Monitor Resolution Problems After Recent Updates on Bullseye
I have used my Raspberry Pi4 (8 gb) and Dell Ultrasharp 24 Monitor for
the past 2 months. Running Raspberry Pi OS (Bullseye arm64), I've had minimal problems.
The display ran at the preferred resolution of 1920X1080 at 60Hz. My only issue
was that the monitor would NOT actually blank after the set time and never
actually turn off at the time set in the Power Manager. Instead, the monitor
would go all black, but the LED backlighting would not actually turn off.
Two days ago I received an update, which I applied. The update and additions
consisted of the following:
linux-libc-dev,
raspberrypi-bootloader,
raspberrypi-kernel,
xserver-common,
xserver-xorg-core,
xserver-xorg-legacy.
While rebooting after the update I saw instructions briefly scroll across the
screen and then the screen went blank with no further monitor activity. I
could SSH into the Pi from another computer and perform a shutdown and edit
files. I have followed every hint that I have found on this forum, making
multiple changes to config.txt and cmdline.txt as specified. I can get the
monitor to work after a boot by using safe mode (hdmi_safe=1), in which case
the desktop comes up in 640x480. I can then go to the Display dialog under
Settings and attempt to set the resolution at 1920x1080, but to no avail. The
monitor refuses to be set to that resolution. The highest resolution that the
monitor will accept by this method is a resolution of 1280X720 at 60Hz. I have
also tried forcing the monitor by using a hdmi_group=2 and hdmi_mode=85 from
within the config.txt file. I have also tried setting various combinations of
settings from within the config.txt file with no success. I also have
attempted to set the resolution from a command within the cmdline.txt file
using 'video=HDMI-A-1:1920x1080@60D' as specified in this forum and elsewhere.
When I do this, my monitor halts during the boot process and displays a message
that 1920X1080 60Hz is not supported by the monitor and monitor goes into sleep
mode. This message is obviously in error.
I have also noticed that my mouse is ineffective more often at this higher
resolution. It often takes multiple clicks and repositioning to get a
response.
Can anyone give me other things to try, or point me in a direction.
linux-libc-dev,
raspberrypi-kernel,
xserver-common,
xserver-xorg-core,
response.
Re: Monitor Resolution Problems After Recent Updates on Bullseye
I've stopped reading here
viewtopic.php?p=2091185#p2091185
did you bother to search the forum before posting? Known bug, fixed already, so pleaee update your OS!My only issue
Can you run raspinfo and post the output?
Here it is....lots of it....had to post in 2 messages.
System Information
Raspberry Pi 4 Model B Rev 1.4
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
Raspberry Pi reference 2023-02-21
Generated using pi-gen, https://github.com/RPi-Distro/pi-gen, 25e2319effa91eb95edd9d9209eb9f8a584d67be, stage2
Linux desktop-pi 6.1.19-v8+ #1637 SMP PREEMPT Tue Mar 14 11:11:47 GMT 2023 aarch64 GNU/Linux
Revision : d03114
Serial : 10000000cca1c94f
Model : Raspberry Pi 4 Model B Rev 1.4
Throttled flag : throttled=0x0
Camera : supported=0 detected=0, libcamera interfaces=0
Videocore information
Mar 17 2023 10:50:39
Copyright (c) 2012 Broadcom
version 82f3750a65fadae9a38077e3c2e217ad158c8d54 (clean) (release) (start)
alloc failures: 0
compactions: 0
legacy block fails: 0
Filesystem information
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 126310856 12807916 108339960 11% /
devtmpfs 3774516 0 3774516 0% /dev
tmpfs 3780692 26944 3753748 1% /dev/shm
tmpfs 1512280 1452 1510828 1% /run
tmpfs 5120 4 5116 1% /run/lock
/dev/sda1 261108 31378 229730 13% /boot
tmpfs 756136 36 756100 1% /run/user/1000
Filename Type Size Used Priority
/var/swap file 102396 0 -2
Package version information
raspberrypi-ui-mods:
Installed: (none)
raspberrypi-sys-mods:
Installed: 20221019
openbox:
Installed: (none)
lxpanel:
Installed: (none)
pcmanfm:
Installed: (none)
rpd-plym-splash:
Installed: (none)
Networking Information
USB Information
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
|__ Port 2: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 3: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 3, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 4: Dev 4, If 0, Class=Hub, Driver=hub/7p, 480M
|__ Port 7: Dev 7, If 2, Class=Video, Driver=uvcvideo, 480M
|__ Port 7: Dev 7, If 0, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 7: Dev 7, If 3, Class=Video, Driver=uvcvideo, 480M
|__ Port 7: Dev 7, If 1, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 5: Dev 6, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 5: Dev 6, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 5: Dev 6, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 1: Dev 5, If 1, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 1: Dev 5, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 1: Dev 5, If 0, Class=Audio, Driver=snd-usb-audio, 12M
Display Information
Running (F)KMS and X
Screen 0: minimum 320 x 200, current 1280 x 720, maximum 7680 x 7680
HDMI-1 connected primary 1280x720+0+0 (0x52) normal (normal left inverted right x axis y axis) 527mm x 296mm
Identifier: 0x45
Timestamp: 56999
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff0010ac5d4157453344
311e010380351e78eeee95a3544c9926
0f5054a54b00714f8180a9c0d1c00101
010101010101023a801871382d40582c
45000f282100001e000000ff00483531
463632330a2020202020000000fc0044
454c4c205532343139480a20000000fd
00384c1e5311000a202020202020011f
020322f14f9005040302071601061112
1513141f23097f078301000065030c00
1000023a801871382d40582c45000f28
2100001e011d8018711c1620582c2500
0f282100009e011d007251d01e206e28
55000f282100001e8c0ad08a20e02d10
103e96000f2821000018000000000000
0000000000000000000000000000008d
Output format: Automatic
supported: Automatic, RGB, YCbCr 4:2:2, YCbCr 4:4:4
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
max bpc: 8
range: (8, 12)
bottom margin: 16
range: (0, 100)
top margin: 16
range: (0, 100)
right margin: 24
range: (0, 100)
left margin: 24
range: (0, 100)
Colorspace: Default
supported: Default, SMPTE_170M_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, DCI-P3_RGB_Theater
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 32
supported: 32
non-desktop: 0
range: (0, 1)
1920x1080 (0x48) 148.500MHz +HSync +VSync +preferred
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x49) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1080 (0x4a) 148.352MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080i (0x4b) 74.250MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.75KHz
v: height 1080 start 1084 end 1094 total 1125 clock 60.00Hz
1920x1080i (0x4c) 74.250MHz +HSync +VSync Interlace
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 28.12KHz
v: height 1080 start 1084 end 1094 total 1125 clock 50.00Hz
1920x1080i (0x4d) 74.176MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.72KHz
v: height 1080 start 1084 end 1094 total 1125 clock 59.94Hz
1600x900 (0x4e) 108.000MHz +HSync +VSync
h: width 1600 start 1624 end 1704 total 1800 skew 0 clock 60.00KHz
v: height 900 start 901 end 904 total 1000 clock 60.00Hz
1280x1024 (0x4f) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x50) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1152x864 (0x51) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1280x720 (0x52) 74.250MHz +HSync +VSync *current
