redvli
Camera tuningfile path
Sat Jul 22, 2023 6:10 pm
There is a difference between 32-bit and 64-bit RPiOS:
dpkg -L libcamera0 | grep ov5647_noir
[32] /usr/share/libcamera/ipa/raspberrypi/ov5647_noir.json
[64] /usr/share/libcamera/ipa/rpi/vc4/ov5647_noir.json
Silverlock
Re: Audacity throws an error
Tue Jul 25, 2023 5:59 pm
beta-tester wrote:
Sat Jan 29, 2022 8:29 pm
i still have this issue with Audacity on my RasPi OS. and i have no workaround.
i can not find the source of that specific version 2.4.2~dfsg0-5,
https://github.com/audacity/audacity/bl ... O.cpp#L958
there is noted that it maybe should be compiled in another way... if the assert message is thrown from there.
On the off chance you're still looking for a solution for this, here's what worked for me (this was on a Pi 4B).
Remove the audacity and audacity-data packages.
Download audacity and audacity 2.4.2~dfsg0-5 debs from packages.debian.org/bullseye/armhf.
https://packages.debian.org/bullseye/ar ... y/download
https://packages.debian.org/bullseye/ar ... a/download
Install these (audacity-data first). Run audacity. No assert on startup.
The audacity binary is different between the deb from here and the one that was installed from Rpi. You'd think the packages would be identical, but apparently not.
Happy audacity'ing.
twilightened
Re: STICKY: Bullseye - Comments and bug reports thread.
Sat Aug 26, 2023 9:28 pm
VLC has problems after the latest update. Normally, when in fullscreen, "esc" should turn back to window mode. After the latest updates, esc just kills vlc. By the way, even whan active in the settings, it does not remember the playback position.
beta-tester
Wed Aug 30, 2023 4:25 pm
the thing with [ESC] happens on my system as well, but not always.
twilightened
Thu Aug 31, 2023 7:11 pm
Another "long term" problem is desktop becoming unresponsive to mouse clicks when RPI is left untouched for a while. The solution i found is to do ctrl+alt+del, and then cancel the shutdown options pop up, then desktop becomes responsive again.
twilightened
Mon Sep 25, 2023 11:54 pm
These things that i mentioned are still happening. VLC does not remember the playback position and when in fullscreen, any attempt at exiting fullscreen ends up in shutting down the app completely.
redvli
Tue Sep 26, 2023 6:08 am
I discovered that it actually worked better after some update. I haven't tracked which versions, but it seems difficult to get it 'perfect' on RPiOS. See also viewtopic.php?t=356193
twilightened
Wed Sep 27, 2023 8:04 pm
For months it has been like that. When i go fullscreen, there is no turning back. The moment i press ESC to go back to window mode, VLC just kills itself. Double click in full screen does exactly the same thing. The app just crashes. When i rerun the program, the video starts from the beginning which means VLC also fails to remember the playback position.
I am on a RPIOS 64bit. Latest version of everthing.
DarkElvenAngel
Wed Sep 27, 2023 8:29 pm
twilightened wrote: For months it has been like that. When i go fullscreen, there is no turning back. The moment i press ESC to go back to window mode, VLC just kills itself. Double click in full screen does exactly the same thing. The app just crashes. When i rerun the program, the video starts from the beginning which means VLC also fails to remember the playback position.
I'm also on RPIOS 64bit and I just tried to play an mp4 switch to full screen then press ESC to go back to window mode. It worked the was so screen flashing but it didn't crash and video kept playing.
Maybe your not using dtoverlay=vc4-kms-v3d in your config.txt?
It could you have to uninstall and reinstall it? I'm running from an SSD That could make a difference.
twilightened
Thu Sep 28, 2023 12:20 am
This is a complete reinstall from scratch. The problem still persists. I have that line you mentioned in my config.txt. I have tried different GPU memory portions. It is all the same. Coming back from full screen crashes VLC. By the way, i mostly play "HEVC" files (X265). I don't know if that makes any difference. Also, if i change the output renderer to OpenGL, the problem goes away. I even can see the OSD when i do that. However, detrimentally, "screen tearing" is the negative outcome of selecting OpenGL as renderer.
So, all in all, VLC still has lots of issues under RPIOS. I don't think it is just me. We are in need of an alternative at least. "Kodi" is the way to go i guess. But of course, it has its own issues and defects.
beta-tester
Thu Sep 28, 2023 5:37 am
i am also affected by this issue since few weeks/months. nearly always VLC close itself (crash?) when i try to go from fullscreen back to window mode by pressing [ESC]-key.
only in some really really rare cases it goes back as normal.
i watch mostly mp4 videos.
i am running RaspiOS bullseye 32bit (from 2021-10-30 and updated regularly over time) on my RPi4 4GB from an SSD (on USB3).
dtoverlay=vc4-kms-v3d is set in config.txt
$ uname -a
Linux server 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU/Linux
 $ vcgencmd version
Mar 17 2023 10:50:39
Copyright (c) 2012 Broadcom
version 82f3750a65fadae9a38077e3c2e217ad158c8d54 (clean) (release) (start)
$ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
$ cat /etc/rpi-issue
Raspberry Pi reference 2021-10-30
Generated using pi-gen, https://github.com/RPi-Distro/pi-gen, 288b21fc27e128ea6b330777aca68e0061ebf4fe, stage4
beta-tester
Sun Oct 01, 2023 11:15 am
here the log of "VLC -vvv" the first time fullscreen back to normal was successfull, but the second time vlc crashed with memory access error (Speicherzugriffsfehler)
pi@rpi:~ $ vlc -vvv
VLC media player 3.0.18 Vetinari (revision 3.0.13-8-g41878ff4f2)
[01e2db98] main libvlc debug: VLC media player - 3.0.18 Vetinari
[01e2db98] main libvlc debug: Copyright © 1996-2022 the VideoLAN team
[01e2db98] main libvlc debug: revision 3.0.13-8-g41878ff4f2
[01e2db98] main libvlc debug: configured with ./configure  '--build=arm-linux-gnueabihf' '--prefix=/usr' '--includedir=${prefix}/include' '--mandir=${prefix}/share/man' '--infodir=${prefix}/share/info' '--sysconfdir=/etc' '--localstatedir=/var' '--disable-option-checking' '--disable-silent-rules' '--libdir=${prefix}/lib/arm-linux-gnueabihf' '--runstatedir=/run' '--disable-maintainer-mode' '--disable-dependency-tracking' '--disable-debug' '--config-cache' '--disable-update-check' '--enable-fast-install' '--docdir=/usr/share/doc/vlc' '--with-binary-version=1:3.0.18-0+rpt7+deb11u1' '--enable-a52' '--enable-aa' '--enable-aribsub' '--enable-avahi' '--enable-bluray' '--enable-caca' '--enable-chromaprint' '--enable-chromecast' '--enable-dav1d' '--enable-dbus' '--enable-dca' '--enable-dvbpsi' '--enable-dvdnav' '--enable-faad' '--enable-flac' '--enable-fluidsynth' '--enable-freetype' '--enable-fribidi' '--enable-gles2' '--enable-gnutls' '--enable-harfbuzz' '--enable-jack' '--enable-kate' '--enable-libass' '--enable-libmpeg2' '--enable-libxml2' '--enable-lirc' '--enable-live555' '--enable-mad' '--enable-matroska' '--enable-mod' '--enable-mpc' '--enable-mpg123' '--enable-mtp' '--enable-ncurses' '--enable-notify' '--enable-ogg' '--enable-opus' '--enable-pulse' '--enable-qt' '--enable-realrtsp' '--enable-samplerate' '--enable-sdl-image' '--enable-sftp' '--enable-shine' '--enable-shout' '--enable-skins2' '--enable-soxr' '--enable-spatialaudio' '--enable-speex' '--enable-srt' '--enable-svg' '--enable-svgdec' '--enable-taglib' '--enable-theora' '--enable-twolame' '--enable-upnp' '--enable-vnc' '--enable-vorbis' '--enable-x264' '--enable-x265' '--enable-zvbi' '--with-kde-solid=/usr/share/solid/actions/' '--disable-aom' '--disable-crystalhd' '--disable-d3d11va' '--disable-decklink' '--disable-directx' '--disable-dsm' '--disable-dxva2' '--disable-fdkaac' '--disable-fluidlite' '--disable-freerdp' '--disable-goom' '--disable-gst-decode' '--disable-libtar' '--disable-macosx' '--disable-macosx-avfoundation' '--disable-macosx-qtkit' '--disable-mfx' '--disable-microdns' '--disable-opencv' '--disable-projectm' '--disable-schroedinger' '--disable-sparkle' '--disable-telx' '--disable-vpx' '--disable-vsxu' '--disable-wasapi' '--disable-mmal-avcodec' '--enable-alsa' '--enable-dc1394' '--enable-dv1394' '--enable-libplacebo' '--enable-linsys' '--enable-nfs' '--enable-udev' '--enable-v4l2' '--enable-wayland' '--enable-vcd' '--enable-smbclient' '--disable-oss' '--disable-mmx' '--disable-sse' '--enable-neon' '--enable-mmal' '--disable-vdpau' '--disable-libva' '--disable-altivec' '--enable-omxil' '--enable-omxil-vout' '--enable-rpi-omxil' 'build_alias=arm-linux-gnueabihf' 'CFLAGS=-g -O2 -ffile-prefix-map=/build/vlc-tPgqQj/vlc-3.0.18=. -fstack-protector-strong -Wformat -Werror=format-security ' 'LDFLAGS=-Wl,-z,relro -Wl,-z,now' 'CPPFLAGS=-Wdate-time -D_FORTIFY_SOURCE=2' 'CXXFLAGS=-g -O2 -ffile-prefix-map=/build/vlc-tPgqQj/vlc-3.0.18=. -fstack-protector-strong -Wformat -Werror=format-security ' 'OBJCFLAGS=-g -O2 -ffile-prefix-map=/build/vlc-tPgqQj/vlc-3.0.18=. -fstack-protector-strong -Wformat -Werror=format-security'
[01e2db98] main libvlc debug: searching plug-in modules
[01e2db98] main libvlc debug: loading plugins cache file /usr/lib/arm-linux-gnueabihf/vlc/plugins/plugins.dat
[01e2db98] main libvlc debug: recursively browsing `/usr/lib/arm-linux-gnueabihf/vlc/plugins'
[01e2db98] main libvlc debug: plug-ins loaded: 519 modules
[01e2db98] main libvlc debug: opening config file (/home/pi/.config/vlc/vlcrc)
[01e2ddb8] main logger debug: looking for logger module matching "any": 4 candidates
[01e2ddb8] main logger debug: using logger module "console"
[01e2db98] main libvlc debug: translation test: code is "de"
[01e98630] main keystore debug: looking for keystore module matching "memory": 4 candidates
[01e98630] main keystore debug: using keystore module "memory"
[01e2db98] main libvlc debug: CPU has capabilities FPU
[01ea70a0] main input debug: Creating an input for 'Medienbibliothek'
[01ea70a0] main input debug: selected audio language[0] de
[01ea70a0] main input debug: selected sub language[0] de
[01ea70a0] main input debug: Input is a meta file: disabling unneeded options
[01ea70a0] main input debug: using timeshift granularity of 50 MiB
[01ea70a0] main input debug: using default timeshift path
[01ea70a0] main input debug: `file/directory:///home/pi/.local/share/vlc/ml.xspf' gives access `file' demux `directory' path `/home/pi/.local/share/vlc/ml.xspf'
[01eaacb8] main input source debug: creating demux: access='file' demux='directory' location='/home/pi/.local/share/vlc/ml.xspf' file='/home/pi/.local/share/vlc/ml.xspf'
[01e97898] main demux debug: looking for access_demux module matching "file": 19 candidates
[01e97898] main demux debug: no access_demux modules matched
[01e8fc58] main stream debug: creating access: file:///home/pi/.local/share/vlc/ml.xspf
[01e8fc58] main stream debug:  (path: /home/pi/.local/share/vlc/ml.xspf)
[01e8fc58] main stream debug: looking for access module matching "file": 30 candidates
[01e8fc58] main stream debug: using access module "filesystem"
[01e90600] main stream debug: looking for stream_filter module matching "prefetch,cache_read": 26 candidates
[01e90600] cache_read stream debug: Using stream method for AStream*
[01e90600] cache_read stream debug: starting pre-buffering
[01e90600] cache_read stream debug: received first data after 0 ms
[01e90600] cache_read stream debug: pre-buffering done 299 bytes in 0s - 1149 KiB/s
[01e90600] main stream debug: using stream_filter module "cache_read"
[01e90e90] main stream debug: looking for stream_filter module matching "any": 26 candidates
[01e90e90] playlist stream debug: using XSPF playlist reader
[01e90e90] main stream debug: using stream_filter module "playlist"
[01e90e90] main stream debug: stream filter added to 0x1e90600
[01e93160] main stream debug: looking for stream_filter module matching "any": 26 candidates
[01e93160] main stream debug: no stream_filter modules matched
[01e97cc0] main stream_directory debug: looking for stream_directory module matching "any": 1 candidates
[01e97cc0] main stream_directory debug: no stream_directory modules matched
[01eaacb8] main input source debug: attachment of directory-extractor failed for file:///home/pi/.local/share/vlc/ml.xspf
[01e93160] main stream debug: looking for stream_filter module matching "record": 26 candidates
[01e93160] main stream debug: using stream_filter module "record"
[01e97898] main demux debug: looking for demux module matching "directory": 55 candidates
[01e97898] main demux debug: using demux module "directory"
[01e982b8] main demux meta debug: looking for meta reader module matching "any": 2 candidates
[01e982b8] lua demux meta debug: Trying Lua scripts in /home/pi/.local/share/vlc/lua/meta/reader
[01e982b8] lua demux meta debug: Trying Lua scripts in /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/reader
[01e982b8] lua demux meta debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/reader/filename.luac
[01e982b8] lua demux meta debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader
[01e982b8] main demux meta debug: no meta reader modules matched
[01ea70a0] main input debug: `file/directory:///home/pi/.local/share/vlc/ml.xspf' successfully opened
[01eb8eb0] main xml reader debug: looking for xml reader module matching "any": 1 candidates
[01eb8eb0] main xml reader debug: using xml reader module "xml"
[01ea70a0] main input debug: EOF reached
[01e97898] main demux debug: removing module "directory"
[01e93160] main stream debug: removing module "record"
[01e90e90] main stream debug: removing module "playlist"
[01e90600] main stream debug: removing module "cache_read"
[01e8fc58] main stream debug: removing module "filesystem"
[01ea5720] main playlist debug: creating audio output
[01eb47e0] main audio output debug: looking for audio output module matching "any": 5 candidates
[01eb47e0] vlcpulse audio output debug: using library version 14.2.0
[01eb47e0] vlcpulse audio output debug:  (compiled with version 14.2.0, protocol 34)
[01eb47e0] vlcpulse audio output debug: connected locally to /run/user/1000/pulse/native as client #404
[01eb47e0] vlcpulse audio output debug: using protocol 34, server protocol 34
[01eb47e0] pulse audio output debug: adding sink 0: alsa_output.platform-fef00700.hdmi.hdmi-stereo (Internes Audio Digital Stereo (HDMI))
[01eb47e0] main audio output debug: using audio output module "pulse"
[01ea5720] main playlist debug: keeping audio output
[01e982b8] main interface debug: looking for interface module matching "dbus,none": 19 candidates
[01e982b8] dbus interface debug: listening on dbus as: org.mpris.MediaPlayer2.vlc
[01e982b8] main interface debug: using interface module "dbus"
[01e2db98] main libvlc debug: no running VLC instance - continuing normally...
