FezVrasta
Re: RPi 3B+ gigabit ethernet bad download speeds.
Mon May 21, 2018 8:01 am
Oh that sucks... I applied this update and limited the freq_sdram to 500 and the situation got better, now I can watch a movie just fine, if it gets stuck a restart is enough to have it run for several hours.
But yeah... I bought the B+ just because of the faster ethernet and this is pretty disappointing :-(
Mon May 21, 2018 9:12 am
billybangleballs wrote:
Sun May 20, 2018 3:21 pm
FezVrasta wrote:
Sat May 19, 2018 6:15 pm
Hi guys, I came here because I'm having SMB problems as well.
All the tests I did (iperf, speedtest-cli, manual tests) all run smoothly, the problem is when I try to play a video from the mounted hard drive of my RPi3 B+ from a device connected to it via SMB.
Is there any workaround (even if it may mean to give up on the gigabit speed) to get the SMB work properly while I wait for a proper fix from the maintainers?
Thanks!
I went back to using a plain 3B, the 3B+ is just not right in the networking, and it was the faster networking that I bought it for. Hopefully there will be a fix sometime in the future.
There will be, once we figure out all the issues.
fedekrum
Sat Jun 02, 2018 2:40 pm
To the RBPi team. Is there any news on this issue?
bergkuh
Tue Jun 05, 2018 7:38 am
Same issue here with my new Pi 3 B+. Any news on this? Already did a kernel update today.
Tue Jun 05, 2018 8:22 am
First thing to check is whether you have flow control enabled on your router, if not this can cause problems.
bergkuh
Tue Jun 05, 2018 9:01 am
My FritzBox 6490 is set to Power Mode (1 Gbit/s) on each port, my D-Link DGS-1005D has IEEE 802.3x Flow Control enabled by default.
Tue Jun 05, 2018 9:11 am
Without flow control you get a lot of transmissions which can badly affect speed. This is due to the limited speed we can get data off the ethernet chip via the USB interface - it cannot cope with full gigabit rates, so unless flow control is turned on will be swamped, which causes retransmits.
But it appears this is not your issue. What sort of data rates are you getting? I would expect about 200-250Mbits/s.
bergkuh
Tue Jun 05, 2018 9:24 am
I think there's a problem in general.
~# speedtest-cli
Retrieving speedtest.net configuration...
Testing from Vodafone Kabel Deutschland...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by wilhelm.tel (Norderstedt) [17.40 km]: 15.795 ms
Testing download speed................................................................................
Download: 66.68 Mbit/s
Testing upload speed................................................................................................
Upload: 26.29 Mbit/s
Same Host tested on my PC (Win 10, same switch) with the following result:
~# ethtool -i eth0
driver: lan78xx
version: 1.0.6
firmware-version:
expansion-rom-version:
bus-info: usb-3f980000.usb-1.1.1
supports-statistics: yes
supports-test: no
supports-eeprom-access: yes
supports-register-dump: no
supports-priv-flags: no
I've tried to transfer a 5GB .ts file (IPTV recorded movie) from the Pi to my PC. The Pi seems seems to "freeze" and CPU/RAM is maxed out. After a while the process (I guess samba) stopped without transferring any byte.
EDIT: Using a CAT 6 cable on both devices. Using DietPi on the Pi B+ with Pi Hole, OpenVPN, Tvheadend installed.
Tue Jun 05, 2018 10:05 am
There is a suspected issue with Samba (and perhaps other network sharing mechanisms) that we haven't got to the bottom of yet, that may be unrelated.
The speedtest-cli result look exactly like flow control is not working effectively.
bergkuh
Tue Jun 05, 2018 11:53 am
Pi is directly attached to my FritzBox 6490:
~# speedtest-cli
Hosted by wilhelm.tel (Norderstedt) [17.40 km]: 17.61 ms
Download: 64.57 Mbit/s
Upload: 25.59 Mbit/s
Result from my PC:
So I can't see any Flow Control related settings in my FritzBox, the Port is set to Power Mode.