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x53) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1280x720 (0x54) 74.176MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1024x768 (0x55) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x56) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x57) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x58) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x576 (0x59) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x576i (0x5a) 13.500MHz -HSync -VSync Interlace
h: width 720 start 732 end 795 total 864 skew 0 clock 15.62KHz
v: height 576 start 580 end 586 total 625 clock 50.00Hz
720x480 (0x5b) 27.027MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.50KHz
v: height 480 start 489 end 495 total 525 clock 60.00Hz
720x480 (0x5c) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
720x480i (0x5d) 13.514MHz -HSync -VSync Interlace
h: width 720 start 739 end 801 total 858 skew 0 clock 15.75KHz
v: height 480 start 488 end 494 total 525 clock 60.00Hz
720x480i (0x5e) 13.500MHz -HSync -VSync Interlace
h: width 720 start 739 end 801 total 858 skew 0 clock 15.73KHz
v: height 480 start 488 end 494 total 525 clock 59.94Hz
640x480 (0x5f) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x60) 25.200MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.50KHz
v: height 480 start 490 end 492 total 525 clock 60.00Hz
640x480 (0x61) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
720x400 (0x62) 28.320MHz -HSync +VSync
h: width 720 start 738 end 846 total 900 skew 0 clock 31.47KHz
v: height 400 start 412 end 414 total 449 clock 70.08Hz
HDMI-2 connected 640x480+0+0 (0x63) normal (normal left inverted right x axis y axis) 0mm x 0mm
Identifier: 0x46
Timestamp: 56999
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 4
CRTCs: 4
filter:
max bpc: 8
range: (8, 12)
bottom margin: 16
range: (0, 100)
top margin: 16
range: (0, 100)
right margin: 24
range: (0, 100)
left margin: 24
range: (0, 100)
Colorspace: Default
link-status: Good
CONNECTOR_ID: 42
supported: 42
non-desktop: 0
range: (0, 1)
640x480 (0x63) 23.975MHz -HSync +VSync *current
h: width 640 start 664 end 720 total 800 skew 0 clock 29.97KHz
v: height 480 start 483 end 487 total 500 clock 59.94Hz
Connector 0 (32) HDMI-A-1 (connected)
Encoder 0 (31) TMDS
Crtc 3 (96) 1280x720@60.00 74.250 1280/110/40/220/+ 720/5/5/20/+ 60 (60.00)
Plane 3 (86) fb-id: 340 (crtcs: 3) 0,0 1280x720 -> 0,0 1280x720 (XR24 AR24 AB24 XB24 RG16 BG16 AR15 XR15 RG24 BG24 YU16 YV16 YU24 YV24 YU12 YV12 NV12 NV21 NV16 NV61 P030 XR30 AR30 AB30 XB30 RGB8 BGR8 XR12 AR12 XB12 AB12 BX12 BA12 RX12 RA12)
FB 340 1280x720 XR24
Plane 25 (309) fb-id: 343 (crtcs: 3) 0,0 64x64 -> 759,257 64x64 (XR24 AR24 AB24 XB24 RG16 BG16 AR15 XR15 RG24 BG24 YU16 YV16 YU24 YV24 YU12 YV12 NV12 NV21 NV16 NV61 P030 XR30 AR30 AB30 XB30 RGB8 BGR8 XR12 AR12 XB12 AB12 BX12 BA12 RX12 RA12)
FB 343 64x64 AR24
Connector 1 (42) HDMI-A-2 (connected)
Encoder 1 (41) TMDS
0 1920x1080@60.00 148.500 1920/88/44/148/+ 1080/4/5/36/+ 60 (60.00) P|D
1 1920x1080@60.00 148.500 1920/88/44/148/+ 1080/4/5/36/+ 60 (60.00) D 16:9
2 1920x1080@59.94 148.352 1920/88/44/148/+ 1080/4/5/36/+ 60 (59.94) D 16:9
3 1920x1080i@60.00 74.250 1920/88/44/148/+ 1080/4/10/31/+ 60 (60.00) D
4 1920x1080i@60.00 74.250 1920/88/44/148/+ 1080/4/10/31/+ 60 (60.00) D 16:9
5 1920x1080i@59.94 74.176 1920/88/44/148/+ 1080/4/10/31/+ 60 (59.94) D 16:9
6 1920x1080@50.00 148.500 1920/528/44/148/+ 1080/4/5/36/+ 50 (50.00) D 16:9
7 1920x1080i@50.00 74.250 1920/528/44/148/+ 1080/4/10/31/+ 50 (50.00) D 16:9
8 1600x900@60.00 108.000 1600/24/80/96/+ 900/1/3/96/+ 60 (60.00) D
9 1280x1024@75.02 135.000 1280/16/144/248/+ 1024/1/3/38/+ 75 (75.02) D
10 1280x1024@60.02 108.000 1280/48/112/248/+ 1024/1/3/38/+ 60 (60.02) D
11 1152x864@75.00 108.000 1152/64/128/256/+ 864/1/3/32/+ 75 (75.00) D
12 1280x720@60.00 74.250 1280/110/40/220/+ 720/5/5/20/+ 60 (60.00) D
13 1280x720@60.00 74.250 1280/110/40/220/+ 720/5/5/20/+ 60 (60.00) D 16:9
14 1280x720@59.94 74.176 1280/110/40/220/+ 720/5/5/20/+ 60 (59.94) D 16:9
15 1280x720@50.00 74.250 1280/440/40/220/+ 720/5/5/20/+ 50 (50.00) D 16:9
16 1024x768@75.03 78.750 1024/16/96/176/+ 768/1/3/28/+ 75 (75.03) D
17 1024x768@60.00 65.000 1024/24/136/160/- 768/3/6/29/- 60 (60.00) D
18 800x600@75.00 49.500 800/16/80/160/+ 600/1/3/21/+ 75 (75.00) D
19 800x600@60.32 40.000 800/40/128/88/+ 600/1/4/23/+ 60 (60.32) D
20 720x576@50.00 27.000 720/12/64/68/- 576/5/5/39/- 50 (50.00) D 4:3
21 720x576@50.00 27.000 720/12/64/68/- 576/5/5/39/- 50 (50.00) D 16:9
22 720x576i@50.00 13.500 720/12/63/69/- 576/4/6/39/- 50 (50.00) D 2x|16:9
23 720x576i@50.00 13.500 720/12/63/69/- 576/4/6/39/- 50 (50.00) D 2x|4:3
24 720x480@60.00 27.027 720/16/62/60/- 480/9/6/30/- 60 (60.00) D 4:3
25 720x480@60.00 27.027 720/16/62/60/- 480/9/6/30/- 60 (60.00) D 16:9
26 720x480@59.94 27.000 720/16/62/60/- 480/9/6/30/- 60 (59.94) D
27 720x480@59.94 27.000 720/16/62/60/- 480/9/6/30/- 60 (59.94) D 16:9
28 720x480@59.94 27.000 720/16/62/60/- 480/9/6/30/- 60 (59.94) D 4:3
29 720x480i@60.00 13.514 720/19/62/57/- 480/8/6/31/- 60 (60.00) D 2x|16:9
30 720x480i@60.00 13.514 720/19/62/57/- 480/8/6/31/- 60 (60.00) D 2x|4:3
31 720x480i@59.94 13.500 720/19/62/57/- 480/8/6/31/- 60 (59.94) D 2x|16:9
32 720x480i@59.94 13.500 720/19/62/57/- 480/8/6/31/- 60 (59.94) D 2x|4:3
33 640x480@75.00 31.500 640/16/64/120/- 480/1/3/16/- 75 (75.00) D
34 640x480@60.00 25.200 640/16/96/48/- 480/10/2/33/- 60 (60.00) D 4:3
35 640x480@59.94 25.175 640/16/96/48/- 480/10/2/33/- 60 (59.94) U|D
36 640x480@59.94 25.175 640/16/96/48/- 480/10/2/33/- 60 (59.94) D 4:3
37 720x400@70.08 28.320 720/18/108/54/- 400/12/2/35/+ 70 (70.08) D
0 640x480@59.94 23.975 640/24/56/80/- 480/3/4/13/+ 60 (59.94) U
Part 2:
[/code]
HDMI0: HDMI_HOTPLUG = 0x00000001
HDMI1: HDMI_HOTPLUG = 0x00000000
/sys/kernel/debug/dri/1/state:
plane[47]: plane-0
crtc=(null)
fb=0
crtc-pos=0x0+0+0
src-pos=0.000000x0.000000+0.000000+0.000000
rotation=1
normalized-zpos=0
color-encoding=ITU-R BT.709 YCbCr
color-range=YCbCr limited range
plane[64]: plane-1
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=0
plane[75]: plane-2
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=0
plane[86]: plane-3
crtc=pixelvalve-2
fb=340
allocated by = Xorg
refcount=2
format=XR24 little-endian (0x34325258)
modifier=0x0
size=1280x720
layers:
size[0]=1280x720
pitch[0]=5120
offset[0]=0
obj[0]:
name=0
refcount=3
start=00100b3a
size=3686400
imported=no
dma_addr=0x00000000c2c00000
vaddr=000000005c8fdc3b
crtc-pos=1280x720+0+0
src-pos=1280.000000x720.000000+0.000000+0.000000
rotation=1
normalized-zpos=0
plane[97]: plane-4
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=0
plane[108]: plane-5
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=0
plane[119]: plane-6
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=1
plane[129]: plane-7
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=2
plane[139]: plane-8
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=3
plane[149]: plane-9
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=4
plane[159]: plane-10
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=5
plane[169]: plane-11
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=6
plane[179]: plane-12
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=7
plane[189]: plane-13
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=8
plane[199]: plane-14
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=9