[01ec5348] main interface debug: looking for interface module matching "hotkeys,none": 19 candidates
[01ec5348] main interface debug: using interface module "hotkeys"
[01ec5a28] main interface debug: looking for interface module matching "globalhotkeys,none": 19 candidates
[01ec5a28] main interface debug: using interface module "xcb_hotkeys"
[01e2db98] main libvlc: VLC wird mit dem Standard-Interface ausgeführt. Benutzen Sie 'cvlc', um VLC ohne Interface zu verwenden.
[01ec64a8] main interface debug: looking for interface module matching "any": 19 candidates
[e1b8ddc0] main generic debug: looking for extension module matching "any": 1 candidates
[e1b8ddc0] lua generic debug: Opening Lua Extension module
[e1b8ddc0] lua generic debug: Trying Lua scripts in /home/pi/.local/share/vlc/lua/extensions
[e1b8ddc0] lua generic debug: Trying Lua scripts in /usr/lib/arm-linux-gnueabihf/vlc/lua/extensions
[e1b8ddc0] lua generic debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/extensions/VLSub.luac
[e1b8ddc0] lua generic debug: Scanning Lua script /usr/lib/arm-linux-gnueabihf/vlc/lua/extensions/VLSub.luac
[e1b8ddc0] lua generic debug: Script /usr/lib/arm-linux-gnueabihf/vlc/lua/extensions/VLSub.luac has the following capability flags: 0x5
[e1b8ddc0] lua generic debug: Trying Lua scripts in /usr/share/vlc/lua/extensions
[e1b8ddc0] main generic debug: using extension module "lua"
[01ec64a8] main interface debug: using interface module "qt"
[01ea5720] main playlist: playlist is empty
[01ea5720] main playlist debug: nothing to play
Non-native QFileDialog supports only local files
libpng warning: iCCP: known incorrect sRGB profile
[01ea5720] main playlist debug: processing request item: ATARI - Game Over - 160325_atari_inf_3328k_p36v12.mp4, node: Wiedergabeliste, skip: 0
[01ea5720] main playlist debug: rebuilding array of current - root Wiedergabeliste
[01ea5720] main playlist debug: rebuild done - 1 items, index 0
[01ea5720] main playlist debug: starting playback of new item
[01ea5720] main playlist debug: resyncing on ATARI - Game Over - 160325_atari_inf_3328k_p36v12.mp4
[01ea5720] main playlist debug: ATARI - Game Over - 160325_atari_inf_3328k_p36v12.mp4 is at 0
[01ea5720] main playlist debug: creating new input thread
[df103f30] main input debug: Creating an input for preparsing 'ATARI - Game Over - 160325_atari_inf_3328k_p36v12.mp4'
[dfb02ed0] main input debug: Creating an input for 'ATARI - Game Over - 160325_atari_inf_3328k_p36v12.mp4'
[dfb02ed0] main input debug: selected audio language[0] de
[dfb02ed0] main input debug: selected sub language[0] de
[01ea5720] main playlist debug: requesting art for new input thread
[dfb02ed0] main input debug: using timeshift granularity of 50 MiB
[dfb02ed0] main input debug: using default timeshift path
[dfb02ed0] main input debug: `file:///media/pi/data/Content/ATARI%20-%20Game%20Over%20-%20160325_atari_inf_3328k_p36v12.mp4' gives access `file' demux `any' path `/media/pi/data/Content/ATARI%20-%20Game%20Over%20-%20160325_atari_inf_3328k_p36v12.mp4'
[f4506628] main input source debug: creating demux: access='file' demux='any' location='/media/pi/data/Content/ATARI%20-%20Game%20Over%20-%20160325_atari_inf_3328k_p36v12.mp4' file='/media/pi/data/Content/ATARI - Game Over - 160325_atari_inf_3328k_p36v12.mp4'
[f4506778] main demux debug: looking for access_demux module matching "file": 19 candidates
[01ec64a8] qt interface debug: IM: Setting an input
[f4506778] main demux debug: no access_demux modules matched
[f4507718] main stream debug: creating access: file:///media/pi/data/Content/ATARI%20-%20Game%20Over%20-%20160325_atari_inf_3328k_p36v12.mp4
[f4507718] main stream debug:  (path: /media/pi/data/Content/ATARI - Game Over - 160325_atari_inf_3328k_p36v12.mp4)
[f4507718] main stream debug: looking for access module matching "file": 30 candidates
[f4507718] main stream debug: using access module "filesystem"
[f4507968] main stream debug: looking for stream_filter module matching "prefetch,cache_read": 26 candidates
[f4507968] cache_read stream debug: Using stream method for AStream*
[f4507968] cache_read stream debug: starting pre-buffering
[f4507968] cache_read stream debug: received first data after 0 ms
[f4507968] cache_read stream debug: pre-buffering done 1024 bytes in 0s - 6535 KiB/s
[f4507968] main stream debug: using stream_filter module "cache_read"
[f4507be0] main stream debug: looking for stream_filter module matching "any": 26 candidates
[f4507be0] lua stream debug: Trying Lua scripts in /home/pi/.local/share/vlc/lua/playlist
[f4507be0] lua stream debug: Trying Lua scripts in /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist
[f4507be0] lua stream debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist/anevia_streams.luac
[f4507be0] lua stream debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist/anevia_xml.luac
[f4507be0] lua stream debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist/appletrailers.luac
[f4507be0] lua stream debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist/bbc_co_uk.luac
[f4507be0] lua stream debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist/cue.luac
[f4507be0] lua stream debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist/dailymotion.luac
[f4507be0] lua stream debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist/jamendo.luac
[f4507be0] lua stream debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist/koreus.luac
[f4507be0] lua stream debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist/liveleak.luac
[f4507be0] lua stream debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist/newgrounds.luac
[f4507be0] lua stream debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist/rockbox_fm_presets.luac
[f4507be0] lua stream debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist/soundcloud.luac
[f4507be0] lua stream debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist/twitch.luac
[f4507be0] lua stream debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist/vimeo.luac
[f4507be0] lua stream debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist/vocaroo.luac
[f4507be0] lua stream debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/playlist/youtube.luac
[f4507be0] lua stream debug: Trying Lua scripts in /usr/share/vlc/lua/playlist
[f4507be0] main stream debug: no stream_filter modules matched
[f45089d8] main stream_directory debug: looking for stream_directory module matching "any": 1 candidates
