Imperf3kt
Contact: Twitter
Re: Raspberry Pi 4 Heatsink vs Fan vs Flirc Case
Mon Aug 19, 2019 1:12 am
deanresin wrote:
Fri Aug 16, 2019 9:05 pm
Imperf3kt wrote:
Thu Jun 27, 2019 3:47 am
I already told you, in the manual.
Specifically section 5.6 on the bottom of page 11
I am unable to find the link to download it in my history, so here's a screenshot.
The 50°C you are referring to is ambient maximum.
If this isn't acceptable, here is a post by a Raspberry Pi engineer.
https://www.raspberrypi.org/forums/view ... 9#p1486109
That is a big difference from "maximum operating temperature". When I turn on my RPI4 it will never operate below 50°C just sitting there turned on with no case.
I suggest you look up what ambient means.
Since I posted that, there have been several posts by engineers which seem to imply the "maximum" operating temperature is about 120°C, at which point things start to destroy themselves and after about 85°C will experience a reduced life expectancy (hence why the Pi begins throttling at 80°C)
55:55:44:44:4C
52:4C:52:42:41
deanresin
Mon Aug 19, 2019 1:17 am
Sorry, I thought you were the person who said "That said, the RPi 4 has a maximum operating temp of 50 C according to their published specs". I must have been mistaken.
Imperf3kt
Contact: Twitter
Mon Aug 19, 2019 1:18 am
All good.
I apologise for the rather blunt reply.
55:55:44:44:4C
52:4C:52:42:41
e-raser
Tue Aug 20, 2019 1:25 pm
For me the FLIRC case is doing a really good job on the Pi 4. See stressberry comparison below.
And if you wanna see the difference from a Pi 3 B+ in a FLIRC case (green line) to the Pi 4 in the FLIRC case (orange line):
1) Nextcloud & Pi-hole & ... @ RPi OS @ Pi 4 (4 GB)
2) Home Assistant @ HASS OS @ Pi 4 (8 GB)
3) Kodi media center @ LibreELEC @ Pi 3 B+
4) Testing system @ RPi OS @ Pi 2
5) Backup/restore system (raspiBackup) @ RPi OS Lite @ Pi 2
neilgl
Tue Aug 20, 2019 7:01 pm
My flirc case arrived today and is giving me a reduction in temperature of around 20 degrees C at idle with one monitor attached. And it is silent.
clicky
Wed Aug 21, 2019 7:21 am
I would really like to see graph of Flirc Case vs Fan Shim. :)
castletonroad
Mon Aug 26, 2019 10:10 am
hippie403 wrote:
Sat Aug 17, 2019 6:04 am
Youtube video of Pi 4 FLIRC case testing: https://youtu.be/vkLr08K0c1E Sounds like it is perfectly adequate. I've got one on order for my second Pi 4. I have a case with a small fan and 4 small heat sinks, idling at 42C ambient 22C.
Thanks - I was unsure, but then I watched the video. Ordered one, so will see how I go.
Raspberry Pi 4 Model B | Raspberry Pi 3 Model B | Raspberry Pi 2 Model B
LTolledo
Mon Aug 26, 2019 11:03 am
Have this one on my new RPi4B-4G
which is similar to what I use with my RPi3B and RPi3B+
on ambient of 29C to 30C the RPi4B-$G CPU temp hovers on 50C during the upgrade cycle but stays on 45C while viewing youtube videos...
my fan's power is taken from TP1 and TP7 on the underside....
Some people be like:
emilfr
Mon Aug 26, 2019 11:14 am
Anyone know where to get Flirc case for RPI4 in UK?
RPI Zero W || RPI 2B || 2x RPI 3B || 2x RPI 4B4G
LTolledo
Mon Aug 26, 2019 2:50 pm
On my RPi4B-4G setup mentioned above,
changing the blue thermal pad to thin copper sheet improved cooling further
idling at 36C, watching YT videos at 40C, maxing at 45C during apt install/update/upgrades CPU at around 80%
e-raser
Mon Aug 26, 2019 4:20 pm
Dude, just run a Stressberry benchmark. Your information like „watching YT videos temp. = xx degrees“ is not really comparable.
Nice setup anyway. What about the fan noise?
pica200
Mon Aug 26, 2019 4:22 pm
I have seen these heatsink cases with fan and always wondered where the fans suck/blow air from/to? Is there a hole in the heatsink or are the fans mounted in such a way so there is a gap between them and the heatsink? These tiny fans must be pretty noisy. I have a case without the fans and recently got a 40x40mm fan so i'm ready for overclocking when i get to it.
dprees
Mon Aug 26, 2019 4:26 pm
I got mine here:
https://thepihut.com/products/flirc-raspberry-pi-4-case
It really works, just as everyone says. Maximum temp I can get my Pi4 4Gb once I put it into the FLIRC case was 61C, no matter how hard I stress it (at stock, btw...no overclocking).