Another try:
~# apt install --reinstall raspberrypi-kernel
~# ethtool -s eth0 speed 100 duplex full
~# speedtest-cli
Hosted by wilhelm.tel (Norderstedt) [17.40 km]: 15.865 ms
Download: 91.88 Mbit/s
Upload: 27.61 Mbit/s
Tue Jun 05, 2018 12:24 pm
I'm currently doing some testing, via Samba, simply doing an rsync from the mounted drive to the SD card. Seen no issues so far after about 25GB transferred. Currently giving 24.68MB/s, which is 197MBits/s, about what I would expect.
According to ifconfig, no dropped packets on eth0. Can you try ifconfig and see if you are dropping?
Edit: flow control might be referred to as pause control or some variant.
bergkuh
Tue Jun 05, 2018 12:40 pm
Copied a 6 GB file from my Pi (Cat 6, directly attached to FritzBox) to my Windows 7 (Cat 6, attached over Switch) working PC.
~# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        xxx
        ether xxx  txqueuelen 1000  (Ethernet)
        RX packets 475152  bytes 499772618 (476.6 MiB)
        RX errors 0  dropped 939  overruns 0  frame 0
        TX packets 348063  bytes 1013243430 (966.3 MiB)
Windows told me the average upload/download speed was about 6.5 MB/s. So atm Samba is'nt freezing anymore.
Tue Jun 05, 2018 1:49 pm
Now tried in the same direction as your test, (Pi to samba) and whilst the speed was slightly lower, it was still 21.7MB/s (173Mbits/s) with no drops in either direction after 3GB or so.
If you are seeing dropped packets then that sort of implies a dodgy ethernet link - either flow control is off or something else is going awry,
speedtest-cli does show speeds of 80-90Mbits/s (5 tests), however, we have an shared office link of only 100Mbit/s anyway, so therefor the results are not useful.
Tue Jun 05, 2018 2:58 pm
There is a comment in another thread concerning samba problem, which has apparently been fixed by doing the following
ethtool --offload eth0 rx off tx off
Might be worth trying to see if it makes any difference.
bergkuh
Tue Jun 05, 2018 3:09 pm
Thanks for your help. I'll checkout my network overall and you suggested "samba fix". Keep up the good work, will report back with my results.
mikerr
Tue Jun 05, 2018 3:21 pm
I posted my results over here:
viewtopic.php?f=36&t=13695&start=150#p1323794
but 38meg/sec over samba via pi RAMdisk is pretty close to practical USB2 maximums.
helmar74
Sat Jun 09, 2018 7:29 am
I set sudo ethtool --offload eth0 rx off tx off
And now network performance is fine.
... but after reboot offload is turned on again.
How can I persist the setting, so that it is also set after reboot?
Thanks a lot
helmar
simplerick
Mon Jun 11, 2018 1:23 am
Hi
I had done the following and seen a marginal improvement in download speeds.
sudo apt-get update
sudo apt-get dist-upgrade
Would my sd card where raspbian is installed have any effect on speedtest-cli performance? (would speedtest be caching its downloaded data to memory or sd card?)
I have the standard Sandisk 32gb Class 4 card, nothing fancy.
CharlyDelta
Thu Jun 28, 2018 8:41 pm
Not too bad here...
speedtest-cli
Testing from Bell Canada (76.69.193.60)...
Hosted by Openface Internet (Montreal, QC) [31.97 km]: 7.291 ms
Download: 216.49 Mbit/s
Testing upload speed....................................................................................................
Upload: 216.17 Mbit/s
nidcornifleur@gmail.com
magore
Sat Jul 07, 2018 2:46 am
I found the following settings help transfer speeds for the Ethernet port
Run as root
sysctl -w net.core.rmem_max=8388608
sysctl -w net.core.wmem_max=8388608
sysctl -w net.core.rmem_default=65536
sysctl -w net.core.wmem_default=65536
sysctl -w net.ipv4.tcp_rmem='4096 87380 8388608'
sysctl -w net.ipv4.tcp_wmem='4096 65536 8388608'
sysctl -w net.ipv4.tcp_mem='8388608 8388608 8388608'
sysctl -w net.ipv4.route.flush=1
ejolson
Sat Jul 07, 2018 6:13 pm
Run as root
Thanks for sharing. It looks like you are changing the TCP window size. Would you like to explain in more detail what each setting means, how you determined the settings and the before versus after speed differences. I tried some similar settings last month, but couldn't figure out how to actually increase performance.
