I put a LCD 7" touchscreen on it, and the display is working (after having done the trick explained here). At least in text mode.
The whole is powered with two USB cables plugged on my workstation USB ports (so, with a good power supply I think). One cable is plugged on the rpi's micro-usb port, and the other on the display's port. If I don't plug the rpi's micro-usb port, there isn't enough current to active the Wifi dongle.
I manage to login through the tty console using the display and a connected keyboard, or via ssh from my workstation.
I have LXDE with lightdm installed, but I can't get the graphics using startx, nor using lightdm. Nothing appears, the screen turns black and I lose the keyboard control (I can't switch to tty2, tty3 etc.) The only way then is to reboot from ssh.
I have tried other things: xinit openbox, xinit startlxde-pi, startx, sudo systemctl start slim, etc.
The Xorg log doesn't seem to contain any errors:
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
[ 655.059] Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
[ 655.059] Current Operating System: Linux pave 4.19.85+ #1279 Fri Nov 22 15:30:38 GMT 2019 armv6l
[ 655.059] Kernel command line: coherent_pool=1M bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=686ad6a5-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 655.061] Build Date: 05 June 2019 12:49:54PM
[ 655.061] xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
[ 655.061] Current version of pixman: 0.36.0
[ 655.061] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 655.062] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 655.063] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Dec 2 12:59:11 2019
[ 655.065] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 655.068] (==) No Layout section. Using the first Screen section.
[ 655.069] (==) No screen section available. Using defaults.
[ 655.069] (**) |-->Screen "Default Screen Section" (0)
[ 655.069] (**) | |-->Monitor "<default monitor>"
[ 655.074] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 655.075] (**) | |-->Device "Allwinner A10/A13 FBDEV"
[ 655.075] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 655.075] (==) Automatically adding devices
[ 655.075] (==) Automatically enabling devices
[ 655.075] (==) Automatically adding GPU devices
[ 655.076] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 655.076] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 655.076] Entry deleted from font path.
[ 655.077] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 655.077] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 655.077] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 655.077] (II) Loader magic: 0x1fcf80
[ 655.078] (II) Module ABI versions:
[ 655.078] X.Org ANSI C Emulation: 0.4
[ 655.078] X.Org Video Driver: 24.0
[ 655.078] X.Org XInput driver : 24.1
[ 655.078] X.Org Server Extension : 10.0
[ 655.091] (++) using VT number 7
[ 655.091] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 655.093] (II) no primary bus or device found
[ 655.093] (II) LoadModule: "glx"
[ 655.095] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 655.188] (II) Module glx: vendor="X.Org Foundation"
[ 655.188] compiled for 1.20.4, module version = 1.0.0
[ 655.188] ABI class: X.Org Server Extension, version 10.0
[ 655.189] (II) LoadModule: "fbturbo"
[ 655.190] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[ 655.192] (II) Module fbturbo: vendor="X.Org Foundation"
[ 655.192] compiled for 1.20.3, module version = 0.5.1
[ 655.192] Module class: X.Org Video Driver
[ 655.193] ABI class: X.Org Video Driver, version 24.0
[ 655.193] (II) FBTURBO: driver for framebuffer: fbturbo
[ 655.194] (WW) Falling back to old probe method for fbturbo
[ 655.194] (II) Loading sub module "fbdevhw"
[ 655.194] (II) LoadModule: "fbdevhw"
[ 655.196] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 655.198] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 655.198] compiled for 1.20.4, module version = 0.0.2
[ 655.198] ABI class: X.Org Video Driver, version 24.0
[ 655.199] (II) FBTURBO(0): using /dev/fb0
[ 655.199] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 655.200] (II) FBTURBO(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 655.201] (==) FBTURBO(0): Depth 24, (==) framebuffer bpp 32
[ 655.201] (==) FBTURBO(0): RGB weight 888
[ 655.201] (==) FBTURBO(0): Default visual is TrueColor
[ 655.201] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[ 655.202] (II) FBTURBO(0): hardware: BCM2708 FB (video memory: 1500kB)
[ 655.202] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 655.202] (**) FBTURBO(0): Option "fbdev" "/dev/fb0"
[ 655.203] (**) FBTURBO(0): Option "SwapbuffersWait" "true"
[ 655.204] (II) FBTURBO(0): processor: ARM1176
[ 655.204] (II) FBTURBO(0): checking modes against framebuffer device...
[ 655.205] (II) FBTURBO(0): checking modes against monitor...
