carrier acquired
Nov 29 02:56:42 raspberrypi dhcpcd[339]: DUID 00:01:00:01:21:b0:de:6a:b8:27:eb:cb:76:07
Nov 29 02:56:42 raspberrypi dhcpcd[339]: wlan0: IAID eb:cb:76:07
Nov 29 02:56:42 raspberrypi dhcpcd[339]: wlan0: adding address fe80::e155:9544:daa:ffa1
Nov 29 02:56:42 raspberrypi dhcpcd[339]: wlan0: carrier lost
Nov 29 02:56:42 raspberrypi dhcpcd[339]: wlan0: deleting address fe80::e155:9544:daa:ffa1
Nov 29 02:56:45 raspberrypi kernel: [   26.321825] EXT4-fs (mmcblk0p2): resized to 3670016 blocks
Nov 29 02:56:49 raspberrypi systemd[1]: Created slice User Slice of pi.
Nov 29 02:56:49 raspberrypi systemd[1]: Started Session c1 of user pi.
Nov 29 02:56:49 raspberrypi systemd[1]: Starting User Manager for UID 1000...
Nov 29 02:56:49 raspberrypi lightdm[358]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Nov 29 02:56:49 raspberrypi systemd[1]: Started Light Display Manager.
Nov 29 02:56:49 raspberrypi lightdm[358]: Could not enumerate user data directory /var/lib/lightdm/data: Error opening directory '/var/lib/lightdm/data': No such file or directory
Nov 29 02:56:52 raspberrypi systemd[431]: Starting D-Bus User Message Bus Socket.
Nov 29 02:56:52 raspberrypi systemd[431]: Reached target Paths.
Nov 29 02:56:52 raspberrypi systemd[431]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Nov 29 02:56:52 raspberrypi systemd[431]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Nov 29 02:56:52 raspberrypi systemd[431]: Listening on GnuPG cryptographic agent (access for web browsers).
Nov 29 02:56:52 raspberrypi systemd[431]: Listening on GnuPG cryptographic agent and passphrase cache.
Nov 29 02:56:52 raspberrypi systemd[431]: Reached target Timers.
Nov 29 02:56:52 raspberrypi systemd[431]: Listening on D-Bus User Message Bus Socket.
Nov 29 02:56:52 raspberrypi systemd[431]: Reached target Sockets.
Nov 29 02:56:52 raspberrypi systemd[431]: Reached target Basic System.
Nov 29 02:56:52 raspberrypi systemd[431]: Reached target Default.
Nov 29 02:56:52 raspberrypi systemd[431]: Startup finished in 2.779s.
Nov 29 02:56:52 raspberrypi systemd[1]: Started User Manager for UID 1000.
Nov 29 02:56:54 raspberrypi ssh-keygen[285]: ssh-keygen: generating new host keys: RSA DSA ECDSA ED25519
Nov 29 02:56:54 raspberrypi systemctl[449]: Removed /etc/systemd/system/multi-user.target.wants/regenerate_ssh_host_keys.service.
Nov 29 02:56:54 raspberrypi systemd[1]: Reloading.
Nov 29 02:56:55 raspberrypi systemd[1]: Started Regenerate SSH host keys.
Nov 29 02:56:55 raspberrypi systemd[1]: Starting Turn on SSH if /boot/ssh is present...
Nov 29 02:56:56 raspberrypi kernel: [   36.698838] EXT4-fs (mmcblk0p2): resized to 6291456 blocks
Nov 29 02:57:00 raspberrypi lightdm[358]: session_get_login1_session_id: assertion 'session != NULL' failed
Nov 29 02:57:00 raspberrypi systemd[1]: Reloading.
Nov 29 02:57:02 raspberrypi kernel: [   43.560052] EXT4-fs (mmcblk0p2): resized filesystem to 7803392
Nov 29 02:57:03 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Nov 29 02:57:03 raspberrypi resize2fs_once[238]: Filesystem at /dev/mmcblk0p2 is mounted on /; on-line resizing required
Nov 29 02:57:03 raspberrypi resize2fs_once[238]: old_desc_blocks = 1, new_desc_blocks = 2
Nov 29 02:57:03 raspberrypi resize2fs_once[238]: The filesystem on /dev/mmcblk0p2 is now 7803392 (4k) blocks long.
Nov 29 02:57:04 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Nov 29 02:57:04 raspberrypi systemd[1]: Started Turn on SSH if /boot/ssh is present.
Nov 29 02:57:04 raspberrypi systemd[1]: Reloading.
Nov 29 02:57:06 raspberrypi systemd[1]: Reached target Multi-User System.
Nov 29 02:57:06 raspberrypi systemd[1]: Reached target Graphical Interface.
Nov 29 02:57:06 raspberrypi resize2fs_once[238]: .
Nov 29 02:57:06 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Nov 29 02:57:06 raspberrypi systemd[1]: Started LSB: Resize the root filesystem to fill partition.
Nov 29 02:57:06 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Nov 29 02:57:06 raspberrypi systemd[1]: Startup finished in 1.699s (kernel) + 45.350s (userspace) = 47.050s.
Nov 29 02:57:06 raspberrypi lightdm[523]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Nov 29 02:57:07 raspberrypi systemd[1]: Started Session c2 of user pi.
Nov 29 02:57:07 raspberrypi lightdm[358]: Error opening audit socket: Protocol not supported
Nov 29 02:57:07 raspberrypi systemd[431]: Started D-Bus User Message Bus.
Nov 29 02:57:11 raspberrypi dbus-daemon[541]: Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service'
Nov 29 02:57:11 raspberrypi systemd[431]: Starting Virtual filesystem service...
Nov 29 02:57:11 raspberrypi dbus-daemon[541]: Successfully activated service 'org.gtk.vfs.Daemon'
Nov 29 02:57:11 raspberrypi systemd[431]: Started Virtual filesystem service.
Nov 29 02:57:11 raspberrypi kernel: [   52.013141] fuse init (API version 7.26)
Nov 29 02:57:11 raspberrypi systemd[1]: Mounting FUSE Control File System...
Nov 29 02:57:11 raspberrypi systemd[1]: Mounted FUSE Control File System.
Nov 29 02:57:13 raspberrypi dbus[263]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
Nov 29 02:57:13 raspberrypi systemd[1]: Starting Authorization Manager...
Nov 29 02:57:13 raspberrypi polkitd[661]: started daemon version 0.105 using authority implementation `local' version `0.105'
Nov 29 02:57:13 raspberrypi dbus[263]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Nov 29 02:57:13 raspberrypi systemd[1]: Started Authorization Manager.
Nov 29 02:57:21 raspberrypi dbus-daemon[541]: Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service'
Nov 29 02:57:21 raspberrypi systemd[431]: Starting Virtual filesystem service - disk device monitor...
Nov 29 02:57:21 raspberrypi dbus[263]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
Nov 29 02:57:21 raspberrypi systemd[1]: Starting Disk Manager...
Nov 29 02:57:22 raspberrypi udisksd[696]: udisks daemon version 2.1.8 starting
Nov 29 02:57:22 raspberrypi dbus[263]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Nov 29 02:57:22 raspberrypi systemd[1]: Started Disk Manager.
Nov 29 02:57:22 raspberrypi udisksd[696]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Nov 29 02:57:23 raspberrypi dbus-daemon[541]: Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Nov 29 02:57:23 raspberrypi systemd[431]: Started Virtual filesystem service - disk device monitor.
Nov 29 02:57:23 raspberrypi dbus-daemon[541]: Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service'
Nov 29 02:57:23 raspberrypi systemd[431]: Starting Virtual filesystem service - digital camera monitor...
Nov 29 02:57:23 raspberrypi dbus-daemon[541]: Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Nov 29 02:57:23 raspberrypi systemd[431]: Started Virtual filesystem service - digital camera monitor.
Nov 29 02:57:24 raspberrypi dbus-daemon[541]: Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service'
Nov 29 02:57:24 raspberrypi systemd[431]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Nov 29 02:57:24 raspberrypi kernel: [   64.685529] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Nov 29 02:57:24 raspberrypi dhcpcd[339]: wlan0: carrier acquired
Nov 29 02:57:24 raspberrypi dhcpcd[339]: wlan0: IAID eb:cb:76:07
Nov 29 02:57:24 raspberrypi dhcpcd[339]: wlan0: adding address fe80::592a:178f:b470:c16d
Nov 29 02:57:24 raspberrypi dbus-daemon[541]: Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Nov 29 02:57:24 raspberrypi systemd[431]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Nov 29 02:57:24 raspberrypi dbus-daemon[541]: Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service'
Nov 29 02:57:24 raspberrypi systemd[431]: Starting Virtual filesystem service - Apple File Conduit monitor...
