piusernumberone
some mirrors don't work
Sat Jan 28, 2023 1:10 pm
When I try to
apt update
there are three adresses where Raspberry Pi OS tries to fetch:
http://archive.raspberrypi.org/debian bullseye InRelease
http://raspbian.raspberrypi.org/raspbian bullseye InRelease
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
The first two succeed but the third one outputs an error
Connction timed out [IP: 93.93.128.193 80]
Pinging 93.93.128.193 is successful too, without any significant difference in time with pinging other IP adresses.
I searched for alternative official mirrors but didn't find any. There's a raspbian.org mirror which is not the same as raspberrypi.org, is it supported and safe in general?
pidd
Re: some mirrors don't work
Sat Jan 28, 2023 5:03 pm
Work with me, I can't spot any difference in that line.
$ sudo apt update
Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
Get:3 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
Get:4 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [311 kB]
Fetched 13.6 MB in 26s (531 kB/s)
Reading package lists... Done
Building dependency tree... Done
8 packages can be upgraded. Run 'apt list --upgradable' to see them.
piusernumberone
Sat Jan 28, 2023 8:00 pm
Mine is similar except:
Ign:3 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
and then
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/bullseye/main/binary-armhf/Packages Connction timed out [IP: 93.93.128.193 80]
I typed it manually so i hope there's no typos in there.
I don't know why there are two
Get3
s and no
Get4
Also:
ping raspberrypi.org
ping archive.raspberrypi.org
ping raspbian.raspberrypi.org
all three are succesful, I think it's either the differnece between
ping
and
apt update
protocols etc.(I'm no network engineer) or somehow the pi can only reach the main directories but not the inner directories if that makes sense.
pidd
Sat Jan 28, 2023 8:38 pm
Its probably a mirror down, it happens sometimes. It appears the MythicBeasts mirror you are having problems with.
See if you can view http://93.93.128.193/raspbian/dists/bul ... ary-armhf/
piusernumberone
Sat Jan 28, 2023 9:03 pm
pidd wrote: Its probably a mirror down, it happens sometimes. It appears the MythicBeasts mirror you are having problems with.
Yes, it says
Index of /raspbian/dists/bullseye/main/binary-armhf
Is it possible to download these and install them offline?
Why does it show up on my browser but doesn't respond to apt?
Is it useful if i somehow increase the timout for apt until it can fetch this?
If i understand correctly, the raspberrypi.org redirects me to some other mirrors, is there a list somewhere to copy/paste into
sources.list
