bensimmo
Re: Advent 2022
Sat Dec 03, 2022 11:59 am
Already behind.
Day2
Python (3.10+) because I've not used Match/Case before in Python.
Part2, but just switch the addition for Part1.
import csv
ROCK = 1
PAPER = 2
SCISSOR = 3
WIN = 6
DRAW = 3
LOST = 0
total = 0
with open('input.txt', newline='\n') as f:
    reader = csv.reader(f)
    for row in reader:
        match row:
            case ['A X']:
                total += (SCISSOR + LOST)
            case ['A Y']:
                total += (ROCK + DRAW)
            case ['A Z']:
                total += (PAPER + WIN)
            case ['B X']:
                total += (ROCK + LOST)
            case ['B Y']:
                total += (PAPER + DRAW)
            case ['B Z']:
                total += (SCISSOR + WIN)
            case ['C X']:
                total += (PAPER + LOST)
            case ['C Y']:
                total += (SCISSOR + DRAW)
            case ['C Z']:
                total += (ROCK + WIN)
            case other:
                print("error")
print(f"Score = {total}")
I wonder if everyone's puzzle had the same answer.
I guess not as my day2 are different 12740 & 11980
lurk101
Re: Advent 2022
Sat Dec 03, 2022 2:48 pm
day3 translated for pshell
#pragma uchar
int toprio(char c) { return c > 'Z' ? c - 'a' + 1 : c - 'A' + 27; }
int part1(char* line) {
    char* cp = line;
    while (*cp)
        ++cp;
    int n = cp - line;
    cp = line;
    int i, j, h = n / 2;
    for (i = 0; i < h; ++i)
        for (j = h; j < n; ++j)
            if (line[i] == line[j])
                return toprio(line[i]);
int part2(char* l1, char* l2, char* l3) {
    char count1[53], count2[53], count3[53];
    memset(count1, 0, 53);
    memset(count2, 0, 53);
    memset(count3, 0, 53);
    char* cp = l1;
    while (*cp)
        count1[toprio(*cp++)] = 1;
    cp = l2;
    while (*cp)
        count2[toprio(*cp++)] = 1;
    cp = l3;
    while (*cp)
        count3[toprio(*cp++)] = 1;
    int i;
    for (i = 1; i < 53; ++i)
        if (count1[i] && count2[i] && count3[i])
            return i + 1;
    return 0;
char* txt;
void nextline() {
    while ((*txt != '\n') && *txt)
        ++txt;
    if (*txt == '\n') {
        *txt = 0;
        ++txt;
char *l1, *l2, *l3;
void main() {
    int start = time_us_32(), f = open("day3.txt", O_RDONLY), n = lseek(f, 0, SEEK_END);
    lseek(f, 0, SEEK_SET);
    txt = (char*)malloc(n + 1);
    read(f, txt, n);
    txt[n] = 0;
    int prio = 0, badges = 0;
    while (*txt) {
        l1 = txt;
        nextline();
        l2 = txt;
        nextline();
        l3 = txt;
        nextline();
        prio += part1(l1) + part1(l2) + part1(l3);
        badges += part2(l1, l2, l3);
    printf("--- Day 3: Rucksack Reorganization ---\n"
           "Part 1 - %d\nPart 2 - %d\nElapsed - %f ms.\n",
           prio, badges, (float)(time_us_32() - start) / 1000.0);
History doesn’t repeat itself, it rarely even rhymes.
bensimmo
Re: Advent 2022
Sat Dec 03, 2022 3:13 pm
Python again
Part1
total = 0
def get_priority(letter):
    if letter.islower():
        value = ord(letter) - 97 + 1
    elif letter.isupper():
        value = ord(letter) - 65 + 27
    else:
        value = "E"
    return value
with open('input.txt', newline='\n') as file:
    for row in file:
        row = row.rstrip("\r\n")
        half_row=int(len(row)/2)
        compartment1 = set(row[:half_row])
        compartment2 = set(row[half_row:])
        for item in compartment1:
            if item in compartment2:
                total += get_priority(item)
print(f"sum of priorities = {total}")
Part2
total = 0
    else:
    return value
    elves = [row.strip("\r\n") for row in file.readlines()]
for elf in range(0, len(elves), 3):
    common_item = []
    group_elf = (set(elves[elf]) , set(elves[elf+1]), set(elves[elf+2]))
    for item in group_elf[1]:
        if item in group_elf[0]:
            common_item.append(item)
    for item in group_elf[2]:
        if item in common_item:
RogerW
Re: Advent 2022
Sat Dec 03, 2022 3:50 pm
A variation on day 3 in c++
#include <iostream>
#include <fstream>
#include <cstring>
int main()
    std::ifstream file("/home/roger/Advent22/Dec3/data.txt");
    char a[100];
    char* b;
    char r;
    int score = 0;
    // Part 1
    while(file)
        file.getline(a,sizeof(a));
        int l = std::strlen(a)/2;