Nov 29 02:57:24 raspberrypi dhcpcd[339]: wlan0: soliciting a DHCP lease
Nov 29 02:57:24 raspberrypi dhcpcd[339]: wlan0: offered 192.168.0.31 from 192.168.0.254
Nov 29 02:57:24 raspberrypi dhcpcd[339]: wlan0: probing address 192.168.0.31/24
Nov 29 02:57:24 raspberrypi gvfs-afc-volume-monitor[716]: Volume monitor alive
Nov 29 02:57:24 raspberrypi dbus-daemon[541]: Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Nov 29 02:57:24 raspberrypi systemd[431]: Started Virtual filesystem service - Apple File Conduit monitor.
Nov 29 02:57:24 raspberrypi dbus-daemon[541]: Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service'
Nov 29 02:57:24 raspberrypi systemd[431]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
Nov 29 02:57:25 raspberrypi dhcpcd[339]: wlan0: soliciting an IPv6 router
Nov 29 02:57:25 raspberrypi dbus-daemon[541]: Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
Nov 29 02:57:25 raspberrypi systemd[431]: Started Virtual filesystem service - GNOME Online Accounts monitor.
Nov 29 02:57:25 raspberrypi avahi-daemon[272]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::592a:178f:b470:c16d.
Nov 29 02:57:25 raspberrypi avahi-daemon[272]: New relevant interface wlan0.IPv6 for mDNS.
Nov 29 02:57:25 raspberrypi avahi-daemon[272]: Registering new address record for fe80::592a:178f:b470:c16d on wlan0.*.
Nov 29 02:57:28 raspberrypi dhcpcd[339]: wlan0: leased 192.168.0.31 for 864000 seconds
Nov 29 02:57:28 raspberrypi avahi-daemon[272]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.31.
Nov 29 02:57:28 raspberrypi dhcpcd[339]: wlan0: adding route to 192.168.0.0/24
Nov 29 02:57:28 raspberrypi dhcpcd[339]: wlan0: adding default route via 192.168.0.254
Nov 29 02:57:28 raspberrypi avahi-daemon[272]: New relevant interface wlan0.IPv4 for mDNS.
Nov 29 02:57:28 raspberrypi avahi-daemon[272]: Registering new address record for 192.168.0.31 on wlan0.IPv4.
Feb 13 12:06:17 raspberrypi systemd-timesyncd[205]: Synchronized to time server 194.177.34.116:123 (0.debian.pool.ntp.org).
Feb 13 12:06:17 raspberrypi systemd[431]: Time has been changed
Feb 13 12:06:17 raspberrypi systemd[1]: Time has been changed
Feb 13 12:06:17 raspberrypi systemd[1]: Reached target Network is Online.
Feb 13 12:06:17 raspberrypi systemd[1]: Starting Daily apt download activities...
Feb 13 12:06:22 raspberrypi dhcpcd[339]: wlan0: no IPv6 Routers available
Feb 13 12:06:39 raspberrypi systemd[1]: Started Daily apt download activities.
Feb 13 12:06:39 raspberrypi systemd[1]: apt-daily.timer: Adding 1h 32min 43.028191s random time.
Feb 13 12:06:39 raspberrypi systemd[1]: apt-daily.timer: Adding 7h 56min 46.576448s random time.
Feb 13 12:06:39 raspberrypi systemd[1]: Starting Daily apt upgrade and clean activities...
Feb 13 12:06:43 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Feb 13 12:06:43 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 56min 41.445210s random time.
Feb 13 12:06:43 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 49min 28.372278s random time.
Feb 13 12:10:05 raspberrypi systemd[1]: Started Session c3 of user pi.
Feb 13 12:11:26 raspberrypi dbus[263]: [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service'
Feb 13 12:11:26 raspberrypi systemd[1]: Starting PackageKit Daemon...
Feb 13 12:11:26 raspberrypi PackageKit: daemon start
Feb 13 12:11:26 raspberrypi dbus[263]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Feb 13 12:11:26 raspberrypi systemd[1]: Started PackageKit Daemon.
Feb 13 12:17:01 raspberrypi CRON[1117]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Feb 13 12:20:08 raspberrypi systemd[1]: Starting Cleanup of Temporary Directories...
Feb 13 12:20:09 raspberrypi systemd[1]: Started Cleanup of Temporary Directories.
carriba
Contact: ICQ
Tue Feb 13, 2018 3:57 pm
And here the contents of the /var/log/kern.log after 1st boot of Raspbian (based on the November 2017 image):
Once booting has completed, I fired the usual "sudo apt-get update; sudo apt-get upgrade" commands that displays the following list of OS packages to be updated (and have been updated):
Hit:1 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
  wolfram-engine
The following packages will be upgraded:
  base-files bind9-host bluez-firmware curl dbus dbus-user-session dbus-x11 erlang-base erlang-crypto erlang-syntax-tools firmware-atheros
  firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek gir1.2-gdkpixbuf-2.0 gstreamer1.0-omx gstreamer1.0-omx-rpi
  gstreamer1.0-omx-rpi-config gtk2-engines-clearlookspix idle-python2.7 iproute2 libavcodec57 libavfilter6 libavformat57 libavresample3 libavutil55
  libbind9-140 libcurl3 libcurl3-gnutls libdbus-1-3 libdns-export162 libdns162 libfm-data libfm-extra4 libfm-gtk-data libfm-gtk4 libfm-modules libfm4
  libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-common libicu57 libisc-export160 libisc160 libisccc140 libisccfg140 liblwres141 libobrender32v5 libobt2v5
  libpoppler64 libpostproc54 libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib libsqlite3-0 libssl1.0.2 libswresample2 libswscale4
  libtasn1-6 libtiff5 libxcursor1 libxkbcommon-x11-0 libxkbcommon0 libxml2 lxpanel lxpanel-data lxplug-bluetooth lxplug-network lxplug-ptbatt openbox
  openssh-client openssh-server openssh-sftp-server pcmanfm pi-bluetooth pipanel pishutdown poppler-utils python-scrollphathd python2.7 python2.7-dev
  python2.7-minimal python3-scrollphathd raspberrypi-sys-mods raspberrypi-ui-mods raspi-config rc-gui realvnc-vnc-server rpd-icons rpi-chromium-mods rsync
  sensible-utils ssh tzdata
95 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 97.5 MB of archives.
After this operation, 1,177 kB of additional disk space will be used.
carriba
Contact: ICQ
Tue Feb 13, 2018 4:00 pm
And here the contents of the /var/log/syslog after a reboot and 2nd boot of Raspbian (after OS packages update):
Feb 13 12:53:55 raspberrypi systemd[1]: Stopping OpenBSD Secure Shell server...
Feb 13 12:53:55 raspberrypi systemd[1]: Stopped OpenBSD Secure Shell server.
Feb 13 12:53:55 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Feb 13 12:53:56 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Feb 13 12:55:56 raspberrypi systemd[1]: Stopping User Manager for UID 1000...
Feb 13 12:55:56 raspberrypi systemd[1]: Stopped target Timers.
Feb 13 12:55:56 raspberrypi systemd[1]: Unmounting RPC Pipe File System...
Feb 13 12:55:56 raspberrypi systemd[431]: Stopping Virtual filesystem service - Media Transfer Protocol monitor...
Feb 13 12:55:56 raspberrypi systemd[1]: Stopping Session c3 of user pi.
Feb 13 12:55:56 raspberrypi systemd[1]: Stopped Daily apt upgrade and clean activities.
Feb 13 12:55:56 raspberrypi systemd[431]: Stopping Virtual filesystem service - GNOME Online Accounts monitor...
Feb 13 12:55:56 raspberrypi systemd[431]: Stopping Virtual filesystem service - disk device monitor...
Feb 13 12:55:56 raspberrypi systemd[431]: Stopping Virtual filesystem service...
Feb 13 12:55:56 raspberrypi systemd[431]: Stopping Virtual filesystem service - digital camera monitor...
Feb 13 12:55:56 raspberrypi systemd[431]: Stopping D-Bus User Message Bus...
Feb 13 12:55:56 raspberrypi udisksd[696]: udisks daemon version 2.1.8 exiting
Feb 13 12:55:56 raspberrypi systemd[431]: Stopped target Default.
Feb 13 12:55:56 raspberrypi systemd[1]: Stopping Session c1 of user pi.
