okay so i reflashed again this morning with Raspbian 32 bit Bullseye which is the default recommended OS by the imager.
I don't think there's a difference between the two Pis since both are 8gb Pi 4s and I've used the same cable and monitor for both.
Also I'm not sure by what you mean to make sure KMS is enabled. I've said that both dtoverlay=vc4-kms-v3d and dtoverlay=vc4-fkms-v3d don't work for me in config.txt; if i leave the line regarding dtoverlay commented, i get a working display that's a little slow due to no gl i think but i don't think that's optimal.
fyi, im trying to use just a hp 1920x1080p monitor, i tried another monitor and it was also black screen.
doesn't do anything for me.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.15.61-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1579 SMP Fri Aug 26 11:13:03 BST 2022
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[ 0.000000] random: crng init done
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x00000000fbffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] percpu: Embedded 16 pages/cpu s35788 r8192 d21556 u65536
[ 0.000000] pcpu-alloc: s35788 r8192 d21556 u65536 alloc=16*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011008
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:50:D5:C6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=cce375cd-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
[ 0.000000] Memory: 3601324K/4050944K available (10240K kernel code, 1385K rwdata, 3304K rodata, 2048K init, 592K bss, 121940K reserved, 327680K cma-reserved, 3264512K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 35501 entries in 105 pages
[ 0.000000] ftrace: allocated 105 pages with 4 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 25)
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000020] Switching to timer-based delay loop, resolution 18ns
[ 0.000370] Console: colour dummy device 80x30
[ 0.000436] printk: console [tty1] enabled
[ 0.000500] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.000530] pid_max: default: 32768 minimum: 301
[ 0.000673] LSM: Security Framework initializing
[ 0.000884] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000914] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002500] cgroup: Disabling memory control group subsystem
[ 0.002735] CPU: Testing write buffer coherency: ok
[ 0.002789] CPU0: Spectre BHB: enabling loop workaround for all CPUs
[ 0.003232] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004600] Setting up static identity map for 0x200000 - 0x20003c
[ 0.004806] rcu: Hierarchical SRCU implementation.
[ 0.005833] smp: Bringing up secondary CPUs ...
[ 0.007050] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008402] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.009697] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009920] smp: Brought up 1 node, 4 CPUs
[ 0.009941] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.009961] CPU: All CPU(s) started in HYP mode.
[ 0.009974] CPU: Virtualization extensions available.
[ 0.010769] devtmpfs: initialized
[ 0.026279] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.026504] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.026536] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.036972] pinctrl core: initialized pinctrl subsystem
[ 0.038275] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.042930] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.043735] audit: initializing netlink subsys (disabled)
[ 0.044006] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.044655] thermal_sys: Registered thermal governor 'step_wise'
[ 0.045465] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.045487] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.045917] Serial: AMBA PL011 UART driver
[ 0.060950] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.100080] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-08-26T14:03:16, variant start
[ 0.110096] raspberrypi-firmware soc:firmware: Firmware hash is 102f1e848393c2112206fadffaaf86db04e98326
[ 0.170457] Kprobes globally optimized
[ 0.176540] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.181751] vgaarb: loaded
[ 0.182234] SCSI subsystem initialized
[ 0.182498] usbcore: registered new interface driver usbfs
[ 0.182560] usbcore: registered new interface driver hub
[ 0.182634] usbcore: registered new device driver usb
[ 0.183053] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.183248] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.183562] pps_core: LinuxPPS API ver. 1 registered
[ 0.183577] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.183605] PTP clock support registered
[ 0.185369] clocksource: Switched to clocksource arch_sys_counter
[ 0.266157] VFS: Disk quotas dquot_6.6.0
[ 0.266267] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.266457] FS-Cache: Loaded
[ 0.266676] CacheFiles: Loaded
[ 0.267847] simple-framebuffer 3e3cf000.framebuffer: framebuffer at 0x3e3cf000, 0x7f8000 bytes
[ 0.267870] simple-framebuffer 3e3cf000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 0.268413] Console: switching to colour frame buffer device 240x67
[ 0.278998] simple-framebuffer 3e3cf000.framebuffer: fb0: simplefb registered!