        b = a + l;
        for(int i = 0; i < l; i++)
            r = a[i];
            for(int j = 0; j < l ; j++)
                if(b[j] == r)
                    i= l;
                    j = l;
                    if( r < 'a')
                        score += r - 'A' + 27;
                    else
                        score += r - 'a' + 1;
    std::cout << "Part 1 " << score << "\n";
    // rewind
    file.clear();
    file.seekg(0);
    //part 2
    char c[3][100];
    int len[3];
    score = 0;
    while(file)
        for(int i = 0; i < 3; i++)
            file.getline(c[i],100);
            len[i] = std::strlen(c[i]);
        for(int i = 0; i < len[0]; i++)
            r = c[0][i];
            for(int j = 0; j < len[1] ; j++)
                if(c[1][j] == r)
                    for(int k = 0; k < len[2] ; k++)
                        if(c[2][k] == r)
                            i = 100;
                            j = 100;
                            k = 100;
                            if( r < 'a')
                            else
    std::cout << "Part 2 " << score << "\n";
    file.close();
    return 0;
ejolson
Re: Advent 2022
Sat Dec 03, 2022 5:36 pm
#include <iostream>
#include <fstream>
#include <cstring>
int main()
    char a[100];
    char* b;
    char r;
    int score = 0;
    // Part 1
    while(file)
        b = a + l;
            r = a[i];
                if(b[j] == r)
                    i= l;
                    j = l;
                    if( r < 'a')
                    else
    // rewind
    file.clear();
    file.seekg(0);
    //part 2
    char c[3][100];
    int len[3];
    score = 0;
    while(file)
            r = c[0][i];
                if(c[1][j] == r)
                        if(c[2][k] == r)
                            i = 100;
                            j = 100;
                            k = 100;
                            if( r < 'a')
                            else
    file.close();
    return 0;
Welcome to the party! It's amazing how many different ways there are to solve the same puzzle in just one language.
ejolson
Re: Advent 2022
Sat Dec 03, 2022 5:39 pm
Already behind.
Day2
import csv
ROCK = 1
PAPER = 2
SCISSOR = 3
WIN = 6
DRAW = 3
LOST = 0
total = 0
    for row in reader:
        match row:
            case ['A X']:
            case ['A Y']:
            case ['A Z']:
            case ['B X']:
            case ['B Y']:
            case ['B Z']:
            case ['C X']:
            case ['C Y']:
            case ['C Z']:
            case other:
                print("error")
That's good to know. I was surprised to get the same answer as lurk101 and wondered whether something had gone wrong with the website for that puzzle.
lurk101
Re: Advent 2022
Sun Dec 04, 2022 5:42 am
day4
#define title "--- Day 4: Camp Cleanup ---"
#include <chrono>
#include <fstream>
#include <iostream>
#include <string>
using namespace std;
using namespace chrono;
int part1(int l1, int h1, int l2, int h2) {
    if (l1 < l2)
        return h1 >= h2 ? 1 : 0;
    if (l2 < l1)
        return h2 >= h1 ? 1 : 0;
    return 1;
int part2(int l1, int h1, int l2, int h2) {
    if (l1 < l2)
        return h1 < l2 ? 0 : 1;
    if (l2 < l1)
        return h2 < l1 ? 0 : 1;
    return 1;
int main() {
    auto start = high_resolution_clock::now();
    ifstream f("day4.txt");
    string l;
    int contained = 0, overlapped = 0;
    while (getline(f, l)) {
        int l1, h1, l2, h2;
        (void)sscanf(l.c_str(), "%d-%d,%d-%d", &l1, &h1, &l2, &h2);
        contained += part1(l1, h1, l2, h2);
        overlapped += part2(l1, h1, l2, h2);
    cout << title << endl
        << "Part 1 - " << contained << endl
        << "Part 2 - " << overlapped << endl
        << "Elapsed - "
        << duration_cast<microseconds>(high_resolution_clock::now() - start).count() / 1e3
        << " ms." << endl;
pi@pi4b:~/AoC-2022-cplusplus/day4 $ taskset -c 3 ./a.out
Part 1 - 605
Part 2 - 914
Elapsed - 0.902 ms.
rock@rock-5b:~/AoC-2022-cplusplus/day4$ taskset -c 7 ./a.out
Part 1 - 605
Part 2 - 914
Elapsed - 0.537 ms.
ejolson
Re: Advent 2022
Sun Dec 04, 2022 5:43 am
Another day it's another puzzle and a Pshell solution.
/aofcode/2022/: cc day04.c
Advent of Code 2022 Day 4 Camp Cleanup
Part 1 The subset sum is 534
Part 2 The intersection sum is 841
Total execution time 0.0456240 seconds.