plane[209]: plane-15
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=a
plane[219]: plane-16
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=b
plane[229]: plane-17
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=c
plane[239]: plane-18
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=d
plane[249]: plane-19
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=e
plane[259]: plane-20
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=f
plane[269]: plane-21
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=10
plane[279]: plane-22
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=11
plane[289]: plane-23
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=11
plane[299]: plane-24
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=11
plane[309]: plane-25
crtc=pixelvalve-2
fb=343
allocated by = Xorg
refcount=1
format=AR24 little-endian (0x34325241)
modifier=0x0
size=64x64
layers:
size[0]=64x64
pitch[0]=256
offset[0]=0
obj[0]:
name=0
refcount=3
start=001001ce
size=16384
imported=no
dma_addr=0x00000000df850000
vaddr=00000000c4fce24c
crtc-pos=64x64+759+257
src-pos=64.000000x64.000000+0.000000+0.000000
rotation=1
normalized-zpos=1
plane[319]: plane-26
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=11
plane[329]: plane-27
crtc=(null)
fb=0
crtc-pos=0x0+0+0
rotation=1
normalized-zpos=11
crtc[57]: txp
enable=0
active=0
self_refresh_active=0
planes_changed=0
mode_changed=0
active_changed=0
connectors_changed=0
color_mgmt_changed=0
plane_mask=0
connector_mask=0
encoder_mask=0
mode: "": 0 0 0 0 0 0 0 0 0 0 0x0 0x0
crtc[74]: pixelvalve-0
enable=0
active=0
planes_changed=0
mode_changed=0
active_changed=0
plane_mask=0
connector_mask=0
encoder_mask=0
crtc[85]: pixelvalve-1
enable=0
active=0
planes_changed=0
mode_changed=0
active_changed=0
plane_mask=0
connector_mask=0
encoder_mask=0
crtc[96]: pixelvalve-2
enable=1
active=1
planes_changed=1
mode_changed=0
active_changed=0
plane_mask=2000008
connector_mask=1
encoder_mask=1
mode: "": 60 74250 1280 1390 1430 1650 720 725 730 750 0x0 0x5
crtc[107]: pixelvalve-4
enable=0
active=0
planes_changed=0
mode_changed=0
active_changed=0
plane_mask=0
connector_mask=0
encoder_mask=0
crtc[118]: pixelvalve-3
enable=0
active=0
planes_changed=0
mode_changed=0
active_changed=0
plane_mask=0
connector_mask=0
encoder_mask=0
connector[32]: HDMI-A-1
crtc=pixelvalve-2
self_refresh_aware=0
connector[42]: HDMI-A-2
crtc=(null)
connector[63]: Writeback-1
crtc=(null)
config.txt
arm_64bit=1
arm_boost=1
arm_freq=1800
audio_pwm_mode=514
camera_auto_detect=1
config_hdmi_boost=5
core_freq=500
core_freq_min=200
disable_commandline_tags=2
disable_l2cache=1
display_auto_detect=1
display_hdmi_rotate=-1
display_lcd_rotate=-1
dvfs=3
enable_gic=1
enable_uart=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=500
gpu_freq_min=250
hdmi_safe=1
init_uart_clock=0x2dc6c00
lcd_framerate=60
mask_gpu_interrupt0=3072
mask_gpu_interrupt1=25635
max_framebuffers=2
over_voltage_avs=-20000
overscan_bottom=16
overscan_left=24
overscan_right=24
overscan_top=16
pause_burst_frames=1
program_serial_random=1
total_mem=8192
hdmi_drive:0=2
hdmi_force_cec_address:0=65535
hdmi_force_cec_address:1=65535
hdmi_force_hotplug:0=1
hdmi_force_hotplug:1=1
hdmi_group:0=2
hdmi_group:1=2
hdmi_mode:0=4
hdmi_mode:1=4
hdmi_pixel_freq_limit:0=0x11e1a300
hdmi_pixel_freq_limit:1=0x11e1a300
device_tree=-
overlay_prefix=overlays/
hdmi_cvt:0=
hdmi_cvt:1=
hdmi_edid_filename:0=
hdmi_edid_filename:1=
hdmi_timings:0=
hdmi_timings:1=
cmdline.txt
coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:640x480M@60D,margin_left=24,margin_right=24,margin_top=16,margin_bottom=16 video=HDMI-A-2:640x480M@60D,margin_left=24,margin_right=24,margin_top=16,margin_bottom=16 smsc95xx.macaddr=DC:A6:32:CC:FE:52 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=tty1 root=PARTUUID=65037d67-02 rootfstype=ext4 fsck.repair=yes rootwait
raspi-gpio settings
BANK0 (GPIO 0 to 27):
GPIO 0: level=1 fsel=0 func=INPUT pull=UP
GPIO 1: level=1 fsel=0 func=INPUT pull=UP
GPIO 2: level=1 fsel=4 alt=0 func=SDA1 pull=UP
GPIO 3: level=1 fsel=4 alt=0 func=SCL1 pull=UP
GPIO 4: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 5: level=1 fsel=0 func=INPUT pull=UP
GPIO 6: level=1 fsel=0 func=INPUT pull=UP
GPIO 7: level=1 fsel=0 func=INPUT pull=UP
GPIO 8: level=1 fsel=0 func=INPUT pull=UP
GPIO 9: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 10: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 11: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 12: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 13: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 14: level=1 fsel=2 alt=5 func=TXD1 pull=NONE
GPIO 15: level=1 fsel=2 alt=5 func=RXD1 pull=UP
GPIO 16: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 17: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 18: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 19: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 20: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 21: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 22: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 23: level=1 fsel=0 func=INPUT pull=DOWN
GPIO 24: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 25: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 26: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 27: level=0 fsel=0 func=INPUT pull=DOWN
BANK1 (GPIO 28 to 45):
GPIO 28: level=1 fsel=2 alt=5 func=RGMII_MDIO pull=UP
GPIO 29: level=0 fsel=2 alt=5 func=RGMII_MDC pull=DOWN
GPIO 30: level=0 fsel=7 alt=3 func=CTS0 pull=UP
GPIO 31: level=0 fsel=7 alt=3 func=RTS0 pull=NONE
GPIO 32: level=1 fsel=7 alt=3 func=TXD0 pull=NONE
GPIO 33: level=1 fsel=7 alt=3 func=RXD0 pull=UP
GPIO 34: level=0 fsel=7 alt=3 func=SD1_CLK pull=NONE
GPIO 35: level=1 fsel=7 alt=3 func=SD1_CMD pull=UP
GPIO 36: level=1 fsel=7 alt=3 func=SD1_DAT0 pull=UP
GPIO 37: level=1 fsel=7 alt=3 func=SD1_DAT1 pull=UP
GPIO 38: level=1 fsel=7 alt=3 func=SD1_DAT2 pull=UP
GPIO 39: level=1 fsel=7 alt=3 func=SD1_DAT3 pull=UP
GPIO 40: level=0 fsel=4 alt=0 func=PWM1_0 pull=NONE
GPIO 41: level=1 fsel=4 alt=0 func=PWM1_1 pull=NONE
GPIO 42: level=0 fsel=1 func=OUTPUT pull=UP
GPIO 43: level=1 fsel=0 func=INPUT pull=UP
GPIO 44: level=1 fsel=0 func=INPUT pull=UP
GPIO 45: level=1 fsel=0 func=INPUT pull=UP
BANK2 (GPIO 46 to 53):
GPIO 46: level=0 fsel=0 func=INPUT pull=UP
GPIO 47: level=0 fsel=0 func=INPUT pull=UP
GPIO 48: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 49: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 50: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 51: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 52: level=0 fsel=0 func=INPUT pull=DOWN
GPIO 53: level=0 fsel=0 func=INPUT pull=DOWN
vcdbg log messages
006493.852: brfs: File read: /mfs/sd/config.txt
006494.878: brfs: File read: 2180 bytes
006575.085: HDMI1:EDID error reading EDID block 0 attempt 0
006576.099: HDMI1:EDID giving up on reading EDID block 0
006577.207: brfs: File read: /mfs/sd/config.txt
007384.990: gpioman: gpioman_get_pin_num: pin DISPLAY_DSI_PORT not defined
007387.510: *** Restart logging
007387.530: brfs: File read: 2180 bytes
007451.252: hdmi: HDMI1:EDID error reading EDID block 0 attempt 0
007452.266: hdmi: HDMI1:EDID giving up on reading EDID block 0
007457.309: hdmi: HDMI1:EDID error reading EDID block 0 attempt 0
007458.326: hdmi: HDMI1:EDID giving up on reading EDID block 0
007464.590: HDMI0: hdmi_pixel_encoding: 300000000
