I have not figured out a way for letting the prboom libretro port look for prboom.wad at another directory than the rom directory.Aloshi wrote:Hmm...would it be possible to put it in another directory? I could modify the search to skip hidden files that start with ".", and you could rename it to ".prboom.wad". Would that work?petrockblog wrote:knowbody wrote: @Aloshi: What would you suggest to hide this "supplementary" prboom.wad file?
Also, I just tried to make the prboom.wad hidden, but then prboom does not find it as well.
For an easy-to-use system, I thought that in the end the --gamelist-only option for emulation station might be at least one possibility to hide prboom.wad.
An alternative would be an explicit "hide" entry in the gamelist.xml, which would have to be implemented.