[f45089d8] main stream_directory debug: no stream_directory modules matched
[f4506628] main input source debug: attachment of directory-extractor failed for file:///media/pi/data/Content/ATARI%20-%20Game%20Over%20-%20160325_atari_inf_3328k_p36v12.mp4
[f4507be0] main stream debug: looking for stream_filter module matching "record": 26 candidates
[f4507be0] main stream debug: using stream_filter module "record"
[f450e4d8] main demux debug: looking for demux module matching "mp4": 55 candidates
[01e8f168] main meta fetcher debug: looking for meta fetcher module matching "any": 1 candidates
[01e8f168] lua meta fetcher debug: Trying Lua scripts in /home/pi/.local/share/vlc/lua/meta/fetcher
[01e8f168] lua meta fetcher debug: Trying Lua scripts in /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/fetcher
[01e8f168] lua meta fetcher debug: Trying Lua scripts in /usr/share/vlc/lua/meta/fetcher
[01e8f168] main meta fetcher debug: no meta fetcher modules matched
[01e8f168] main art finder debug: looking for art finder module matching "any": 2 candidates
[01e8f168] lua art finder debug: Trying Lua scripts in /home/pi/.local/share/vlc/lua/meta/art
[01e8f168] lua art finder debug: Trying Lua scripts in /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art
[01e8f168] lua art finder debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art/00_musicbrainz.luac
[01e8f168] lua art finder debug: skipping script (unmatched scope) /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art/00_musicbrainz.luac
[01e8f168] lua art finder debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art/01_googleimage.luac
[01e8f168] lua art finder debug: skipping script (unmatched scope) /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art/01_googleimage.luac
[01e8f168] lua art finder debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art/02_frenchtv.luac
[01e8f168] lua art finder debug: skipping script (unmatched scope) /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art/02_frenchtv.luac
[01e8f168] lua art finder debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art/03_lastfm.luac
[01e8f168] lua art finder debug: skipping script (unmatched scope) /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art/03_lastfm.luac
[01e8f168] lua art finder debug: Trying Lua scripts in /usr/share/vlc/lua/meta/art
[01e8f168] main art finder debug: no art finder modules matched
[de5050d0] main meta fetcher debug: looking for meta fetcher module matching "any": 1 candidates
[de5050d0] lua meta fetcher debug: Trying Lua scripts in /home/pi/.local/share/vlc/lua/meta/fetcher
[de5050d0] lua meta fetcher debug: Trying Lua scripts in /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/fetcher
[de5050d0] lua meta fetcher debug: Trying Lua scripts in /usr/share/vlc/lua/meta/fetcher
[de5050d0] main meta fetcher debug: no meta fetcher modules matched
[de5061c0] main art finder debug: looking for art finder module matching "any": 2 candidates
[de5061c0] lua art finder debug: Trying Lua scripts in /home/pi/.local/share/vlc/lua/meta/art
[de5061c0] lua art finder debug: Trying Lua scripts in /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art
[de5061c0] lua art finder debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art/00_musicbrainz.luac
[de5061c0] lua art finder debug: skipping script (unmatched scope) /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art/00_musicbrainz.luac
[de5061c0] lua art finder debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art/01_googleimage.luac
[de5061c0] lua art finder debug: skipping script (unmatched scope) /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art/01_googleimage.luac
[de5061c0] lua art finder debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art/02_frenchtv.luac
[de5061c0] lua art finder debug: skipping script (unmatched scope) /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art/02_frenchtv.luac
[de5061c0] lua art finder debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art/03_lastfm.luac
[de5061c0] lua art finder debug: skipping script (unmatched scope) /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/art/03_lastfm.luac
[de5061c0] lua art finder debug: Trying Lua scripts in /usr/share/vlc/lua/meta/art
[de5061c0] main art finder debug: no art finder modules matched
[f4507be0] mp4 stream warning: unknown box type GPAC (incompletely loaded)
[f4507be0] mp4 stream debug: dumping root Box "root"
[f4507be0] mp4 stream debug: |   + ftyp size 24 offset 0
[f4507be0] mp4 stream debug: |   + moov size 2431155 offset 24
[f4507be0] mp4 stream debug: |   |   + mvhd size 108 offset 32
[f4507be0] mp4 stream debug: |   |   + iods size 21 offset 140
[f4507be0] mp4 stream debug: |   |   + trak size 1062778 offset 161
[f4507be0] mp4 stream debug: |   |   |   + tkhd size 92 offset 169
[f4507be0] mp4 stream debug: |   |   |   + mdia size 1062649 offset 261
[f4507be0] mp4 stream debug: |   |   |   |   + mdhd size 32 offset 269
[f4507be0] mp4 stream debug: |   |   |   |   + hdlr size 55 offset 301
[f4507be0] mp4 stream debug: |   |   |   |   + minf size 1062554 offset 356
[f4507be0] mp4 stream debug: |   |   |   |   |   + vmhd size 20 offset 364
[f4507be0] mp4 stream debug: |   |   |   |   |   + dinf size 36 offset 384
[f4507be0] mp4 stream debug: |   |   |   |   |   |   + dref size 28 offset 392
[f4507be0] mp4 stream debug: |   |   |   |   |   |   |   + url  size 12 offset 408
[f4507be0] mp4 stream debug: |   |   |   |   |   + stbl size 1062490 offset 420
[f4507be0] mp4 stream debug: |   |   |   |   |   |   + stsd size 178 offset 428
[f4507be0] mp4 stream debug: |   |   |   |   |   |   |   + avc1 size 162 offset 444
[f4507be0] mp4 stream debug: |   |   |   |   |   |   |   |   + avcC size 56 offset 530
[f4507be0] mp4 stream debug: |   |   |   |   |   |   |   |   + btrt size 20 offset 586
[f4507be0] mp4 stream debug: |   |   |   |   |   |   + stts size 24 offset 606
[f4507be0] mp4 stream debug: |   |   |   |   |   |   + ctts size 523096 offset 630
[f4507be0] mp4 stream debug: |   |   |   |   |   |   + stss size 5356 offset 523726
[f4507be0] mp4 stream debug: |   |   |   |   |   |   + stsc size 40 offset 529082
[f4507be0] mp4 stream debug: |   |   |   |   |   |   + stsz size 266896 offset 529122
[f4507be0] mp4 stream debug: |   |   |   |   |   |   + stco size 266892 offset 796018
[f4507be0] mp4 stream debug: |   |   |   + udta size 29 offset 1062910
[f4507be0] mp4 stream debug: |   |   |   |   + GPAC size 21 offset 1062918 (????)
