Thanks for your help, I finally got it to work (I was trying to log into a neighbor's raspberry pi).
This is a great system, very useful, polished and well documented. So nice to see this kind of work done!
- peppy.player
Re: Peppy player
New version (Klimt Edition) of the Peppy Player was released today.
The disk images with the new release are available here:
https://github.com/project-owner/PeppyP ... isk-Images
Here are the main features of the new release:
- Added new mode - Archive. It allows to search and play audio files from the Internet Archive web site.
https://github.com/project-owner/Peppy.doc/wiki/Archive
- Refactored the Voice Assistant. Now it can work offline. By default two voice models have been provided for English and German. The models for the other supported languages can be downloaded from the Internet using the Configuration Web UI.
Using the voice commands it's possible to search and play files from a file system and collection.
https://github.com/project-owner/Peppy. ... -Assistant
- Refactored icons. Created a new lightweight set of icons.
https://github.com/project-owner/Peppy.doc/wiki/Icons
- Fixed the Horoscope screensaver:
https://github.com/project-owner/Peppy. ... /Horoscope
- Implemented default ALSA device selection.
https://github.com/project-owner/Peppy. ... dio-Device
- Improved the on-screen keyboard functionality
- Fixed radio favorites issue.
- peppy.player
Re: Peppy player
All voice commands supported by the player can be found here:
https://github.com/project-owner/Peppy. ... e-Commands
- peppy.player
Re: Peppy player
Here is a new entry in the Gallery - Portable player by Dee:
https://github.com/project-owner/PeppyP ... by-dee-usa
- peppy.player
Re: Peppy player
Today the number of the Peppy Player disk image downloads from GitHub exceeded 10,000 since 10.30.2018
There is no exact statistics avialable for source code downloads. Using a rough estimate (12 downloads per week) it's another 3,000 downloads.
Re: Peppy player
First of all, thank you for this great piece of software. After some problems, I got it to run with a 3,5" display from ELGOO (from Amazon.de).
May I ask for a wish/feature?
My son would like to use the peppy player as an alarm clock radio at bed. Therefore the use case would be: screensaver with clock = on, if alarm time arrived, activate player with last station/song (even better: activate special alarm stream/song).
Any chance that you can/want to implement this feature?
Thanks and best regards,
Jürgen
Jürgen
- peppy.player
Re: Peppy player
Hi Jürgen,
Thank you!
The Alarm Clock functionality which you described is very similar to the current Timer functionality:
https://github.com/project-owner/Peppy.doc/wiki/Timer
The only missing parts are Clock screensaver and dedicated sound. I believe it should not take too much time to implement. Hopefully I can add this feature in the next version (tentative release date - September).
Best regards
Thank you!
Best regards
- peppy.player
Re: Peppy player
New version (Kandinsky Edition) of the Peppy Player was released today.
- Implemented a File Playlist Editor in the Web UI.
https://github.com/project-owner/Peppy. ... ist-Editor
- Refactored the keyboard editor - added a cursor functionality
- Added new VU Meter Screensaver types
- Implemented VU Meter screensaver in the Web UI
https://github.com/project-owner/Peppy. ... i/VU-Meter
- It's possible now to hide/show different Player screen elements
https://github.com/project-owner/Peppy. ... yer-Screen
- Improved a performance of the image viewer (zoom in, zoom out and pan actions)
- Added mpd dictionary update functionality.
- Fixed YA Streams issue
- Fixed the Stock screensaver
The complete list of changes can be found in the Release Notes:
https://github.com/project-owner/PeppyP ... n-20230924