For reference the code is
/*  Advent of Code 2022 Day 4 Camp Cleanup
    Written December 2022 by Eric Olson */
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <fcntl.h>
#ifdef LINUX
#include <time.h>
static struct timespec tic_start;
void tic(){
    clock_gettime(CLOCK_MONOTONIC_RAW,&tic_start);
float toc(){
    struct timespec tic_stop;
    clock_gettime(CLOCK_MONOTONIC_RAW,&tic_stop);
    float sec=tic_stop.tv_sec-tic_start.tv_sec;
    return sec+(tic_stop.tv_nsec-tic_start.tv_nsec)*1.0e-9;
#endif
#ifndef LINUX
int tstart;
void tic(){
    tstart=time_us_32();
float toc(){
    return (float)(time_us_32()-tstart)/1000000.0;
#endif
#define BUFSZ 128
#define UGBSZ 32
struct fpspec {
    int fd,a,b,m;
    char c[BUFSZ],u[UGBSZ];
    struct fpspec *r;
struct fpspec rroot;
struct fpspec *fproot;
char *psindex(char *s,int c){
    do {
        if(*s==c) return s;
    } while(*++s);
    return 0;
char *fierror;
struct fpspec *fpopen(char *fn,char *mode){
    int m=0;
    if(psindex(mode,'r')) m|=1;
    if(psindex(mode,'w')) m|=2;
    if(!m){
        printf("Invalid mode %s to open file %s!\n",mode,fn);
        exit(1);
    switch(--m){
case 0:
        m=O_RDONLY; break;
case 1:
        m=O_WRONLY; break;
case 2:
        m=O_RDWR; break;
    int fd=open(fn,m);
    if(fd<0){
        printf("Unable to open %s for mode %s!\n",fn,mode);
        exit(1);
    struct fpspec *fp,*fpo;
    for(fp=&rroot;fp;fpo=fp,fp=fp->r){
        if(fp->fd==0||fp->fd==fd){
            fp->fd=fd;
            fp->a=0; fp->b=0; fp->m=0;
            return fp;
    fp=(struct fpspec *)malloc(sizeof(struct fpspec));
    if(!fp){
        printf("Can't allocate memory for fpspec!\n");
        exit(1);
    fpo->r=fp;
    fp->fd=fd;
    fp->r=0;
    return fp;
int fpgetc(struct fpspec *fp){
    if(fp->m) return fp->u[--fp->m];
    if(fp->a>=fp->b){
        if(fp->fd<0) return -1;
        fp->a=0;
        fp->b=read(fp->fd,fp->c,BUFSZ);
    if(fp->a<fp->b){
        return fp->c[fp->a++];
    return -1;
char *fpgets(char *s,int n,struct fpspec *fp){
    int i=0;
    --n;
    for(i=0;i<n;i++){
        int c=fpgetc(fp);
        if(c<=0||c=='\n'||c=='\r'){
            if(c<=0&&!i) return 0;
            s[i]=0;
            return s;
        s[i]=c;
    s[n]=0;
    return s;
void fpugetc(int c,struct fpspec *fp){
    if(fp->a>0) fp->c[--fp->a]=c;
    else if(fp->m<UGBSZ) fp->u[fp->m++]=c;
    else {
        printf("Unget buffer overflow fpugetc!\n");
        exit(1);
int fpputc(int c,struct fpspec *fp){
    char b=c;
    return write(fp->fd,&b,1);
int fpclose(struct fpspec *fp){
    return close(fp->fd);
struct interval {
    int a,b;
int mydigit(int c){
    if(c>='0'&&c<='9') return c-'0';
    return -1;
char *getint(int *n,char *s){
    *n=0;
    for(;;){
        int d=mydigit(*s);
        if(d<0) return s;
        *n=*n*10+d;
        ++s;
char *parserange(struct interval *I0,char *s){
    s=getint(&I0->a,s);
    if(*s=='-') ++s;
    else {
        printf("Parse range missing - at %s\n",s);
        exit(1);
    s=getint(&I0->b,s);
    return s;
char subset(struct interval *I0,struct interval *I1){
    if(I0->a<I1->a) return 0;
    if(I0->b>I1->b) return 0;
    return 1;
char meet(struct interval *I0,struct interval *I1){
    if(I0->a>I1->b) return 0;
    if(I0->b<I1->a) return 0;
    return 1;
void dowork(){
    char *fn="day04.txt";
    struct fpspec *fp=fpopen(fn,"r");
    if(!fp){
        printf("Unable to open %s for reading!\n",fn);
        exit(1);
    char *s,buf[128];
    struct interval I0,I1;
    int rsum1=0,rsum2=0;
    for(;;){
        s=fpgets(buf,128,fp);
        if(!s) break;
        s=parserange(&I0,s);
        if(*s==',') ++s;
        else {
            printf("Pair specifier missing , at %s\n",s);
            exit(1);
        s=parserange(&I1,s);
        if(subset(&I0,&I1)||subset(&I1,&I0)) ++rsum1;
        if(meet(&I1,&I0)) ++rsum2;
    printf("Part 1 The subset sum is %d\n",rsum1);
    printf("Part 2 The intersection sum is %d\n",rsum2);
int main(){
    printf("Advent of Code 2022 Day 4 Camp Cleanup\n\n");
    tic();
    dowork();
    printf("\nTotal execution time %g seconds.\n",toc());
    return 0;
This time I developed the code on a Pi Zero and then transferred it to the Pico. No changes were needed for Pshell. Simply typing cc day04.c is sure easier than creating a CMakeLists.txt file and running cmake followed by make. If the dog developer weren't asleep tails would certainly be wagging.