[f4507be0] mp4 stream debug: |   |   + trak size 1368191 offset 1062939
[f4507be0] mp4 stream debug: |   |   |   + tkhd size 92 offset 1062947
[f4507be0] mp4 stream debug: |   |   |   + mdia size 1368062 offset 1063039
[f4507be0] mp4 stream debug: |   |   |   |   + mdhd size 32 offset 1063047
[f4507be0] mp4 stream debug: |   |   |   |   + hdlr size 55 offset 1063079
[f4507be0] mp4 stream debug: |   |   |   |   + minf size 1367967 offset 1063134
[f4507be0] mp4 stream debug: |   |   |   |   |   + smhd size 16 offset 1063142
[f4507be0] mp4 stream debug: |   |   |   |   |   + dinf size 36 offset 1063158
[f4507be0] mp4 stream debug: |   |   |   |   |   |   + dref size 28 offset 1063166
[f4507be0] mp4 stream debug: |   |   |   |   |   |   |   + url  size 12 offset 1063182
[f4507be0] mp4 stream debug: |   |   |   |   |   + stbl size 1367907 offset 1063194
[f4507be0] mp4 stream debug: |   |   |   |   |   |   + stsd size 91 offset 1063202
[f4507be0] mp4 stream debug: |   |   |   |   |   |   |   + mp4a size 75 offset 1063218
[f4507be0] mp4 stream debug: |   |   |   |   |   |   |   |   + esds size 39 offset 1063254
[f4507be0] mp4 stream debug: |   |   |   |   |   |   + stts size 400336 offset 1063293
[f4507be0] mp4 stream debug: |   |   |   |   |   |   + stsc size 200176 offset 1463629
[f4507be0] mp4 stream debug: |   |   |   |   |   |   + stsz size 500408 offset 1663805
[f4507be0] mp4 stream debug: |   |   |   |   |   |   + stco size 266888 offset 2164213
[f4507be0] mp4 stream debug: |   |   |   + udta size 29 offset 2431101
[f4507be0] mp4 stream debug: |   |   |   |   + GPAC size 21 offset 2431109 (????)
[f4507be0] mp4 stream debug: |   |   + udta size 49 offset 2431130
[f4507be0] mp4 stream debug: |   |   |   + GPAC size 14 offset 2431138 (????)
[f4507be0] mp4 stream debug: |   |   |   + cprt size 27 offset 2431152
[f4507be0] mp4 stream debug: |   + mdat size 1111529731 offset 2431179
[f4507be0] mp4 stream debug: |   + free size 58 offset 1113960910
[f450e4d8] mp4 demux debug: unrecognized major media specification (mp42).
[f450e4d8] mp4 demux debug: found 2 tracks
[f450e4d8] mp4 demux debug: track[Id 0x1] read 66719 chunk
[f450e4d8] mp4 demux warning: STTS table of 1 entries
[f450e4d8] mp4 demux warning: CTTS table of 65385 entries
[f450e4d8] mp4 demux debug: track[Id 0x1] read 66719 samples length:2668s
[dfb02ed0] main input debug: selecting program id=0
[f450e4d8] mp4 demux debug: adding track[Id 0x1] video (enable) language deu
[f450e4d8] mp4 demux debug: track[Id 0x2] read 66718 chunk
[f450e4d8] mp4 demux warning: STTS table of 50040 entries
[f450e4d8] mp4 demux debug: track[Id 0x2] read 125097 samples length:2668s
[f450e4d8] mp4 demux debug: adding track[Id 0x2] audio (enable) language deu
[f450e4d8] main demux debug: using demux module "mp4"
[dfb02ed0] main input debug: looking for a subtitle file in /media/pi/data/Content/
[f450f988] main decoder debug: looking for video decoder module matching "any": 17 candidates
[f450f988] avcodec decoder debug: using ffmpeg Lavc58.91.100
[f450f988] avcodec decoder debug: CPU flags: 0x0000003f
[f450f988] avcodec decoder debug: allowing 5 thread(s) for decoding
[h264_v4l2m2m @ 0xf4512c50] nal_unit_type: 7(SPS), nal_ref_idc: 3
[h264_v4l2m2m @ 0xf4512c50] nal_unit_type: 8(PPS), nal_ref_idc: 3
[h264_v4l2m2m @ 0xf4512c50] probing device /dev/video23
[h264_v4l2m2m @ 0xf4512c50] driver 'bcm2835-isp' on card 'bcm2835-isp' in unknown mode
[h264_v4l2m2m @ 0xf4512c50] probing device /dev/video22
[h264_v4l2m2m @ 0xf4512c50] driver 'bcm2835-isp' on card 'bcm2835-isp' in splane mode
[h264_v4l2m2m @ 0xf4512c50] v4l2 output format not supported
[h264_v4l2m2m @ 0xf4512c50] probing device /dev/video21
[h264_v4l2m2m @ 0xf4512c50] probing device /dev/video20
[h264_v4l2m2m @ 0xf4512c50] probing device /dev/video16
[h264_v4l2m2m @ 0xf4512c50] probing device /dev/video15
[h264_v4l2m2m @ 0xf4512c50] probing device /dev/video31
[h264_v4l2m2m @ 0xf4512c50] driver 'bcm2835-codec' on card 'bcm2835-codec-encode_image' in mplane mode
[h264_v4l2m2m @ 0xf4512c50] probing device /dev/video19
[h264_v4l2m2m @ 0xf4512c50] driver 'rpivid' on card 'rpivid' in mplane mode
[h264_v4l2m2m @ 0xf4512c50] probing device /dev/video18
[h264_v4l2m2m @ 0xf4512c50] driver 'bcm2835-codec' on card 'bcm2835-codec-image_fx' in mplane mode
[h264_v4l2m2m @ 0xf4512c50] probing device /dev/video12
[h264_v4l2m2m @ 0xf4512c50] driver 'bcm2835-codec' on card 'bcm2835-codec-isp' in mplane mode
[h264_v4l2m2m @ 0xf4512c50] probing device /dev/video14
[h264_v4l2m2m @ 0xf4512c50] probing device /dev/video11
[h264_v4l2m2m @ 0xf4512c50] driver 'bcm2835-codec' on card 'bcm2835-codec-encode' in mplane mode
[h264_v4l2m2m @ 0xf4512c50] probing device /dev/video10
[h264_v4l2m2m @ 0xf4512c50] driver 'bcm2835-codec' on card 'bcm2835-codec-decode' in mplane mode
[h264_v4l2m2m @ 0xf4512c50] Using device /dev/video10
[h264_v4l2m2m @ 0xf4512c50] requesting formats: output=H264 capture=YU12
[h264_v4l2m2m @ 0xf4512c50] output: H264 16 buffers initialized: 0000x0000, sizeimage 00756736, bytesperline 00000000
[h264_v4l2m2m @ 0xf4512c50] Driver 'bcm2835-codec': Quirks=0
[h264_v4l2m2m @ 0xf4512c50] check_profile: Control supported: 0x990a6b
[f450f988] avcodec decoder debug: available hardware decoder output format 181 (drm_prime)
[f450f988] avcodec decoder debug: available software decoder output format 23 (nv12)
[f450f988] avcodec decoder debug: available software decoder output format 0 (yuv420p)
[f450f988] avcodec decoder debug: trying format drm_prime
[cf404520] main spu text debug: looking for text renderer module matching "any": 2 candidates
[cf404520] freetype spu text debug: Building font databases.
