I have a weird issue with the wifi for some of my RPis. it gets disconnected et reconnect each 5 minutes and I don't know what's causing this.
I found those lines every 5 minutes in my logs :
wlan0: CTRL-EVENT-CONNECTED - Connection to 00:24:d4:62:16:58 completed [id=0 id_str=mbxwpa]
p2p-dev-wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
wlan0: CTRL-EVENT-DISCONNECTED bssid=00:24:d4:62:16:58 reason=0 locally_generated=1
and here is the iwconfig output :
wlan0 IEEE 802.11 ESSID:"SSID2"
Mode:Managed Frequency:2.437 GHz Access Point: 00:24:D4:62:16:58
Bit Rate=14.4 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality=45/70 Signal level=-65 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
I have another box in another network that works perfectly. and here is its iwconfig :
wlan0 IEEE 802.11 ESSID:"SSID1"
Mode:Managed Frequency:2.457 GHz Access Point: 7C:26:64:69:D6:90
Bit Rate=72.2 Mb/s Tx-Power=31 dBm
Encryption key:off
Link Quality=59/70 Signal level=-51 dBm
Tx excessive retries:3 Invalid misc:0 Missed beacon:0