Feb 13 12:55:56 raspberrypi bluetoothd[373]: Endpoint unregistered: sender=:1.4 path=/A2DP/SBC/Source/1
Feb 13 12:55:56 raspberrypi systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Feb 13 12:55:56 raspberrypi bluetoothd[373]: Endpoint unregistered: sender=:1.4 path=/A2DP/SBC/Sink/1
Feb 13 12:55:56 raspberrypi systemd[1]: Stopped Daily apt download activities.
Feb 13 12:55:57 raspberrypi systemd[1]: Stopped target System Time Synchronized.
Feb 13 12:55:57 raspberrypi avahi-daemon[272]: Got SIGTERM, quitting.
Feb 13 12:57:08 raspberrypi systemd-modules-load[86]: Inserted module 'i2c_dev'
Feb 13 12:57:08 raspberrypi systemd-fsck[89]: e2fsck 1.43.4 (31-Jan-2017)
Feb 13 12:57:08 raspberrypi systemd-fsck[89]: Superblock last mount time (Wed Nov 29 02:56:24 2017,
Feb 13 12:57:08 raspberrypi systemd-fsck[89]: #011now = Thu Nov  3 17:16:43 2016) is in the future.
Feb 13 12:57:08 raspberrypi systemd-fsck[89]: Fix? yes
Feb 13 12:57:08 raspberrypi systemd-fsck[89]: Superblock last write time (Wed Nov 29 02:56:23 2017,
Feb 13 12:57:08 raspberrypi systemd-fsck[89]: Pass 1: Checking inodes, blocks, and sizes
Feb 13 12:57:08 raspberrypi fake-hwclock[92]: Tue 13 Feb 12:56:00 UTC 2018
Feb 13 12:57:08 raspberrypi systemd[1]: Started Apply Kernel Variables.
Feb 13 12:57:08 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
Feb 13 12:57:08 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
Feb 13 12:57:08 raspberrypi systemd-udevd[124]: Network interface NamePolicy= disabled on kernel command line, ignoring.
Feb 13 12:57:08 raspberrypi systemd[1]: Started udev Kernel Device Manager.
Feb 13 12:57:08 raspberrypi systemd[1]: Started Set the console keyboard layout.
Feb 13 12:57:08 raspberrypi systemd-fsck[89]: Pass 2: Checking directory structure
Feb 13 12:57:08 raspberrypi systemd-fsck[89]: Pass 3: Checking directory connectivity
Feb 13 12:57:08 raspberrypi systemd-fsck[89]: Pass 4: Checking reference counts
Feb 13 12:57:08 raspberrypi systemd-fsck[89]: Pass 5: Checking group summary information
Feb 13 12:57:08 raspberrypi systemd-fsck[89]: rootfs: 137108/1923472 files (0.2% non-contiguous), 1223005/7803392 blocks
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] Linux version 4.9.59+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1047 Sun Oct 29 11:47:10 GMT 2017
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] cma: Reserved 8 MiB at 0x1b400000
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] Memory policy: Data cache writeback
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] On node 0 totalpages: 114688
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] free_area_init_node: node 0, pgdat c0914e10, node_mem_map db010000
Feb 13 12:57:08 raspberrypi kernel: [    0.000000]   Normal zone: 1008 pages used for memmap
Feb 13 12:57:08 raspberrypi kernel: [    0.000000]   Normal zone: 0 pages reserved
Feb 13 12:57:08 raspberrypi kernel: [    0.000000]   Normal zone: 114688 pages, LIFO batch:31
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] pcpu-alloc: [0] 0
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 113680
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:9E:23:52 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait net.ifnames=0 biosdevname=0 logo.nologo plymouth.ignore-serial-consoles
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] Memory: 435944K/458752K available (5950K kernel code, 491K rwdata, 1948K rodata, 396K init, 725K bss, 14616K reserved, 8192K cma-reserved)
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] Virtual kernel memory layout:
Feb 13 12:57:08 raspberrypi kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Feb 13 12:57:08 raspberrypi kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Feb 13 12:57:08 raspberrypi kernel: [    0.000000]     vmalloc : 0xdc800000 - 0xff800000   ( 560 MB)
Feb 13 12:57:08 raspberrypi kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
Feb 13 12:57:08 raspberrypi kernel: [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
Feb 13 12:57:08 raspberrypi kernel: [    0.000000]       .text : 0xc0008000 - 0xc05d7a48   (5951 kB)
Feb 13 12:57:08 raspberrypi kernel: [    0.000000]       .init : 0xc0841000 - 0xc08a4000   ( 396 kB)
Feb 13 12:57:08 raspberrypi kernel: [    0.000000]       .data : 0xc08a4000 - 0xc091ef48   ( 492 kB)
Feb 13 12:57:08 raspberrypi kernel: [    0.000000]        .bss : 0xc091ef48 - 0xc09d4648   ( 726 kB)
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Feb 13 12:57:08 raspberrypi kernel: [    0.000000] NR_IRQS:16 nr_irqs:16 16
Feb 13 12:57:08 raspberrypi kernel: [    0.000032] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
Feb 13 12:57:08 raspberrypi kernel: [    0.000076] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
Feb 13 12:57:08 raspberrypi kernel: [    0.000176] bcm2835: system timer (irq = 27)
Feb 13 12:57:08 raspberrypi kernel: [    0.000647] Console: colour dummy device 80x30
Feb 13 12:57:08 raspberrypi kernel: [    0.001435] console [tty1] enabled
Feb 13 12:57:08 raspberrypi kernel: [    0.001492] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Feb 13 12:57:08 raspberrypi kernel: [    0.060363] pid_max: default: 32768 minimum: 301
Feb 13 12:57:08 raspberrypi kernel: [    0.060830] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Feb 13 12:57:08 raspberrypi kernel: [    0.060903] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Feb 13 12:57:08 raspberrypi kernel: [    0.062198] Disabling memory control group subsystem
Feb 13 12:57:08 raspberrypi kernel: [    0.062408] CPU: Testing write buffer coherency: ok
Feb 13 12:57:08 raspberrypi kernel: [    0.062512] ftrace: allocating 21715 entries in 64 pages
Feb 13 12:57:08 raspberrypi kernel: [    0.180837] Setting up static identity map for 0x8200 - 0x8238
Feb 13 12:57:08 raspberrypi kernel: [    0.182908] devtmpfs: initialized
Feb 13 12:57:08 raspberrypi kernel: [    0.192881] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Feb 13 12:57:08 raspberrypi kernel: [    0.193397] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Feb 13 12:57:08 raspberrypi kernel: [    0.193496] futex hash table entries: 256 (order: -1, 3072 bytes)
Feb 13 12:57:08 raspberrypi kernel: [    0.194820] pinctrl core: initialized pinctrl subsystem
Feb 13 12:57:08 raspberrypi kernel: [    0.196344] NET: Registered protocol family 16
Feb 13 12:57:08 raspberrypi kernel: [    0.198977] DMA: preallocated 1024 KiB pool for atomic coherent allocations
Feb 13 12:57:08 raspberrypi kernel: [    0.208737] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Feb 13 12:57:08 raspberrypi kernel: [    0.208832] hw-breakpoint: maximum watchpoint size is 4 bytes.
Feb 13 12:57:08 raspberrypi kernel: [    0.208973] Serial: AMBA PL011 UART driver
Feb 13 12:57:08 raspberrypi kernel: [    0.211920] bcm2835-mbox 2000b880.mailbox: mailbox enabled
Feb 13 12:57:08 raspberrypi kernel: [    0.212742] uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
Feb 13 12:57:08 raspberrypi kernel: [    0.262720] bcm2835-dma 20007000.dma: DMA legacy API manager at dc80d000, dmachans=0x1
Feb 13 12:57:08 raspberrypi kernel: [    0.265470] SCSI subsystem initialized
Feb 13 12:57:08 raspberrypi kernel: [    0.265799] usbcore: registered new interface driver usbfs
Feb 13 12:57:08 raspberrypi kernel: [    0.265972] usbcore: registered new interface driver hub
Feb 13 12:57:08 raspberrypi kernel: [    0.266216] usbcore: registered new device driver usb
Feb 13 12:57:08 raspberrypi kernel: [    0.270902] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-10-24 17:09
Feb 13 12:57:08 raspberrypi kernel: [    0.273031] clocksource: Switched to clocksource timer
Feb 13 12:57:08 raspberrypi kernel: [    0.327236] VFS: Disk quotas dquot_6.6.0
Feb 13 12:57:08 raspberrypi kernel: [    0.327438] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Feb 13 12:57:08 raspberrypi kernel: [    0.327814] FS-Cache: Loaded
Feb 13 12:57:08 raspberrypi kernel: [    0.328223] CacheFiles: Loaded
Feb 13 12:57:08 raspberrypi kernel: [    0.347670] NET: Registered protocol family 2
Feb 13 12:57:08 raspberrypi kernel: [    0.349095] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
Feb 13 12:57:08 raspberrypi kernel: [    0.349252] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Feb 13 12:57:08 raspberrypi kernel: [    0.349385] TCP: Hash tables configured (established 4096 bind 4096)
Feb 13 12:57:08 raspberrypi kernel: [    0.349520] UDP hash table entries: 256 (order: 0, 4096 bytes)
Feb 13 12:57:08 raspberrypi kernel: [    0.349588] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Feb 13 12:57:08 raspberrypi kernel: [    0.349951] NET: Registered protocol family 1
Feb 13 12:57:08 raspberrypi kernel: [    0.350756] RPC: Registered named UNIX socket transport module.