[cf404520] freetype spu text debug: Took -21211 microseconds
[cf404520] main spu text debug: using text renderer module "freetype"
[cf429248] main scale debug: looking for video converter module matching "any": 18 candidates
[swscaler @ 0xce57d2e0] Forcing full internal H chroma due to input having non subsampled chroma
[cf429248] swscale scale debug: 32x32 (32x32) chroma: YUVA -> 16x16 (16x16) chroma: RGBA with scaling using Bicubic (good quality)
[cf429248] main scale debug: using video converter module "swscale"
[ce596e88] main scale debug: looking for video converter module matching "any": 18 candidates
[ce596e88] yuvp scale debug: YUVP to YUVA converter
[ce596e88] main scale debug: using video converter module "yuvp"
[cf4034a8] main video output debug: Deinterlacing available
[cf4034a8] main video output debug: deinterlace -1, mode auto, is_needed 0
[cf413f20] main window debug: looking for vout window module matching "qt,any": 6 candidates
[cf413f20] qt window debug: requesting video window...
[cf413f20] main window debug: resized to 674x383
[cf413f20] main window debug: using vout window module "qt"
[cf42f4f0] main inhibit debug: looking for inhibit module matching "any": 2 candidates
[cf42f4f0] dbus_screensaver inhibit debug: cannot find service org.freedesktop.ScreenSaver
[cf42f4f0] dbus_screensaver inhibit debug: cannot find service org.freedesktop.PowerManagement.Inhibit
[cf42f4f0] dbus_screensaver inhibit debug: cannot find service org.mate.SessionManager
[cf42f4f0] dbus_screensaver inhibit debug: cannot find service org.gnome.SessionManager
[cf42f4f0] main inhibit debug: using inhibit module "xdg"
[cf4034a8] main video output debug: Opening vout display wrapper
[df1060c8] main vout display debug: looking for vout display module matching "any": 18 candidates
[df1060c8] mmal_xsplitter vout display debug: >>> OpenMmalX11: DPV0,1280x720 [(0,0) 1280/720] sar:0/0
[df105d90] main generic debug: looking for vout display module matching "opengles2": 18 candidates
[df1060c8] main vout display debug: VoutDisplayEvent 'resize' 674x383
[df1064b8] main gl debug: looking for opengl es2 module matching "any": 2 candidates
[df1064b8] egl_x11 gl debug: EGL version 1.4 by Mesa Project
[df1064b8] egl_x11 gl debug:  extensions: EGL_ANDROID_blob_cache EGL_CHROMIUM_sync_control EGL_EXT_buffer_age EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_EXT_swap_buffers_with_damage EGL_KHR_cl_event2 EGL_KHR_config_attribs EGL_KHR_create_context EGL_KHR_create_context_no_error EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_no_config_context EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_KHR_swap_buffers_with_damage EGL_EXT_pixel_format_float EGL_KHR_wait_sync EGL_MESA_configless_context EGL_MESA_drm_image EGL_MESA_image_dma_buf_export EGL_MESA_query_driver EGL_NOK_texture_from_pixmap
[df1064b8] main gl debug: using opengl es2 module "egl_x11"
[df1064b8] gles2 gl: Initialized libplacebo v2.72.0 (API v72)
[df184d80] main generic debug: looking for glconv module matching "any": 2 candidates
[df184d80] drm_gl_conv generic debug: <<< OpenGLConverter: DPV0 1280x720 [(0,0) 1280/720] sar:0/0
[df184d80] main generic debug: using glconv module "drm_gl_conv"
[df105d90] main generic debug: using vout display module "gles2"
[df1060c8] mmal_xsplitter vout display debug: R/G/B: 00000000/00000000/00000000
[df1060c8] mmal_xsplitter vout display debug: Opengles2 output found
[cb39c798] main generic debug: looking for vout display module matching "mmal_vout": 18 candidates
[cb39c798] mmal_vout generic debug: KMS active - mmal vout disabled
[cb39c798] main generic debug: no vout display modules matched
[df1060c8] mmal_xsplitter vout display debug: Failed to open Xsplitter:mmal_vout module
[df1060c8] main vout display debug: using vout display module "mmal_xsplitter"
[cf4034a8] main video output debug: original format sz 1280x720, of (0,0), vsz 1280x720, 4cc DPV0, sar 1:1, msk r0x0 g0x0 b0x0
[df1060c8] mmal_xsplitter vout display debug: Change size: 674, 383: fs=0
[cf404520] main spu text debug: removing module "freetype"
[cf404520] freetype spu text debug: Took -19890 microseconds
[cf41e730] main generic debug: looking for hw decoder module matching "any": 1 candidates
[cf41e730] drm_avcodec generic debug: Open: pix_fmt=181
[cf41e730] main generic debug: using hw decoder module "drm_avcodec"
[f450f988] avcodec decoder: Using DRM Video Accel for hardware decoding
[h264_v4l2m2m @ 0xf4512c50] Format drm_prime chosen by get_format().
[h264_v4l2m2m @ 0xf4512c50] avctx requested=-1 ((null)) 1280x720; get_format requested=181 (drm_prime)
[f450f988] avcodec decoder debug: codec (h264_v4l2m2m) started
[f450f988] main decoder debug: using video decoder module "avcodec"
[cf4094d0] main decoder debug: looking for audio decoder module matching "any": 21 candidates
[cf4094d0] main decoder debug: using audio decoder module "faad"
[cf42eb90] main demux meta debug: looking for meta reader module matching "any": 2 candidates
[cf42eb90] lua demux meta debug: Trying Lua scripts in /home/pi/.local/share/vlc/lua/meta/reader
[cf42eb90] lua demux meta debug: Trying Lua scripts in /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/reader
[cf42eb90] lua demux meta debug: Trying Lua playlist script /usr/lib/arm-linux-gnueabihf/vlc/lua/meta/reader/filename.luac
[cf42eb90] lua demux meta debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader
[cf42eb90] main demux meta debug: no meta reader modules matched
[dfb02ed0] main input debug: `file:///media/pi/data/Content/ATARI%20-%20Game%20Over%20-%20160325_atari_inf_3328k_p36v12.mp4' successfully opened
[f450e4d8] mp4 demux debug: track[Id 0x1] using Sync Sample Box (stss)
[f450e4d8] mp4 demux debug: stss gives 0 --> 0 (sample number)
[dfb02ed0] main input debug: Buffering 0%
[cf4094d0] faad decoder warning: decoded zero sample
[01ea5720] main playlist debug: reusing audio output
[01eb47e0] pulse audio output debug: using stereo channel map
[dfb02ed0] main input debug: Buffering 25%
[dfb02ed0] main input debug: Buffering 50%
[h264_v4l2m2m @ 0xf4512c50] output set status 1074026002 (ON) OK
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000001 count=0
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000001 count=1
[01eb47e0] pulse audio output debug: changed buffer metrics: maxlength=4194304, tlength=53744, prebuf=0, minreq=15360
[01eb47e0] pulse audio output debug: connected to sink alsa_output.platform-fef00700.hdmi.hdmi-stereo
[01eb47e0] main audio output debug: output 'f32l' 48000 Hz Stereo frame=1 samples/8 bytes
[e0e0a138] main volume debug: looking for audio volume module matching "any": 3 candidates
[01eb47e0] pulse audio output debug: changing sink 0: alsa_output.platform-fef00700.hdmi.hdmi-stereo (Internes Audio Digital Stereo (HDMI))
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 1, ts=0.000002 count=1
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 1, ts=0.000002 count=2
[e0e0a138] main volume debug: using audio volume module "float_mixer"
[01eb47e0] main audio output debug: input 'f32l' 48000 Hz Stereo frame=1 samples/8 bytes
[e0e0f960] main audio filter debug: looking for audio filter module matching "scaletempo": 16 candidates
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000003 count=1
[e0e0f960] scaletempo audio filter debug: format: 48000 rate, 2 nch, 4 bps, fl32
[e0e0f960] scaletempo audio filter debug: params: 30 stride, 0,200 overlap, 14 search
[e0e0f960] scaletempo audio filter debug: 1,000 scale, 1440,000 stride_in, 1440 stride_out, 1152 standing, 288 overlap, 672 search, 2400 queue, fl32 mode
[e0e0f960] main audio filter debug: using audio filter module "scaletempo"
[01eb47e0] main audio output debug: conversion: 'f32l'->'f32l' 48000 Hz->48000 Hz Stereo->Stereo
[01eb47e0] main audio output debug: conversion pipeline complete
[e0e088e8] main audio resampler debug: looking for audio resampler module matching "any": 4 candidates
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000003 count=2
[e0e088e8] main audio resampler debug: using audio resampler module "samplerate"
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000004 count=0
[dfb02ed0] main input debug: Buffering 75%
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000004 count=1
[h264_v4l2m2m @ 0xf4512c50] Dq event 5
[h264_v4l2m2m @ 0xf4512c50] V4L2 capture changed: alloc=0 (32x32) -> (1280x720)
[h264_v4l2m2m @ 0xf4512c50] Source change: SAR: 1/1, wxh 1280x720 crop 1280x720 @ 0,0, reinit=1
[h264_v4l2m2m @ 0xf4512c50] reinit context
[dfb02ed0] main input debug: Buffering 100%
[dfb02ed0] main input debug: Stream buffering done (1250 ms in 40 ms)