lurk101
Re: Advent 2022
Sun Dec 04, 2022 7:15 am
day4 pshell translation
    if (l1 < l2)
    if (l2 < l1)
    return 1;
    if (l1 < l2)
    if (l2 < l1)
    return 1;
char* txt;
int number() {
    int n = strtol(txt, &txt, 10);
    if (txt)
        ++txt;
    return n;
void main() {
    int start = time_us_32(), f = open("day4.txt", O_RDONLY), n = lseek(f, 0, SEEK_END);
    read(f, txt, n);
    txt[n] = 0;
    while (*txt) {
        int l1 = number(), h1 = number(), l2 = number(), h2 = number();
    printf("--- Day 4: Camp Cleanup ---\nPart 1 - %d\nPart 2 - %d\nElapsed - %f\n",
        contained, overlapped, (float)(time_us_32() - start) / 1000.0);
They usually get harder after day4
/AoC/day4/: cc day4
Part 1 - 605
Part 2 - 914
Elapsed - 15.693000
RogerW
Re: Advent 2022
Sun Dec 04, 2022 10:28 am
Finally got my head round day 2
It is a bit long winded - I need to remember how to pass a 2 dimensional array to a function.
#include <iostream>
#include <fstream>
int main()
    std::ifstream file("/home/roger/Advent22/Dec2/data.txt");
    char b[6];
    int total = 0;
    //                  r  p  s
    int scores[3][3] = {4, 8, 3,    // rock
                        1, 5, 9,    // paper
                        7, 2, 6};   // scissors
    while(file)
        file.getline(b,sizeof(b));
        if(b[0] == '\0')
            break;
        total += scores[b[0] - 'A'][b[2] - 'X'];
    std::cout << "Part 1 " << total << "\n";
    file.clear();
    file.seekg(0);
    total = 0;
    //                   l  d  w
    int scores2[3][3] = {3, 4, 8,
                         1, 5, 9,
                         2, 6, 7};
    while(file)
        if(b[0] == '\0')
            break;
        total += scores2[b[0] - 'A'][b[2] - 'X'];
    std::cout << "Part 2 " << total << "\n";
    file.close();
    return 0;
bensimmo
Re: Advent 2022
Sun Dec 04, 2022 11:51 am
Simple Python Day4
contains_total = 0
overlap_total = 0
for elf in elves:
    elf_pair = elf.replace("-",",")
    elf_pair = elf_pair.split(",")
    if   (int(elf_pair[0]) >= int(elf_pair[2])) and (int(elf_pair[1]) <= int(elf_pair[3])):
        contains_total += 1
    elif (int(elf_pair[0]) <= int(elf_pair[2])) and (int(elf_pair[1]) >= int(elf_pair[3])):
        contains_total += 1
    elif (int(elf_pair[1]) <  int(elf_pair[2])) or  (int(elf_pair[3]) <  int(elf_pair[0])):
        pass # No overlap
    else:
        overlap_total += 1
print(f"Fully contains = {contains_total}")
print(f"Any Overlap = {contains_total + overlap_total}")
ejolson
Re: Advent 2022
Sun Dec 04, 2022 6:54 pm
I like the way the comments are formatted for scores and scores2. That makes it a lot easier to understand what's going on.
Did you get the same day 2 output as lurk101 and I in
viewtopic.php?p=2059145#p2059145
Given over 100 000 people are participating
 4   78769  2338  *******************
 3  105679  5794  **************************
 2  139786  6301  *********************************
 1  174045  6723  *****************************************
https://adventofcode.com/2022/stats
I suspect the chances are pretty high some people get the same puzzles or at least output. Finding two identical solutions in this thread was surprising--three identical solutions would be even more so.
lurk101
Re: Advent 2022
Sun Dec 04, 2022 7:20 pm
There must be a finite number of data sets per puzzle. Could it be that you're assigned a data set index that you keep throughout the 25 days?
