I need a very basic one-channel oscilloscope display using a RPi Zero W. This is for a seismometer "stomp" display for a learning center display.
All it has to do is display the voltage waveform of the seismometer and on a big monitor or TV using HDMI or a HDMI-AV converter (which I have). I don't need any of the usual oscilloscope features such as triggering etc.
Anyone know of off-the-shelf products or schematics for such a thing? And that will run on Raspberry PI 32-bit OS?
Re: RPi Zero W and basic one-channel oscilloscope?
Have you looked at the excellent piscope from joan : https://abyz.me.uk/rpi/pigpio/piscope.html or did you want analogue measurements?
Edit or https://www.raspberrypi.com/news/build ... i-arduino/ but using a pico not an Arduino?
I need analog input only. And I can use the Pico too. I was hoping for just a simple screen with an analog waveform on it.
Thanks.
Thanks.
Ok that last link maybe good (pico not Arduino)
Seismograph aren't fast. What speed you are talking about. IT should be below 1Khz.I need a very basic one-channel oscilloscope display using a RPi Zero W. This is for a seismometer "stomp" display for a learning center display.
something like this in python. use pyplot
You just need an adc converter . An ADS1115 or the ADS1015 from automation hat. works great.
or someting like that.
https://www.earthinversion.com/geophysi ... eismogram/ Do your google search.
Just in case you use an ADS1115 (I'd recommend it), you can find a base library right here:
https://github.com/Clave-EIDEAnalog/EIDEAnalog
which is fully documented here:
https://github.com/Clave-EIDEAnalog/DOCS