007464.603: HDMI1: hdmi_pixel_encoding: 300000000
007465.296: kernel=
007470.025: dtb_file 'bcm2711-rpi-4-b.dtb'
007472.738: brfs: File read: /mfs/sd/bcm2711-rpi-4-b.dtb
007472.755: Loaded 'bcm2711-rpi-4-b.dtb' to 0x100 size 0xcd71
007485.928: brfs: File read: 52593 bytes
007493.259: brfs: File read: /mfs/sd/overlays/overlay_map.dtb
007574.295: brfs: File read: 2347 bytes
007575.415: brfs: File read: /mfs/sd/config.txt
007575.828: dtparam: i2c_arm=on
007584.699: dtparam: audio=on
007589.285: brfs: File read: 2180 bytes
007599.544: brfs: File read: /mfs/sd/overlays/vc4-kms-v3d-pi4.dtbo
007661.753: Loaded overlay 'vc4-kms-v3d'
007865.321: brfs: File read: 3913 bytes
007867.293: brfs: File read: /mfs/sd/cmdline.txt
007867.352: Read command line from file 'cmdline.txt':
007867.374: 'console=tty1 root=PARTUUID=65037d67-02 rootfstype=ext4 fsck.repair=yes rootwait'
008021.660: brfs: File read: 81 bytes
008318.698: brfs: File read: /mfs/sd/kernel8.img
008318.720: Loaded 'kernel8.img' to 0x80000 size 0x7d6b1b
009491.920: Kernel relocated to 0x200000
009491.933: Device tree loaded to 0x1fee2a00 (size 0xd58a)
009496.279: bfs_xhci_stop
009496.285: XHCI-STOP
009496.370: xHC ver: 256 HCS: 05000420 fc000031 00e70004 HCC: 002841eb
009496.386: USBSTS 18
011859.893: vchiq_core: vchiq_init_state: slot_zero = 0xdf800000, is_master = 1
011866.467: TV service:host side not connected, dropping notification 0x00000002, 0x00000002, 0x00000004
011866.487: TV service:host side not connected, dropping notification 0x00000002, 0x00000002, 0x00000004
dmesg log
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 6.1.19-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1637 SMP PREEMPT Tue Mar 14 11:11:47 GMT 2023
[ 0.000000] random: crng init done
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.4
[ 0.000000] efi: UEFI not found.
[ 0.000000] OF: reserved mem: failed to allocate memory for node 'linux,cma': size 512 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff]
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000001fefffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[ 0.000000] On node 0, zone DMA32: 256 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] cma: Reserved 8 MiB at 0x000000001f400000
[ 0.000000] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
[ 0.000000] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1918724
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:640x480M@60D,margin_left=24,margin_right=24,margin_top=16,margin_bottom=16 video=HDMI-A-2:640x480M@60D,margin_left=24,margin_right=24,margin_top=16,margin_bottom=16 smsc95xx.macaddr=m.m.m.m vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=tty1 root=PARTUUID=65037d67-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x000000001b400000-0x000000001f400000] (64MB)
[ 0.000000] Memory: 7549036K/7797760K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 240532K reserved, 8192K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 39741 entries in 156 pages
[ 0.000000] ftrace: allocated 156 pages with 4 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000305] Console: colour dummy device 80x25
[ 0.000942] printk: console [tty1] enabled
[ 0.001022] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[ 0.001065] pid_max: default: 32768 minimum: 301
[ 0.001212] LSM: Security Framework initializing
[ 0.001466] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001579] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.002858] cgroup: Disabling memory control group subsystem
[ 0.005141] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.005177] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.005376] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.005572] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.006039] rcu: Hierarchical SRCU implementation.
[ 0.006064] rcu: Max phase no-delay instances is 1000.
[ 0.007411] EFI services will not be available.
[ 0.008036] smp: Bringing up secondary CPUs ...
[ 0.009146] Detected PIPT I-cache on CPU1
[ 0.009296] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.010473] Detected PIPT I-cache on CPU2
[ 0.010600] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.011743] Detected PIPT I-cache on CPU3
[ 0.011866] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.012068] smp: Brought up 1 node, 4 CPUs
[ 0.012160] SMP: Total of 4 processors activated.
[ 0.012182] CPU features: detected: 32-bit EL0 Support
[ 0.012202] CPU features: detected: 32-bit EL1 Support
[ 0.012225] CPU features: detected: CRC32 instructions
[ 0.012368] CPU: All CPU(s) started at EL2
[ 0.012402] alternatives: applying system-wide alternatives
[ 0.014321] devtmpfs: initialized
[ 0.026744] Enabled cp15_barrier support
[ 0.026808] Enabled setend support
[ 0.027042] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.027094] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.027730] pinctrl core: initialized pinctrl subsystem
[ 0.028597] DMI not present or invalid.
[ 0.029284] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.032844] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.033173] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.034183] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.034294] audit: initializing netlink subsys (disabled)
[ 0.034577] audit: type=2000 audit(0.032:1): state=initialized audit_enabled=0 res=1
[ 0.035170] thermal_sys: Registered thermal governor 'step_wise'
[ 0.035264] cpuidle: using governor menu
[ 0.035691] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.035911] ASID allocator initialised with 32768 entries
[ 0.036123] Serial: AMBA PL011 UART driver
[ 0.051369] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.076212] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
[ 0.080234] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
[ 0.096712] KASLR enabled
[ 0.132148] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.138200] SCSI subsystem initialized
[ 0.138490] usbcore: registered new interface driver usbfs
[ 0.138565] usbcore: registered new interface driver hub
[ 0.138647] usbcore: registered new device driver usb
[ 0.139081] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.139317] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.139708] pps_core: LinuxPPS API ver. 1 registered
[ 0.139733] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.139775] PTP clock support registered
[ 0.140896] vgaarb: loaded
[ 0.141688] clocksource: Switched to clocksource arch_sys_counter
[ 0.142364] VFS: Disk quotas dquot_6.6.0
[ 0.142459] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.142668] FS-Cache: Loaded
[ 0.142842] CacheFiles: Loaded
[ 0.152538] NET: Registered PF_INET protocol family
[ 0.153595] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.162598] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.162727] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.162774] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.163189] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.165805] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.166075] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.166205] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.166570] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.167416] RPC: Registered named UNIX socket transport module.
[ 0.167448] RPC: Registered udp transport module.
[ 0.167468] RPC: Registered tcp transport module.