[ 0.289520] NET: Registered PF_INET protocol family
[ 0.289776] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.291407] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.291441] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.291467] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.291534] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.291607] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.291769] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.291807] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.292072] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.296349] RPC: Registered named UNIX socket transport module.
[ 0.296366] RPC: Registered udp transport module.
[ 0.296380] RPC: Registered tcp transport module.
[ 0.296394] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.296415] PCI: CLS 0 bytes, default 64
[ 1.334643] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.337333] Initialise system trusted keyrings
[ 1.337662] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 1.346712] zbud: loaded
[ 1.348694] FS-Cache: Netfs 'nfs' registered for caching
[ 1.349588] NFS: Registering the id_resolver key type
[ 1.349632] Key type id_resolver registered
[ 1.349647] Key type id_legacy registered
[ 1.349775] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.349791] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.350901] Key type asymmetric registered
[ 1.350918] Asymmetric key parser 'x509' registered
[ 1.351148] bounce: pool size: 64 pages
[ 1.351224] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.351459] io scheduler mq-deadline registered
[ 1.351475] io scheduler kyber registered
[ 1.361094] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.361137] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.361230] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.361323] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
[ 1.417475] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.417881] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.417901] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.417923] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.418017] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.418264] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.422046] PCI: bus0: Fast back to back transfers disabled
[ 1.422386] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.422516] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.422946] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.426719] PCI: bus1: Fast back to back transfers disabled
[ 1.426780] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.426808] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.426895] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.426921] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.427341] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 1.427578] pcieport 0000:00:00.0: PME: Signaling with IRQ 79
[ 1.441793] iproc-rng200 fe104000.rng: hwrng registered
[ 1.442193] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.443836] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.456926] brd: module loaded
[ 1.467459] loop: module loaded
[ 1.468322] Loading iSCSI transport class v2.0-870.
[ 1.473704] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.565537] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.566818] usbcore: registered new interface driver r8152
[ 1.566891] usbcore: registered new interface driver lan78xx
[ 1.566954] usbcore: registered new interface driver smsc95xx
[ 1.568574] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
[ 1.568743] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.568781] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.574493] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00003c0000000890
[ 1.575596] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.575624] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.575650] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.576043] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.576066] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.576085] usb usb1: Product: xHCI Host Controller
[ 1.576101] usb usb1: Manufacturer: Linux 5.15.61-v7l+ xhci-hcd
[ 1.576117] usb usb1: SerialNumber: 0000:01:00.0
[ 1.576902] hub 1-0:1.0: USB hub found
[ 1.576985] hub 1-0:1.0: 1 port detected
[ 1.578011] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.578034] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.578052] usb usb2: Product: xHCI Host Controller
[ 1.578068] usb usb2: Manufacturer: Linux 5.15.61-v7l+ xhci-hcd
[ 1.578084] usb usb2: SerialNumber: 0000:01:00.0
[ 1.578787] hub 2-0:1.0: USB hub found
[ 1.578875] hub 2-0:1.0: 4 ports detected
[ 1.580795] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.581170] dwc_otg: FIQ enabled
[ 1.581184] dwc_otg: NAK holdoff enabled
[ 1.581197] dwc_otg: FIQ split-transaction FSM enabled
[ 1.581215] Module dwc_common_port init
[ 1.581680] usbcore: registered new interface driver uas
[ 1.581789] usbcore: registered new interface driver usb-storage
[ 1.582010] mousedev: PS/2 mouse device common for all mice
[ 1.587415] sdhci: Secure Digital Host Controller Interface driver
[ 1.587434] sdhci: Copyright(c) Pierre Ossman
[ 1.588209] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.593274] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.593628] hid: raw HID events driver (C) Jiri Kosina
[ 1.593819] usbcore: registered new interface driver usbhid
[ 1.593835] usbhid: USB HID core driver
[ 1.600516] Initializing XFRM netlink socket
[ 1.600563] NET: Registered PF_PACKET protocol family
[ 1.600682] Key type dns_resolver registered
[ 1.601177] Registering SWP/SWPB emulation handler
[ 1.601982] registered taskstats version 1
[ 1.602013] Loading compiled-in X.509 certificates
[ 1.602827] Key type ._fscrypt registered
[ 1.602843] Key type .fscrypt registered
[ 1.602858] Key type fscrypt-provisioning registered
[ 1.615599] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.615938] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.616092] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 1.625573] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.626064] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.627374] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.627395] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.657750] of_cfs_init
[ 1.658017] of_cfs_init: OK
[ 1.692816] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.693148] Waiting for root device PARTUUID=cce375cd-02...
