VihangaA
Boot stuck at rc-local.service
Fri Jul 19, 2019 11:49 am
I setup Rasbian on a 32GB sd card and inserted it into Raspberry Pi 3 Model B(V1.2). When I swtch on the Raspberry Pi, It's boot stuck at
rc-local.service
It get power from a power adapter(5v = 3000mA)
Keyboard and mouse is connected.(When I removed the keyboard and mouse and switched on the raspberry pi, it stuck at "polkit.service")
How can I overcome from this?
Re: Boot stuck at rc-local.service
Sat Jul 20, 2019 8:41 am
What did you put in /etc/rc.local?
Try this:
[CTRL]+[ALT]+[PRT SC]
[R]
[CTRL]+[ALT]+[F2]
That will terminate the rc.local process and give you a command line login screen.
If that doesn't work you'll need a second SDCard and a USB SDCard reader. Boot plain Raspbian from the second SDCard as a "rescue system". Mount the broken SDCard in the USB reader and undo the damage.