[ 655.205] (II) FBTURBO(0): Virtual size is 800x480 (pitch 800)
[ 655.205] (**) FBTURBO(0): Built-in mode "current"
[ 655.206] (==) FBTURBO(0): DPI set to (96, 96)
[ 655.206] (II) Loading sub module "fb"
[ 655.206] (II) LoadModule: "fb"
[ 655.208] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 655.209] (II) Module fb: vendor="X.Org Foundation"
[ 655.210] compiled for 1.20.4, module version = 1.0.0
[ 655.210] ABI class: X.Org ANSI C Emulation, version 0.4
[ 655.213] (II) FBTURBO(0): using backing store heuristics
[ 655.266] (II) FBTURBO(0): can't load 'g2d_23' kernel module
[ 655.266] (II) FBTURBO(0): failed to enable the use of sunxi display controller
[ 655.267] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[ 655.267] (II) FBTURBO(0): G2D hardware acceleration can't be enabled
[ 655.267] (II) FBTURBO(0): enabled fbdev copyarea acceleration
[ 655.268] (==) FBTURBO(0): Backing store enabled
[ 655.270] (==) FBTURBO(0): DPMS enabled
[ 655.271] (II) FBTURBO(0): failed to enable hardware cursor
[ 655.271] (II) FBTURBO(0): no 3D acceleration because the driver has been compiled without libUMP
[ 655.271] (II) FBTURBO(0): if this is wrong and needs to be fixed, please check ./configure log
[ 655.272] (II) Initializing extension Generic Event Extension
[ 655.275] (II) Initializing extension SHAPE
[ 655.277] (II) Initializing extension MIT-SHM
[ 655.280] (II) Initializing extension XInputExtension
[ 655.284] (II) Initializing extension XTEST
[ 655.286] (II) Initializing extension BIG-REQUESTS
[ 655.289] (II) Initializing extension SYNC
[ 655.292] (II) Initializing extension XKEYBOARD
[ 655.295] (II) Initializing extension XC-MISC
[ 655.298] (II) Initializing extension SECURITY
[ 655.301] (II) Initializing extension XFIXES
[ 655.304] (II) Initializing extension RENDER
[ 655.307] (II) Initializing extension RANDR
[ 655.313] (II) Initializing extension COMPOSITE
[ 655.316] (II) Initializing extension DAMAGE
[ 655.318] (II) Initializing extension MIT-SCREEN-SAVER
[ 655.321] (II) Initializing extension DOUBLE-BUFFER
[ 655.324] (II) Initializing extension RECORD
[ 655.327] (II) Initializing extension DPMS
[ 655.329] (II) Initializing extension Present
[ 655.332] (II) Initializing extension DRI3
[ 655.332] (II) Initializing extension X-Resource
[ 655.335] (II) Initializing extension XVideo
[ 655.338] (II) Initializing extension XVideo-MotionCompensation
[ 655.338] (II) Initializing extension SELinux
[ 655.338] (II) SELinux: Disabled on system
[ 655.338] (II) Initializing extension GLX
[ 655.341] (II) AIGLX: Screen 0 is not DRI2 capable
[ 656.214] (II) IGLX: Loaded and initialized swrast
[ 656.220] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 656.220] (II) Initializing extension XFree86-VidModeExtension
[ 656.223] (II) Initializing extension XFree86-DGA
[ 656.226] (II) Initializing extension XFree86-DRI
[ 656.226] (II) Initializing extension DRI2
[ 657.014] (II) config/udev: Adding input device FT5406 memory based driver (/dev/input/event0)
[ 657.015] (**) FT5406 memory based driver: Applying InputClass "libinput touchscreen catchall"
[ 657.016] (**) FT5406 memory based driver: Applying InputClass "tslib touchscreen"
[ 657.016] (II) LoadModule: "tslib"
[ 657.017] (II) Loading /usr/lib/xorg/modules/input/tslib_drv.so
[ 657.021] (II) Module tslib: vendor="X.Org Foundation"
[ 657.021] compiled for 1.20.3, module version = 0.0.1
[ 657.021] Module class: X.Org XInput Driver
[ 657.021] ABI class: X.Org XInput driver, version 24.1
[ 657.022] (II) Using input driver 'tslib' for 'FT5406 memory based driver'
[ 657.022] (**) FT5406 memory based driver: always reports core events
[ 657.029] (**) Option "config_info" "udev:/sys/devices/virtual/input/input0/event0"
[ 657.030] (II) XINPUT: Adding extended input device "FT5406 memory based driver" (type: TOUCHSCREEN, id 6)
[ 657.030] xf86TslibControlProc
[ 657.031] (**) FT5406 memory based driver: (accel) keeping acceleration scheme 1
