rin67630
BULLSEYE regression: settings for small screens
Wed Nov 30, 2022 5:27 pm
since Bullseye the appearance settings for small screens are lost after a reboot.
It worked better in Buster.
And the appearance settings Menu bar continue to jeopardize the panel settings when "left" ist chosen.
The "menu bar" settings should be removed from appearance, it conflicts with the "panel settings".
Please forward to respective maintainers.
klricks
Re: BULLSEYE regression: settings for small screens
Wed Nov 30, 2022 6:55 pm
Are you using the correct app from [Menu] --> [Preferences]?
pipanel
It works correctly for me and there is not a choice selection for Left or Right,....... Top or Bottom only.
rin67630
Wed Nov 30, 2022 8:49 pm
What means "correct" app?
You have unfortunately two concurring ways to configure the panel
a) from Preferences --> Apparence Settings --> Menu bar (imo is the wrong way and should be removed)
b) from a right click on the panel --> panel settings (this is the right way, which includes the left placement option and a lot of better features)
This is a screen from the orginal LXPanel and the very place to enter settings.
Having two different programs doing (almost) the same things is imho a mess and a waste of resources.
Regards.
aBUGSworstnightmare
Thu Dec 01, 2022 5:41 am
What if there are multiple ways for getting the same result (so no right or wrong one)?
What is your 'small screen' definition? Might be different for others ...
kerry_s
Thu Dec 01, 2022 8:13 am
raspberry is a fork of lxde, there settings are done a bit different in some cases.
you can expect the panel to work with the setting of top or bottom, but left and right are not tested, same go's for the applets, not all will work as the raspberry team have also done some work on lxpanel.
you have to think of it as raspberry os desktop, not lxde desktop, the settings they know to work are presented to you in the menu, while other settings are just hanging around because there just part of the code, to much trouble to remove/rewrite.
it's not a regression or broken, it's how they wish it to be used, it's there vision of how they want it.
your free to change it to your needs, you just need to understand, it's a fork, they have modified it from the original lxde desktop.
Thu Dec 01, 2022 9:43 am
Any more detail on this? What is a small screen? Procedure to replicate?
rin67630
Sat Dec 03, 2022 8:21 pm
Small screen is one of the three settings on Preferences --> Apparence Settings (last tab).
That sets the icons and the fonts to small.
After a reboot these settings are gone, that was not the case with buster.
rin67630
Sat Dec 03, 2022 8:37 pm
There is no reason to duplicate the settings and make the job twice, confusing people with different wordings, conflicting and finally providing a less capable solution.
I would strongly recommend to take completely out the confusing "menu bar" stuff from the appearance settings and use a menu entry "panel settings" that just leads to the LXDE dialog.
aBUGSworstnightmare
Sun Dec 04, 2022 6:21 am
need to check that on a freshly installed OS. If they were 'gone' then it's after an update, and not a simple reboot.
Checked it on a DUT which runs a 64-bit OS
pi@CM4WaveC:~ $ uname -a
Linux CM4WaveC 5.15.76-v8+ #1597 SMP PREEMPT Fri Nov 4 12:16:41 GMT 2022 aarch64 GNU/Linux
Right Click on Desktop -> DESKTOP PREFERENCES -> DEFAULTS
Everything is there; settings can be changed and are persistent after reboot.
So what is your complaint? DUT is a 2GB Pi with a VGA display connected to DPI interface.
Unchanged settings
Changed the defaults to SMALL SCREEN. Compare to the image with unchanged settings shown above.
aBUGSworstnightmare
Sun Dec 04, 2022 7:04 am
Tested with a fresh 32-bit installation, set the defaults to small.
fresh 32-bit Bullseye installation, defaults set to small
Installed all updates and rebooted -> panel got reset to initial (medium) settings.
installed all updates. After the reboot the panel size got reverted.
Set appearance to small screen defaults again -> done!
Setting defaults to small screen again -> done
Not a real issue, only a 'lil inconvenient for some of us... If you want to avoid that second selection simply make the change after the update/upgrade.
Edit: If I want to change the appearance I'm doing this via xrandr
xrandr --output HDMI-1 --primary --scale 1.5x1.5
rin67630
Tue Dec 06, 2022 9:47 pm
Objection !
It is a regression.
It worked without the flaw in Buster.
Can it possibly be caused by a more extensive use of the overlay file system now?
And -please- think about users of the Adafruit 320*240 pixels LCD HAT, do not assume HDMI and external monitors.
aBUGSworstnightmare
Wed Dec 07, 2022 6:32 am
Objection !
It is a regression.
sorry, don't get your point! I' ve posted the outcome of my testing - made with a 640x480pixels 5.6in screen connected to DPI interface, running KMS graphics driver - and demonstrated it is working as expected.
So what's the problem still? Will work for smaller screens as well. Sorry, can't show that as the VGA is the smallest one I have on hands atm, but know it's working as I've used it with 3.5in QVGA screens already
rin67630
Wed Dec 07, 2022 8:22 am
You have seen yourself that the small screen setting does not survive a boot cycle after power down.
