hitsware
One More Time .....
Fri Aug 05, 2022 12:59 am
I again am trying Bullseye .
It still does not see my monitors .
( Screen configuration tool does not work )
( Though it works with Buster )
What does work :
xrandr --output HDMI-1 --mode 1280x720
But I would like not to have to open the
terminal every time I reboot .
I ' ve tried rc blah et. al , but cannot get
any of those to work .
Raspi config no longer has a screen tool .
Even config.txt seems not to work ..
Any insights appreciated .......
http://www.hitswares.com/
kerry_s
Re: One More Time .....
Fri Aug 05, 2022 7:33 am
if it can not see the monitors, what do you expect it to do?
what monitors? brand? make? model?
your expecting the same as your pi, you want us to guess what your doing wrong without knowing anything about your setup.
first start with the stickys
maybe post raspinfo output, it'll create a raspinfo.txt file in your home folder.
thagrol
Fri Aug 05, 2022 12:09 pm
And what, exactly, did you try? rc.local and @reboot cron jobs will run before the desktop has started so will fail.
If you're autobooting to the desktop, did you try adding that xrandrx line to /etc/xdg/lxsession/LXDE-pi/autostart ?
aBUGSworstnightmare
Fri Aug 05, 2022 12:23 pm
What does work :
which Pi do you use?
Prepare a fresh uSD with Bullseye, enable SSH.
Boot the system, then connect via SSH and get all updates
sudo apt-get update
sudo apt-get full-upgrade
reboot
Most likely still no display, so run below command in a SSH terminal and post the result here
DISPLAY=:0 xrandr --verbose
That will give us an idea what you have connected (and if any monitor is detected at all).
hitsware
Fri Aug 05, 2022 9:02 pm
See the monitors .
> brand? make? model?
https://www.sceptre.com/pub/Manuals/LED ... 0guide.pdf
> raspinfo output
Maybe the problem ...... :
004910.214: arasan: arasan_emmc_open
005060.429: brfs: File read: /mfs/sd/config.txt
005061.393: brfs: File read: 2075 bytes
005179.073: HDMI1:EDID error reading EDID block 0 attempt 0
005185.097: HDMI1:EDID error reading EDID block 0 attempt 1
005191.122: HDMI1:EDID error reading EDID block 0 attempt 2
005197.144: HDMI1:EDID error reading EDID block 0 attempt 3
005203.168: HDMI1:EDID error reading EDID block 0 attempt 4
005209.191: HDMI1:EDID error reading EDID block 0 attempt 5
005215.216: HDMI1:EDID error reading EDID block 0 attempt 6
005221.238: HDMI1:EDID error reading EDID block 0 attempt 7
005227.262: HDMI1:EDID error reading EDID block 0 attempt 8
005233.285: HDMI1:EDID error reading EDID block 0 attempt 9
005234.301: HDMI1:EDID giving up on reading EDID block 0
005236.194: brfs: File read: /mfs/sd/config.txt
006344.182: gpioman: gpioman_get_pin_num: pin DISPLAY_DSI_PORT not defined
006346.704: *** Restart logging
006346.724: brfs: File read: 2075 bytes
006410.498: hdmi: HDMI1:EDID error reading EDID block 0 attempt 0
006416.525: hdmi: HDMI1:EDID error reading EDID block 0 attempt 1
006423.035: hdmi: HDMI1:EDID error reading EDID block 0 attempt 2
006435.035: hdmi: HDMI1:EDID error reading EDID block 0 attempt 3
006441.087: hdmi: HDMI1:EDID error reading EDID block 0 attempt 4
006447.139: hdmi: HDMI1:EDID error reading EDID block 0 attempt 5
006453.188: hdmi: HDMI1:EDID error reading EDID block 0 attempt 6
006459.241: hdmi: HDMI1:EDID error reading EDID block 0 attempt 7
006465.293: hdmi: HDMI1:EDID error reading EDID block 0 attempt 8
006471.345: hdmi: HDMI1:EDID error reading EDID block 0 attempt 9
006472.378: hdmi: HDMI1:EDID giving up on reading EDID block 0
006477.474: hdmi: HDMI1:EDID error reading EDID block 0 attempt 0
006483.526: hdmi: HDMI1:EDID error reading EDID block 0 attempt 1
006489.575: hdmi: HDMI1:EDID error reading EDID block 0 attempt 2
006495.628: hdmi: HDMI1:EDID error reading EDID block 0 attempt 3
006501.679: hdmi: HDMI1:EDID error reading EDID block 0 attempt 4
006507.731: hdmi: HDMI1:EDID error reading EDID block 0 attempt 5
006513.782: hdmi: HDMI1:EDID error reading EDID block 0 attempt 6
006519.834: hdmi: HDMI1:EDID error reading EDID block 0 attempt 7
006525.885: hdmi: HDMI1:EDID error reading EDID block 0 attempt 8
006531.937: hdmi: HDMI1:EDID error reading EDID block 0 attempt 9
006532.970: hdmi: HDMI1:EDID giving up on reading EDID block 0
006533.008: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
006533.039: HDMI0: hdmi_pixel_encoding: 300000000
006533.064: HDMI1: hdmi_pixel_encoding: 300000000
006538.814: dtb_file 'bcm2711-rpi-4-b.dtb'
hitsware
Fri Aug 05, 2022 9:28 pm
Like This :
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@xscreensaver -no-splash
@xrandr --output HDMI-1 --mode 1280x720
Still doesn't work ...