[ 0.167488] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.167524] PCI: CLS 0 bytes, default 64
[ 0.170302] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.170708] kvm [1]: IPA Size Limit: 44 bits
[ 0.172049] kvm [1]: vgic interrupt IRQ9
[ 0.172306] kvm [1]: Hyp mode initialized successfully
[ 1.253010] Initialise system trusted keyrings
[ 1.253477] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.261255] zbud: loaded
[ 1.264229] NFS: Registering the id_resolver key type
[ 1.264287] Key type id_resolver registered
[ 1.264309] Key type id_legacy registered
[ 1.264451] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.264481] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.265926] Key type asymmetric registered
[ 1.265958] Asymmetric key parser 'x509' registered
[ 1.266051] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.266344] io scheduler mq-deadline registered
[ 1.266374] io scheduler kyber registered
[ 1.268305] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)
[ 1.276630] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.276696] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.276805] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.276919] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
[ 1.278221] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.278257] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.278287] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.278378] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.278657] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.282496] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.282802] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
[ 1.283011] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
[ 1.283155] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
[ 1.347786] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.347893] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.347977] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.348266] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.348801] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.348857] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.348894] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.348952] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.348985] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.350100] simple-framebuffer 3e9f1000.framebuffer: framebuffer at 0x3e9f1000, 0x103000 bytes
[ 1.350138] simple-framebuffer 3e9f1000.framebuffer: format=a8r8g8b8, mode=592x448x32, linelength=2368
[ 1.351733] Console: switching to colour frame buffer device 74x28
[ 1.352936] simple-framebuffer 3e9f1000.framebuffer: fb0: simplefb registered!
[ 1.361220] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 1.365476] iproc-rng200 fe104000.rng: hwrng registered
[ 1.366890] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
[ 1.370120] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.384846] brd: module loaded
[ 1.394620] loop: module loaded
[ 1.396269] Loading iSCSI transport class v2.0-870.
[ 1.402661] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.461846] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.463812] usbcore: registered new interface driver r8152
[ 1.464671] usbcore: registered new interface driver lan78xx
[ 1.465481] usbcore: registered new interface driver smsc95xx
[ 1.512079] pci 0000:00:00.0: enabling device (0000 -> 0002)
[ 1.512990] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.513776] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.515879] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000e40000000890
[ 1.518315] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.519040] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.520399] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.521485] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 1.522878] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.524248] usb usb1: Product: xHCI Host Controller
[ 1.524962] usb usb1: Manufacturer: Linux 6.1.19-v8+ xhci-hcd
[ 1.525702] usb usb1: SerialNumber: 0000:01:00.0
[ 1.527168] hub 1-0:1.0: USB hub found
[ 1.527975] hub 1-0:1.0: 1 port detected
[ 1.529767] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 1.531157] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.532634] usb usb2: Product: xHCI Host Controller
[ 1.533395] usb usb2: Manufacturer: Linux 6.1.19-v8+ xhci-hcd
[ 1.534189] usb usb2: SerialNumber: 0000:01:00.0
[ 1.535660] hub 2-0:1.0: USB hub found
[ 1.536478] hub 2-0:1.0: 4 ports detected
[ 1.539126] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.540210] dwc_otg: FIQ enabled
[ 1.540222] dwc_otg: NAK holdoff enabled
[ 1.540233] dwc_otg: FIQ split-transaction FSM enabled
[ 1.540250] Module dwc_common_port init
[ 1.540833] usbcore: registered new interface driver uas
[ 1.541707] usbcore: registered new interface driver usb-storage
[ 1.542623] mousedev: PS/2 mouse device common for all mice
[ 1.551333] sdhci: Secure Digital Host Controller Interface driver
[ 1.552048] sdhci: Copyright(c) Pierre Ossman
[ 1.553456] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.557997] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.559111] hid: raw HID events driver (C) Jiri Kosina
[ 1.559939] usbcore: registered new interface driver usbhid
[ 1.560599] usbhid: USB HID core driver
[ 1.570077] NET: Registered PF_PACKET protocol family
[ 1.570921] Key type dns_resolver registered
[ 1.573020] registered taskstats version 1
[ 1.573806] Loading compiled-in X.509 certificates
[ 1.575300] Key type .fscrypt registered
[ 1.575935] Key type fscrypt-provisioning registered
[ 1.592666] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.594682] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.595487] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.605095] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
[ 1.607449] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, base_baud = 62500000) is a 16550
[ 1.610504] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.611707] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.614559] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.615343] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.651920] mmc1: Controller never released inhibit bit(s).
[ 1.656937] of_cfs_init
[ 1.657899] of_cfs_init: OK
[ 1.691796] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.693712] Waiting for root device PARTUUID=65037d67-02...
[ 1.743076] mmc1: new high speed SDIO card at address 0001
[ 1.781725] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.932328] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.933891] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.935426] usb 1-1: Product: USB2.0 Hub
[ 1.938016] hub 1-1:1.0: USB hub found
[ 1.939050] hub 1-1:1.0: 4 ports detected
[ 2.058024] usb 2-2: new SuperSpeed USB device number 2 using xhci_hcd
[ 2.079176] usb 2-2: New USB device found, idVendor=2537, idProduct=1068, bcdDevice= 1.00
[ 2.080585] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.082019] usb 2-2: Product: NS1068
[ 2.082728] usb 2-2: Manufacturer: Norelsys
[ 2.083435] usb 2-2: SerialNumber: 0123456789ABCDE
[ 2.086825] usb-storage 2-2:1.0: USB Mass Storage device detected
[ 2.088131] usb-storage 2-2:1.0: Quirks match for vid 2537 pid 1068: 800000
[ 2.089724] scsi host0: usb-storage 2-2:1.0
[ 2.233721] usb 1-1.3: new low-speed USB device number 3 using xhci_hcd
[ 2.388610] usb 1-1.3: New USB device found, idVendor=2516, idProduct=0004, bcdDevice= 0.01
[ 2.390045] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.391449] usb 1-1.3: Product: QuickFire Rapid keyboard
[ 2.392166] usb 1-1.3: Manufacturer: CM Storm
[ 2.412950] input: CM Storm QuickFire Rapid keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:2516:0004.0001/input/input0
[ 2.474379] hid-generic 0003:2516:0004.0001: input,hidraw0: USB HID v1.10 Keyboard [CM Storm QuickFire Rapid keyboard] on usb-0000:01:00.0-1.3/input0
[ 2.511269] input: CM Storm QuickFire Rapid keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:2516:0004.0002/input/input1
[ 2.570016] input: CM Storm QuickFire Rapid keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:2516:0004.0002/input/input2
[ 2.572781] hid-generic 0003:2516:0004.0002: input,hidraw1: USB HID v1.10 Device [CM Storm QuickFire Rapid keyboard] on usb-0000:01:00.0-1.3/input1
[ 2.653721] usb 1-1.4: new high-speed USB device number 4 using xhci_hcd
[ 2.754105] usb 1-1.4: New USB device found, idVendor=2001, idProduct=f103, bcdDevice= 1.00
[ 2.755830] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.759059] hub 1-1.4:1.0: USB hub found
[ 2.760062] hub 1-1.4:1.0: 7 ports detected
[ 3.049721] usb 1-1.4.1: new full-speed USB device number 5 using xhci_hcd
[ 3.153944] usb 1-1.4.1: New USB device found, idVendor=0c76, idProduct=1468, bcdDevice= 1.00
[ 3.155636] usb 1-1.4.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.157308] usb 1-1.4.1: Product: KLIM Talk
[ 3.164992] input: KLIM Talk as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.2/0003:0C76:1468.0003/input/input3
[ 3.226075] hid-generic 0003:0C76:1468.0003: input,hidraw2: USB HID v1.00 Device [KLIM Talk] on usb-0000:01:00.0-1.4.1/input2
[ 3.305721] usb 1-1.4.5: new full-speed USB device number 6 using xhci_hcd
[ 3.413602] usb 1-1.4.5: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.07
[ 3.415287] usb 1-1.4.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.416935] usb 1-1.4.5: Product: USB Receiver
[ 3.417778] usb 1-1.4.5: Manufacturer: Logitech
[ 3.429024] input: Logitech USB Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.5/1-1.4.5:1.0/0003:046D:C52B.0004/input/input4
[ 3.490615] hid-generic 0003:046D:C52B.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.4.5/input0
[ 3.499453] input: Logitech USB Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.5/1-1.4.5:1.1/0003:046D:C52B.0005/input/input5
[ 3.502523] input: Logitech USB Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.5/1-1.4.5:1.1/0003:046D:C52B.0005/input/input6
[ 3.562007] input: Logitech USB Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.5/1-1.4.5:1.1/0003:046D:C52B.0005/input/input7
[ 3.565146] hid-generic 0003:046D:C52B.0005: input,hiddev96,hidraw4: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.4.5/input1
[ 3.574010] hid-generic 0003:046D:C52B.0006: hiddev97,hidraw5: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.4.5/input2
[ 3.626014] scsi 0:0:0:0: Direct-Access ATA Samsung SSD 870 2B6Q PQ: 0 ANSI: 6
[ 3.629082] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[ 3.631600] sd 0:0:0:0: [sda] Write Protect is off
[ 3.632492] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 3.633221] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 3.638573] sda: sda1 sda2
[ 3.639919] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.653737] usb 1-1.4.7: new high-speed USB device number 7 using xhci_hcd
[ 3.660582] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
[ 3.662345] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
[ 3.665816] devtmpfs: mounted
[ 3.674790] Freeing unused kernel memory: 4160K
[ 3.675802] Run /sbin/init as init process
[ 3.676590] with arguments:
[ 3.676600] /sbin/init
[ 3.676610] with environment:
[ 3.676619] HOME=/
[ 3.676630] TERM=linux
[ 3.837226] systemd[1]: System time before build time, advancing clock.