lurk101
Re: Advent 2022
Mon Dec 05, 2022 5:53 am
day5
#define title "--- 5: Supply Stacks ---"
#include <chrono>
#include <fstream>
#include <iostream>
#include <string>
#include <list>
#include <algorithm>
list<char> stack[10], stack2[10];
int main() {
    ifstream f("day5.txt");
    string l;
        if (l[1] == '1') {
            getline(f, l);
            break;
        int len = l.length();
        for (int i = 1; i < 10; ++i) {
            if (((i * 4) - 3) >= len)
                break;
            char c = l[(i * 4) - 3];
            if (c != ' ')
                stack[i].push_front(c);
        stack2[i] = stack[i];
    int n, from, to;
    string s;
    while (f >> s >> n >> s >> from >> s >> to) {
        for (int j = 0; j < n; ++j) {
            stack[to].push_back(stack[from].back());
            stack[from].pop_back();
        list<char> temp;
            temp.push_back(stack2[from].back());
            stack2[from].pop_back();
        while (temp.size()) {
            stack2[to].push_back(temp.back());
            temp.pop_back();
    cout << title << endl << "Part 1 - ";
    for (int i = 1; i < 10; i++)
        if (stack[i].size())
            cout << stack[i].back();
    cout << endl << "Part 2 - ";
        if (stack2[i].size())
            cout << stack2[i].back();
    cout << endl << "Elapsed - "
        << " ms." << endl;
Part 1 - VGBBJCRMN
Part 2 - LBBVJBRMH
Elapsed - 5.801 ms.
RogerW
Re: Advent 2022
Mon Dec 05, 2022 9:53 am
Not the same I am afraid. Part 1 14069, Part 2 12411
RogerW
Re: Advent 2022
Mon Dec 05, 2022 2:27 pm
My variation on day 5. I did not get the same answers as lurk101
#include <iostream>
#include <fstream>
#include <stack>
#include <string>
void loadstacks(std::ifstream& file,std::stack<char>* stacks)
    // we need to load stacks from the bottom up
    // my data only needed 8 lines
    char lines[16][40];
    int cols[9] = {1,5,9,13,17,21,25,29,33};
    int next = 0;
    while(true)
        file.getline(lines[next],sizeof(lines[next]));
        //std::cout << lines[next] << "\n";
        if(lines[next][1] == '1')
            next--;
            break;
        next++;
    while(next >= 0)
        for(int i = 0; i < 9 ;i++)
            if(lines[next][cols[i]] != ' ')
                stacks[i].push(lines[next][cols[i]]);
        next--;
std::string top(std::stack<char>* stacks)
    std::string s;
    for(int i = 0; i < 9 ; i++)
        s += stacks[i].top();
    return s;
void move(std::stack<char>* stacks,int mov,int from,int to)
    // move crates
    for(int i = 0; i < mov; i++)
        stacks[to].push(stacks[from].top());
        stacks[from].pop();
void move2(std::stack<char>* stacks,int mov,int from,int to)
    // for part 2 order is preserved
    std::stack<char> s;
        s.push(stacks[from].top());
        stacks[from].pop();
        stacks[to].push(s.top());
        s.pop();
int main()
    std::cout << "Advent of Code 2022 day 5\n";
    std::ifstream file("/home/roger/Advent22/Dec5/Data.txt");
    std::stack<char> stacks[9];
    // load the stacks
    loadstacks(file,stacks);
    // skip a line
    char buf[40];
    file.getline(buf,sizeof(buf));
    int mov,from,to;
    std::string s;
    while(!file.eof())
        file >> s >> mov >> s >> from >> s >> to ;
        move(stacks,mov,from - 1,to - 1);
    std::cout << "Part 1 " << top(stacks) << "\n";
    // reposition file
    file.clear();
    file.seekg(0);
    std::stack<char> stacks2[9];
    // load the stacks
    loadstacks(file,stacks2);
    // skip a line
    while(!file.eof())
        move2(stacks2,mov,from - 1,to - 1);
    std::cout << "Part 2 " << top(stacks2) << "\n";
    file.close();
    return 0;
lurk101
Re: Advent 2022
Tue Dec 06, 2022 12:57 am
Day 5 for pshell
Uncovered a few compiler issues with this one!
