Whenever I try to install Spicy using "sudo pip3 install spicy"
It fails with some error messages and keeps retrying again and again....
Any help is appreciated ..Thank You!
These are the error messages I got...:
pi@raspberrypi:~ $ sudo pip3 install spicy
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting spicy
Downloading spicy-0.16.0-py2.py3-none-any.whl (1.7 kB)
Collecting scipy
Downloading scipy-1.10.1.tar.gz (42.4 MB)
|████████████████████████████████| 42.4 MB 15 kB/s
Installing build dependencies ... done
Getting requirements to build wheel ... done
Installing backend dependencies ... done
Preparing wheel metadata ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /tmp/tmpskp_ivr4_in_process.py prepare_metadata_f or_build_wheel /tmp/tmpnq5pv3xz
cwd: /tmp/pip-install-up2xk2ks/scipy_c9d9e2ed11754f998ae5940b801eb8f6
Complete output (40 lines):
The Meson build system
Version: 1.0.1
Source dir: /tmp/pip-install-up2xk2ks/scipy_c9d9e2ed11754f998ae5940b801eb8f6
Build dir: /tmp/pip-install-up2xk2ks/scipy_c9d9e2ed11754f998ae5940b801eb8f6/.mesonpy-_5gddfk5/build
Build type: native build
Project name: SciPy
Project version: 1.10.1
C compiler for the host machine: cc (gcc 10.2.1 "cc (Raspbian 10.2.1-6+rpi1) 10.2.1 20210110")
C linker for the host machine: cc ld.bfd 2.35.2
C++ compiler for the host machine: c++ (gcc 10.2.1 "c++ (Raspbian 10.2.1-6+r pi1) 10.2.1 20210110")
C++ linker for the host machine: c++ ld.bfd 2.35.2
Cython compiler for the host machine: cython (cython 0.29.33)
Host machine cpu family: arm
Host machine cpu: armv7l
Compiler for C supports arguments -Wno-unused-but-set-variable: YES
Compiler for C supports arguments -Wno-unused-function: YES
Compiler for C supports arguments -Wno-conversion: YES
Compiler for C supports arguments -Wno-misleading-indentation: YES
Compiler for C supports arguments -Wno-incompatible-pointer-types: YES
Library m found: YES
../../meson.build:63:0: ERROR: Unknown compiler(s): [['gfortran'], ['flang'] , ['nvfortran'], ['pgfortran'], ['ifort'], ['ifx'], ['g95']]
The following exception(s) were encountered:
Running `gfortran --version` gave "[Errno 2] No such file or directory: 'gfortran'"
Running `gfortran -V` gave "[Errno 2] No such file or directory: 'gfortran'"
Running `flang --version` gave "[Errno 2] No such file or directory: 'flang' "
Running `flang -V` gave "[Errno 2] No such file or directory: 'flang'"
Running `nvfortran --version` gave "[Errno 2] No such file or directory: 'nvfortran'"
Running `nvfortran -V` gave "[Errno 2] No such file or directory: 'nvfortran '"
Running `pgfortran --version` gave "[Errno 2] No such file or directory: 'pgfortran'"
Running `pgfortran -V` gave "[Errno 2] No such file or directory: 'pgfortran '"
Running `ifort --version` gave "[Errno 2] No such file or directory: 'ifort' "
Running `ifort -V` gave "[Errno 2] No such file or directory: 'ifort'"
Running `ifx --version` gave "[Errno 2] No such file or directory: 'ifx'"
Running `ifx -V` gave "[Errno 2] No such file or directory: 'ifx'"
Running `g95 --version` gave "[Errno 2] No such file or directory: 'g95'"
Running `g95 -V` gave "[Errno 2] No such file or directory: 'g95'"
A full log can be found at /tmp/pip-install-up2xk2ks/scipy_c9d9e2ed11754f998 ae5940b801eb8f6/.mesonpy-_5gddfk5/build/meson-logs/meson-log.txt
+ meson setup --prefix=/usr /tmp/pip-install-up2xk2ks/scipy_c9d9e2ed11754f99 8ae5940b801eb8f6 /tmp/pip-install-up2xk2ks/scipy_c9d9e2ed11754f998ae5940b801eb8f 6/.mesonpy-_5gddfk5/build --native-file=/tmp/pip-install-up2xk2ks/scipy_c9d9e2ed 11754f998ae5940b801eb8f6/.mesonpy-native-file.ini -Ddebug=false -Doptimization=2
WARNING: Discarding https://files.pythonhosted.org/packages/84/a9/2bf119f3f9cff1 f376f924e39cfae18dec92a1514784046d185731301281/scipy-1.10.1.tar.gz#sha256=2cf9df b80a7b4589ba4c40ce7588986d6d5cebc5457cad2c2880f6bc2d42f3a5 (from https://pypi.or g/simple/scipy/) (requires-python:<3.12,>=3.8). Command errored out with exit status 1: /usr/bin/python3 /tmp/tmpskp_ivr4_in_process.py prepare_metadata_for_build_wheel /tmp/tmpnq5pv3xz Check the logs for full command output.