Feb 13 12:57:08 raspberrypi kernel: [    0.350832] RPC: Registered udp transport module.
Feb 13 12:57:08 raspberrypi kernel: [    0.350871] RPC: Registered tcp transport module.
Feb 13 12:57:08 raspberrypi kernel: [    0.350907] RPC: Registered tcp NFSv4.1 backchannel transport module.
Feb 13 12:57:08 raspberrypi kernel: [    0.352214] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
Feb 13 12:57:08 raspberrypi kernel: [    0.354898] workingset: timestamp_bits=14 max_order=17 bucket_order=3
Feb 13 12:57:08 raspberrypi kernel: [    0.375639] FS-Cache: Netfs 'nfs' registered for caching
Feb 13 12:57:08 raspberrypi kernel: [    0.377471] NFS: Registering the id_resolver key type
Feb 13 12:57:08 raspberrypi kernel: [    0.377583] Key type id_resolver registered
Feb 13 12:57:08 raspberrypi kernel: [    0.377627] Key type id_legacy registered
Feb 13 12:57:08 raspberrypi kernel: [    0.382141] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Feb 13 12:57:08 raspberrypi kernel: [    0.382607] io scheduler noop registered
Feb 13 12:57:08 raspberrypi kernel: [    0.382673] io scheduler deadline registered (default)
Feb 13 12:57:08 raspberrypi kernel: [    0.383296] io scheduler cfq registered
Feb 13 12:57:08 raspberrypi kernel: [    0.389213] BCM2708FB: allocated DMA memory 5b500000
Feb 13 12:57:08 raspberrypi kernel: [    0.389348] BCM2708FB: allocated DMA channel 0 @ dc80d000
Feb 13 12:57:08 raspberrypi kernel: [    0.397642] Console: switching to colour frame buffer device 82x26
Feb 13 12:57:08 raspberrypi kernel: [    0.409181] bcm2835-rng 20104000.rng: hwrng registered
Feb 13 12:57:08 raspberrypi kernel: [    0.412709] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
Feb 13 12:57:08 raspberrypi kernel: [    0.420422] vc-sm: Videocore shared memory driver
Feb 13 12:57:08 raspberrypi kernel: [    0.448391] brd: module loaded
Feb 13 12:57:08 raspberrypi kernel: [    0.464296] loop: module loaded
Feb 13 12:57:08 raspberrypi kernel: [    0.467577] Loading iSCSI transport class v2.0-870.
Feb 13 12:57:08 raspberrypi kernel: [    0.471705] usbcore: registered new interface driver smsc95xx
Feb 13 12:57:08 raspberrypi kernel: [    0.475153] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Feb 13 12:57:08 raspberrypi kernel: [    0.706923] Core Release: 2.80a
Feb 13 12:57:08 raspberrypi kernel: [    0.710294] Setting default values for core params
Feb 13 12:57:08 raspberrypi kernel: [    0.713708] Finished setting default values for core params
Feb 13 12:57:08 raspberrypi kernel: [    0.917428] Using Buffer DMA mode
Feb 13 12:57:08 raspberrypi kernel: [    0.920676] Periodic Transfer Interrupt Enhancement - disabled
Feb 13 12:57:08 raspberrypi kernel: [    0.923937] Multiprocessor Interrupt Enhancement - disabled
Feb 13 12:57:08 raspberrypi kernel: [    0.927120] OTG VER PARAM: 0, OTG VER FLAG: 0
Feb 13 12:57:08 raspberrypi kernel: [    0.930366] Dedicated Tx FIFOs mode
Feb 13 12:57:08 raspberrypi kernel: [    0.934234] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xdb514000 dma = 0x5b514000 len=9024
Feb 13 12:57:08 raspberrypi kernel: [    0.940783] FIQ FSM acceleration enabled for :
Feb 13 12:57:08 raspberrypi kernel: [    0.940783] Non-periodic Split Transactions
Feb 13 12:57:08 raspberrypi kernel: [    0.940783] Periodic Split Transactions
Feb 13 12:57:08 raspberrypi kernel: [    0.940783] High-Speed Isochronous Endpoints
Feb 13 12:57:08 raspberrypi kernel: [    0.940783] Interrupt/Control Split Transaction hack enabled
Feb 13 12:57:08 raspberrypi kernel: [    0.956873] dwc_otg: Microframe scheduler enabled
Feb 13 12:57:08 raspberrypi kernel: [    0.957002] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc0451694
Feb 13 12:57:08 raspberrypi kernel: [    0.960306] WARN::hcd_init_fiq:460: FIQ ASM at 0xc0451970 length 36
Feb 13 12:57:08 raspberrypi kernel: [    0.963599] WARN::hcd_init_fiq:486: MPHI regs_base at 0xdc8a5000
Feb 13 12:57:08 raspberrypi kernel: [    0.966944] dwc_otg 20980000.usb: DWC OTG Controller
Feb 13 12:57:08 raspberrypi kernel: [    0.970166] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
Feb 13 12:57:08 raspberrypi kernel: [    0.973539] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
Feb 13 12:57:08 raspberrypi kernel: [    0.976704] Init: Port Power? op_state=1
Feb 13 12:57:08 raspberrypi kernel: [    0.979855] Init: Power Port (0)
Feb 13 12:57:08 raspberrypi kernel: [    0.983399] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Feb 13 12:57:08 raspberrypi kernel: [    0.986684] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 13 12:57:08 raspberrypi kernel: [    0.989906] usb usb1: Product: DWC OTG Controller
Feb 13 12:57:08 raspberrypi kernel: [    0.993006] usb usb1: Manufacturer: Linux 4.9.59+ dwc_otg_hcd
Feb 13 12:57:08 raspberrypi kernel: [    0.996275] usb usb1: SerialNumber: 20980000.usb
Feb 13 12:57:08 raspberrypi kernel: [    1.000615] hub 1-0:1.0: USB hub found
Feb 13 12:57:08 raspberrypi kernel: [    1.003970] hub 1-0:1.0: 1 port detected
Feb 13 12:57:08 raspberrypi kernel: [    1.007955] dwc_otg: FIQ enabled
Feb 13 12:57:08 raspberrypi kernel: [    1.007966] dwc_otg: NAK holdoff enabled
Feb 13 12:57:08 raspberrypi kernel: [    1.007971] dwc_otg: FIQ split-transaction FSM enabled
Feb 13 12:57:08 raspberrypi kernel: [    1.007992] Module dwc_common_port init
Feb 13 12:57:08 raspberrypi kernel: [    1.008487] usbcore: registered new interface driver usb-storage
Feb 13 12:57:08 raspberrypi kernel: [    1.012125] mousedev: PS/2 mouse device common for all mice
Feb 13 12:57:08 raspberrypi kernel: [    1.017162] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
Feb 13 12:57:08 raspberrypi kernel: [    1.020990] bcm2835-cpufreq: min=700000 max=1000000
Feb 13 12:57:08 raspberrypi kernel: [    1.024853] sdhci: Secure Digital Host Controller Interface driver
Feb 13 12:57:08 raspberrypi kernel: [    1.027967] sdhci: Copyright(c) Pierre Ossman
Feb 13 12:57:08 raspberrypi kernel: [    1.031485] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
Feb 13 12:57:08 raspberrypi kernel: [    1.037336] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
Feb 13 12:57:08 raspberrypi kernel: [    1.040852] sdhci-pltfm: SDHCI platform and OF driver helper
Feb 13 12:57:08 raspberrypi kernel: [    1.044778] ledtrig-cpu: registered to indicate activity on CPUs
Feb 13 12:57:08 raspberrypi kernel: [    1.048345] hidraw: raw HID events driver (C) Jiri Kosina
Feb 13 12:57:08 raspberrypi kernel: [    1.051969] usbcore: registered new interface driver usbhid
Feb 13 12:57:08 raspberrypi kernel: [    1.055436] usbhid: USB HID core driver
Feb 13 12:57:08 raspberrypi kernel: [    1.060021] vchiq: vchiq_init_state: slot_zero = 0xdb580000, is_master = 0
Feb 13 12:57:08 raspberrypi kernel: [    1.065514] [vc_sm_connected_init]: start
Feb 13 12:57:08 raspberrypi kernel: [    1.076132] [vc_sm_connected_init]: end - returning 0
Feb 13 12:57:08 raspberrypi kernel: [    1.080154] Initializing XFRM netlink socket
Feb 13 12:57:08 raspberrypi kernel: [    1.083687] NET: Registered protocol family 17
Feb 13 12:57:08 raspberrypi kernel: [    1.087240] Key type dns_resolver registered
Feb 13 12:57:08 raspberrypi kernel: [    1.092426] registered taskstats version 1
Feb 13 12:57:08 raspberrypi kernel: [    1.104932] uart-pl011 20201000.serial: cts_event_workaround enabled
Feb 13 12:57:08 raspberrypi kernel: [    1.108510] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
Feb 13 12:57:08 raspberrypi kernel: [    1.117782] sdhost: log_buf @ db513000 (5b513000)
Feb 13 12:57:08 raspberrypi kernel: [    1.193112] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Feb 13 12:57:08 raspberrypi kernel: [    1.199341] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
Feb 13 12:57:08 raspberrypi kernel: [    1.202974] mmc-bcm2835 20300000.mmc: DMA channel allocated
Feb 13 12:57:08 raspberrypi kernel: [    1.236335] random: fast init done
Feb 13 12:57:08 raspberrypi kernel: [    1.280225] mmc0: host does not support reading read-only switch, assuming write-enable
Feb 13 12:57:08 raspberrypi kernel: [    1.287423] of_cfs_init
Feb 13 12:57:08 raspberrypi kernel: [    1.291005] of_cfs_init: OK
Feb 13 12:57:08 raspberrypi kernel: [    1.299840] mmc0: new high speed SDHC card at address 0001
Feb 13 12:57:08 raspberrypi kernel: [    1.309226] Waiting for root device /dev/mmcblk0p2...
