I tried to run Octoprint in a Container. On the host the Prusa Mini+ is actually connected to I am running socat with the following params:
ExecStart=/usr/bin/socat -d -d -d TCP4-LISTEN:4000,fork,reuseaddr /dev/ttyACM0,raw,echo=1,b115200
I found out that the cdc_acm-Device /dev/ttyACM0 does not work properly when I try to use it over socat. It worked for several days then it stopped working. Unplugging and replugging the USB cable (from the printer to the socat host which is a RPi 4 running RPi OS BullsEye) helped once. Then it seemed to have stopped working completely. I managed to make it work again by removing the kernel module and re-adding it:
modprobe -r cdc_acm
modprobe cdc_acm
But that also seemed to work only 1 out of 100 times.
When I install Octoprint locally on the RPi everything works as it should.
So... any ideas what might be wrong with /dev/ttyACM0? Or might my socat params be wrong?
Any hints would be highly appreciated!
Cheers,
Ronzo
