As you can see, the count rate with this small 10 x 2.5 cm board is typically at around 25 counts per second (just natural background) with my setup here, whereas you typically display in counts per minute with Geiger counters.
If you want to learn more about the project, this is all part of the Mini SiD project that I've been working on the past couple of months. Everything is fully open source and I have a Hackaday project page, as well as a GitHub repo with complementary documentation. It's fully certified as open hardware by the OSHWA
https://github.com/OpenGammaProject/Mini-SiD
https://hackaday.io/project/188090-mini ... iver-board
There is already somebody who built himself a nice little device using a very similar approach to me here. The Mini SiD board he is using there is already outdated by now, but the form factor and principle of operation remain the exact same. Thanks to RD-Gammaspectra for the neat example!
https://rd-gammaspectra.xyz/?p=255
Let me know if you have any questions or suggestions!