Feb 13 12:57:08 raspberrypi kernel: [    1.313328] mmcblk0: mmc0:0001 00000 29.8 GiB
Feb 13 12:57:08 raspberrypi kernel: [    1.319121]  mmcblk0: p1 p2
Feb 13 12:57:08 raspberrypi kernel: [    1.328738] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Feb 13 12:57:08 raspberrypi kernel: [    1.333824] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Feb 13 12:57:08 raspberrypi kernel: [    1.338732] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Feb 13 12:57:08 raspberrypi kernel: [    1.344816] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Feb 13 12:57:08 raspberrypi kernel: [    1.437618] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 13 12:57:08 raspberrypi kernel: [    1.443839] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Feb 13 12:57:08 raspberrypi kernel: [    1.448308] devtmpfs: mounted
Feb 13 12:57:08 raspberrypi kernel: [    1.452902] Freeing unused kernel memory: 396K
Feb 13 12:57:08 raspberrypi kernel: [    1.456198] This architecture does not have kernel memory protection.
Feb 13 12:57:08 raspberrypi kernel: [    1.474311] mmc1: new high speed SDIO card at address 0001
Feb 13 12:57:08 raspberrypi kernel: [    2.062858] NET: Registered protocol family 10
Feb 13 12:57:08 raspberrypi kernel: [    2.094756] ip_tables: (C) 2000-2006 Netfilter Core Team
Feb 13 12:57:08 raspberrypi kernel: [    3.506138] i2c /dev entries driver
Feb 13 12:57:08 raspberrypi kernel: [   64.745973] random: crng init done
Feb 13 12:57:08 raspberrypi kernel: [   64.877402] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Feb 13 12:57:08 raspberrypi kernel: [   67.161596] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
Feb 13 12:57:08 raspberrypi kernel: [   68.292502] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
Feb 13 12:57:08 raspberrypi kernel: [   68.309589] usbcore: registered new interface driver brcmfmac
Feb 13 12:57:08 raspberrypi kernel: [   68.741190] brcmfmac: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
Feb 13 12:57:08 raspberrypi kernel: [   68.742419] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
Feb 13 12:57:08 raspberrypi systemd[1]: Started File System Check on Root Device.
Feb 13 12:57:08 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
Feb 13 12:57:08 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
Feb 13 12:57:08 raspberrypi systemd[1]: Starting Load/Save Random Seed...
Feb 13 12:57:08 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
Feb 13 12:57:08 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
Feb 13 12:57:08 raspberrypi systemd[1]: Starting udev Coldplug all Devices...
Feb 13 12:57:08 raspberrypi systemd[1]: Started Load/Save Random Seed.
Feb 13 12:57:08 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
Feb 13 12:57:08 raspberrypi systemd[1]: Started udev Coldplug all Devices.
Feb 13 12:57:08 raspberrypi systemd[1]: Starting Show Plymouth Boot Screen...
Feb 13 12:57:08 raspberrypi systemd[1]: Received SIGRTMIN+20 from PID 158 (plymouthd).
Feb 13 12:57:08 raspberrypi systemd[1]: Started Show Plymouth Boot Screen.
Feb 13 12:57:08 raspberrypi systemd[1]: Reached target Encrypted Volumes.
Feb 13 12:57:08 raspberrypi systemd[1]: Reached target Paths.
Feb 13 12:57:08 raspberrypi systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Feb 13 12:57:08 raspberrypi systemd[1]: Found device /dev/serial1.
Feb 13 12:57:08 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/7b7fce4f-01.
Feb 13 12:57:08 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/7b7fce4f-01...
Feb 13 12:57:08 raspberrypi systemd-fsck[177]: fsck.fat 4.1 (2017-01-24)
Feb 13 12:57:08 raspberrypi systemd-fsck[177]: /dev/mmcblk0p1: 144 files, 42655/83705 clusters
Feb 13 12:57:08 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/7b7fce4f-01.
Feb 13 12:57:08 raspberrypi systemd[1]: Mounting /boot...
Feb 13 12:57:08 raspberrypi systemd[1]: Mounted /boot.
Feb 13 12:57:08 raspberrypi systemd[1]: Reached target Local File Systems.
Feb 13 12:57:08 raspberrypi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Feb 13 12:57:08 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
Feb 13 12:57:08 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
Feb 13 12:57:08 raspberrypi systemd[1]: Starting Raise network interfaces...
Feb 13 12:57:08 raspberrypi systemd[1]: Starting Set console font and keymap...
Feb 13 12:57:08 raspberrypi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Feb 13 12:57:08 raspberrypi systemd[1]: Started Preprocess NFS configuration.
Feb 13 12:57:08 raspberrypi systemd[1]: Started Set console font and keymap.
Feb 13 12:57:08 raspberrypi systemd[1]: Reached target NFS client services.
Feb 13 12:57:08 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
Feb 13 12:57:08 raspberrypi systemd[1]: Reached target Remote File Systems.
Feb 13 12:57:08 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Feb 13 12:57:08 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Feb 13 12:57:08 raspberrypi systemd[1]: Starting Network Time Synchronization...
Feb 13 12:57:08 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Feb 13 12:57:08 raspberrypi systemd[1]: Started Network Time Synchronization.
Feb 13 12:57:08 raspberrypi systemd[1]: Reached target System Time Synchronized.
Feb 13 12:57:08 raspberrypi systemd[1]: Reached target System Initialization.
Feb 13 12:57:08 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Feb 13 12:57:08 raspberrypi systemd[1]: Listening on triggerhappy.socket.
Feb 13 12:57:08 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
Feb 13 12:57:08 raspberrypi systemd[1]: apt-daily.timer: Adding 6h 43min 39.610214s random time.
Feb 13 12:57:08 raspberrypi systemd[1]: Started Daily apt download activities.
Feb 13 12:57:08 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 38min 1.544771s random time.
Feb 13 12:57:08 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Feb 13 12:57:08 raspberrypi systemd[1]: Reached target Timers.
Feb 13 12:57:08 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Feb 13 12:57:08 raspberrypi systemd[1]: Reached target Sockets.