That is imho not acceptable. Preferences MUST be remanant. They were with buster, they do not any more with Bullseye.
When you have a 320*240 LCD HAT, you get a complete mess and can't get out without external help.
I had a real hard time a couple of years ago trying to convince the Raspberry team to take attention to the users of these HATs:
-Adafruit: https://learn.adafruit.com/adafruit-pit ... i/overview
-Seed: https://www.seeedstudio.com/3-5-Inch-TF ... -2248.html
-Waveshare: https://www.waveshare.com/4inch-hdmi-lcd-h.htm
Finally Buster came out with the brilliant idea of the "small screens" defaults. What a relief !
And now Bulleyes jeopardizes it again just because it forgets the preferences?
aBUGSworstnightmare
Wed Dec 07, 2022 9:40 am
wrong!
It does not survive after a kernel update. That's what I've noted.once changed after the initial update the settings will survive reboots.
Feel free to raise an issue on https://github.com/raspberrypi/linux
rin67630
Wed Dec 07, 2022 8:08 pm
It does not survive a power cycle neither.
aBUGSworstnightmare
Wed Dec 07, 2022 9:07 pm
Will test once again on a fresh Bullseye.
Be prepared to get blamed in case it's working as expected.
will do this test on DSI/DPI and HDMI...
aBUGSworstnightmare
Thu Dec 08, 2022 7:37 am
all done on an RPi4 1GB, HW rev 1.5
Started testing on 32-bit OS
pi@32-test:~ $ uname -a
Linux 32-test 5.15.61-v7l+ #1579 SMP Fri Aug 26 11:13:03 BST 2022 armv7l GNU/Linux
1. Ran update and upgrade via SSH
sudo apt-get update
sudo apt-get full-upgrade
2. reboot
3. check kernel version again
Linux 32-test 5.15.76-v7l+ #1597 SMP Fri Nov 4 12:14:58 GMT 2022 armv7l GNU/Linux
4. start raspi-config and enable VNC
5. connect to the DUT via VNC
6. right click on desktop -> DESKTOP preferences-> select small
7. reboot the system
-> settings have survived the reboot
1 (aBUGSworstnightmare) : 0 (rin67630)
8. shutdown the system and re-power if after some seconds
-> settings have survived re-power
2 (aBUGSworstnightmare) : 0 (rin67630)
testing on 64-bit OS
pi@64-test:~ $ uname -a
Linux 64-test 5.15.61-v8+ #1579 SMP PREEMPT Fri Aug 26 11:16:44 BST 2022 aarch64 GNU/Linux
9. ran update and upgrade via SSH
10. reboot
11. check kernel again
Linux 64-test 5.15.76-v8+ #1597 SMP PREEMPT Fri Nov 4 12:16:41 GMT 2022 aarch64 GNU/Linux
12. start raspi-config and enable VNC
13. connect to the DUT via VNC
14. right click on desktop -> DESKTOP preferences-> select small
15. reboot the system
3 (aBUGSworstnightmare) : 0 (rin67630)
16. shutdown the system and re-power it after some seconds
4 (aBUGSworstnightmare) : 0 (rin67630)
rin67630 wrote:It does not survive a power cycle neither.
@rin67360 .. what's your next incorrect claim/statement?
Will test HDMI later when I have my 5.9in FHD screen connected. Intend to do it the other way around and select defaults for large screens there as FHD on 5.9in is quite small.
But .. pretty sure this will lead to 6 (aBUGSworstnightmare) : 0 (rin67630)
Btw, here is the config.txt I've tested with (that's the one from 64-bit as example; just added the overlay for th 5.6in DPI display, rest all stock). I've enabled a DPI display, One is able to test all the above even without having the physical display connected as VNC will happily show you the results!
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# Automatically load overlays for detected cameras
camera_auto_detect=1
# Automatically load overlays for detected DSI displays
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Run in 64-bit mode
arm_64bit=1
# Disable compensation for displays with overscan
disable_overscan=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[all]
[pi4]
# Run as fast as firmware / board allows
arm_boost=1
[all]
dtoverlay=vc4-kms-dpi-panel,at056tn53v1
dtparam=backlight-pwm=1,backlight-pwm-chan=1,backlight-pwm-gpio=19
#dtparam=rotate=180
Thu Dec 08, 2022 10:06 am
sudo apt-get update
2. reboot
10. reboot
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
max_framebuffers=2
arm_64bit=1
disable_overscan=1
[cm4]
otg_mode=1
[all]
[pi4]
arm_boost=1
[all]
#dtparam=rotate=180
Your attitude in some recent posts is not what I would like to see. Please keep this aggressive tone off the forums. Nothing wrong with the content, just the presentation.
aBUGSworstnightmare
Thu Dec 08, 2022 10:11 am
Wow .. With FIFA world championship ongoing we're not allowed to make references...?
I'm taking my time to show things are working whereas other users make incorrect statements without providing even simplest evidence.
Will leave such posts to other audiences feedback next time (and save that 30min of time it took me to prepare this post above from scratch).
Return to “Raspberry Pi OS”