[ 3.989199] NET: Registered PF_INET6 protocol family
[ 3.991949] Segment Routing with IPv6
[ 3.992779] In-situ OAM (IOAM) with IPv6
[ 4.008410] usb 1-1.4.7: New USB device found, idVendor=046d, idProduct=081d, bcdDevice= 0.10
[ 4.009982] usb 1-1.4.7: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 4.011496] usb 1-1.4.7: SerialNumber: 6F9B83A0
[ 4.046090] systemd[1]: systemd 247.3-7+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 4.050267] systemd[1]: Detected architecture arm64.
[ 4.059478] systemd[1]: Set hostname to <desktop-pi>.
[ 4.635174] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[ 4.753213] systemd[1]: /lib/systemd/system/clamav-freshclam.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 4.781366] systemd[1]: Queued start job for default target Graphical Interface.
[ 4.799424] systemd[1]: Created slice system-getty.slice.
[ 4.802934] systemd[1]: Created slice system-modprobe.slice.
[ 4.805987] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 4.808760] systemd[1]: Created slice User and Session Slice.
[ 4.811261] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.815323] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.818688] systemd[1]: Reached target Slices.
[ 4.820774] systemd[1]: Reached target Swap.
[ 4.826193] systemd[1]: Listening on Syslog Socket.
[ 4.828981] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 4.832137] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 4.835373] systemd[1]: Listening on Journal Audit Socket.
[ 4.838210] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.841138] systemd[1]: Listening on Journal Socket.
[ 4.846962] systemd[1]: Listening on udev Control Socket.
[ 4.849861] systemd[1]: Listening on udev Kernel Socket.
[ 4.852649] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 4.874200] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.881075] systemd[1]: Mounting RPC Pipe File System...
[ 4.888834] systemd[1]: Mounting Kernel Debug File System...
[ 4.896776] systemd[1]: Mounting Kernel Trace File System...
[ 4.899650] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 4.906936] systemd[1]: Starting Restore / save the current clock...
[ 4.914140] systemd[1]: Starting Set the console keyboard layout...
[ 4.921836] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 4.930510] systemd[1]: Starting Load Kernel Module configfs...
[ 4.938739] systemd[1]: Starting Load Kernel Module drm...
[ 4.948964] systemd[1]: Starting Load Kernel Module fuse...
[ 4.956781] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 4.966567] systemd[1]: Starting File System Check on Root Device...
[ 4.979620] systemd[1]: Starting Journal Service...
[ 4.990588] systemd[1]: Starting Load Kernel Modules...
[ 4.998280] systemd[1]: Starting Coldplug All udev Devices...
[ 5.011611] systemd[1]: Starting Uncomplicated firewall...
[ 5.040902] fuse: init (API version 7.37)
[ 5.067868] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.072361] systemd[1]: Mounted RPC Pipe File System.
[ 5.081374] systemd[1]: Mounted Kernel Debug File System.
[ 5.088773] systemd[1]: Mounted Kernel Trace File System.
[ 5.100275] i2c_dev: i2c /dev entries driver
[ 5.104135] systemd[1]: Finished Restore / save the current clock.
[ 5.110451] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 5.127978] systemd[1]: modprobe@configfs.service: Succeeded.
[ 5.135561] systemd[1]: Finished Load Kernel Module configfs.
[ 5.141037] systemd[1]: modprobe@drm.service: Succeeded.
[ 5.143814] systemd[1]: Finished Load Kernel Module drm.
[ 5.147767] systemd[1]: modprobe@fuse.service: Succeeded.
[ 5.150158] systemd[1]: Finished Load Kernel Module fuse.
[ 5.155243] systemd[1]: Finished Load Kernel Modules.
[ 5.182586] systemd[1]: Mounting FUSE Control File System...
[ 5.189989] systemd[1]: Mounting Kernel Configuration File System...
[ 5.198534] systemd[1]: Started File System Check Daemon to report status.
[ 5.220992] systemd[1]: Starting Apply Kernel Variables...
[ 5.248890] systemd[1]: Mounted FUSE Control File System.
[ 5.259657] systemd[1]: Mounted Kernel Configuration File System.
[ 5.324370] systemd[1]: Finished Apply Kernel Variables.
[ 5.364745] systemd[1]: Finished File System Check on Root Device.
[ 5.402672] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.493073] systemd[1]: Started Journal Service.
[ 5.550804] EXT4-fs (sda2): re-mounted. Quota mode: none.
[ 5.632308] systemd-journald[143]: Received client request to flush runtime journal.
[ 6.678246] mc: Linux media interface: v0.10
[ 6.838087] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.847883] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 6.847924] [vc_sm_connected_init]: start
[ 6.848978] [vc_sm_connected_init]: installed successfully
[ 6.905803] videodev: Linux video capture interface: v2.00
[ 6.971412] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 6.976226] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 6.976458] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.022697] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.025392] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.032309] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.070230] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 7.081758] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.084456] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.096010] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.096655] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.122067] rpivid feb10000.codec: Device registered as /dev/video19
[ 7.130234] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 7.139694] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 7.152975] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 7.155819] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 7.199970] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 7.209163] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 7.209223] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 7.219740] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 7.219787] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 7.219811] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 7.219847] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 7.219866] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 7.222791] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 7.222854] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 7.242119] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 7.242181] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 7.249893] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 7.249950] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 7.260458] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 7.297509] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 7.332858] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 7.340669] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 7.340719] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 7.340756] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 7.340777] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 7.340795] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 7.346216] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 7.718706] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 7.755797] Console: switching to colour dummy device 80x25
[ 7.781322] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.827415] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 7.836087] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 7.842311] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 7.843158] [drm] forcing HDMI-A-1 connector on
[ 7.969834] Registered IR keymap rc-cec
[ 7.990853] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 8.083913] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input9
[ 8.133851] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 8.164784] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.189824] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 8.227265] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 8.228046] [drm] forcing HDMI-A-2 connector on
[ 8.313412] Registered IR keymap rc-cec
[ 8.313790] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 8.314401] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input10
[ 8.321209] usb 1-1.4.7: Found UVC 1.00 device <unnamed> (046d:081d)
[ 8.369168] input: UVC Camera (046d:081d) as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7/1-1.4.7:1.2/input/input11
[ 8.371077] usbcore: registered new interface driver uvcvideo
[ 8.374339] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 8.388511] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 8.409848] usbcore: registered new interface driver brcmfmac
[ 8.411077] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 8.424090] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 8.439607] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 8.492194] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 8.492915] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 8.510143] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 8.615397] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 8.722281] usb 1-1.4.1: Warning! Unlikely big volume range (=496), cval->res is probably wrong.
