rew
RPI falls back to 1280x720 from x1024.
Fri Sep 14, 2012 2:00 pm
I have an HDMI->VGA converter module connected to my 'pi, as I have a bunch of TFT VGA monitors lying around, but no HDMI ones.
When I boot the 'pi with the cable attached, it comes up nicely in 1280x1024 as I told it to:
hdmi_drive=1
hdmi_group=2
hdmi_mode=35
hdmi_force_hotplug=1
config_hdmi_boost=4
disable_overscan=1
(hdmi_mode=35 is 1280x1024@60Hz in group 2)
However, somehow, the mode drops to a 60Hz 1280x720 mode when the monitor is not connected during boot. I was hoping to prevent these problems by specifying hdmi_force_hotplug=1, and directly specifying a mode that I want.
Why does it drop to a lower resolution if the monitor is not connected?
Just to be sure: the /proc/cmdline file shows "fbheight=720", so it is not my VGA converter that isn't booted correctly and somehow converting the 1280x1024 mode into 1280x720 (as if such a cheap piece of electronics would be capable of such a feat).
Check out our raspberry pi addons: https://www.bitwizard.nl/shop/
dom
Re: RPI falls back to 1280x720 from x1024.
Fri Sep 14, 2012 2:04 pm
A hack would be:
sudo /opt/vc/bin/tvservice -d /boot/edid.dat
and add hdmi_edid_file=1 to config.txt. You would then always see your monitor's edid even when it is not plugged in.
rew
Mon Sep 17, 2012 2:08 pm
OK. That will "hack" it into submission, but that leaves me with the question why it doesn't work in the first place. Wasn't there something with a maximum dot clock that was assumed if no edid data is available? Can I overrule that? This would come closer to my sense of "cleanlyness"....
jongep86
Tue Dec 11, 2012 10:10 pm
I had a similar problem and have the display correctly working now. I'll explain what I did so others can benefit.
I have a Hp1825 hooked up with a hdmi cable to a hdmi-dvi converter in the dvi input.
The monitor works with hdmi and my laptop but the with raspberry pi the monitor is not displaying anything. The screen is 'on', the backlight is on.
tvservice -s only showed me the default (I think 1280x720)
tvservice -m CEA of -m DMT gives "Group CEA has 0 modes:" and "Group DMThas 0 modes:"
tvservice -d edid.dat followed by a "edidparser edid.dat' gives me a lot of correctly looking output !
The solution now was to save the edid.dat to /boot/edid.dat and to put 'hdmi_edid_file=1" in /boot/config.txt.
Combined with "hdmi_group=2" & "hdmi_mode=36" (1280x1024@75), hdmi_force_hotplug=1, config_hdmi_boost=4, in /boot/config.txt.
I tried "hdmi_ignore_edid=0xa5000080" before, that only gives me broken, partially output only after I killed startx.....
I tried a lot of "hdmi_group" and "hdmi_mode" combo's
turkk33
Fri Aug 15, 2014 2:50 pm
This is awesome thank you. I was missing my config.txt file altogether but you can find the default file here: http://elinux.org/R-Pi_ConfigurationFile
I made a txt file on my desktop in Windows and used WinSCP to transfer the file to /boot/.
edugalvani
Sun Jul 19, 2015 1:14 am
Firstly, thank you very much for these info, I also had a similar battle to find a perfect combination of parameters which fits to my monitor model.
However, on each boot, RBPi keeps loading another settings on config.txt file, so I'd like to know how to create and to configure this 'edid.dat' file which needs to be saved in the /boot folder together with the config.txt file.
Thank you!
Brisou394
Sun Mar 18, 2018 11:43 pm
I Was stuck too...
I used this for my 1080p monitor (PC)
#hdmi_force_mode=1
sdtv_aspect=3
hdmi_drive=2
hdmi_group=2
hdmi_mode=82
and I think it is this that brings back the good stuff..
edid_content_type=0
See ya.
rayfranco
Wed Aug 19, 2020 6:02 am
My new HP Z29 (3840x2160 @ 60Hz) monitor came in today (8-18-20). For about 8 hours, I thought that I had made a $500 mistake. Thank goodness for this form and threat. After commenting out the fkms line, I now have native resolution.
The problem and the work around exist in both the Raspberry 0S-32 and 0S-64.
I wish I could help y'all, but y'all are way ahead of me.