[h264_v4l2m2m @ 0xf4512c50] capture: YU12 20 buffers initialized: 1280x0720, sizeimage 01382400, bytesperline 00001280
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 0, ts=0.000000 count=1
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 1, ts=0.000000 count=2
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 2, ts=0.000000 count=3
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 3, ts=0.000000 count=4
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 4, ts=0.000000 count=5
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 5, ts=0.000000 count=6
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 6, ts=0.000000 count=7
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 7, ts=0.000000 count=8
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 8, ts=0.000000 count=9
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 9, ts=0.000000 count=10
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 10, ts=0.000000 count=11
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 11, ts=0.000000 count=12
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 12, ts=0.000000 count=13
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 13, ts=0.000000 count=14
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 14, ts=0.000000 count=15
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 15, ts=0.000000 count=16
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 16, ts=0.000000 count=17
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 17, ts=0.000000 count=18
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 18, ts=0.000000 count=19
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 19, ts=0.000000 count=20
[h264_v4l2m2m @ 0xf4512c50] capture set status 1074026002 (ON) OK
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000005 count=0
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000005 count=1
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 1, ts=0.000006 count=1
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 1, ts=0.000006 count=2
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 2, ts=0.000007 count=2
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 2, ts=0.000007 count=3
[h264_v4l2m2m @ 0xf4512c50] Decode running
[f450f988] main decoder debug: Received first picture
[h264_v4l2m2m @ 0xf4512c50] pts_stats_add: decoder: New interval: 0->40000/1=40000
[dfb02ed0] main input debug: Decoder wait done in 47 ms
[01eb47e0] pulse audio output debug: cannot synchronize start
[01eb47e0] pulse audio output debug: deferring start (30284 us)
[01eb47e0] pulse audio output debug: deferring start (8084 us)
[01eb47e0] pulse audio output warning: starting late (-14592 us)
[01eb47e0] pulse audio output debug: started
[01eb47e0] pulse audio output debug: underflow
[df1060c8] main vout display debug: auto hiding mouse cursor
[cf4034a8] main video output warning: picture is too late to be displayed (missing 325 ms)
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000008 count=0
[h264_v4l2m2m @ 0xf4512c50] capture: Buffer requeue
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 1, ts=0.000003 count=19
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000008 count=1
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000009 count=0
[cf4034a8] main video output warning: picture is too late to be displayed (missing 287 ms)
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000009 count=1
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000010 count=0
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000010 count=1
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000011 count=0
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 2, ts=0.000002 count=17
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 1, ts=0.000840 count=1
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000868 count=0
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000868 count=1
[cf4034a8] qt video output debug: Qt: Fullscreen state changed
[cf4034a8] qt video output debug: Qt: Entering Fullscreen
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 2, ts=0.000843 count=1
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000869 count=0
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000869 count=1
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 5, ts=0.000846 count=1
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000874 count=0
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000874 count=1
[cf413f20] main window debug: resized to 1920x1080
[df1060c8] main vout display debug: VoutDisplayEvent 'resize' 1920x1080
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 6, ts=0.000849 count=1
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000875 count=0
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000875 count=1
[df1060c8] mmal_xsplitter vout display: Try drm
[cb0b84f0] main generic debug: looking for vout display module matching "drm_vout": 18 candidates
[cb0b84f0] drm_vout generic: <<< OpenDrmVout: Fmt=DPV0
[cb0b84f0] drm_vout generic debug: index 116 screen 0 rem 1
[cb0b84f0] drm_vout generic debug: output[0/2] 69: conn 0/0 crtc 66
[cb0b84f0] drm_vout generic debug: get_lease_fd OK: fd=61
[cb0b84f0] drm_vout generic debug: Using conn <auto>
[cb0b84f0] drm_vout generic error: drmu_plane_new_find_type: No plane found for types 0x5
[cb0b84f0] drm_vout generic warning: Cannot allocate subplane 1
[cb0b84f0] drm_vout generic debug: Create dumb 0xcb3bc4e8 AB24 128x128 / 128x128 size: 65536
[cb0b84f0] drm_vout generic debug: Window: fullscreen
[cb0b84f0] main generic debug: using vout display module "drm_vout"
[df1060c8] mmal_xsplitter vout display debug: Change size: 1920, 1080: fs=1
[df1060c8] main vout display warning: VoutDisplayEvent 'pictures invalid'
[cf4034a8] main video output warning: picture is too late to be displayed (missing 80 ms)
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 9, ts=0.000851 count=1
[cf4034a8] main video output warning: picture is too late to be displayed (missing 40 ms)
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 10, ts=0.000853 count=2
[cf4034a8] main video output debug: picture might be displayed late (missing 1 ms)
[df1060c8] mmal_xsplitter vout display debug: <<< mmal_x11_control: Pic reset: fmt: DPV0,1280x720<-DPV0,1280x720, source: DPV0,1280x720/1280x720
[cb0b84f0] drm_vout generic warning: Reset Pictures
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000876 count=0
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000876 count=1
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000877 count=0
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000877 count=1
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 0, ts=0.000852 count=1
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000878 count=0
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000878 count=1
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 15, ts=0.000857 count=1
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000881 count=0
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000881 count=1
[cf413f20] main window debug: resized to 674x495
[df1060c8] main vout display debug: VoutDisplayEvent 'resize' 674x495
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 16, ts=0.000856 count=1
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000882 count=0
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000882 count=1
[df1060c8] mmal_xsplitter vout display debug: Change size: 674, 495: fs=1
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 17, ts=0.000859 count=1
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.000883 count=0
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.000883 count=1
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 1, ts=0.001094 count=1
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.001120 count=0
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.001120 count=1
[cf4034a8] qt video output debug: Qt: Quitting Fullscreen
[cf413f20] main window debug: resized to 674x412
[df1060c8] main vout display debug: VoutDisplayEvent 'resize' 674x412
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 2, ts=0.001097 count=1
[df1060c8] mmal_xsplitter vout display debug: Change size: 674, 412: fs=0
[h264_v4l2m2m @ 0xf4512c50] --- output pre VIDIOC_QBUF: index 0, ts=0.001121 count=0
[cb0b84f0] main generic debug: removing module "drm_vout"
[cb0b84f0] drm_vout generic debug: <<< CloseDrmVout
[h264_v4l2m2m @ 0xf4512c50] --- output VIDIOC_QBUF: index 0, ts=0.001121 count=1
[h264_v4l2m2m @ 0xf4512c50] --- capture VIDIOC_QBUF: index 3, ts=0.001096 count=1
on github, which raspberry pi repository is responsible for VLC ?