hitsware
Fri Aug 05, 2022 9:47 pm
hitsware@raspberrypi:~ $ raspinfo
System Information
Raspberry Pi 4 Model B Rev 1.1
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
Raspberry Pi reference 2022-04-04
Generated using pi-gen, https://github.com/RPi-Distro/pi-gen, 226b479f8d32919c9fe36dd5b4c20c02682f8180, stage4
Linux raspberrypi 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l GNU/Linux
Revision	: c03111
Serial		: 100000009502f7e3
Model		: Raspberry Pi 4 Model B Rev 1.1
Throttled flag  : throttled=0x0
Camera          : supported=0 detected=0, libcamera interfaces=0
aBUGSworstnightmare
Fri Aug 05, 2022 10:00 pm
System Information
VERSION_ID="11"
Revision	: c03111
thanks for the info but I want to see
kerry_s
Fri Aug 05, 2022 10:53 pm
your tv does not provide the correct info to use as a pc screen.
hitsware
Fri Aug 05, 2022 10:55 pm
Before adjustment
hitsware@raspberrypi:~ $ DISPLAY=:0 xrandr --verbose
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 7680 x 7680
HDMI-1 connected primary 1920x1080+0+0 (0x48) normal (normal left inverted right x axis y axis) 413mm x 234mm
	Identifier: 0x45
	Timestamp:  18722
	Subpixel:   unknown
	Gamma:      1.0:1.0:1.0
	Brightness: 1.0
	Clones:
	CRTC:       0
	CRTCs:      0
	Transform:  1.000000 0.000000 0.000000
	            0.000000 1.000000 0.000000
	            0.000000 0.000000 1.000000
	           filter:
	_MUTTER_PRESENTATION_OUTPUT: 0
	EDID:
		00ffffffffffff004e14730600000000
		0c1b0103802213782aeed1a555489b26
		125054210800310081c0010101010101
		010101010101662156aa51001e30468f
		33009dea1000001e000000ff00000a20
		20202020202020202020000000fd0032
		3c1e3c09000a202020202020000000fc
		004531360a20202020202020202001d3
		020329f15090050403020716011f1213
		14201511062309070767030c00100038
		2d83010000e3050301000000ff003030
		0a20202020202020202020000000ff00
		100a2020202020202020202020011d00
		7251d01e206e28550006442100001e8c
		0ad08a20e02d10103e96000644210000
		18000000000000000000000000000083
	Broadcast RGB: Automatic
		supported: Automatic, Full, Limited 16:235
	max bpc: 8
		range: (8, 12)
	bottom margin: 0
		range: (0, 100)
	top margin: 0
		range: (0, 100)
	right margin: 0
		range: (0, 100)
	left margin: 0
		range: (0, 100)
	Colorspace: Default
		supported: Default, SMPTE_170M_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, DCI-P3_RGB_Theater
	link-status: Good
		supported: Good, Bad
	CONNECTOR_ID: 32
		supported: 32
	non-desktop: 0
		range: (0, 1)
  1920x1080 (0x48) 148.500MHz +HSync +VSync *current
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  67.50KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  60.00Hz
  1920x1080 (0x49) 148.500MHz +HSync +VSync
        h: width  1920 start 2448 end 2492 total 2640 skew    0 clock  56.25KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  50.00Hz
  1920x1080 (0x4a) 148.352MHz +HSync +VSync
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  67.43KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  59.94Hz
  1920x1080i (0x4b) 74.250MHz +HSync +VSync Interlace
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  33.75KHz
        v: height 1080 start 1084 end 1094 total 1125           clock  60.00Hz
  1920x1080i (0x4c) 74.250MHz +HSync +VSync Interlace
        h: width  1920 start 2448 end 2492 total 2640 skew    0 clock  28.12KHz
        v: height 1080 start 1084 end 1094 total 1125           clock  50.00Hz
  1920x1080 (0x4d) 74.250MHz +HSync +VSync
        h: width  1920 start 2558 end 2602 total 2750 skew    0 clock  27.00KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  24.00Hz
  1920x1080i (0x4e) 74.176MHz +HSync +VSync Interlace
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  33.72KHz
        v: height 1080 start 1084 end 1094 total 1125           clock  59.94Hz
  1920x1080 (0x4f) 74.176MHz +HSync +VSync
        h: width  1920 start 2558 end 2602 total 2750 skew    0 clock  26.97KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  23.98Hz
  1280x720 (0x50) 74.250MHz +HSync +VSync
        h: width  1280 start 1390 end 1430 total 1650 skew    0 clock  45.00KHz