[ 8.722317] usb 1-1.4.1: [50] FU [Mic Capture Volume] ch = 1, val = 0/7936/16
[ 8.751506] Console: switching to colour frame buffer device 80x30
[ 8.752727] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 9.128814] usb 1-1.4.7: set resolution quirk: cval->res = 384
[ 9.242217] usbcore: registered new interface driver snd-usb-audio
[ 9.524524] logitech-djreceiver 0003:046D:C52B.0006: hiddev96,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.4.5/input2
[ 9.647978] input: Logitech Wireless Device PID:4072 Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.5/1-1.4.5:1.2/0003:046D:C52B.0006/0003:046D:4072.0007/input/input12
[ 9.652832] input: Logitech Wireless Device PID:4072 Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.5/1-1.4.5:1.2/0003:046D:C52B.0006/0003:046D:4072.0007/input/input13
[ 9.662589] hid-generic 0003:046D:4072.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4072] on usb-0000:01:00.0-1.4.5/input2:1
[ 10.310386] input: Logitech MX Anywhere 2 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.5/1-1.4.5:1.2/0003:046D:C52B.0006/0003:046D:4072.0007/input/input17
[ 10.317086] logitech-hidpp-device 0003:046D:4072.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech MX Anywhere 2] on usb-0000:01:00.0-1.4.5/input2:1
[ 10.582991] uart-pl011 fe201000.serial: no DMA platform data
[ 10.600460] 8021q: 802.1Q VLAN Support v1.8
[ 10.770477] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k FS
[ 11.457250] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 11.460503] bcmgenet fd580000.ethernet eth0: Link is Down
[ 14.845985] usb 1-1.4.7: reset high-speed USB device number 7 using xhci_hcd
[ 15.550110] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 15.550160] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 16.783878] v3d fec00000.v3d: MMU error from client L2T (0) at 0x1081000, pte invalid
[ 18.363388] Bluetooth: Core ver 2.22
[ 18.363485] NET: Registered PF_BLUETOOTH protocol family
[ 18.363490] Bluetooth: HCI device and connection manager initialized
[ 18.363507] Bluetooth: HCI socket layer initialized
[ 18.363514] Bluetooth: L2CAP socket layer initialized
[ 18.363529] Bluetooth: SCO socket layer initialized
[ 18.379664] Bluetooth: HCI UART driver ver 2.3
[ 18.379685] Bluetooth: HCI UART protocol H4 registered
[ 18.379754] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 18.379925] Bluetooth: HCI UART protocol Broadcom registered
[ 18.530548] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.530567] Bluetooth: BNEP filters: protocol multicast
[ 18.530583] Bluetooth: BNEP socket layer initialized
[ 18.535885] Bluetooth: MGMT ver 1.22
[ 18.544919] NET: Registered PF_ALG protocol family
[ 27.753651] logitech-hidpp-device 0003:046D:4072.0007: HID++ 4.5 device connected.
EEPROM
BOOTLOADER: up to date
CURRENT: Wed 11 Jan 2023 05:40:52 PM UTC (1673458852)
LATEST: Wed 11 Jan 2023 05:40:52 PM UTC (1673458852)
RELEASE: stable (/lib/firmware/raspberrypi/bootloader/stable)
Use raspi-config to change the release.
VL805_FW: Using bootloader EEPROM
VL805: up to date
CURRENT: 000138c0
LATEST: 000138c0
Re: Monitor Resolution Problems After Recent Updates on Bullseye
Can you remove any hdmi settings from config.txt (like hdmi_safe=1).
Also remove any custom display settings from cmdline.txt (if you have them).
These settings are likely masking the real cause.
Grab another log.
Note "raspinfo | pastebinit" and just post the url is probably quicker. ("sudo apt install pastebinit" if it's not already installed).
Grab another log.
Thanks!!
OK, will do another raspinfo using default config.txt. Will have to SSH into the Pi.
Here's the 'tvservice' output I got this morning, if that also helps.
tvservice -n
device_name=DEL-DELL_U2419H
tvservice -s
state 0xa [HDMI DMT (4) RGB full 4:3], 640x480 @ 60.00Hz, progressive
Group DMT has 11 modes:
(prefer) mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 6: 640x480 @ 75Hz 4:3, clock:31MHz progressive
mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
mode 11: 800x600 @ 75Hz 4:3, clock:49MHz progressive
mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
mode 18: 1024x768 @ 75Hz 4:3, clock:78MHz progressive
mode 21: 1152x864 @ 75Hz 4:3, clock:108MHz progressive
mode 35: 1280x1024 @ 60Hz 5:4, clock:108MHz progressive
mode 36: 1280x1024 @ 75Hz 5:4, clock:135MHz progressive
mode 82: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
mode 83: 1600x900 @ 60Hz 16:9, clock:108MHz progressive
Group CEA has 15 modes:
mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive
mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
mode 6: 720x480 @ 60Hz 4:3, clock:27MHz x2 interlaced
mode 7: 720x480 @ 60Hz 16:9, clock:27MHz x2 interlaced
(native) mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
mode 17: 720x576 @ 50Hz 4:3, clock:27MHz progressive
mode 18: 720x576 @ 50Hz 16:9, clock:27MHz progressive
mode 19: 1280x720 @ 50Hz 16:9, clock:74MHz progressive
mode 20: 1920x1080 @ 50Hz 16:9, clock:74MHz interlaced
mode 21: 720x576 @ 50Hz 4:3, clock:27MHz x2 interlaced
mode 22: 720x576 @ 50Hz 16:9, clock:27MHz x2 interlaced
mode 31: 1920x1080 @ 50Hz 16:9, clock:148MHz progressive
tvservice -n
tvservice -s
OK here's the URL to my dead monitor PI using the default config.txt:
https://paste.debian.net/1274820/
Many thanks, jstewa
Many thanks, jstewa
Looked at some of the output and it appears that the boot process is NOT finding the edid file. I checked my /lib/firmware/ and I can't find it either. I wonder how critical that is for determining how to configure the monitor? Just a thought.
extremely critical!
OK, generated an edid using tvservice and put the resulting file in the /boot directory. Now have 1920X1080.
Hope this helps others with a similar problem.
Thanks for your help.....having the raspinfo file was critical.
Turns out you have to disable dtoverlay=vc4-kms-v3d to get the correct resolution. I still keep the edid.dat file in the /lib/firmware directory.
Complicated problem. Interesting.
Then your either running FKMS (in case you have dtoverlay=vc4-fkms-v3d added to config.txt) or even on legacy graphics driver -> both of them are deprecated!
I don't know how to test for which one I'm running, but I have the following in my config.txt file:
# Enable DRM VC4 V3D driver
#dtoverlay=vc4-kms-v3d
max_framebuffers=2
max_framebuffers=2
then you're on legacy graphics driver - with no HW acceleration at all!
If that's working for you, fine with that.
A few comments. This is your fundamental issue:
We can't read the edid.
That is a hardware problem. It may be the display, it may be the cable.
If you have other cables or displays to test you can narrow this down.
If the display has multiple hdmi inputs then try other ones.
You can also try the second hdmi port of the Pi4.
I'd guess you'd uncommented because you got no display output due to the missing edid.
I'd try uncommenting this line, and adding to cmdline.txt (on same line).
(assuming you are connected to first HDMI port on Pi4).
006575.586: HDMI1:EDID error reading EDID block 0 attempt 0
006576.600: HDMI1:EDID giving up on reading EDID block 0
As mentioned, the default is to have this uncommented.
video=HDMI-A-1:1920x1080@60D
Thanks for your reply. OK on my main problem: not reading the monitor parameters. I originally thought that I could generate an edid.dat file
using the tvservice program and place the generated file somewhere where it would be found by the boot process. I tried /lib/firmware and /boot subdirectories. Neither worked with the original config.txt file.
It turns out that I must disable dtoverlay=vc4-kms-v3d line in my config.txt file to get any monitor output in the desired resolution of 1920X1080. That's true no matter what I do. I changed my hdmi cable. Actually I had another one of the same brand (new in the package) and tried that with the dtoverlay line enabled of course). I must admit that both of my hdmi cables are somewhat suspect, being fairly inexpensive. I will get ones of higher quality and try them.
I also tried putting 'video=HDMI-A-1:1920x1080@60D' in front of my cmdline.txt file. Still no video, unless of course, I disabled the dtoverlay line in config.txt.
