See https://gitlab.freedesktop.org/gstreame ... issues/952 - this issue repros on both versions. There is a (locked) thread that indicates that a needed include is missing on the 64bit version, and follows on to note that the RPi4 doesn't use these systems.
Full error at the link above, but happy to dup if you think it helps. What is the right workaround here?
Linux raspberrypi 5.10.92-v7l+ #1514 SMP Mon Jan 17 17:38:03 GMT 2022 armv7l GNU/Linux
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
333 FAILED: gst-libs/gst/gl/libgstgl-1.0.so.0.1804.0.p/egl_gstglcontext_egl.c.o
334 cc -Igst-libs/gst/gl/libgstgl-1.0.so.0.1804.0.p -I. -I.. -Igst-libs -I../gst-libs -Isubprojects/gl-headers/abyss -I../subprojects/gl-headers/abyss -Isubprojects/gl-headers/wglext -I../subprojects/gl-headers/wglext -Igst-libs/gst/gl -Igst-libs/gst/video -I/usr/include/gstreamer-1.0 -I/usr/include/arm-linux-gnueabihf -I/usr/include/glib-2.0 -I/usr/lib/arm-linux-gnueabihf/glib-2.0/include -I/usr/include/orc-0.4 -I/usr/include/interface/vmcs_host/linux -I/usr/include/interface/vcos/pthreads -fdiagnostics-color=always -pipe -D_FILE_OFFSET_BITS=64 -Wall -Winvalid-pch -O3 -fvisibility=hidden -fno-strict-aliasing -DG_DISABLE_CAST_CHECKS -Wmissing-declarations -Wredundant-decls -Wundef -Wwrite-strings -Wformat -Wformat-nonliteral -Wformat-security -Winit-self -Wmissing-include-dirs -Waddress -Wno-multichar -Wvla -Wpointer-arith -Wmissing-prototypes -Wdeclaration-after-statement -Wno-unused -fPIC -DUSE_VCHIQ_ARM -pthread -DHAVE_CONFIG_H -DUSE_EGL_RPI -DBUILDING_GST_GL -MD -MQ gst-libs/gst/gl/libgstgl-1.0.so.0.1804.0.p/egl_gstglcontext_egl.c.o -MF gst-libs/gst/gl/libgstgl-1.0.so.0.1804.0.p/egl_gstglcontext_egl.c.o.d -o gst-libs/gst/gl/libgstgl-1.0.so.0.1804.0.p/egl_gstglcontext_egl.c.o -c ../gst-libs/gst/gl/egl/gstglcontext_egl.c
335 In file included from ../gst-libs/gst/gl/egl/gstglcontext_egl.c:37:
336 ../gst-libs/gst/gl/egl/gstegl.h:35:9: warning: bad option '-fgnu89-inline' to pragma 'optimize' [-Wpragmas]
337 35 | #pragma GCC optimize ("gnu89-inline")
338 | ^~~
339 In file included from ../gst-libs/gst/gl/egl/gstglcontext_egl.c:52:
340 ../gst-libs/gst/gl/egl/../dispmanx/gstglwindow_dispmanx_egl.h:35:9: warning: bad option '-fgnu89-inline' to pragma 'optimize' [-Wpragmas]
341 35 | #pragma GCC optimize ("gnu89-inline")
342 | ^~~
343 In file included from ../gst-libs/gst/gl/egl/gstglcontext_egl.c:52:
344 ../gst-libs/gst/gl/egl/../dispmanx/gstglwindow_dispmanx_egl.h:66:3: error: unknown type name 'EGL_DISPMANX_WINDOW_T'
345 66 | EGL_DISPMANX_WINDOW_T native;
346 | ^~~~~~~~~~~~~~~~~~~~~
347 ../gst-libs/gst/gl/egl/../dispmanx/gstglwindow_dispmanx_egl.h:67:3: error: unknown type name 'EGL_DISPMANX_WINDOW_T'
348 67 | EGL_DISPMANX_WINDOW_T foreign;
349 | ^~~~~~~~~~~~~~~~~~~~~
350 ninja: build stopped: subcommand failed.
Re: Fail building Gstreamer 1.20.0 or 1.18.5 on 32bit - unknown type name ‘EGL_DISPMANX_WINDOW_T’
-DUSE_EGL_RPI is invalid with 64bit architectures.
https://github.com/GStreamer/gst-plugin ... build#L235
implies gl_winsys wants to not be set to "auto", and probably wants to be "egl".
Or ideally the logic in https://github.com/GStreamer/gst-plugin ... build#L394 wants to be a bit smarter than just looking for bcm_host.
Thanks. Yes, after much fiddling (you'd honestly think the default would work), that seemed to help. At least it builds now.
also on 64bit Re: Fail building Gstreamer 1.20.0 or 1.18.5 on 32bit - unknown type name ‘EGL_DISPMANX_WINDOW_T’
Trying to build GStreamer 1.21 (development) on R Pi OS (bullseye) Lite 64bit.
also fails to build gst-plugins-base because of this EGL_DISPMANX_WINDOW_T error.
is there a workaround?
EDIT: from 6by9's reply, I worked out that the solution for avoiding the EGL_DISPMANX_ error on a 64-bit R Pi OS system turns out to be to replace
meson build
with
meson build -Dgst-plugins-base:gl_winsys=egl
(assuming that you want to build for the egl gl -windowing system.)
The default is "gl_winsys=auto" which seems to pickup up dispmanx by mistake.
choices for the gl_winsys option: : ['x11', 'wayland', 'win32', 'winrt', 'cocoa', 'dispmanx', 'egl', 'viv-fb', 'gbm', 'android', 'auto'],
description : 'A comma separated list of opengl windows systems to enable building against. Supported values are x11, wayland, win32, winrt, cocoa, dispmanx, egl, viv-fb, gbm, and android')
Just make sure its not "auto", and your list doesn't include dispmanx
Edited by fduncanh just now
meson build
with
I faced this problem too when building gst-plugins-base 1.18.
The work around described by fduncanh did not work.
The meson option should be specified as:
meson build -Dgl_winsys=egl
NOT
NOT