Feb 13 12:57:08 raspberrypi systemd[1]: Reached target Basic System.
Feb 13 12:57:08 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Feb 13 12:57:08 raspberrypi systemd[1]: Started D-Bus System Message Bus.
Feb 13 12:57:08 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Feb 13 12:57:08 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Feb 13 12:57:08 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
Feb 13 12:57:08 raspberrypi systemd[1]: Started Regular background program processing daemon.
Feb 13 12:57:08 raspberrypi systemd[1]: Starting System Logging Service...
Feb 13 12:57:08 raspberrypi avahi-daemon[244]: Found user 'avahi' (UID 108) and group 'avahi' (GID 112).
Feb 13 12:57:08 raspberrypi thd[248]: Found socket passed from systemd
Feb 13 12:57:08 raspberrypi cron[249]: (CRON) INFO (pidfile fd = 3)
Feb 13 12:57:08 raspberrypi cron[249]: (CRON) INFO (Running @reboot jobs)
Feb 13 12:57:08 raspberrypi avahi-daemon[244]: Successfully dropped root privileges.
Feb 13 12:57:08 raspberrypi avahi-daemon[244]: avahi-daemon 0.6.32 starting up.
Feb 13 12:57:08 raspberrypi systemd[1]: Starting Login Service...
Feb 13 12:57:08 raspberrypi systemd[1]: Starting Check for v3d driver...
Feb 13 12:57:08 raspberrypi avahi-daemon[244]: Successfully called chroot().
Feb 13 12:57:08 raspberrypi avahi-daemon[244]: Successfully dropped remaining capabilities.
Feb 13 12:57:08 raspberrypi avahi-daemon[244]: No service file found in /etc/avahi/services.
Feb 13 12:57:08 raspberrypi avahi-daemon[244]: Network interface enumeration completed.
Feb 13 12:57:08 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Feb 13 12:57:08 raspberrypi avahi-daemon[244]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 2654366925.
Feb 13 12:57:08 raspberrypi systemd[1]: Starting LSB: Autogenerate and use a swap file...
Feb 13 12:57:08 raspberrypi liblogging-stdlog:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="253" x-info="http://www.rsyslog.com"] start
Feb 13 12:57:08 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
Feb 13 12:57:08 raspberrypi systemd[1]: Started System Logging Service.
Feb 13 12:57:08 raspberrypi dhcpcd[263]: dev: loaded udev
Feb 13 12:57:08 raspberrypi dhcpcd[263]: no valid interfaces found
Feb 13 12:57:08 raspberrypi dhcpcd[263]: forked to background, child pid 280
Feb 13 12:57:08 raspberrypi kernel: [   72.585357] uart-pl011 20201000.serial: no DMA platform data
Feb 13 12:57:08 raspberrypi systemd[1]: Started Check for v3d driver.
Feb 13 12:57:08 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Feb 13 12:57:09 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Feb 13 12:57:09 raspberrypi dphys-swapfile[264]: Starting dphys-swapfile swapfile setup ...
Feb 13 12:57:09 raspberrypi systemd[1]: Started Login Service.
Feb 13 12:57:09 raspberrypi raspi-config[238]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
Feb 13 12:57:09 raspberrypi raspi-config[238]:  No. Switching to ondemand scaling governor.
Feb 13 12:57:09 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Feb 13 12:57:09 raspberrypi dphys-swapfile[264]: want /var/swap=100MByte, checking existing: keeping it
Feb 13 12:57:09 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Feb 13 12:57:09 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
Feb 13 12:57:10 raspberrypi systemd[1]: Started Raise network interfaces.
Feb 13 12:57:10 raspberrypi systemd[1]: Reached target Network.
Feb 13 12:57:10 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
Feb 13 12:57:10 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Feb 13 12:57:10 raspberrypi systemd[1]: Starting Permit User Sessions...
Feb 13 12:57:10 raspberrypi kernel: [   74.237567] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SSFS
Feb 13 12:57:10 raspberrypi dphys-swapfile[264]: done.
Feb 13 12:57:10 raspberrypi systemd[1]: Started LSB: Autogenerate and use a swap file.
Feb 13 12:57:10 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
Feb 13 12:57:10 raspberrypi systemd[1]: Started Permit User Sessions.
Feb 13 12:57:10 raspberrypi systemd[1]: Starting Light Display Manager...
Feb 13 12:57:10 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
Feb 13 12:57:10 raspberrypi systemd[1]: Starting Terminate Plymouth Boot Screen...
Feb 13 12:57:10 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 158 (plymouthd).
Feb 13 12:57:10 raspberrypi systemd[1]: Started Hold until boot process finishes up.
Feb 13 12:57:11 raspberrypi systemd[1]: Started Terminate Plymouth Boot Screen.
Feb 13 12:57:11 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
Feb 13 12:57:11 raspberrypi systemd[1]: Started Getty on tty1.
Feb 13 12:57:11 raspberrypi systemd[1]: Reached target Login Prompts.
Feb 13 12:57:11 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Feb 13 12:57:11 raspberrypi systemd-udevd[155]: Process '/sbin/crda' failed with exit code 249.
Feb 13 12:57:11 raspberrypi dhcpcd-run-hooks[366]: wlan0: starting wpa_supplicant
Feb 13 12:57:11 raspberrypi lightdm[348]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Feb 13 12:57:12 raspberrypi kernel: [   76.031276] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Feb 13 12:57:12 raspberrypi kernel: [   76.031293] brcmfmac: power management disabled
Feb 13 12:57:12 raspberrypi systemd[1]: Started Light Display Manager.
Feb 13 12:57:12 raspberrypi dhcpcd[280]: wlan0: waiting for carrier
Feb 13 12:57:12 raspberrypi dhcpcd[280]: wlan0: carrier acquired
Feb 13 12:57:12 raspberrypi dhcpcd[280]: DUID 00:01:00:01:21:b0:de:6a:b8:27:eb:cb:76:07
Feb 13 12:57:12 raspberrypi dhcpcd[280]: wlan0: IAID eb:cb:76:07
Feb 13 12:57:12 raspberrypi dhcpcd[280]: wlan0: adding address fe80::e155:9544:daa:ffa1
Feb 13 12:57:12 raspberrypi dhcpcd[280]: wlan0: carrier lost
Feb 13 12:57:12 raspberrypi dhcpcd[280]: wlan0: deleting address fe80::e155:9544:daa:ffa1
Feb 13 12:57:13 raspberrypi kernel: [   77.118362] Bluetooth: Core ver 2.22
Feb 13 12:57:13 raspberrypi kernel: [   77.118505] NET: Registered protocol family 31
Feb 13 12:57:13 raspberrypi kernel: [   77.118513] Bluetooth: HCI device and connection manager initialized
Feb 13 12:57:13 raspberrypi kernel: [   77.118535] Bluetooth: HCI socket layer initialized
Feb 13 12:57:13 raspberrypi kernel: [   77.118549] Bluetooth: L2CAP socket layer initialized
Feb 13 12:57:13 raspberrypi kernel: [   77.118591] Bluetooth: SCO socket layer initialized
Feb 13 12:57:13 raspberrypi kernel: [   77.153960] Bluetooth: HCI UART driver ver 2.3
Feb 13 12:57:13 raspberrypi kernel: [   77.153976] Bluetooth: HCI UART protocol H4 registered
Feb 13 12:57:13 raspberrypi kernel: [   77.153981] Bluetooth: HCI UART protocol Three-wire (H5) registered
Feb 13 12:57:13 raspberrypi kernel: [   77.154140] Bluetooth: HCI UART protocol Broadcom registered
Feb 13 12:57:13 raspberrypi btuart[243]: bcm43xx_init
Feb 13 12:57:13 raspberrypi btuart[243]: Flash firmware /lib/firmware/BCM43430A1.hcd
Feb 13 12:57:13 raspberrypi btuart[243]: Set BDADDR UART: b8:27:eb:34:89:f8
Feb 13 12:57:13 raspberrypi btuart[243]: Set Controller UART speed to 3000000 bit/s
Feb 13 12:57:13 raspberrypi btuart[243]: Device setup complete
Feb 13 12:57:13 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
Feb 13 12:57:13 raspberrypi systemd[1]: Starting Bluetooth service...
Feb 13 12:57:13 raspberrypi systemd[1]: Reached target Multi-User System.
Feb 13 12:57:13 raspberrypi bluetoothd[403]: Bluetooth daemon 5.43
Feb 13 12:57:13 raspberrypi systemd[1]: Started Bluetooth service.