int line_length(char* t) {
    char* cp = t;
    int l = 0;
    while (*cp++ != '\n')
        l++;
    return l;
void push(int *stk, char c) {
    stk[++stk[0]] = c;
char pop(int *stk) {
    return stk[stk[0]--];
int size(int* stk) {
    return stk[0];
char top(int* stk) {
    return stk[stk[0]];
void reverse(int *stk) {
    int i, n = size(stk);
    if (n < 2)
        return;
    for (i = 0; i < n / 2; ++i) {
        int temp = stk[i + 1];
        stk[i + 1] = stk[n - i];
        stk[n - i] = temp;
char* skip_past_str(char* t) {
    while (*t != ' ')
        ++t;
    ++t;
    return t;
int s1[9][60], s2[9][60];
void main() {
    int start = time_us_32();
    int f = open("day5.txt", O_RDONLY);
    int i, j, n = lseek(f, 0, SEEK_END);
    char* txt = (char*)malloc(n + 1);
    read(f, txt, n);
    txt[n] = 0;
    for (i = 0; i < 9; ++i)
        s1[i][0] = 0;
    while (txt[1] != '1') {
        int len = line_length(txt);
        for (i = 0; i < 9; ++i) {
            if (((i * 4) + 1) >= len)
                break;
            char c = txt[(i * 4) + 1];
            if (c != ' ')
                push(s1[i], c);
        txt += len + 1;
    txt += line_length(txt) + 1;
        reverse(s1[i]);
    memcpy(s2, s1, sizeof(s2));
    int from, to;
    while (*txt) {
                if (line_length(txt) == 0)
                        break;
        txt = skip_past_str(txt);
        txt = skip_past_str(++txt);
        from = strtol(txt, &txt, 10) - 1;
        to = strtol(txt, &txt, 10) - 1;
        if (*txt)
            ++txt;
        for (j = 0; j < n; ++j)
            push(s1[to], pop(s1[from]));
        int temp[60];
        temp[0] = 0;
            push(temp, pop(s2[from]));
            push(s2[to], pop(temp));
    printf("--- 5: Supply Stacks ---\nPart 1 - ");
    for (i = 0; i < 9; i++)
        if (size(s1[i]))
            printf("%c", top(s1[i]));
    printf("\nPart 2 - ");
        if (size(s2[i]))
            printf("%c", top(s2[i]));
    printf("\nElapsed - %f ms.\n", (float)(time_us_32() - start) / 1000.0);
/: cc day5
Part 1 - VGBBJCRMN
Part 2 - LBBVJBRMH
Elapsed - 26.541000 ms.
ejolson
Re: Advent 2022
Tue Dec 06, 2022 1:37 am
Day 5 for pshell
Do I need to update my copy of Pshell?
Fido's been working on a solution using dogly (doubly) linked lists to represent the stacks. This seems like a weird data structure for this puzzle to me but Fido insisted. In my opinion someone is enjoying all the dogfooding too much.
Hopefully, day 5 will be finished before the next puzzle opens.
lurk101
Re: Advent 2022
Tue Dec 06, 2022 2:40 am
Two problems discovered. Text strings, which are allocated as global data, were limited to the 1st 4K. That should have been 16K. I've pushed a fix for that.
The second problem I don't have a fix for yet. Seems large local arrays aren't handled properly. This can me illustrated by moving the S1 and S2 array declarations in day5.c from global storage to local inside main. The local storage version crashes. There should be plenty of stack space left to accommodate large locals.
Oh! and a third. sizeof seems to be broken for multidimensional arrays.
ejolson
Re: Advent 2022
Tue Dec 06, 2022 2:48 am
I've been somewhat frugal with memory by using an out-of-core algorithm for each solution so far. Fido's code didn't discover any bugs.
The output was
/aofcode/2022/: cc day05.c
Advent of Code 2022 Day 5 Camp Cleanup
Part 1 The reversed crates are QPJPLMNNR
Part 2 The correct crates are BQDNWJPVJ
Total execution time 0.0795550 seconds.
and the code
/*  Advent of Code 2022 Day 5 Camp Cleanup
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <fcntl.h>
#include <string.h>
#ifdef LINUX
#include <time.h>
void tic(){
float toc(){
#endif
#ifndef LINUX
int tstart;
void tic(){
float toc(){
#endif
#define BUFSZ 128
#define UGBSZ 32
struct fpspec {
    int fd,a,b,m;
    struct fpspec *r;
    do {
        if(*s==c) return s;
    } while(*++s);
    return 0;
char *fierror;
    int m=0;
    if(!m){
        exit(1);
    switch(--m){
case 0:
        m=O_RDONLY; break;
case 1:
        m=O_WRONLY; break;
case 2:
        m=O_RDWR; break;
    int fd=open(fn,m);
    if(fd<0){
        exit(1);
            fp->fd=fd;
            return fp;
    if(!fp){
        exit(1);
    fpo->r=fp;
    fp->fd=fd;
    fp->r=0;
    return fp;
    if(fp->a>=fp->b){
        fp->a=0;
    if(fp->a<fp->b){
    return -1;
    int i=0;
    --n;
    for(i=0;i<n;i++){
        int c=fpgetc(fp);
            s[i]=0;
            return s;
        s[i]=c;
    s[n]=0;
    return s;
    else {
        exit(1);
    char b=c;
int mydigit(int c){