RPIgoodSBC
Thu Jul 12, 2018 3:20 pm
Rasp-berry good test on ethernet gigabit on Linux raspberrypi 4.14.52-v7+ ...Rpi3B+...
My ISP is 200Down/20Up and I am running de pi with /boot/config.txt...
arm_freq=1200
sdram_freq=450
I like less performance and stable than more fast and not stable.
On 1080p youtube videos Rpi3B+ is no more than 60C and my old Rpi3B go up to 70-80C.
Very good thermal managament on Rpi3B+.
Here the screenshoot...
joostman
Sun Jul 15, 2018 5:05 pm
Run as root
If I change this value, it looks like it worked, but checking afterwards, does not seem to have changed it.
pi@p1mon:/$ sudo sysctl -w net.core.wmem_default=65536
net.core.wmem_default = 65536
pi@p1mon:/$ sudo sysctl -a | grep core.rmem
net.core.rmem_default = 163840
I was very enthusiastic and hoping this would fix it, but forgot to check what the default values were... :(
The speedtest did not change anything for me.
I also have 200 Mbit down / 20 up, but never get these figures from the download.
Only if I connect the Pi to my Ziggo (provider) router direct, it give me figures around the 200.
Now I have behind my provider router a Ubiquiti router and switch and the speeds are 1/4th of normal.
This is only the case for my Pi, a NAS, also on the same switch, does get the normal Internet speeds :-/
root@p1mon:~# speedtest-cli --server 3587 --secure --no-upload
Testing from Ziggo (xx.xx.xx.xx)...
Retrieving information for the selected server...
Hosted by LeaseWeb (Haarlem) [26.84 km]: 904.579 ms
Download: 57.82 Mbit/s
Skipping upload test
root@p1mon:~#
Sun Jul 15, 2018 7:34 pm
Sounds like flow control is not turned on on your router, that will cause these results.
RPIgoodSBC
Thu Jul 19, 2018 4:57 pm
Performance test overclocked ram=550 and gpu=450 raspberrypi 3B+ and results on gigabit ethernet youtube 1920x1080@30fps fullscreen video and downloads speeds gigabit ethernet.
Linux raspberrypi 4.14.52-v7+ #1123 SMP Wed Jun 27 17:35:49 BST 2018 armv7l GNU/Linux
Raspberry pi3B+ official power supply and semi-open case plastic acrylic bottom and top.
Little heatsinks on cpu, ethernet and ram chips.
Booting from usb using Sandisk Extreme 32Gb usb 3.0.
Flow control enabled on router, 200/20 connection ISP and adjusted to 192/19,2 -4% from default ISP.
/boot/config.txt have this parameters added...
arm_freq=1400
sdram_freq=550
gpu_freq=450
temp_soft_limit=70
gpu_mem=256
Screenshots...at the end of the post...
You can stress cpu and test temperature with this command line...
openssl speed -multi 4 rsa2048 ; openssl speed -multi 4 rsa2048 ; openssl speed -multi 4 rsa2048 ; openssl speed -multi 4 rsa2048
You can test write speeds SD or usb host system with this command line...you need at least 2GB free space...
sudo dd if=/dev/zero of=/testfile bs=16M count=128 oflag=direct && sync ; sudo rm -f /testfile
With this settings youtube video in fullscreen is very smooth audio and video with temp up to 66C on my pi3B+.
For better youtube chromium fullscreen 1920x1080@30 performance you can add this to /etc/chromium-browser/default
sudo leafpad /etc/chromium-browser/default
CHROMIUM_FLAGS="$CHROMIUM_FLAGS --enable-native-gpu-memory-buffers --enable-gpu-rasterization"
Save and exit restart chromium and on chromium address bar type... chrome://gpu/ and you see two new lines accelerated...
Graphics Feature Status...
Multiple Raster Threads: Enabled
Native GpuMemoryBuffers: Hardware accelerated
Rasterization: Hardware accelerated
You can test performance with this 1920x1080@30 video www.youtube.com/watch?v=HiZXABMNCUY or www.youtube.com/watch?v=bMJ7KwqiO8c
The sweet point on fullscreen youtube fullscreen videos seems to be 1920x1080@24
iperf3 test from my big PC sending and my pi3B+ receiving...