[ 1.792106] mmc0: new ultra high speed DDR50 SDHC card at address 5048
[ 1.794268] mmcblk0: mmc0:5048 SD32G 28.9 GiB
[ 1.799913] mmcblk0: p1 p2
[ 1.800210] mmc1: new high speed SDIO card at address 0001
[ 1.801244] mmcblk0: mmc0:5048 SD32G 28.9 GiB
[ 1.812860] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 1.812886] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.865443] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.935712] EXT4-fs (mmcblk0p2): recovery complete
[ 1.937109] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 1.937200] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.938132] devtmpfs: mounted
[ 1.949326] Freeing unused kernel image (initmem) memory: 2048K
[ 1.949657] Run /sbin/init as init process
[ 1.949671] with arguments:
[ 1.949684] /sbin/init
[ 1.949698] splash
[ 1.949711] with environment:
[ 1.949723] HOME=/
[ 1.949736] TERM=linux
[ 2.048128] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 2.048162] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.048182] usb 1-1: Product: USB2.0 Hub
[ 2.050533] hub 1-1:1.0: USB hub found
[ 2.050868] hub 1-1:1.0: 4 ports detected
[ 2.290315] systemd[1]: System time before build time, advancing clock.
[ 2.385423] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[ 2.501223] NET: Registered PF_INET6 protocol family
[ 2.502973] Segment Routing with IPv6
[ 2.503017] In-situ OAM (IOAM) with IPv6
[ 2.524145] usb 1-1.3: New USB device found, idVendor=258a, idProduct=0036, bcdDevice= 1.00
[ 2.524177] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.524197] usb 1-1.3: Product: Wired Gaming Mouse
[ 2.524213] usb 1-1.3: Manufacturer: SINOWEALTH
[ 2.542496] input: SINOWEALTH Wired Gaming Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:258A:0036.0001/input/input0
[ 2.542980] hid-generic 0003:258A:0036.0001: input,hidraw0: USB HID v1.11 Mouse [SINOWEALTH Wired Gaming Mouse] on usb-0000:01:00.0-1.3/input0
[ 2.556075] input: SINOWEALTH Wired Gaming Mouse Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:258A:0036.0002/input/input1
[ 2.582277] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.583196] systemd[1]: Detected architecture arm.
[ 2.585459] systemd[1]: Set hostname to <raspberrypi>.
[ 2.626025] hid-generic 0003:258A:0036.0002: input,hiddev96,hidraw1: USB HID v1.11 Keyboard [SINOWEALTH Wired Gaming Mouse] on usb-0000:01:00.0-1.3/input1
[ 2.725490] usb 1-1.4: new low-speed USB device number 4 using xhci_hcd
[ 2.865568] usb 1-1.4: New USB device found, idVendor=413c, idProduct=2113, bcdDevice= 1.10
[ 2.865604] usb 1-1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.865625] usb 1-1.4: Product: Dell KB216 Wired Keyboard
[ 2.879013] input: Dell KB216 Wired Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:413C:2113.0003/input/input3
[ 2.946396] hid-generic 0003:413C:2113.0003: input,hidraw2: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-0000:01:00.0-1.4/input0
[ 2.954263] input: Dell KB216 Wired Keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:413C:2113.0004/input/input4
[ 3.015809] input: Dell KB216 Wired Keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:413C:2113.0004/input/input5
[ 3.016098] hid-generic 0003:413C:2113.0004: input,hidraw3: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-0000:01:00.0-1.4/input1
[ 3.303942] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[ 3.486748] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.493109] systemd[1]: Created slice system-getty.slice.
[ 3.494556] systemd[1]: Created slice system-modprobe.slice.
[ 3.495656] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.496567] systemd[1]: Created slice User and Session Slice.
[ 3.497121] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.498343] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.499070] systemd[1]: Reached target Slices.