I'll be buying a FLIRC case along with every Pi 4 I buy from now on...
e-raser
Mon Aug 26, 2019 6:01 pm
jcyr wrote:
Mon Aug 26, 2019 4:35 pm
I've got to wonder how much these metal cases affect WiFi and Bluetooth performance?
Great question. Did no before/after test but when switching my mediacenter hardware from Pi 2 to Pi 3 B+ (Pi 2 with external WiFi dongle, Pi 3 B+ with FLIRC case) the WiFi signal was significantly worse than with the external WiFi dongle. Might have two reasons in this case:
A) FLIRC metal case has an impact
B) External WiFi dongle with adjustable antenna is simply better
...or a mix of both.
At the end I disabled internal WiFi and used the external dongle on the Pi 3 B+ with FLIRC case.
pica200
Mon Aug 26, 2019 7:09 pm
Did no before after test either but these heatsink enclosures seem to not block BT/WiFi much if at all. WiFi signal strength seems to be similar to other devices in the same room.
emilfr
Mon Aug 26, 2019 7:13 pm
https://www.raspberrypi.org/forums/view ... p?t=158301
LTolledo
Mon Aug 26, 2019 9:03 pm
it quiet... (using android phone app) about 22db measured 30mm above the setup.
WiFi signal to setup is also good, as its not fully covered. my setup is about 1100mm away from my router
the WiFi side is facing away from the router...
HawaiianPi
Mon Aug 26, 2019 11:37 pm
I don't have a graph, but if I was a betting man, I'd put my money on the fan. In my experience, a fan alone works better than a heatsink alone.
However, if both solutions keep the Pi4 below the 80C throttling temperature, then I would prefer the Flirc. In the end the goal is to keep the Pi cool enough to maintain maximum performance and prevent heat damage, and temps below 80C do that, so does a few C difference here or there really matter? The Flirc makes no noise, does not require any additional power, and will not pull dust into your system (like a fan).
On the other hand, the Fan Shim is a pretty cool little gadget (pun intended). It has an addressable switch and RGB LED which you could use for other things (default is manual fan control and temperature indicator). It's pretty quiet, but definitely not silent. It is louder than the Noctua 40 x 10mm fans I have on other systems, but you can install Pimoroni's software to toggle the fan on and off as needed (Buster required).
On my Pi 3B(+) models, if there is any effect, it's negligible (I have not noticed a significant loss in signal or performance after moving both a 3B and 3B+ into Flirc cases). Do note that the Flic is plastic on the bottom and part of the side near the wireless antenna (unlike some other cases which enclose the Pi in a metal box).
It's harder to tell on the Pi4, because it's WiFi performance seems to be lower, and more variable than my Pi3 models (things have improved with updates, so I assume the software is still being optimised). From a visual comparison, the walls of the Pi4 Flirc look noticeably thinner than the Pi3 Flirc, but I have no idea if that makes any difference.
I have a 4B2 in an open sided acrylic case, and a 4B4 in a Flirc, and neither one has great WiFi performance (both are worse than a 3B+ in a Flirc). In testing, their results are so inconsistent and variable, it's hard to draw conclusions. I've been disappointed in the Pi4 WiFi so far, but as I said, it seems to be getting better. Since it's all new hardware and a new Raspbian version, I would hope that performance would improve with new soft-ware and firmware (which seems to be the case, and I hope it improves further).
HawaiianPi
Tue Aug 27, 2019 12:55 am
jcyr wrote:
Tue Aug 27, 2019 12:01 am
Personally, I prefer a software controlled fan. A Noctua AX10 4 wire fan running at 20-30% speed is silent and all that is needed to keep the PI4 under 80C.
Agree that is all you need. Disagree that's the preferred solution (at least on a system that runs 24/7).
Imperf3kt
Contact: Twitter
Tue Aug 27, 2019 1:21 am
jcyr wrote:
Tue Aug 27, 2019 1:07 am
Nothing a can of compressed air won't fix... :D
If you leave it too long the dust will bind to the surfaces and a can of "air" unfortunately won't fix it.
The best fix is to install a filter and clean it every so often.
55:55:44:44:4C
52:4C:52:42:41
karrika
Tue Aug 27, 2019 4:40 am
I have used FLIRC cases for all my pi's. The new Pi4 FLIRC case has the same flaw as the older ones. You cannot easily use a 40-pin ribbon cable because the two screw poles are too thick for the connector. So I routinely mill away the metal all the way to the screw to fit in Black Hat3r cable. So my HAT boards are outside the case.
The temp is below 65 degrees for normal surfing etc with the FLIRC case.
emilfr
Tue Aug 27, 2019 9:55 am
I got mine here:
HawaiianPi
Tue Aug 27, 2019 10:55 am
The flaw is in the cable. A 2x20 DuPont connector would fit, but most cable makers use the fat "IDE" drive style connector, and those will interfere with more than the Flirc. There is at least one pre-made cable that fits, but I don't have a link handy (try checking the Flirc support site, as I believe they suggest a cable)..