I replaced the Dell monitor with another I have for another purpose, a Spectre (17 inch). Still no change. I checked the output of raspinfo using the Spectre and edid was not read correctly. Exactly the same as my Dell monitor.
You mentioned trying the second video out port on my pi4B. If I move my hdmi cable from one output to the other, there is no video on the second port. Since this could be hardware problem with the pi4B, I replaced the computer with a pi400. Exactly the same results, including only output on only one video port. If, however, I do the same using pi400 running exactly the same OS (but NOT updated with the recent updates), video is present constantly on both ports.
In all cases, I noted the data in the 'Display app' in the applications folder of XFCE were missing or incorrect. In all cases, the Display app did not pick up the name of the monitor in use (as it had before the recent update). The monitors are named 'Default' in the app now. The app shows the resolution of 1920X1080 (with no other options shown) and a frequency of 0hz. I guess this confirms that monitor parameters are not properly read from the monitor.
I will continue to run the pi4B using the DToverlay disabled to get the higher resolution video. I realize that this solution maybe be temporary.
Thanks again and take care.
Sounds to me like the hdmi cable is most likely the problem.
Cheap cables can save money by only wiring up some connections.
They may leave out hotplug detect or SDL/SCA (used for reading edid).
On a pi4 if you boot without an sdcard, you will get a diagnostic screen output.
Do you see this? It should report whether hotplug is detected and edid can be read
(if not try an eeprom update).
what you see is because of viewtopic.php?p=2093015#p2092696jstewa wrote: ↑Wed Mar 22, 2023 11:38 pmThanks for your reply. OK on my main problem: not reading the monitor parameters. I originally thought that I could generate an edid.dat file
You've been told you're on legacy when you disable dtoverlay=vc4-kms-v3d
Btw, do you know your Pi has booted correctly? Use a fresh OS image, enable SSH and then connect to you Pi for checking
sudo apt install kms++-utils
uname -a
sudo sh -c 'cat /sys/kernel/debug/dri/?/hdmi0_regs' | grep HOTPLUG
sudo sh -c 'cat /sys/kernel/debug/dri/?/hdmi1_regs' | grep HOTPLUG
kmsprint -m
OK, new image.....
~ $ uname -a
Linux raspberrypi 6.1.19-v8+ #1637 SMP PREEMPT Tue Mar 14 11:11:47 GMT 2023 aarch64 GNU/Linux
~ $ sudo sh -c 'cat /sys/kernel/debug/dri/?/hdmi0_regs' | grep HOTPLUG
~ $ sudo sh -c 'cat /sys/kernel/debug/dri/?/hdmi1_regs' | grep HOTPLUG
:~ $ kmsprint -m
0 1920x1080@60.00 148.500 1920/88/44/148/+ 1080/4/5/36/+ 60 (60.00) P|U|D
35 640x480@59.94 25.175 640/16/96/48/- 480/10/2/33/- 60 (59.94) D
~ $ uname -a
:~ $ kmsprint -m
Here is my Raspberrypi 4 debug.dom wrote: ↑Tue Mar 21, 2023 2:54 pmCan you remove any hdmi settings from config.txt (like hdmi_safe=1).
Grab another log.
https://paste.debian.net/1275101/
This is the latest raspinfo after removing the video configuration from cmdline.txt
https://paste.debian.net/1275106/
I am using a HP W1972a monitor. Monitor has 2 display ports - VGA and DVI. Raspberrypi 4 connected on 1st HDMI output to the DVI port using an adaptor to HDMI the monitor.
sanjayd wrote: ↑Fri Mar 24, 2023 9:39 amHere is my Raspberrypi 4 debug.dom wrote: ↑Tue Mar 21, 2023 2:54 pmCan you remove any hdmi settings from config.txt (like hdmi_safe=1).
Grab another log.
Running Legacy framebuffer
That should show like below on a mint OS
Running (F)KMS and X
Display Information
Screen 0: minimum 320 x 200, current 800 x 1280, maximum 7680 x 7680
HDMI-1 disconnected primary (normal left inverted right x axis y axis)
Identifier: 0x45
Timestamp: 19049
Subpixel: unknown
Clones:
CRTCs: 3
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
Output format: Automatic
supported: Automatic, RGB, YCbCr 4:2:2, YCbCr 4:4:4
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
max bpc: 8
range: (8, 12)
bottom margin: 0
range: (0, 100)
top margin: 0
range: (0, 100)
right margin: 0
range: (0, 100)
left margin: 0
range: (0, 100)
Colorspace: Default
supported: Default, SMPTE_170M_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, DCI-P3_RGB_Theater
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 32
supported: 32
non-desktop: 0
range: (0, 1)
HDMI-2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x46
Timestamp: 19049
Subpixel: unknown
Clones:
CRTCs: 4
filter:
max bpc: 8
range: (8, 12)
bottom margin: 0
range: (0, 100)
top margin: 0
range: (0, 100)
right margin: 0
range: (0, 100)
left margin: 0
range: (0, 100)
Colorspace: Default
link-status: Good
CONNECTOR_ID: 42
supported: 42
non-desktop: 0
range: (0, 1)
DSI-1 connected 800x1280+0+0 (0x49) normal (normal left inverted right x axis y axis) 0mm x 0mm
Identifier: 0x47
Timestamp: 19049
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 2
CRTCs: 2
filter:
link-status: Good
CONNECTOR_ID: 48
supported: 48
non-desktop: 0
range: (0, 1)
800x1280 (0x49) 71.000MHz *current +preferred
h: width 800 start 832 end 833 total 890 skew 0 clock 79.78KHz
v: height 1280 start 1308 end 1309 total 1323 clock 60.30Hz
Connector 0 (32) HDMI-A-1 (disconnected)
Encoder 0 (31) TMDS
Connector 1 (42) HDMI-A-2 (disconnected)
Encoder 1 (41) TMDS
Connector 2 (48) DSI-1 (connected)
Encoder 2 (47) DSI
Crtc 2 (87) 800x1280@60.30 71.000 800/32/1/57/? 1280/28/1/14/? 60 (60.30)
Plane 2 (77) fb-id: 342 (crtcs: 2) 0,0 800x1280 -> 0,0 800x1280 (XR24 AR24 AB24 XB24 RG16 BG16 AR15 XR15 RG24 BG24 YU16 YV16 YU24 YV24 YU12 YV12 NV12 NV21 NV16 NV61 P030 XR30 AR30 AB30 XB30 RGB8 BGR8 XR12 AR12 XB12 AB12 BX12 BA12 RX12 RA12)
FB 342 800x1280 XR24
Plane 24 (301) fb-id: 345 (crtcs: 2) 0,0 64x64 -> 414,770 64x64 (XR24 AR24 AB24 XB24 RG16 BG16 AR15 XR15 RG24 BG24 YU16 YV16 YU24 YV24 YU12 YV12 NV12 NV21 NV16 NV61 P030 XR30 AR30 AB30 XB30 RGB8 BGR8 XR12 AR12 XB12 AB12 BX12 BA12 RX12 RA12)
FB 345 64x64 AR24
0 800x1280@60.30 71.000 800/32/1/57/? 1280/28/1/14/? 60 (60.30) P|D
HDMI0: HDMI_HOTPLUG = 0x00000000
Do you have another monitor with DVI input for cross-checking your HDMI-to-DVI adapter? Have you tested without a uSD inserted (as asked to by DOM)?
I have another sdcard with raspberry pi os installed. I did an update and check if the monitor shuts off. I could ssh to the monitor.
No changes done to the cmdline.txt
I don't have another monitor.
The log of raspinfo is attached.
https://paste.debian.net/1275171/
Hope this helps. If I need to run any commands before the log, let me know. This sdcard has a freshly installed RpiOS. Just "apt update" and "apt upgrade" done on it.
Any more comments for me (jstewa). My last post was Thu Mar 23, 2023 12:48 pm.....looks like you're responding to another user.
- HawaiianPi
Try the official documentation for info on using your own EDID file.
raspberrypi.com/documentation/computers/config_txt.html#hdmi_ignore_edid
You need either hdmi_ignore_edid=0xa5000080 if you are configuring manually.
Or, hdmi_edid_file=1 to use an edid.dat file in the boot partition