        v: height  720 start  725 end  730 total  750           clock  60.00Hz
  1280x720 (0x51) 74.250MHz +HSync +VSync
        h: width  1280 start 1720 end 1760 total 1980 skew    0 clock  37.50KHz
        v: height  720 start  725 end  730 total  750           clock  50.00Hz
  1280x720 (0x52) 74.176MHz +HSync +VSync
        h: width  1280 start 1390 end 1430 total 1650 skew    0 clock  44.96KHz
        v: height  720 start  725 end  730 total  750           clock  59.94Hz
  1024x768 (0x53) 65.000MHz -HSync -VSync
        h: width  1024 start 1048 end 1184 total 1344 skew    0 clock  48.36KHz
        v: height  768 start  771 end  777 total  806           clock  60.00Hz
  800x600 (0x54) 40.000MHz +HSync +VSync
        h: width   800 start  840 end  968 total 1056 skew    0 clock  37.88KHz
        v: height  600 start  601 end  605 total  628           clock  60.32Hz
  720x576 (0x55) 27.000MHz -HSync -VSync
        h: width   720 start  732 end  796 total  864 skew    0 clock  31.25KHz
        v: height  576 start  581 end  586 total  625           clock  50.00Hz
  720x576i (0x56) 13.500MHz -HSync -VSync Interlace
        h: width   720 start  732 end  795 total  864 skew    0 clock  15.62KHz
        v: height  576 start  580 end  586 total  625           clock  50.00Hz
  720x480 (0x57) 27.027MHz -HSync -VSync
        h: width   720 start  736 end  798 total  858 skew    0 clock  31.50KHz
        v: height  480 start  489 end  495 total  525           clock  60.00Hz
  720x480 (0x58) 27.000MHz -HSync -VSync
        h: width   720 start  736 end  798 total  858 skew    0 clock  31.47KHz
        v: height  480 start  489 end  495 total  525           clock  59.94Hz
  720x480i (0x59) 13.514MHz -HSync -VSync Interlace
        h: width   720 start  739 end  801 total  858 skew    0 clock  15.75KHz
        v: height  480 start  488 end  494 total  525           clock  60.00Hz
  720x480i (0x5a) 13.500MHz -HSync -VSync Interlace
        h: width   720 start  739 end  801 total  858 skew    0 clock  15.73KHz
        v: height  480 start  488 end  494 total  525           clock  59.94Hz
  640x480 (0x5b) 25.200MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.50KHz
        v: height  480 start  490 end  492 total  525           clock  60.00Hz
  640x480 (0x5c) 25.175MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.47KHz
        v: height  480 start  490 end  492 total  525           clock  59.94Hz
HDMI-2 disconnected (normal left inverted right x axis y axis)
	Identifier: 0x46
	Timestamp:  18722
	Subpixel:   unknown
	Clones:
	CRTCs:      4
	           filter:
	max bpc: 8
		range: (8, 12)
	bottom margin: 0
		range: (0, 100)
	top margin: 0
		range: (0, 100)
	right margin: 0
		range: (0, 100)
	left margin: 0
		range: (0, 100)
	Colorspace: Default
	link-status: Good
	CONNECTOR_ID: 41
		supported: 41
	non-desktop: 0
		range: (0, 1)
hitsware
Fri Aug 05, 2022 11:01 pm
After adjustment
Screen 0: minimum 320 x 200, current 1280 x 720, maximum 7680 x 7680
HDMI-1 connected primary 1280x720+0+0 (0x50) normal (normal left inverted right x axis y axis) 413mm x 234mm
	Identifier: 0x45
	Timestamp:  290008
	Subpixel:   unknown
	Gamma:      1.0:1.0:1.0
	Brightness: 1.0
	Clones:
	CRTC:       0
	CRTCs:      0
	           filter:
	EDID:
	max bpc: 8
		range: (8, 12)
	bottom margin: 0
		range: (0, 100)
	top margin: 0
		range: (0, 100)
	right margin: 0
		range: (0, 100)
	left margin: 0
		range: (0, 100)
	Colorspace: Default
	link-status: Good
	CONNECTOR_ID: 32
		supported: 32
	non-desktop: 0
		range: (0, 1)
  1280x720 (0x50) 74.250MHz +HSync +VSync *current
	Identifier: 0x46
	Timestamp:  290008
	Subpixel:   unknown
	Clones:
	CRTCs:      4
	           filter:
	max bpc: 8
		range: (8, 12)
	bottom margin: 0
		range: (0, 100)
	top margin: 0
		range: (0, 100)
	right margin: 0
		range: (0, 100)
	left margin: 0
		range: (0, 100)
	Colorspace: Default
	link-status: Good
	CONNECTOR_ID: 41
		supported: 41
	non-desktop: 0
		range: (0, 1)
thagrol
Fri Aug 05, 2022 11:03 pm
So here's what I suggest you do next: Post the informatrion that we have asked for. Below is one way to get it.
