i think the next course of action, is to try and re-flash the eeprom to enable debug
[clever@system76:~/apps/rpi]$ git clone https://github.com/raspberrypi/rpi-eeprom
[clever@system76:~/apps/rpi]$ cd rpi-eeprom/
[clever@system76:~/apps/rpi/rpi-eeprom]$ cat bootconf.txt
[all]
BOOT_UART=1
WAKE_ON_GPIO=1
POWER_OFF_ON_HALT=0
ENABLE_SELF_UPDATE=1
BOOT_ORDER=0xf541
[none]
FREEZE_VERSION=0
[clever@system76:~/apps/rpi/rpi-eeprom]$ ./rpi-eeprom-config --config bootconf.txt --out pieeprom.bin firmware/beta/pieeprom-2021-09-27.bin
[clever@system76:~/apps/rpi/rpi-eeprom]$ sha256sum pieeprom.bin | cut -d' ' -f1 > pieeprom.sig
[clever@system76:~/apps/rpi/rpi-eeprom]$ echo 'ts: 42' >> pieeprom.sig
[clever@system76:~/apps/rpi/rpi-eeprom]$ cat pieeprom.sig
7f5baecf2cfe680cfb914b6abe737236ddcbfdf2fffc8aecfe339a06159f7e15
ts: 42
this will grab the latest beta firmware, and modify the config file within it
it enables the debug logs on the uart, and sets the boot order to SD, usb, bcmusb, restart
it then generates a sig file containing the hash, which is needed for the next step
[root@system76:~]# mount -v /dev/mmcblk0p1 /mnt/
[root@system76:~]# cp -vi /home/clever/apps/rpi/rpi-eeprom/pieeprom.{bin,sig} /mnt/
'/home/clever/apps/rpi/rpi-eeprom/pieeprom.bin' -> '/mnt/pieeprom.bin'
'/home/clever/apps/rpi/rpi-eeprom/pieeprom.sig' -> '/mnt/pieeprom.sig'
[root@system76:~]# cp -v /home/clever/apps/rpi/rpi-eeprom/firmware/beta/recovery.bin /mnt/
'/home/clever/apps/rpi/rpi-eeprom/firmware/beta/recovery.bin' -> '/mnt/recovery.bin'
[root@system76:~]# umount /mnt
this puts the new firmware file onto an SD card, along with the official recovery.bin, which does reflashing
all of the above can be done on any system with python2, i just happened to use my x86 laptop, because its got a good SD socket built-in
BMD "vl805.bin" not found
SIG pieeprom.sig 7f5baecf2cfe680cfb914b6abe737236ddcbfdf2fffc8aecfe339a06159f7e15 0
Reading EEPROM: 524288
Writing EEPROM
Verify BOOT EEPROM
BOOT-EEPROM: UPDATED
if you then power up the pi4 with that SD in it, the above will be printed to the serial port
each + represents a block of the SPI that didnt match, so it had to be erased and re-programmed
each . represents a block of SPI that did match, so it was just left as-is
once that is done, you can take the card back out, and turn the pi on a second time, and you should see:
RPi: BOOTLOADER release VERSION:39e76747 DATE: Sep 27 2021 TIME: 14:30:29 BOOTMODE: 0x00000006 part: 0 BUILD_TIMESTAMP=1632749428 0xd328cdce 0x00c03112 0x00051599
PM_RSTS: 0x00001000
part 00000000 reset_info 00000000
uSD voltage 3.3V
Initialising SDRAM 'Micron' 16Gb x2 total-size: 32 Gbit 3200
XHCI-STOP
xHC ver: 256 HCS: 05000420 fc000031 00e70004 HCC: 002841eb
USBSTS 11
xHC ports 5 slots 32 intrs 4
Reset USB port-power 1000 ms
xhci_set_port_power 1 0
xhci_set_port_power 2 0
xhci_set_port_power 3 0
xhci_set_port_power 4 0
xhci_set_port_power 5 0
xhci_set_port_power 1 1
xhci_set_port_power 2 1
xhci_set_port_power 3 1
xhci_set_port_power 4 1
xhci_set_port_power 5 1
XHCI-STOP
USBSTS 10
XHCI-STOP
USBSTS 11
Boot mode: SD (01) order f54
SD HOST: 250000000 CTL0: 0x00000000 BUS: 100000 Hz actual: 100000 HZ div: 2500 (1250) status: 0x1fff0000 delay: 1080
SD HOST: 250000000 CTL0: 0x00000f00 BUS: 100000 Hz actual: 100000 HZ div: 2500 (1250) status: 0x1fff0000 delay: 1080
EMMC
SD retry 1 oc 0
SD retry 2 oc 0
SDV1
SD retry 3 oc 0
SD CMD: 0x371a0010 (55) 0x0 0x1fff0001
Failed to open device: 'sdcard' (cmd 371a0010 status 1fff0001)
Retry SD 1
EMMC
SD retry 1 oc 0
SD retry 2 oc 0
SDV1
SD retry 3 oc 0
Boot mode: USB-MSD (04) order f5
XHCI-STOP
USBSTS 0
XHCI-STOP
USBSTS 1
USB2[1] 400202e1 connected
USB2 root HUB port 1 init
DEV [01:00] 2.16 000000:01 class 9 VID 2109 PID 3431
HUB init [01:00] 2.16 000000:01
it brought the ram online, failed to find an sd card, and has now begun searching usb ports for drives
if something is wrong with the ram, it should print some kind of error during that process