Feb 13 12:57:13 raspberrypi bluetoothd[403]: Starting SDP server
Feb 13 12:57:13 raspberrypi systemd[1]: Started BluezALSA proxy.
Feb 13 12:57:13 raspberrypi kernel: [   77.543122] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Feb 13 12:57:13 raspberrypi kernel: [   77.543135] Bluetooth: BNEP filters: protocol multicast
Feb 13 12:57:13 raspberrypi kernel: [   77.543164] Bluetooth: BNEP socket layer initialized
Feb 13 12:57:13 raspberrypi systemd[1]: Reached target Graphical Interface.
Feb 13 12:57:13 raspberrypi bluetoothd[403]: Bluetooth management interface 1.14 initialized
Feb 13 12:57:13 raspberrypi bluetoothd[403]: Failed to obtain handles for "Service Changed" characteristic
Feb 13 12:57:13 raspberrypi bluetoothd[403]: Sap driver initialization failed.
Feb 13 12:57:13 raspberrypi bluetoothd[403]: sap-server: Operation not permitted (1)
Feb 13 12:57:13 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Feb 13 12:57:13 raspberrypi dbus[239]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Feb 13 12:57:13 raspberrypi bluetoothd[403]: Endpoint registered: sender=:1.6 path=/A2DP/SBC/Source/1
Feb 13 12:57:13 raspberrypi bluetoothd[403]: Endpoint registered: sender=:1.6 path=/A2DP/SBC/Sink/1
Feb 13 12:57:14 raspberrypi kernel: [   77.983333] Bluetooth: RFCOMM TTY layer initialized
Feb 13 12:57:14 raspberrypi kernel: [   77.983371] Bluetooth: RFCOMM socket layer initialized
Feb 13 12:57:14 raspberrypi kernel: [   77.983405] Bluetooth: RFCOMM ver 1.11
Feb 13 12:57:14 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Feb 13 12:57:14 raspberrypi systemd[1]: Reached target Bluetooth.
Feb 13 12:57:14 raspberrypi systemd[1]: Starting Hostname Service...
Feb 13 12:57:14 raspberrypi dbus[239]: [system] Successfully activated service 'org.freedesktop.hostname1'
Feb 13 12:57:14 raspberrypi systemd[1]: Started Hostname Service.
Feb 13 12:57:14 raspberrypi systemd[1]: Startup finished in 1.803s (kernel) + 1min 16.479s (userspace) = 1min 18.283s.
Feb 13 12:57:14 raspberrypi systemd[1]: Created slice User Slice of pi.
Feb 13 12:57:14 raspberrypi systemd[1]: Starting User Manager for UID 1000...
Feb 13 12:57:14 raspberrypi systemd[1]: Started Session c1 of user pi.
Feb 13 12:57:15 raspberrypi systemd[429]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Feb 13 12:57:15 raspberrypi systemd[429]: Listening on GnuPG cryptographic agent (access for web browsers).
Feb 13 12:57:15 raspberrypi systemd[429]: Starting D-Bus User Message Bus Socket.
Feb 13 12:57:15 raspberrypi systemd[429]: Reached target Paths.
Feb 13 12:57:15 raspberrypi systemd[429]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Feb 13 12:57:15 raspberrypi systemd[429]: Reached target Timers.
Feb 13 12:57:15 raspberrypi systemd[429]: Listening on GnuPG cryptographic agent and passphrase cache.
Feb 13 12:57:15 raspberrypi systemd[429]: Listening on D-Bus User Message Bus Socket.
Feb 13 12:57:15 raspberrypi systemd[429]: Reached target Sockets.
Feb 13 12:57:15 raspberrypi systemd[429]: Reached target Basic System.
Feb 13 12:57:15 raspberrypi systemd[429]: Reached target Default.
Feb 13 12:57:15 raspberrypi systemd[429]: Startup finished in 434ms.
Feb 13 12:57:15 raspberrypi systemd[1]: Started User Manager for UID 1000.
Feb 13 12:57:16 raspberrypi lightdm[450]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Feb 13 12:57:16 raspberrypi systemd[1]: Started Session c2 of user pi.
Feb 13 12:57:17 raspberrypi lightdm[348]: Error opening audit socket: Protocol not supported
Feb 13 12:57:17 raspberrypi systemd[429]: Started D-Bus User Message Bus.
Feb 13 12:57:20 raspberrypi dbus-daemon[480]: Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service'
Feb 13 12:57:20 raspberrypi systemd[429]: Starting Virtual filesystem service...
Feb 13 12:57:21 raspberrypi dbus-daemon[480]: Successfully activated service 'org.gtk.vfs.Daemon'
Feb 13 12:57:21 raspberrypi systemd[429]: Started Virtual filesystem service.
Feb 13 12:57:21 raspberrypi kernel: [   85.153164] fuse init (API version 7.26)
Feb 13 12:57:21 raspberrypi systemd[1]: Mounting FUSE Control File System...
Feb 13 12:57:21 raspberrypi systemd[1]: Mounted FUSE Control File System.
Feb 13 12:57:23 raspberrypi dbus[239]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
Feb 13 12:57:23 raspberrypi systemd[1]: Starting Authorization Manager...
Feb 13 12:57:23 raspberrypi polkitd[582]: started daemon version 0.105 using authority implementation `local' version `0.105'
Feb 13 12:57:23 raspberrypi dbus[239]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Feb 13 12:57:23 raspberrypi systemd[1]: Started Authorization Manager.
Feb 13 12:57:31 raspberrypi dbus-daemon[480]: Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service'
Feb 13 12:57:31 raspberrypi systemd[429]: Starting Virtual filesystem service - disk device monitor...
Feb 13 12:57:32 raspberrypi dbus[239]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
Feb 13 12:57:32 raspberrypi systemd[1]: Starting Disk Manager...
Feb 13 12:57:32 raspberrypi udisksd[620]: udisks daemon version 2.1.8 starting
Feb 13 12:57:33 raspberrypi dbus[239]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Feb 13 12:57:33 raspberrypi systemd[1]: Started Disk Manager.
Feb 13 12:57:33 raspberrypi udisksd[620]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Feb 13 12:57:34 raspberrypi dbus-daemon[480]: Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Feb 13 12:57:34 raspberrypi systemd[429]: Started Virtual filesystem service - disk device monitor.
Feb 13 12:57:34 raspberrypi dbus-daemon[480]: Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service'
Feb 13 12:57:34 raspberrypi systemd[429]: Starting Virtual filesystem service - digital camera monitor...
Feb 13 12:57:34 raspberrypi dbus-daemon[480]: Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Feb 13 12:57:34 raspberrypi systemd[429]: Started Virtual filesystem service - digital camera monitor.
Feb 13 12:57:34 raspberrypi dbus-daemon[480]: Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service'
Feb 13 12:57:35 raspberrypi systemd[429]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Feb 13 12:57:35 raspberrypi dbus-daemon[480]: Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Feb 13 12:57:35 raspberrypi systemd[429]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Feb 13 12:57:35 raspberrypi dbus-daemon[480]: Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service'
Feb 13 12:57:35 raspberrypi systemd[429]: Starting Virtual filesystem service - Apple File Conduit monitor...
Feb 13 12:57:35 raspberrypi gvfs-afc-volume-monitor[638]: Volume monitor alive
Feb 13 12:57:35 raspberrypi dbus-daemon[480]: Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Feb 13 12:57:35 raspberrypi systemd[429]: Started Virtual filesystem service - Apple File Conduit monitor.
Feb 13 12:57:35 raspberrypi dbus-daemon[480]: Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service'
Feb 13 12:57:35 raspberrypi systemd[429]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
Feb 13 12:57:35 raspberrypi dbus-daemon[480]: Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
Feb 13 12:57:35 raspberrypi systemd[429]: Started Virtual filesystem service - GNOME Online Accounts monitor.
Feb 13 12:56:02 raspberrypi systemd-modules-load[109]: Inserted module 'i2c_dev'
Feb 13 12:56:02 raspberrypi fake-hwclock[111]: Tue 13 Feb 12:56:00 UTC 2018
Feb 13 12:56:02 raspberrypi systemd[1]: Mounted Configuration File System.
Feb 13 12:56:02 raspberrypi systemd[1]: Started Apply Kernel Variables.
Feb 13 12:56:02 raspberrypi systemd-fsck[135]: e2fsck 1.43.4 (31-Jan-2017)
Feb 13 12:56:02 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
Feb 13 12:56:02 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
Feb 13 12:56:02 raspberrypi systemd-udevd[149]: Network interface NamePolicy= disabled on kernel command line, ignoring.