  1. Create thefollowing shell script:
    #!/bin/bash
    /usr/bin/date >> /home/pi/xrandr.log
    DISPLAY=:0 /usr/bin/xrandr --verbose  >>/home/pi/xrandr.log 2>&1
    DISPLAY=:0 /usr/bin/xrandr --verbose --output HDMI-1 --mode 1280x720 >>/home/pi/xrandr.log  2>&1
  2. Save that as /home/pi/xrandrdebug.sh
  3. Give it execute permission:
    chmod a+x /home/pi/xrandrdebug.sh
  4. Call it using your preferred method during boot (or all of them).
    Cron:
    @reboot /home/pi/xrandrdebug.sh
    rc.local: add the following above "exit 0":
    autostart:
  5. Post the contents of /home/pi/xrandr.log. Wrap it in code tags.
That should give us some idea of what is going on and what, if any, errors are being thrown.
hitsware
Sat Aug 06, 2022 1:53 am
But with Buster it works ?
( It is a ' pc screen ' )
HawaiianPi
Sat Aug 06, 2022 2:33 am
Edit your config.txt file (it's on the small FAT32 "boot" partition which is accessible on a Windows or Mac OS PC).
In the config.txt file, look for the line with:
dtoverlay=vc4-kms-v3d
and change it to
dtoverlay=vc4-fkms-v3d
(basically, just put an f in front of kms on that line)
That configures Bullseye to use the older FKMS graphics driver, which is no-longer supported but still works in Bullseye (FKMS was by prior OS like Buster).
aBUGSworstnightmare
Sat Aug 06, 2022 6:18 am
Another try - after letting us know what the physical resolution of yoir screen is (as the one pocked up as preferred from EDID seem non{working):
Change the content of your kernel command line - 'cmdline.txt'; find it in boot - to below
video=HDMI-A-1:1280x720M@60 console=tty1 root=PARTUUID=cecfa9a5-02 rootfstype=ext4 fsck.repair=yes rootwait plymouth.ignore-serial-consoles
What I want you to do is adding 'video=HDMI-A-1:1280x720M@60' to the beginning of that line. This should force WXGA output of the Pi on HDMI0 (the port next to USB-C on your Pi4).
Keep using KMS!
Sat Aug 06, 2022 8:09 am
and change it to
Unlikely to make any difference. This seems to be a mode selection issue, and FKMS and KMS use exactly the same EDID parsing code.
FKMS would only be of benefit if you've also set a custom mode in config.txt, as that then bypasses the EDID parsing and lists the one mode.
