[ 3.775213] sdhci: Secure Digital Host Controller Interface driver
[ 3.778422] sdhci: Copyright(c) Pierre Ossman
[ 3.781879] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 3.785342] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 3.788708] Error: Driver 'sdhost-bcm2835' is already registered, aborting...
[ 3.792028] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.967945] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 3.971220] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 4.011940] sdhost: log_buf @ 53f6571a (fa853000)
[ 4.032295] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 4.036912] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 4.041633] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 4.050403] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 4.087381] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 4.091191] hctosys: unable to open rtc device (rtc0)
[ 4.172468] mmc1: new high speed SDIO card at address 0001
[ 4.198049] mmc0: host does not support reading read-only switch, assuming write-enable
[ 4.204236] mmc0: new high speed SDHC card at address aaaa
[ 4.208074] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[ 4.213926] mmcblk0: p1 p2
# MMC/SD/SDIO Host Controller Drivers
CONFIG_MMC_BCM2835_MMC=y
CONFIG_MMC_BCM2835_DMA=y
CONFIG_MMC_BCM2835_PIO_DMA_BARRIER=2
CONFIG_MMC_BCM2835_SDHOST=y
# CONFIG_MMC_DEBUG is not set
CONFIG_MMC_ARMMMCI=y
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SDHCI_IO_ACCESSORS=y
CONFIG_MMC_SDHCI_PLTFM=y
CONFIG_MMC_SDHCI_OF_ARASAN=m
CONFIG_MMC_SDHCI_OF_AT91=m
CONFIG_MMC_SDHCI_CADENCE=m
CONFIG_MMC_SDHCI_F_SDH30=m
CONFIG_MMC_SDHCI_IPROC=m
CONFIG_MMC_SPI=m
CONFIG_MMC_TMIO_CORE=m
CONFIG_MMC_TMIO=m
CONFIG_MMC_DW=m
CONFIG_MMC_DW_PLTFM=m
CONFIG_MMC_DW_EXYNOS=m
CONFIG_MMC_DW_K3=m
CONFIG_MMC_VUB300=m
CONFIG_MMC_USHC=m
CONFIG_MMC_USDHI6ROL0=m
CONFIG_MMC_REALTEK_USB=m
CONFIG_MMC_BCM2835=y
CONFIG_MMC_MTK=m
CONFIG_MMC_SDHCI_XENON=m
# CONFIG_MMC_SDHCI_OMAP is not set
CONFIG_MEMSTICK=m
# CONFIG_MEMSTICK_DEBUG is not set
kernel/drivers/mmc/core/mmc_core.ko
kernel/drivers/mmc/core/pwrseq_simple.ko
kernel/drivers/mmc/core/pwrseq_emmc.ko
kernel/drivers/mmc/core/mmc_block.ko
kernel/drivers/mmc/host/armmmci.ko
kernel/drivers/mmc/host/sdhci.ko
kernel/drivers/mmc/host/bcm2835-mmc.ko
kernel/drivers/mmc/host/bcm2835-sdhost.ko
kernel/drivers/mmc/host/bcm2835.ko
kernel/drivers/mmc/host/sdhci-pltfm.ko
sdhci_iproc 16384 0
