eroji
Cannot connect to WiFi if password contains "#"
Sun May 26, 2019 10:29 am
Is there a way to escape a "#" character in the wifi password? I am using the latest minimal stretch version on RPi 3b+. Took me awhile to troubleshoot to isolate the problem down to the wifi password. Using the ASCII encoding of the password also does not seem to work.
k-pi
Re: Cannot connect to WiFi if password contains "#"
Sun May 26, 2019 12:10 pm
Usually you can 'escape' a character by prepending a \ just before the character, but I'm not sure it will work with a password, you likely need to change or delete the password & enter a new one.
This may help.
https://www.cyberciti.biz/faq/linux-del ... -password/
Ernst
Sun May 26, 2019 12:20 pm
On my test equipment I do not have a problem with # in the password.
update_config=1
country=DE
network={
        ssid="XXXXXX"
        psk="Test#Test"
        key_mgmt=WPA-PSK
        priority=20
wlan0     IEEE 802.11  ESSID:"XXXXXX"
          Mode:Managed  Frequency:2.437 GHz  Access Point: 00:16:B6:95:0D:AB
          Bit Rate=54 Mb/s   Tx-Power=31 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:on
          Link Quality=70/70  Signal level=-38 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
Sun May 26, 2019 4:59 pm
You can use wpa_passphrase to generate an encrypted psk so you don't need to put any weird characters in /etc/wpa_supplicant/wpa_supplicant.conf. If you just supply the SSID you will be prompted for the password, then the block to put in the conf file will be displayed and you can copy/paste the bits you need. Note the generated encrypted psk does not have double quotes, unlike the unencrypted password version.
Here's an example with me typing "Pasword_with_weird#characters" (yes, I typoed "password") :oops:
pi@raspberrypi:~ $ wpa_passphrase MY_SSID
# reading passphrase from stdin
network={
	ssid="MY_SSID"
	#psk="Pasword_with_weird#characters"
	psk=5efe543a7bf1f513f73bc7a97612e979e2ca3acd95f57f7d6716d3835a557138
Then replace the existing psk="Pasword_with_weird#characters" with the version shown above.
Unreadable squiggle
klricks
Mon May 27, 2019 1:49 pm
Have you set your keyboard country properly?
Raspbian defaults to UK layout which has # on a different key if not using a UK keyboard
