dwg
Help to set cpu throttling limit on Batocera retro gaming OS.
Tue Aug 02, 2022 1:52 pm
Hi !
I am using Batocera https://batocera.org/ is based on Buildroot. The system doesn't have the cpu throttling mechanism that PI OS have.
I finded in https://www.raspberrypi.com/documentati ... g_txt.html about some options that i can add to the config.txt .
I want to replicate the Raspberry Pi OS cpu throttling behavior. What options, from the documentation, i must add to the config.txt so to have the result i want ? Thanks!
kerry_s
Re: Help to set cpu throttling limit on Batocera retro gaming OS.
Tue Aug 02, 2022 2:25 pm
do lscpu see what the current settings are.
i run mine in performance mode, no throttling.
dwg
Tue Aug 02, 2022 2:39 pm
I try to run the command from the Rpi3 with The Batocera but the command didn't found :
-bash: lscpu: command not found
kerry_s
Tue Aug 02, 2022 4:17 pm
i'm thinking to even boot it needs an rpi kernel and firmware, so it should have the same settings as the standard raspberry os. i don't think you need to do anything.
Return to “Gaming”