PeterO
Tue Aug 27, 2019 12:30 pm
I read elsewhere of a 1-4 dbm signal power reduction with some metal cases. Not too bad! 3dbm is equal to a 50% signal power reduction, which most receivers/transmitters can accommodate at short range.
0 dBm is 1 milliWatt.
3 dBm is 3dB more power than 0 dBm = 2 milliwatts.
What you mean is
I read elsewhere of a 1-4 dB signal power reduction with some metal cases. Not too bad! -3dB is equal to a 50% signal power reduction, which most receivers/transmitters can accommodate at short range.
PeterO
JumpZero
Sat Aug 31, 2019 7:05 pm
I have the flirc case, a Pi4 4GB is inside.
I've done some stress tests recording temperature and frequency then ploting them in graphs.
Without and with overclocking: 1.5 then 1.75 then 2GHz
The test runs 15 minutes (900s) with the 4 cores 100% loaded.
Here under are 5 graphs
The 1st one is @1,5GHz without overclock. CPU loaded 100% 15minutes, temperature 65°C at the end of the test.
The 2nd is the same but at 14 minutes the load is stopped (killall stress) we can see temperature decreasing speed
The 3rd one is the same as 2nd (stress stopped at 14 minutes) but @1.75GHz
The 4th one is @2GHz without stop, but the test started with cold cpu at 40°C (shortly after power on)
The 5th one is @2GHz with a stop at 14 minutes but start with already hot cpu at 55°C on this test we can see after 10 minutes around 80°C the governor throttle the cpu: frequency goes back and forth between 1.33 and 2 Ghz keeping temperature stable around 80°C (alarm icon is blinking). At the end when stress is stopped the frequency goes to 666MHz and here too we can see the temperature decreasing speed.
And here is the code used in this test
#!/bin/bash
# stress et gnuplot must be installed for this script to run
echo " Stress test - Press q to stop. Otherwise the test lasts 900s"
echo " Warning Ctrl-c doesn't stop the process stress. Use q"
echo " Printing and recording temperature and frequency every 5s"
echo " A graph is built at the end of the test"
echo " Press a key to start"
read -rsn1
stress -c 4 -t 900s &
CONTINUE=""
start_time="$(date -u +%s)"
origin_time=$start_time
total_time="$((0))"
rm -f TestResultClock.txt TestResultTemp.txt TestResultTime.txt
echo "total time: $total_time second" | tee TestResultTime.txt
vcgencmd measure_clock arm | tee TestResultClock.txt
vcgencmd measure_temp | tee TestResultTemp.txt
while [[ $CONTINUE != "q" ]] && [[ $CONTINUE != "Q" ]] && (( $total_time < 900 )); do
  read -t 0.25 -s -n 1 CONTINUE
  now_time="$(date -u +%s)"
  elapsed="$(($now_time-$start_time))"
  if (( $elapsed > 4 )); then
    total_time="$(($now_time-$origin_time))"
    echo "total time: $total_time seconds" | tee -a TestResultTime.txt
    vcgencmd measure_clock arm | tee -a TestResultClock.txt
    vcgencmd measure_temp | tee -a TestResultTemp.txt
    echo "Press q to stop. Press a to stop stress but continue recording"
  fi
  if [[ $CONTINUE == "a" ]] || [[ $CONTINUE == "A" ]]; then
   CONTINUE=""
   echo "Killing stress but test continues, temperature is cooling down"
   killall stress
   echo "stress killed"
  fi
done
echo "Test end"
killall -q stress
echo "Done! Now let's build the graph."
cat TestResultTemp.txt | awk 'BEGIN { FS="=" } {print substr ($2, 0, 3)}' > TestResultTempTmp.txt
cat TestResultTime.txt | awk '{print $3}' | paste - TestResultTempTmp.txt > TestResultTempToGraph.txt
cat TestResultClock.txt | awk 'BEGIN { FS="=" } {print $2 / 100000000}' > TestResultClockTmp.txt
cat TestResultTime.txt | awk '{print $3}' | paste - TestResultClockTmp.txt > TestResultClockToGraph.txt
gnuplot -e "reset; set terminal png size 800,600; set pointsize 0.01; \
set output 'Temperature.png'; set title 'CPU load test';
set xlabel 'time (seconds)'; set ylabel 'Temperature(°C) / Frequency(MHz*100)'; plot \
'TestResultClockToGraph.txt' u 1:2 title 'Frequency(MHz*100)' with linespoints, \
'TestResultTempToGraph.txt' u 1:2 title 'Temperature(°C)' with linespoints"
rm -f TestResult*
echo "Et voila, the graph is in Temperature.png."
echo "END"
Jmp0
