hebertovich
Ending a python script in Cron-Answered
Thu Mar 14, 2019 2:36 pm
I have a new dilemma
I now have this cron working fine to start a python script
35 15 * * 2-5 cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; ./opengreen.py
Now I'm trying to figure out how to stop it in the cron at a certain time I've modified the cron to this
# Tasks to be run by cron.
# to run open sign
25 11 * * 2-5 cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; ./opengreen.py
#to stop the script
27 11 * * 2-5 /killall -9 opengreen.py >/home/pi/log_opengreen2.txt 2>&1
#next script
I've also tried Pkill -9 ./opengreen.py or -x and exit(opengreen.py) but to no avail
Anyone know what would work to stop the process in cron
W. H. Heydt
Re: Ending a python script in Cron
Thu Mar 14, 2019 3:28 pm
My "alarm clock" uses mplayer, so in the evening I have a cron job that does "killall mplayer". That depend on that being the only thing I'm doing with mplayer, though. The more specific method would be "kill <PID>" or "kill -9 <PID>", but finding the process ID may be tricky. A "ps -C <programname>" can do it, for instance.
thagrol
Thu Mar 14, 2019 3:36 pm
# to run open sign
#to stop the script
#next script
Take the "/" in front of "killall" out. With it, cron will be looking for something called killall in the root directory ("/") rather than searching the current $PATH for killall.
hebertovich
Thu Mar 14, 2019 6:24 pm
Thanks for the suggestion thagrol
I actually have it working perfect like this ----Thanks everyone for your help
#to run the closed script at 7:30 every mon
30 7 * * mon cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; ./closedor.py
#to stop the script @ 6:29pm mon
29 18 * * mon cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; killall python
# to run open sign mon @ 6:30pm mon
30 18 * * mon cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; ./opengreen.py
#to stop the script @ 8:30pm mon
30 20 * * mon cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; killall python
#to run the closed script at 8:33pm mon
30 20 * * mon ( sleep 03 ; cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; ./closedor.py)
#to run the closed script at 7:30 tue-sun
30 7 * * 2-0 cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; ./closedor.py
#to stop the script @ 10:29am tue-sun
29 10 * * 2-5 cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; killall python
# to run open sign tue-fri @ 10:30
30 10 * * tue-fri cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; ./opengreen.py
#to stop the script @ 8:30pm t-f
30 20 * * 2-5 cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; killall python
#to run the closed script at 8:33pm t-f
30 20 * * 2-5 ( sleep 03 ; cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; ./closedor.py)
# to run open sign sat-sun @ 10:30
30 10 * * sat-sun cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; ./opengreen.py
#to stop the script @ 2:00pm sat-sun
0 14 * * sat-sun cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; killall python
#to run the closed script at 2:03 pm Sat-sun
0 14 * * sat-sun ( sleep 03 ; cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; ./closedor.py)
#to stop it all at 5pm sat-sun
* 17 * * sat-sun cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; killall python
#to stop it all at 10pm mon-fri
* 22 * * mon-fri cd /home/pi/rpi-rgb-led-matrix/bindings/python/samples; killall python
Does what it's supposed to do
hebertovich
Re: Ending a python script in Cron-Answered
Thu Mar 14, 2019 6:57 pm
One last question if my R pi reboots I'm guessing I have to do the /etc/init.d/cron start. and enter my password again to re-initialize the cronjob??
Is there a way to set it so that if I have a power outage or my R pi reboots, the cronjob will automatically start?
could I use @reboot ? or will that hold it till I provide my password?
Return to “Beginners”