[ 3.499234] systemd[1]: Reached target Swap.
[ 3.500288] systemd[1]: Listening on Syslog Socket.
[ 3.501047] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.501458] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.502569] systemd[1]: Listening on Journal Audit Socket.
[ 3.503305] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.504266] systemd[1]: Listening on Journal Socket.
[ 3.509469] systemd[1]: Listening on udev Control Socket.
[ 3.510354] systemd[1]: Listening on udev Kernel Socket.
[ 3.511384] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.516955] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.523292] systemd[1]: Mounting RPC Pipe File System...
[ 3.530594] systemd[1]: Mounting Kernel Debug File System...
[ 3.538288] systemd[1]: Mounting Kernel Trace File System...
[ 3.538958] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 3.552203] systemd[1]: Starting Restore / save the current clock...
[ 3.560026] systemd[1]: Starting Set the console keyboard layout...
[ 3.567948] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 3.576586] systemd[1]: Starting Load Kernel Module configfs...
[ 3.584303] systemd[1]: Starting Load Kernel Module drm...
[ 3.592471] systemd[1]: Starting Load Kernel Module fuse...
[ 3.596422] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 3.608608] systemd[1]: Starting File System Check on Root Device...
[ 3.622089] systemd[1]: Starting Journal Service...
[ 3.638625] systemd[1]: Starting Load Kernel Modules...
[ 3.659935] systemd[1]: Starting Coldplug All udev Devices...
[ 3.684284] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.685216] systemd[1]: Mounted RPC Pipe File System.
[ 3.696425] systemd[1]: Mounted Kernel Debug File System.
[ 3.697377] systemd[1]: Mounted Kernel Trace File System.
[ 3.699680] systemd[1]: Finished Restore / save the current clock.
[ 3.702577] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 3.704815] systemd[1]: modprobe@configfs.service: Succeeded.
[ 3.716984] systemd[1]: Finished Load Kernel Module configfs.
[ 3.726045] systemd[1]: Mounting Kernel Configuration File System...
[ 3.736490] fuse: init (API version 7.34)
[ 3.756158] i2c_dev: i2c /dev entries driver
[ 3.776022] systemd[1]: Started File System Check Daemon to report status.
[ 3.783203] systemd[1]: modprobe@fuse.service: Succeeded.
[ 3.796311] systemd[1]: Finished Load Kernel Module fuse.
[ 3.798735] systemd[1]: Finished Load Kernel Modules.
[ 3.799926] systemd[1]: Mounted Kernel Configuration File System.
[ 3.814356] systemd[1]: Mounting FUSE Control File System...
[ 3.836242] systemd[1]: Starting Apply Kernel Variables...
[ 3.847654] systemd[1]: Mounted FUSE Control File System.
[ 3.904341] systemd[1]: modprobe@drm.service: Succeeded.
[ 3.906014] systemd[1]: Finished Load Kernel Module drm.
[ 3.908847] systemd[1]: Finished File System Check on Root Device.
[ 3.926682] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.932402] systemd[1]: Finished Apply Kernel Variables.
[ 4.068594] systemd[1]: Started Journal Service.
[ 4.110011] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[ 4.191305] systemd-journald[139]: Received client request to flush runtime journal.