[ 657.031] (**) FT5406 memory based driver: (accel) acceleration profile 0
[ 657.031] (**) FT5406 memory based driver: (accel) acceleration factor: 2.000
[ 657.032] (**) FT5406 memory based driver: (accel) acceleration threshold: 4
[ 657.032] xf86TslibControlProc
[+0.00s] DEBUG: Logging to /var/log/lightdm/lightdm.log
[+0.00s] DEBUG: Starting Light Display Manager 1.26.0, UID=0 PID=1214
[+0.00s] DEBUG: Loading configuration dirs from /usr/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration from /usr/share/lightdm/lightdm.conf.d/01_debian.conf
[+0.00s] DEBUG: Loading configuration dirs from /usr/local/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /etc/xdg/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf
[+0.00s] DEBUG: Registered seat module local
[+0.01s] DEBUG: Registered seat module xremote
[+0.01s] DEBUG: Registered seat module unity
[+0.01s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.10s] DEBUG: Monitoring logind for seats
[+0.10s] DEBUG: New seat added from logind: seat0
[+0.10s] DEBUG: Seat seat0: Loading properties from config section Seat:*
[+0.10s] DEBUG: Seat seat0: Starting
[+0.10s] DEBUG: Seat seat0: Creating user session
[+0.12s] DEBUG: Loading users from org.freedesktop.Accounts
[+0.12s] DEBUG: User /org/freedesktop/Accounts/User56244 added
[+0.19s] DEBUG: User /org/freedesktop/Accounts/User56243 added
[+0.29s] DEBUG: Seat seat0: Creating display server of type x
[+0.29s] DEBUG: posix_spawn avoided (fd close requested)
[+0.31s] DEBUG: Using VT 7
[+0.31s] DEBUG: Seat seat0: Starting local X display on VT 7
[+0.32s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+0.32s] DEBUG: XServer 0: Writing X server authority to /var/run/lightdm/root/:0
[+0.32s] DEBUG: XServer 0: Launching X Server
[+0.32s] DEBUG: Launching process 1221: /usr/bin/X :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.32s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+0.32s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.33s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+2.43s] DEBUG: Process 1221 exited with return value 127
[+2.43s] DEBUG: XServer 0: X server stopped
[+2.43s] DEBUG: Releasing VT 7
[+2.43s] DEBUG: XServer 0: Removing X server authority /var/run/lightdm/root/:0
[+2.43s] DEBUG: Seat seat0: Display server stopped
[+2.43s] DEBUG: Seat seat0: Stopping session
[+2.43s] DEBUG: Seat seat0: Session stopped
[+2.43s] DEBUG: Seat seat0: Stopping display server, no sessions require it
[+2.44s] DEBUG: Seat seat0: Active display server stopped, starting greeter
[+2.44s] DEBUG: Seat seat0: Creating greeter session
[+2.44s] DEBUG: Seat seat0: Creating display server of type x
[+2.44s] DEBUG: Using VT 7
[+2.44s] DEBUG: Seat seat0: Starting local X display on VT 7
[+2.44s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+2.44s] DEBUG: XServer 0: Writing X server authority to /var/run/lightdm/root/:0
[+2.44s] DEBUG: XServer 0: Launching X Server
[+2.45s] DEBUG: Launching process 1234: /usr/bin/X :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+2.45s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+4.66s] DEBUG: Process 1234 exited with return value 127
[+4.66s] DEBUG: XServer 0: X server stopped
[+4.66s] DEBUG: Releasing VT 7
[+4.66s] DEBUG: XServer 0: Removing X server authority /var/run/lightdm/root/:0
[+4.67s] DEBUG: Seat seat0: Display server stopped
[+4.67s] DEBUG: Seat seat0: Stopping session
[+4.67s] DEBUG: Seat seat0: Session stopped
[+4.67s] DEBUG: Seat seat0: Stopping display server, no sessions require it
[+4.67s] DEBUG: Seat seat0: Stopping; greeter display server failed to start
[+4.67s] DEBUG: Seat seat0: Stopped
[+4.67s] DEBUG: Required seat has stopped
[+4.67s] DEBUG: Stopping display manager
[+4.67s] DEBUG: Display manager stopped
[+4.67s] DEBUG: Stopping daemon
[+4.75s] DEBUG: Exiting with return value 1
Any ideas?
2019-12-05 EDIT: I am using the official display!
