bgolab
More than perfect pink PICO clone?
Thu Jan 19, 2023 10:08 am
Features: USB-C connector, 16MB flash, reset button, better voltage regulator, 100% pin-to-pin match, USB-cable included.
Schematic:
https://github.com/RetroScaler/RP2040-P ... 221008.pdf
Some sellers:
https://www.aliexpress.com/item/1005004 ... pt=glo2pol
3.5-3.9USD + shipment.
I have not ordered it yet so not sure about what you really get.
Re: More than perfect PICO pink clone?
Thu Jan 19, 2023 11:50 am
Looks interesting!
bgolab
Thu Jan 19, 2023 12:30 pm
This clone is one of the best so far (some Waveshare boards are really 100% compatible ones as well - but much expensive)
It even preserves the 3V3_EN pin (most boards exposes extra GPIO pins at the cost of 3V3_EN and ADC_REF pins).
Sometimes they remove some GND pins to have even more GPIOs.
Thu Jan 19, 2023 12:57 pm
Making it pin compatible is a very sensible idea. I might see if I can grab a couple.
bgolab
Thu Jan 19, 2023 1:02 pm
Yes, there is so many decent expansion boards where we need almost 100% pin-to-pin matching (e.g. Citron Maker, Waveshare Dual / Quad Expansion if you use some advanced modules like UPS, etc).
I cannot understand why some clones have pin 36 and 37 swapped i.e. 3V3 is wired to pin 37 instead of pin 36 (pin 36 is assigned to the GPIO). I can accept loosing the 3V3_EN but swapping these two pins is really painful.
neilgl
Thu Jan 19, 2023 1:48 pm
Is there a version with WiFi?
bgolab
Thu Jan 19, 2023 2:22 pm
I have not seen any compatible with PICO (phy factor).
There are some not compatible like Seeed wio rp2040 (wifi based on ESP8266 I guess) or Lilygo rp2040 (lcd 1.14" + ESP32).
There are some boards with pre-soldered PICO W module like MAKER-PI-PICO-MINI-W but they does not change the flash size of course... They simply add some features like LEDs, buzzer, etc
Thu Jan 19, 2023 3:05 pm
It does seem bizarre. I can understand boards having different footprints and pinouts when intended to be compatible with other products or be a different style board but, when it could be 'drop-in replacement' for a Pico or Pico W, it is ridiculous to make it not.
It reminds me of those Dell PC's and PSU's which used the familiar ATX connector but had different wiring.
scruss
Thu Jan 19, 2023 4:23 pm
Nice: though not exactly looking for more boards right now myself. Good to see someone finally get the pinout right.
Shipping will be a bit slow since Lunar New Year kicks off on Saturday.
Pronouns: he/him
bgolab
Re: More than perfect pink PICO clone?
Fri Jan 20, 2023 11:39 am
My order is scheduled in the middle of February. Just ordered it out of curiosity.
bgolab
Wed Feb 08, 2023 2:46 pm
Just got the boards. Unfortunately they have NOT included the USB-cable - be aware of this.
retroscalerservice
Fri Feb 10, 2023 3:37 am
Sorry for the inconvenience caused to you, please contact the after-sales staff and we will reissue a new typec cable for you
retroscalerservice
Fri Feb 10, 2023 3:38 am
Just got the boards. Unfortunately they have not included the USB-cable - be aware of this.
MatSOBDev
Fri Feb 10, 2023 8:23 am
@retroscalerservice If you are this board creator, maybe some DC-DC converter chip for powering ARM core. Could be I2C GP24-25 on double duty - think it is doable.
retroscalerservice
Wed Feb 15, 2023 12:56 am
Thank you for your suggestion, I will try to modify and test
MatSOBDev
Sun Feb 19, 2023 11:05 am
And together with that, some boards, ex. Pimoroni Tufty2040 use BOOTSEL button as an input when board is running. So simple input and output on the board. And just aesthetics, smaller (flater) package for the flash might look better, but that's only me :D
Sun Feb 19, 2023 3:21 pm
It should be implicit that any RP2040 board which has a BOOTSEL button fitted can use it as an input button when running user code.
trejan
Sun Feb 19, 2023 3:24 pm
Not quite the same. The Tufty board also wires it to a GPIO.
MatSOBDev
Sun Feb 19, 2023 3:43 pm
Yes, there is example how to use it as 'GPIO', but is tricky to run. And here DC-DC regulator has no force PWM pin to drive, so one left to use.
Return to “Other RP2040 boards”
