schoolpost
Libcamera adjusting camera parameters live
Sun Sep 18, 2022 10:06 pm
I'd like to be able to adjust camera parameters while the camera is running. I do not want to close the camera instance and reopen just to change the shutter speed for example. This is for a video application, so it would be quite annoying to the end user as they were adjusting the parameters to have the camera, start and stop constantly.
In libcamera-apps I've noted this method which passes camera parameters before starting the camera, but no subsequent method to do this after the camera is started and running:
https://github.com/raspberrypi/libcamer ... p.cpp#L445
if (camera_->start(&controls_))
		throw std::runtime_error("failed to start camera");
such a method like this would be ideal for my application:
camera_->update(&controls_)
where I could pass a ControlList to the camera.
In the previous version of my application/project the unicam driver exposed v4l2 controls, so it could be controlled outside the application context for example. Is this still possible?
-Csaba Nagy
therealdavidp
Re: Libcamera adjusting camera parameters live
Mon Sep 19, 2022 8:22 am
In libcamera you pass control values like this by putting them into a request object before submitting it (see here, for example).
In libcamera-apps, however, we mostly hide the re-submitting of requests so instead we provide a SetControls method (here) which you can call at any time and it will schedule the controls to be sent as soon as possible.
schoolpost
Mon Sep 19, 2022 8:45 am
Exactly what I was looking for, totally missed that! :?
-Csaba Nagy
schoolpost
Mon Sep 19, 2022 9:18 am
Hypothetically speaking, is there an alternate option for control? I'm guessing v4l2-ctl is out of the question as it probably locks access to the camera as it is being used in the libcamera-app?
I just tested the SetControls() method, which does exactly what it I want, although I do experience a decent amount of delay ( 1s ) between the controllist being summitted to the actual camera parameter changing.
Is there a way to speed up the request queue? is it slow because it is shared with requests for sensor frames?
Not an absolute dealbreaker, but I do know it was near instantaneous when I would control through my old unicam based app with v4l2-ctl
-Csaba Nagy
aBUGSworstnightmare
Mon Sep 19, 2022 9:57 am
You're judging the time from the preview or how do you 'see' the 1s (or so) delay?
schoolpost
Mon Sep 19, 2022 10:05 am
Correct, the preview.
-Csaba Nagy
naushir
Mon Sep 19, 2022 12:08 pm
There will be an inherent delay because of the number of requests already in-flight within the libcamera framework. Since the request with the control is put into the back of the queue, it will be actioned after a number of frames. There may also be additional delays of 1-3 frames if you are setting exposure time or analogue gain on the sensor, as they cannot be set instantaneously.
To "fix" this, you could possibly use a smaller number of requests, so the internal request queue is small. There is active discussions going on with the libcamera folks to somehow reduce this delay - possibly by having controls jump the request queue, but nothing has been concluded yet.
cpixip
Thu Sep 22, 2022 3:09 pm
- you might be interested in this discussion (https://github.com/raspberrypi/picamera ... ssions/152) where a similar issue was discussed in the context of the alpha-release of picamera2.
Short summary: one seems to be able to get fast switches of exposure time with some tricks, but it usually takes about 11-12 frames until a specific exposure setting is "propagated" through the full pipeline. When working with 24fps, that is nearly half a second.
Also, libcamera seems to do some tricks with the digital gain in order to get a faster approach towards a requested exposure value. Basically, as setting the actual requested exposure time seems to need some time, occationally libcamera simulates for example an exposure time of 18928 as
18928 = (DigitalGain = 2,0) * (ExposureTime =  9464)
for one or two frames. That is: the digital gain is used to compensate/adjust the requested exposure time. That is probably the reason why one can no longer set the digital gain in libcamera.
Return to “Camera board”