Feb 13 12:56:02 raspberrypi systemd-fsck[135]: Superblock last mount time is in the future.
Feb 13 12:56:02 raspberrypi systemd-fsck[135]: #011(by less than a day, probably due to the hardware clock being incorrectly set)
Feb 13 12:56:02 raspberrypi systemd-fsck[135]: rootfs: clean, 137452/1923472 files, 1223477/7803392 blocks
Feb 13 12:56:02 raspberrypi systemd[1]: Started File System Check on Root Device.
Feb 13 12:56:02 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
Feb 13 12:56:02 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
Feb 13 12:56:02 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
Feb 13 12:56:02 raspberrypi systemd[1]: Starting Load/Save Random Seed...
Feb 13 12:56:02 raspberrypi systemd[1]: Starting udev Coldplug all Devices...
Feb 13 12:56:02 raspberrypi systemd[1]: Started udev Kernel Device Manager.
Feb 13 12:56:02 raspberrypi systemd[1]: Started Load/Save Random Seed.
Feb 13 12:56:02 raspberrypi systemd[1]: Started Set the console keyboard layout.
Feb 13 12:56:02 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
Feb 13 12:56:02 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
Feb 13 12:56:02 raspberrypi systemd[1]: Started udev Coldplug all Devices.
Feb 13 12:56:02 raspberrypi systemd[1]: Starting Show Plymouth Boot Screen...
Feb 13 12:56:02 raspberrypi systemd[1]: Received SIGRTMIN+20 from PID 207 (plymouthd).
Feb 13 12:56:02 raspberrypi systemd[1]: Started Show Plymouth Boot Screen.
Feb 13 12:56:02 raspberrypi systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Feb 13 12:56:02 raspberrypi systemd[1]: Reached target Paths.
Feb 13 12:56:02 raspberrypi systemd[1]: Reached target Encrypted Volumes.
Feb 13 12:56:02 raspberrypi systemd[1]: Found device /dev/ttyAMA0.
Feb 13 12:56:02 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/7b7fce4f-01.
Feb 13 12:56:02 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/7b7fce4f-01...
Feb 13 12:56:02 raspberrypi mtp-probe: checking bus 1, device 3: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1"
Feb 13 12:56:02 raspberrypi mtp-probe: bus: 1, device: 3 was not an MTP device
Feb 13 12:56:02 raspberrypi systemd-fsck[225]: fsck.fat 4.1 (2017-01-24)
Feb 13 12:56:02 raspberrypi systemd-fsck[225]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Feb 13 12:56:02 raspberrypi systemd-fsck[225]:  Automatically removing dirty bit.
Feb 13 12:56:02 raspberrypi systemd-fsck[225]: Performing changes.
Feb 13 12:56:02 raspberrypi systemd-fsck[225]: /dev/mmcblk0p1: 144 files, 42655/83705 clusters
Feb 13 12:56:02 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/7b7fce4f-01.
Feb 13 12:56:02 raspberrypi systemd[1]: Mounting /boot...
Feb 13 12:56:02 raspberrypi systemd[1]: Mounted /boot.
Feb 13 12:56:02 raspberrypi systemd[1]: Reached target Local File Systems.
Feb 13 12:56:02 raspberrypi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Feb 13 12:56:02 raspberrypi systemd[1]: Starting Raise network interfaces...
Feb 13 12:56:02 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
Feb 13 12:56:02 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
Feb 13 12:56:02 raspberrypi systemd[1]: Starting Set console font and keymap...
Feb 13 12:56:02 raspberrypi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Feb 13 12:56:02 raspberrypi systemd[1]: Started Preprocess NFS configuration.
Feb 13 12:56:02 raspberrypi systemd[1]: Started Set console font and keymap.
Feb 13 12:56:02 raspberrypi systemd[1]: Reached target NFS client services.
Feb 13 12:56:02 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
Feb 13 12:56:02 raspberrypi systemd[1]: Reached target Remote File Systems.
Feb 13 12:56:02 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Feb 13 12:56:02 raspberrypi systemd[1]: Starting Network Time Synchronization...
Feb 13 12:56:02 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Feb 13 12:56:02 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Feb 13 12:56:02 raspberrypi systemd[1]: Started Network Time Synchronization.
Feb 13 12:56:02 raspberrypi systemd[1]: Reached target System Time Synchronized.
Feb 13 12:56:02 raspberrypi systemd[1]: Reached target System Initialization.
Feb 13 12:56:02 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Feb 13 12:56:02 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Feb 13 12:56:02 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
Feb 13 12:56:02 raspberrypi systemd[1]: Listening on triggerhappy.socket.
Feb 13 12:56:02 raspberrypi systemd[1]: Reached target Sockets.
Feb 13 12:56:02 raspberrypi systemd[1]: Reached target Basic System.
Feb 13 12:56:02 raspberrypi systemd[1]: Starting Check for v3d driver...
Feb 13 12:56:02 raspberrypi systemd[1]: Started Regular background program processing daemon.
Feb 13 12:56:02 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Feb 13 12:56:02 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Feb 13 12:56:02 raspberrypi systemd[1]: Starting Login Service...
Feb 13 12:56:02 raspberrypi systemd[1]: Started D-Bus System Message Bus.
Feb 13 12:56:02 raspberrypi cron[305]: (CRON) INFO (pidfile fd = 3)
Feb 13 12:56:02 raspberrypi cron[305]: (CRON) INFO (Running @reboot jobs)
Feb 13 12:56:02 raspberrypi avahi-daemon[307]: Found user 'avahi' (UID 108) and group 'avahi' (GID 112).
Feb 13 12:56:02 raspberrypi avahi-daemon[307]: Successfully dropped root privileges.
Feb 13 12:56:02 raspberrypi avahi-daemon[307]: avahi-daemon 0.6.32 starting up.
Feb 13 12:56:02 raspberrypi avahi-daemon[307]: Successfully called chroot().
Feb 13 12:56:02 raspberrypi avahi-daemon[307]: Successfully dropped remaining capabilities.
Feb 13 12:56:02 raspberrypi avahi-daemon[307]: No service file found in /etc/avahi/services.
Feb 13 12:56:02 raspberrypi dbus[310]: [system] Successfully activated service 'org.freedesktop.systemd1'
Feb 13 12:56:02 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Feb 13 12:56:02 raspberrypi avahi-daemon[307]: Network interface enumeration completed.
Feb 13 12:56:02 raspberrypi systemd[1]: apt-daily.timer: Adding 1h 34min 28.588249s random time.
Feb 13 12:56:02 raspberrypi avahi-daemon[307]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 1633919705.
Feb 13 12:56:02 raspberrypi systemd[1]: Started Daily apt download activities.
Feb 13 12:56:02 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 22min 49.790130s random time.
Feb 13 12:56:02 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Feb 13 12:56:02 raspberrypi systemd[1]: Reached target Timers.
Feb 13 12:56:02 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Feb 13 12:56:02 raspberrypi systemd[1]: Starting LSB: Autogenerate and use a swap file...
Feb 13 12:56:02 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
Feb 13 12:56:02 raspberrypi systemd[1]: Starting System Logging Service...
Feb 13 12:56:02 raspberrypi systemd[1]: Started Check for v3d driver.
Feb 13 12:56:02 raspberrypi thd[318]: Found socket passed from systemd
Feb 13 12:56:02 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
Feb 13 12:56:02 raspberrypi dhcpcd[316]: dev: loaded udev
The line contents "Feb 13 12:56:02 raspberrypi dhcpcd[316]: dev: loaded udev" is indeed the last entry after unplugging the device from its PSU (have been waiting quite a long time to assess whether at any point in time the device will still connect to the knwon Wifi AP).
carriba
Contact: ICQ
Re: No Wifi connection to Pi Zero W after Raspbian update
Tue Feb 13, 2018 4:02 pm
And here the contents of the /var/log/kern.log after 2nd boot of Raspbian (after OS packages updates):
Tue Feb 13, 2018 5:29 pm
That's interesting because your most recent Nov 29 version has the /sbin/crda failure after the initial dhcp 'dev: loaded udev' and that works, no "No valid interfaces" error, and it works.
The repeated udev and the dhcp 'dev: loaded udev' stuff later on in the Feb 13 version seems to be triggered because the data or time has changed.
I am still convinced the "No valid interfaces" in Feb 13 explains why it differs after that, why WiFi can't be found. It's not clear though what is leading to that, what's different before then.
I'll see if I can alter my syslog filtering program to determine what that may be.