    return -1;
char myletter(int c){
    if(c>='A'&&c<='Z') return c-'A';
    return -1;
    *n=0;
    for(;;){
        int d=mydigit(*s);
        if(d<0) return s;
        *n=*n*10+d;
        ++s;
char *bparse(char *s){
    if(!strncmp(s,"   ",3)) return s+3;
    return s;
char *lparse(int *c,char *s){
    if(s[0]=='['){
        *c=myletter(s[1]);
        if(*c>=0){
            if(s[2]==']'){
                return s+3;
    return s;
struct dogll {
    struct dogll *a,*b;
    int x;
#define SMAX 10
struct dogll head[SMAX],tail[SMAX];
void llbins(struct dogll *l0,struct dogll *l1){
    struct dogll *l2=l0->b;
    l1->a=l0; l1->b=l2;
    l2->a=l1; l0->b=l1;
void llains(struct dogll *l1,struct dogll *l2){
    struct dogll *l0=l2->a;
    l1->a=l0; l1->b=l2;
    l2->a=l1; l0->b=l1;
void ddrem(struct dogll *l1){
    struct dogll *l0=l1->a;
    struct dogll *l2=l1->b;
    l0->b=l2; l2->a=l0;
void cleanup(){
    int i;
    for(i=0;i<SMAX;i++){
        struct dogll *l0=&head[i],*l1;
        for(l0=l0->b;l0->b;l0=l1){
            l1=l0->b; free(l0);
        head[i].b=&tail[i];
        tail[i].a=&head[i];
char buf[128];
char *decode(){
    int i;
        struct dogll *l0=&head[i];
        l0=l0->b;
        if(!l0->b) break;
        buf[i]=l0->x+'A';
    buf[i]=0;
    return buf;
void doinit(struct fpspec *fp){
    char *s,*t;
    int c,i;
        head[i].b=&tail[i];
        tail[i].a=&head[i];
    for(;;){
        if(!s) {
            printf("Reached end before initializing\n");
            exit(1);
            s=lparse(&c,t=s);
            if(s>t){
                struct dogll *l1=(struct dogll *)malloc(sizeof(struct dogll));
                l1->x=c;
                llains(l1,&tail[i]);
            } else {
                s=bparse(s);
            if(s==t){
                if(!strncmp(s," 1 ",3)){
                return;
            if(*s==' ') s++;
            if(!*s) break;
char *mstring(char *w,char *s){
    int n=strlen(w);
    if(!strncmp(w,s,n)) return s+n;
    printf("Unable to match %s starting %s\n",w,s);
    exit(1);
void pmove(int *n,int *f,int *t,char *s){
    s=mstring("move ",s);
    s=getint(n,s);
    s=mstring(" from ",s);
    s=getint(f,s); --(*f);
    s=mstring(" to ",s);
    s=getint(t,s); --(*t);
void part1(char *fn){
    if(!fp){
        exit(1);
    doinit(fp);
    char *s;
    for(;;){
        int j,n,f,t;
        if(!s) break;
        pmove(&n,&f,&t,s);
        for(j=0;j<n;j++){
            struct dogll *l1=head[f].b;
            ddrem(l1);
            llbins(&head[t],l1);
    printf("Part 1 The reversed crates are %s\n",decode());
    cleanup();
    fpclose(fp);
void part2(char *fn){
    if(!fp){
        exit(1);
    doinit(fp);
    char *s;
    for(;;){
        int j,n,f,t;
        if(!s) break;
        pmove(&n,&f,&t,s);
        if(f==t) continue;
        struct dogll *l2=head[t].b;
        for(j=0;j<n;j++){
            ddrem(l1);
            llains(l1,l2);
    printf("Part 2 The correct crates are %s\n",decode());
    cleanup();
    fpclose(fp);
void dowork(){
    char *fn="day05.txt";
    part1(fn);
    part2(fn);
int main(){
    printf("Advent of Code 2022 Day 5 Camp Cleanup\n\n");
    tic();
    dowork();
    return 0;
Someone bought up all the dog treats and is scalping them on Amazon. At 346 lines of code I hope the dog developer does not expect to get paid per line.
lurk101
Re: Advent 2022
Tue Dec 06, 2022 4:33 am
Pushed a fix for the string literal and array sizeof problem. I'll look at the large local array issue tomorrow.
lurk101
Re: Advent 2022
Tue Dec 06, 2022 5:40 am
Day 6
#define title "--- Day 6: Tuning Trouble  ---"
#include <chrono>
#include <fstream>
#include <iostream>
#include <string>
bool all_diff(char* c, int l) {
    for (int i = 0; i < l - 1; ++i)
        for (int j = i + 1; j < l; ++j)
            if (c[i] == c[j])
                return false;
    return true;
void rotate(char* cn, char c, int l) {
        cn[i] = cn[i + 1];
    cn[l - 1] = c;
int main() {
    ifstream f("day6.txt");
    char c;
    char c4[4] = { 0 };
    int n1 = 0;
    while (f >> c) {
        rotate(c4, c, 4);
        if ((n1 > 4) && all_diff(c4, 4))
            break;
        ++n1;
    f.clear();
    f.seekg(0, ios_base::beg);
    char c14[14] = { 0 };
    int n2 = 0;
    while (f >> c) {
        rotate(c14, c, 14);
        if ((n2 > 14) && all_diff(c14, 14))
            break;
        ++n2;
        << "Part 1 - " << n1 + 1 << endl
        << "Part 2 - " << n2 + 1 << endl
        << "Elapsed - "
        << " ms." << endl;
Part 1 - 1757
Part 2 - 2950
Elapsed - 0.319 ms.