[ 4.193824] systemd-journald[139]: File /var/log/journal/31ad2d6302544152a5801a7e5d386db4/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 5.409158] mc: Linux media interface: v0.10
[ 5.644307] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.668109] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.698214] videodev: Linux video capture interface: v2.00
[ 5.768458] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.768494] [vc_sm_connected_init]: start
[ 5.772232] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 5.773596] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 5.786054] [vc_sm_connected_init]: installed successfully
[ 5.833095] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 5.891966] i2c i2c-22: Added multiplexed i2c bus 0
[ 5.904527] i2c 10-0010: Fixing up cyclic dependency with fe801000.csi
[ 5.904942] i2c i2c-22: Added multiplexed i2c bus 10
[ 6.055754] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.089728] rpivid feb10000.codec: Device registered as /dev/video19
[ 6.121580] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.128998] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.168822] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.228633] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.234807] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.248539] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.276114] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 6.278906] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 6.285148] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 6.297703] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 6.297756] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.297785] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.297809] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.297832] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.315873] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 6.315936] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 6.362015] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 6.362072] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 6.374348] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 6.375488] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 6.375568] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 6.376652] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 6.378369] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 6.379261] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 6.379297] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.379820] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 6.379887] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 6.380378] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.380406] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.380429] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.381299] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 6.385483] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 6.385553] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 6.414252] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 6.893655] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.950320] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 6.968897] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 7.198169] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 7.207056] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.208461] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.bin failed with error -2
[ 7.222726] checking generic (3e3cf000 7f8000) vs hw (0 ffffffffffffffff)
[ 7.222755] fb0: switching to vc4 from simple
[ 7.229049] Console: switching to colour dummy device 80x30
[ 7.251563] usbcore: registered new interface driver brcmfmac
[ 7.270342] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 7.285849] Registered IR keymap rc-cec
[ 7.286593] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 7.425700] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input6
[ 7.484036] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.484173] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.490093] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 7.972500] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 7.977235] Registered IR keymap rc-cec
[ 8.002684] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 8.061755] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input7
[ 9.039124] uart-pl011 fe201000.serial: no DMA platform data
[ 9.072990] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 9.076386] Registered IR keymap rc-cec
[ 9.076616] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 9.076946] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input8
[ 9.083583] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 9.103935] Registered IR keymap rc-cec
[ 9.107150] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 9.107808] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input9
[ 9.266694] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 9.267276] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 9.267791] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 9.268201] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 9.268654] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 9.268990] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 9.269409] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 9.390762] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 9.432903] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 9.443073] imx219 10-0010: Consider updating driver imx219 to match on endpoints
[ 9.683708] Console: switching to colour frame buffer device 240x67
[ 9.683771] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 11.582978] 8021q: 802.1Q VLAN Support v1.8
[ 11.738770] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 11.927049] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 11.928663] bcmgenet fd580000.ethernet eth0: Link is Down
[ 15.261076] v3d fec00000.v3d: MMU error from client PTB (1) at 0x0, write violation, pte invalid
[ 16.056251] Bluetooth: Core ver 2.22
[ 16.056315] NET: Registered PF_BLUETOOTH protocol family
[ 16.056323] Bluetooth: HCI device and connection manager initialized
[ 16.056343] Bluetooth: HCI socket layer initialized
[ 16.056352] Bluetooth: L2CAP socket layer initialized
[ 16.056367] Bluetooth: SCO socket layer initialized
[ 16.065116] Bluetooth: HCI UART driver ver 2.3
[ 16.065131] Bluetooth: HCI UART protocol H4 registered
[ 16.065182] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 16.065378] Bluetooth: HCI UART protocol Broadcom registered
[ 16.267935] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.267948] Bluetooth: BNEP filters: protocol multicast
[ 16.267962] Bluetooth: BNEP socket layer initialized
[ 16.282571] NET: Registered PF_ALG protocol family
[ 16.305467] cryptd: max_cpu_qlen set to 1000
[ 18.184066] hdmi-audio-codec hdmi-audio-codec.3.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 18.184098] MAI: soc_pcm_open() failed (-19)
[ 18.184726] hdmi-audio-codec hdmi-audio-codec.3.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 18.184745] MAI: soc_pcm_open() failed (-19)
[ 18.185409] hdmi-audio-codec hdmi-audio-codec.3.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 18.185432] MAI: soc_pcm_open() failed (-19)
[ 18.193370] hdmi-audio-codec hdmi-audio-codec.3.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 18.193397] MAI: soc_pcm_open() failed (-19)
[ 18.193689] hdmi-audio-codec hdmi-audio-codec.3.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 18.193706] MAI: soc_pcm_open() failed (-19)
[ 18.193978] hdmi-audio-codec hdmi-audio-codec.3.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 18.193994] MAI: soc_pcm_open() failed (-19)
[ 18.314757] Bluetooth: RFCOMM TTY layer initialized
[ 18.314807] Bluetooth: RFCOMM socket layer initialized
[ 18.314835] Bluetooth: RFCOMM ver 1.11
[ 22.270800] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 23.761851] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 31.835393] cam-dummy-reg: disabling
