I'm trying to build some software but I'm getting an error about ucnv.h :
/usr/include/libxml2/libxml/encoding.h:31:10: fatal error: 'unicode/ucnv.h' file not found
My 64-bit Raspbian is fully up to date with Bullseye.
If I understand correctly how Debian (Raspbian) is supposed to work, if one package X depends on another Y, the dependency Y is supposed to be loaded automatically when I install X. However this was not the case regarding libxml, because ucnv.h is required by it but is missing.
I saw in a forum posting that these days ucnv.h is provided by libiconv-hook-dev, because libiconv-dev has gone away, however libiconv-hook-dev does not provide ucnv.h either.
Can someone let me know which package really has ucnv.h, or do none of them and I need to compile iconv from the source code?
At a certain point, this worldwide search for the correct package, looking under every rock and in every crevice, becomes a burden and it is just way easier to compile the thing myself. Debian's package dependency feature looks good on paper, but in practice it seems broken sometimes. However, I just now compiled libiconv myself, which took all of 30 seconds, and I don't see ucnv.h in it anywhere, so perhaps Debian aarch64's libxml is what is out of date.
- DougieLawson
Re: ucnv.h missing
You need libicu-dev installed.
sudo apt update;sudo apt install libicu-dev
Re: ucnv.h missing
For 64-bit Raspberry Pi OS it is just Debian, not Raspbian.pi5b wrote: ↑Thu May 25, 2023 2:48 pmI'm trying to build some software but I'm getting an error about ucnv.h :
There is a way to install build dependencies for source code, it works for building Debian packages, but not so much for other source.
The way I find out what to install to get a file like ucnv.h is to go to the Debian Packages site and "Search the contents of packages", in this case I search for paths that end in ucnv.h and get the results
/usr/include/mozjs-52/unicode/ucnv.h libmozjs-52-dev [mips]
/usr/include/unicode/ucnv.h libicu-dev
This is a useful look up service, even if you're running the Raspbian-based 32-bit Raspberry Pi OS - just make sure you use apt to install - don't download directly from the Debian site.
Unreadable squiggle
Re: ucnv.h missing
That didn't install it:DougieLawson wrote: ↑Thu May 25, 2023 3:55 pmYou need libicu-dev installed.
$ find /usr -name ucnv.h
$ find /usr -name unicode
/usr/include/boost/spirit/home/support/char_encoding/unicode
/usr/src/linux-headers-6.1.21-v8+/fs/unicode
/usr/share/doc/unicode
/usr/share/unicode
/usr/bin/unicode
$ ls /usr/include/unicode
ustdio.h ustream.h
Re: ucnv.h missing
Your install didn't work properly then, or there is a problem with your system...
notpi@raspi10:~ $ ls /usr/include/unicode
ls: cannot access '/usr/include/unicode': No such file or directory
notpi@raspi10:~ $ sudo apt update;sudo apt install libicu-dev
Hit:1 http://deb.debian.org/debian bullseye InRelease
(blah blah blah)
Reading package lists... Done
Building dependency tree... Done
The following additional packages will be installed:
icu-devtools
Suggested packages:
icu-doc
icu-devtools libicu-dev
0 upgraded, 2 newly installed, 0 to remove and 8 not upgraded.
Need to get 9,657 kB of archives.
After this operation, 45.8 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://deb.debian.org/debian bullseye/main arm64 icu-devtools arm64 67.1-7 [189 kB]
Get:2 http://deb.debian.org/debian bullseye/main arm64 libicu-dev arm64 67.1-7 [9,468 kB]
Fetched 9,657 kB in 3s (3,172 kB/s)
Selecting previously unselected package icu-devtools.
(Reading database ... 46292 files and directories currently installed.)
Preparing to unpack .../icu-devtools_67.1-7_arm64.deb ...
Unpacking icu-devtools (67.1-7) ...
Selecting previously unselected package libicu-dev:arm64.
Preparing to unpack .../libicu-dev_67.1-7_arm64.deb ...
Unpacking libicu-dev:arm64 (67.1-7) ...
Setting up icu-devtools (67.1-7) ...
Setting up libicu-dev:arm64 (67.1-7) ...
Processing triggers for man-db (2.9.4-2) ...
alphaindex.h localpointer.h tmunit.h umisc.h
(lots of files)
dcfmtsym.h putil.h ucnv.h <------ Oh look!!!
(lots more files)
Unreadable squiggle
