iEuropa
Driver for TP-LINK ARCHER T3U WiFi adapter
Wed Jul 08, 2020 10:12 pm
Hello to the community and hopefully hello MrEngman for yet another wifi driver request! :)
Im writing this post here because I recently bought a TP-LINK archer T3U Plus (the plus variant adds an antenna so its basically the same as the T3U, same chip inside) to add AC connectivity to my raspberry pi 3 B+. I have been following the tutorials here and there for a couple hours now but the driver that are available on fars-robotics.net dont seem to be recognizing the vendor ID and/or the product ID to install the proper driver.
I was wondering if you could add the adapter to the list in your drivers and hopefully recompile it :) here are the informations you may need for this:
TP-LINK archer T3U
Realtek RTL8812BU
idVendor 2357
idProduct 0138
Raspberry Pi 3 B+ on kernel revision 5.4.0-v7+ build 1324
Dont hesitate to reply with any additional information you may need! :D
Cheers,
iEuropa
MrEngman
Re: Driver for TP-LINK ARCHER T3U WiFi adapter
Thu Jul 09, 2020 3:53 pm
TP-LINK archer T3U
Realtek RTL8812BU
idVendor 2357
idProduct 0138
Cheers,
iEuropa
Hi iEuropa,
I have updated the driver I compile to include the USB ID for the Archer T3U Plus you have. I assume the kernel you are using is actually 5.4.50-v7+ build 1324, not 5.4.0-v7+ as you posted.
I do not have one of these wifi dongles so cannot test the driver works with it. Let me know how you get on with it.
MrEngman
iEuropa
Thu Jul 09, 2020 4:21 pm
EDIT: The AP have been setup and tested working perfectly :) Kind of an overkill since it's limited to 100 Mbps from the Ethernet port but still way better than nothing hey? :D
I can confirm that the driver is properly usable on my Raspberry and works :) I am gonna do further testing throughout the day, try to setup an AP with the adapter and I will come back to you if I find anything not working or if I successfully managed to run all my tests :)
Thank you a million times!!
Cheers,
iEuropa
rasperrylove
Mon Oct 12, 2020 10:31 pm
Cheers,
iEuropa
Hello!
Can you say me where do you find the driver?
Thanks!!
MrEngman
Mon Oct 12, 2020 11:05 pm
Cheers,
iEuropa
Hello!
Thanks!!
Take a look here
MrEngman
rasperrylove
Mon Oct 12, 2020 11:22 pm
Cheers,
iEuropa
Hello!
Thanks!!
Take a look here
MrEngman
WOw, great!!!
Thank you my friend!!! ^^
krolikbest
Mon Oct 26, 2020 2:58 pm
I just bought it too and provided link makes me a little confused.. Which one of these files should I install? Any help would it be appreciated. I use RPi 3B+ Stretch
Regards,
Ok, already get it :)
CC2099
Sun Nov 22, 2020 2:31 pm
MrEngman, I downloaded 8822bu for my kernel from fars-robotics.net but it doesn't look like it has support for 2357:0138 built into it:
root@raspberrypi:~ # modinfo 8822bu
filename:       /lib/modules/4.19.118-v7+/kernel/drivers/net/wireless/8822bu.ko
version:        v5.3.1_27678.20180430_COEX20180427-5959
author:         Realtek Semiconductor Corp.
description:    Realtek Wireless Lan Driver
license:        GPL
srcversion:     EB4F2C34E0AD3968F852FD0
alias:          usb:v13B1p0043d*dc*dsc*dp*icFFiscFFipFFin*
alias:          usb:v2001p331Ed*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0846p9055d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0E66p0025d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2357p012Dd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2357p0115d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2001p331Cd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v7392pC822d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0B05p184Cd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v7392pB822d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0B05p1812d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDApB812d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDApB82Cd*dc*dsc*dp*icFFiscFFipFFin*
depends:        cfg80211
vermagic:       4.19.118-v7+ SMP mod_unload modversions ARMv7 p2v8
When I connect my Archer T3U Plus (AC1300) nothing happens:
root@raspberrypi:~ # dmesg -c
[   75.996404] usb 1-1.2: new high-speed USB device number 6 using dwc_otg
[   76.127579] usb 1-1.2: New USB device found, idVendor=2357, idProduct=0138, bcdDevice= 2.10
[   76.127593] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   76.127602] usb 1-1.2: Product: 802.11ac NIC
[   76.127611] usb 1-1.2: Manufacturer: Realtek
[   76.127620] usb 1-1.2: SerialNumber: 123456
root@raspberrypi:~ # modprobe 8822bu
[  128.286201] 8822bu: loading out-of-tree module taints kernel.
[  128.456186] usbcore: registered new interface driver rtl88x2bu
I assume you only added support for one specific kernel module? Could you please recompile for 4.19.118-v7 ... and v7l ?
Thanks,
Caleb
MrEngman
Sun Nov 22, 2020 6:37 pm
license:        GPL
depends:        cfg80211
Thanks,
Caleb
Driver now updated. Your wifi is already supported in newer kernel versions 5.4, 5.9 and 5.10.
MrEngman
CC2099
Tue Nov 24, 2020 6:58 pm
Wow. That was fast. Thank you very much! The adapter seems to work fine. Do you know anything about the HALMAC errors that are displayed in dmesg when the rtw_drv_log_level parameter in the config file is set to 2?
  0 = NONE (default)
  1 = ALWAYS
  2 = ERRORS
  3 = WARNINGS
  4 = INFO
  5 = DEBUG
  6 = MAX
For example:
RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
I also see informational messages like:
RTW: rtw_set_802_11_connect(wlan1) fw_state=0x00000000
and warning messages like:
RTW: WARN hw_port0_tsf_sync_sel(wlan1): port0 already disable TSF sync
I assume rtw_drv_log_level is set to 0 because the driver is logging informational and warning messages when only error messages should be logged?
MrEngman
Wed Nov 25, 2020 8:32 pm
  0 = NONE (default)
  1 = ALWAYS
  2 = ERRORS
  3 = WARNINGS
  4 = INFO
  5 = DEBUG
  6 = MAX
For example:
Not sure what those issues are and haven't been able to find any info searching the internet.
rtw_drv_log_level is set to 0 because I compile the driver with it set to 0.
MrEngman
