willwach
RPi metal case
Tue Jul 10, 2012 6:55 am
My solution for a RPi metal case.
It's a rectangular tin in sandblasted optic with single lid.
I fixed the RPi with cutted and self-adhesive Kapa panels.
The cuttings where done by a dremel.
willwach
Re: RPi metal case
Thu Jul 12, 2012 7:21 am
Does someone know a solution to bring out the RPi connectors?
E.g.: A HDMI connector mounted in the case and connected with a short cable to the RPis HDMI connector.
Bukshi
Re: RPi metal case
Thu Jul 12, 2012 7:55 am
Nice ;)
DiscPi - DIY Raspberry Pi case
Mortimer
Re: RPi metal case
Thu Jul 12, 2012 7:57 am
Something like this:
CLICK
Only problem I can't find anything shorter than 1ft.
The purpose of a little toe is to ensure you keep your furniture in the right place.
nadnerb
Re: RPi metal case
Thu Jul 12, 2012 10:33 am
I've just bought this for a case I'm working on. It's the shortest I could find and quite cheap too.
I'll let you know how it is once I get it.
http://www.dealextreme.com/p/hdmi-male- ... 243?item=2
nadnerb
Re: RPi metal case
Thu Jul 12, 2012 10:41 am
Nice case btw.
And actually, you may be better off with something similar to this
http://www.dealextreme.com/p/hdmi-m-to- ... 13?item=36
It's a shame you have already cut the holes for the other ports as this extension might need the board to be moved slightly further away. But there are loads of these adapters about so have a shop around.
Jim JKla
Re: RPi metal case
Fri Jul 13, 2012 11:19 am
I was thinking similar lines use an HDMI to Mini HDMI adaptor then use a cable that connects Mini HDMI to your Monitor whatever it uses. The adaptors tend to be short.
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek ;)
If you find a solution please post it in the wiki the forum dies too quick
willwach
Re: RPi metal case
Mon Jul 30, 2012 7:50 am
So, here is my newest version of RPi case.
It's the same case, but a little bit more case-modding.
If i find an angled USB-Power cable, it will be possible to bring out all the cables at only one side.
The RPi is held by an selfmade plate from KAPA-Plates.
At the end the lid is varnished in red.
ScottBouch
Re: RPi metal case
Tue Aug 07, 2012 12:23 am
That looks really nice!
http://www.scottbouch.com
http://www.youtube.com/user/sbscottmonkey - - - YouTube Channel
babelisk
Re: RPi metal case
Wed Feb 27, 2013 9:15 pm
What a cheap and fantastic solution to a RPi case well done!!!
babelisk
Re: RPi metal case
Wed Feb 27, 2013 9:49 pm
Where do you buy these tins I cannot find them anywhere?
Gary Littlemore
Re: RPi metal case
Thu Mar 07, 2013 1:49 pm
Love it.
3b+, 2b, b+, b, Zero & Zero-W
Return to “Other projects”
