donatom
Fedora37.aarch64 and Jellyfin
Sat Nov 26, 2022 1:17 am
i just installed Fedora-xfce.aarch64 onto my RPi 4b which I did by using dd to copy the OS directly onto a SSD. It runs smoothly and doesn't take forever to boot up (with fedoraARM 36 booting took over 3 minutes).
The other day I installed Jellyfin (a media server like Plex - but it is 100% open-source). The best and easiest way is to follow the Jellyfin wiki https://jellyfin.org/docs/general/admin ... nstalling/ (scroll down to Podman - which is container software like Docker but open-source). Follow the Podman explanation to the end of the section.
It took only a few minutes (maybe 20) to install both Podman and Jellyfin. Everything worked well except that I could not get Jellyfin to access my video files which I have on a separate USB drive. I spent more than an hour changing permissions, etc on the directories and files - to no avail.
I even followed my own wiki about Jellyfin permissions which I placed on this forum last year without success.
I finally tried disabling selinux (sudo setenforce 0) which in fact did work. The obvious problem with this is that this makes your fedora system less secure. In any case I am writing in this forum to help others who are trying to run jellyfin on RPi with Fedora-aarch64 (by the way, using Podman is the only way to install Jellyfin on RPi with Fedora.
Hopefully Jellyfin/Podman fix this bug soon.
trejan
Re: Fedora37.aarch64 and Jellyfin
Sat Nov 26, 2022 2:43 am
You need to read the SELinux audit log to see what is denying access then make a new policy module to allow Jellyfin. I don't have a Fedora system so can't check but there may be a SELinux boolean as well.
donatom
Tue Nov 29, 2022 4:57 pm
Thanks, Trajan. I will look into that as soon as I can.
donatom
Wed Nov 30, 2022 4:28 am
To solve the SELinux denial I ran grep "SELinux is preventing" /var/log/messages and saw that the denial was caused by badly labeled files in my media directory (/media/movies).
Following a suggestion from this site https://github.com/hardenedlinux/harbia ... denied.mkd I ran the following command in terminal: "sudo /sbin/restorecon -R -v /media/movies"
I believe that this has corrected the SELinux denial problem (I'm not exactly sure what is meant by "label" but I guess it indicates that SELinux can allow the use of the files in a directory).
donatom
Wed Nov 30, 2022 11:31 pm
This unfortunately did not solve the problem so I must continue searching for a solution (besides disabling SELinux).
According to the fedora wiki (https://www.redhat.com/sysadmin/selinux-denial2), you should run the following command to figure out why selinux is not allowing something: # grep "SELinux is preventing" /var/log/messages
The read read out will tell you the problem and will also give you suggestions to remedy the situation.
Now I am going to delete my jellyfin container and recreate it using a slightly different command (I will add --priveleged to the podman command, which -- according to https://github.com/jellyfin/jellyfin-docs/issues/317 should give jellyfin access to my media files.
donatom
Sat Dec 03, 2022 1:14 am
I spent hours trying to figure out how to fix selinux. However, it turned out to be the browser - I switched to chromium and now jellyfin can access media files - with selinux enabled.
It seems like firefox has a bug or two.
donatom
Wed Dec 07, 2022 9:19 pm
Well, using Chromium seemed to work - I could at least scan the media files, but when I tried to play files on my phone or television, jellyfin said that it was not able to play the movies.
Then I came across another RedHat selinux trouble-shooting wiki (https://access.redhat.com/documentation ... ng-selinux). I used "sealert -l "*"" as regular user. I saw that ffmpeg and ffprobe were being denied access to my movie files (/media/movies). i understand that jellyfin uses ffmpeg to play the files. I am not sure what ffprobe does, but I enabled access for it to be on the safe side.
Following the instructions from sealert -l "*" command I used the following commands, this time as root:
ausearch -c 'ffmpeg' --raw | audit2allow -M my-ffmpeg
semodule -i my-ffmpeg.pp
ausearch -c 'ffprobe' --raw | audit2allow -M my-ffprobe
semodule -i my-ffprobe.pp
I am now able to view my movie files through jellyfin. FINALLY!
Return to “Pidora / Fedora”