Sat Aug 06, 2022 8:23 am
Before adjustment
	Identifier: 0x45
	Timestamp:  18722
	Subpixel:   unknown
	Gamma:      1.0:1.0:1.0
	Brightness: 1.0
	Clones:
	CRTC:       0
	CRTCs:      0
	           filter:
	EDID:
	max bpc: 8
		range: (8, 12)
	bottom margin: 0
		range: (0, 100)
	top margin: 0
		range: (0, 100)
	right margin: 0
		range: (0, 100)
	left margin: 0
		range: (0, 100)
	Colorspace: Default
	link-status: Good
	CONNECTOR_ID: 32
		supported: 32
	non-desktop: 0
		range: (0, 1)
	Identifier: 0x46
	Timestamp:  18722
	Subpixel:   unknown
	Clones:
	CRTCs:      4
	           filter:
	max bpc: 8
		range: (8, 12)
	bottom margin: 0
		range: (0, 100)
	top margin: 0
		range: (0, 100)
	right margin: 0
		range: (0, 100)
	left margin: 0
		range: (0, 100)
	Colorspace: Default
	link-status: Good
	CONNECTOR_ID: 41
		supported: 41
	non-desktop: 0
		range: (0, 1)
After adjustment
	Identifier: 0x45
	Timestamp:  290008
	Subpixel:   unknown
	Gamma:      1.0:1.0:1.0
	Brightness: 1.0
	Clones:
	CRTC:       0
	CRTCs:      0
	           filter:
	EDID:
	max bpc: 8
		range: (8, 12)
	bottom margin: 0
		range: (0, 100)
	top margin: 0
		range: (0, 100)
	right margin: 0
		range: (0, 100)
	left margin: 0
		range: (0, 100)
	Colorspace: Default
	link-status: Good
	CONNECTOR_ID: 32
		supported: 32
	non-desktop: 0
		range: (0, 1)
	Identifier: 0x46
	Timestamp:  290008
	Subpixel:   unknown
	Clones:
	CRTCs:      4
	           filter:
	max bpc: 8
		range: (8, 12)
	bottom margin: 0
		range: (0, 100)
	top margin: 0
		range: (0, 100)
	right margin: 0
		range: (0, 100)
	left margin: 0
		range: (0, 100)
	Colorspace: Default
	link-status: Good
	CONNECTOR_ID: 41
		supported: 41
	non-desktop: 0
		range: (0, 1)
So your screen says it supports 1080p, but then doesn't work. Either the EDID is wrong, or possibly your cable is of dubious quality and can't reliably carry 1080p.
Did it really work at 1080p with Buster, or just at a lower resolution?
A similar part number of E165W-1600HC lists it as only being a 1366x768 display.
That actually follows from your EDID - the detailed timing descriptors list 1366x768 (not supported on a Pi4), but the CTA-861 extension block then says that 1920x1080@60Hz is the native mode.
If you use the Screen Configuration application to set the mode, then it should save a file (/usr/share/dispsetup.sh IIRC) which will restore that mode on reboot. Manually using xrandr is not persistent (as you've found out).
hitsware
Sat Aug 06, 2022 2:45 pm
ONE MORE TIME ..
New Buster SD :
...Boots into too small screen
...I go to screen configurator
...Choose 1280 / 720
...Screen changes size and asks if I want to save ?
---I say yes and it saves
New Bullseye SD :
...I go to configuratror
...SCREEN DOES NOT CHANGE SIZE
...I get message " resolution has been changed , reboot to take effect "
...Reboot and still same small screen ..
Sat Aug 06, 2022 3:41 pm
ONE MORE TIME ..
Oh, so not
Implying that it doesn't produce any output on the monitors.
One more time ... the Screen Configuration app should save the screen mode in /usr/share/dispsetup.sh. Did it update?
hitsware
Sat Aug 06, 2022 6:00 pm
hitsware@raspberrypi:~ $  /usr/share/dispsetup.sh
crtc 0: disable
screen 0: 1280x720 338x190 mm  95.92dpi
crtc 0:     1280x720  60.00 +0+0 "HDMI-1"
When I clicked to view the file ,
the screen adjusted .....
hitsware
Sat Aug 06, 2022 6:15 pm
and change it to
# Enable DRM VC4 V3D driver
max_framebuffers=2
Still doesn ' t work ....
scruss
Sat Aug 06, 2022 7:13 pm
I have what I suspect is a very similar 1366x768 display (GeChic ON-Lap 2501 15.6"), and after much poking about, got it running as 1360x768 at 59.79Hz. It would only run from a Raspberry Pi 4's HDMI-1 output (it wasn't seen at all on the second), but the screen configurator wrote a working dispsetup.sh which is automatically picked up on boot.
So a question might now be: why isn't hitsware's dispsetup.sh being included in the startup automatically?
Pronouns: he/him
hitsware
Sat Aug 06, 2022 8:52 pm
With Bulls Eye ..... Buster works .
FWIW :
When the Pi 4 first came out ,
these monitors would not work
at all . ( I thought ( @ first ) that
the Pi ' s were not booting .
After ~ 1 year , I tried again and
they worked . Someone once
mentioned ' missing serial numbers '
aBUGSworstnightmare
Sat Aug 06, 2022 9:18 pm
Missing serial numbers was a mutter software issue which was addressed/solverd.
1366x768 is a Hardware issue on the Pi4 which will remain on that SOC.
Return to “Beginners”