lurk101
Re: Advent 2022
Tue Dec 06, 2022 6:19 am
Easy translation of day 6 to pshell
int all_diff(char* c, int l) {
    int i, j;
    for (i = 0; i < l - 1; ++i)
        for (j = i + 1; j < l; ++j)
            if (c[i] == c[j])
                return 0;
    return 1;
    int i;
        cn[i] = cn[i + 1];
    cn[l - 1] = c;
void main() {
    int f = open("day6.txt", O_RDONLY);
    int l = lseek(f, 0, SEEK_END);
    char* txt = (char*)malloc(l + 1);
    read(f, txt, l);
    txt[l] = 0;
    char* cp = txt;
    char c4[4];
    memset(c4, 0, sizeof(c4));
    int n1 = 0;
    while (*cp) {
        rotate(c4, *cp++, 4);
            break;
        ++n1;
    cp = txt;
    char c14[14];
    memset(c14, 0, sizeof(c14));
    int n2 = 0;
    while (*cp) {
        rotate(c14, *cp++, 14);
            break;
        ++n2;
    printf("--- Day 6: Tuning Trouble  ---\nPart 1 - %d\nPart 2 - %d\nElapsed - %f ms.\n", n1 + 1,
           n2 + 1, (float)(time_us_32() - start) / 1000.0);
/AoC/day6/: cc day6
Part 1 - 1757
Part 2 - 2950
Elapsed - 57.172001 ms.
jalih
Re: Advent 2022
Tue Dec 06, 2022 9:11 am
Using 8th I was lazy and just modified my day 2 solution for day 5 task... ;)
  ["P","F","M","Q","W","G","R","T"],
  ["H","F","R"],
  ["P","Z","R","V","G","H","S","D"],
  ["Q","H","P","B","F","W","G"],
  ["P","S","M","J","H"],
  ["M","Z","T","H","S","R","P","L"],
  ["P","T","H","N","M","L"],
  ["F","D","Q","R"],
  ["D","S","C","N","L","P","H"]
] constant data
ns?
ns: stacks
: move
  parsews >n ;
: from  \ n -- n n
  parsews >n n:1- ;
defer: to
: to1  \ n n --
  swap >r parsews >n n:1- swap 2 a:close data swap a:_@
  a:open ( a:pop _swap a:push swap ) r> times 2drop ;
: to2  \ n n --
  dup>r data swap a:@ rot n:neg a:/ _swap r> swap a:!
  parsews >n n:1- a:_@ swap a:+ drop ;
: interpret
  ns:stacks only
  eval
  null only ;
ns
: app:main
  "a5.txt" f:slurp
  ' stacks:to1 w:is stacks:to  \ Change to "stacks:to2" to solve part 2 of the puzzle
  ' stacks:interpret s:eachline data ( -1 a:_@ ) a:map "" a:join . cr ;
jalih
Re: Advent 2022
Tue Dec 06, 2022 8:34 pm
Just solved the day 6 using the 8th programming language. I used combination of brute force, table lookup and some binary magic...
( "" swap s:+ ) 'a 'z a:generate
( 1 swap n:shl ) 0 25 a:generate m:zip
( swap m:_@ ) curry: lookup    \ s -- n
\ MSB of the number
: msb?  \ n -- msb
  n:ln 2 n:ln n:/ n:int ;
\ Bits set in the 32-bit integer
: bits32-set?  \ n -- n
  dup 1 n:shr x55555555 n:band n:-
  dup 2 n:shr x33333333 n:band swap x33333333 n:band n:+
  dup 4 n:shr n:+ x0f0f0f0f n:band
  dup 8 n:shr n:+ x00ff00ff n:band
  dup 16 n:shr n:+ x0000ffff n:band ;
\ Bits set in the integer, handle 32-bit at a time
: bits-set?  \ n -- n
  dup>r msb? n:1+ 32 n:/mod swap if
    n:1+
  then
  >r 0
  ( r@ swap n:shr xffffffff n:band bits32-set?
    n:+  \ bits set
    32 step ) 0 r> 5 n:shl n:1- loop rdrop ;
: sequence \ a n -- a
  a:new
  rot
  ( over swap 4 pick a:slice _swap a:push swap )
  0 2 pick a:len n:1- nip 5 pick n:1+ n:- loop drop nip ;
: find  \ n --
  dup>r sequence
  ( ' lookup a:map ' n:bor 0 a:reduce bits-set? ) a:map
  r@ ' n:= a:indexof null? !if
    r@ n:+ . cr
  else
    drop "Sorry, not found!\n" .
  then drop rdrop ;
: app:main
  "a6.txt" f:slurp >s "" s:/ dup 4 find 14 find ;