- rpi-distro/repo
- raspberrypi/linux
- raspberrypi/userland
ChibitulSmecher
Fri Oct 06, 2023 1:07 pm
I have a Pi 4 Model B 4 GB RAM with running the OS below and I have the screen blanking bug. I did the updates mentioned here, it seemed to work once or twice, but now I can see the screen going blank and the monitor comes right back a few seconds later. I turned the screen blanking ON and OFF and rebooter each time, I tried both from the control panel and also from the terminal utility.
I don't know what else to try. Maybe I just make a habit of turning the monitor ON and OFF manually.
Release date: May 3rd 2023
System: 64-bit
Kernel version: 6.1
Debian version: 11 (bullseye)
dom
Fri Oct 06, 2023 1:14 pm
- rpi-distro/repo
- raspberrypi/linux
RPi-Distro/vlc
twilightened
Fri Oct 06, 2023 7:57 pm
I understand that RPI5 is on schedule to be released so all the attention of the software team is probably on it right now to make things work until the release, however, VLC is the "only" video playback program that can be used under RPI4 and it has been a long time since this bug has been reported. Can RPI4 still get a little bit more love, maybe at least after the release of the PI5? It would be appreciated.
redvli
Sat Oct 07, 2023 7:37 am
I assume there will be a sort of 'big-bang' posting the Bookworm image for all Pis. You might want to 'burn' a fresh image, I will do the well known Debian sources.list* edits etc and then upgrade. I will need to remove bullseye-backports here and there, but no hurry for me. For several Pis I did a dist-upgrade to Debian Testing some time ago, on a Pi3B+ fullscreen console videoplaying with mpv worked really well. But you want desktop GUI I guess, so the easy/best way is to prepare for change to Wayland. You can do it now, but it is experimental in RPiOS Bullseye, so windows might be wrong-sized and so on. As long as it doesn't crash, it might be a better choice. In Bookworm for sure, Pi is not good for using X11.
I am currently typing this on my Pi4-8GB (with bullseye-backports and KDE-Plasma DE), works good enough playing HEVC/H265 1080p50 videos, although I see stutter when a server process on this Pi gets more active. Also that might be gone with Wayland, we will see.
twilightened
Sat Oct 07, 2023 4:07 pm
I just tried wayland (sudo raspi-config) and it has so many problems still. One of the most obvious was when i opened Chromium, there was no button on the taskbar for it, so when you minimize it, it is gone. The on screen text however seemed improved in wayland (seemed like microsoft's clear type to me). And videos played fine both in fullscreen and windowed in VLC so yeah, wayland actually fixes "that" problem but it comes with its own set of issues yet.
twilightened
Fri Oct 13, 2023 10:36 pm
VLC fullscreen problem seems to have been fixed. There is a new output mode in VLC now which is called "X11 video output (XCB)". If you select this one, you can go full screen and come back without any issues. There is no screen tearing, and you can actually see the video controls in fullscreen now. Great work, whoever has done it. I was considering upgrading to Bookworm, but seeing that people are complaining about so many things, i have decided to stay on Bullseye for a while. If it works, don't fix it.
redvli
Sat Oct 14, 2023 6:38 am
I always wondered about the screen tearing in Bullseye that people report, I never actually saw it. My recipe is disabling the compositor in the KDE plasma settings and using the default sddm, after getting rid of every trace of mutter openbox lx* rpi hacks etc. My first trial long time ago was with Xfce, some good results actually (openSUSE Tumbleweed). If you have used KDE for years on PC/tablet, it is simple workaround. Note that I disable all animations, I use KDE mainly for its default apps with konsole the main one. Besides FireFox and mpv.
Wayland is good concept, but it is 'new'. I notice less real-time mouse behavior, both KDE and a fresh 2023-10-10 image I tested on my test Pi4. The Bookworm default desktop is good basic, but I still get the immediate feeling that I play with some toy computer again like in 2014 or so when I bought the Pi1 unfortunately, even though the Pi4-8GB runs/manages my whole house more or less.
PiOS64 Bookworm KDE Wayland or X11 doesn't really matter actually, Wayland is more buggy but faster under the hood, but Pi4 is fast enough to handle the normal X11 overhead. The limited internal bus effects are still there, so when high load multitasking, don't use VC4/HDMI, only the ARMs so headless or use other computer platform.
twilightened
Sat Oct 14, 2023 8:06 pm
I spoke too early. X11 video output module can not display subtitles. This time i actually opened a bug report, hopefuly in the right place:
https://github.com/RPi-Distro/vlc/issues/90
julienrobin28
Sun Oct 22, 2023 10:41 pm
RealVNC server, which is still used/enabled by raspi-config on RPi 1 2 and 3 models, is working on 64 bits versions of the OS, but is broken in 32 bits version, because 32 bits version is relying on libmmal.so
On 32 bits version (broken):
root@pi2-crobe-tuning:~# ldd /usr/bin/vncserver-x11-core
	linux-vdso.so.1 (0x7eb52000)
	/usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so => /usr/lib/arm-linux-gnueabihf/libarmmem-v7l.so (0x76f10000)
	libbcm_host.so => /lib/arm-linux-gnueabihf/libbcm_host.so (0x76ee7000)
	libvcos.so => /lib/arm-linux-gnueabihf/libvcos.so (0x76f27000)
	libmmal.so => not found
	libmmal_core.so => not found
	libmmal_components.so => not found
	libmmal_util.so => not found
	libmmal_vc_client.so => not found
	libvchiq_arm.so => /lib/arm-linux-gnueabihf/libvchiq_arm.so (0x76edf000)
	libvcsm.so => not found
	libcontainers.so => not found
	libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0x76edc000)
	librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0x76ed9000)
	libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0x76ed6000)
	libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0x76e8f000)
	libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0x76e50000)
	libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0x76cd7000)
	/lib/ld-linux-armhf.so.3 (0x76f34000)
journalctl | grep vnc
Oct 23 00:31:28 pi2-crobe-tuning vncserver-x11-serviced[1740]: /usr/bin/vncserver-x11-core: error while loading shared libraries: libmmal.so: cannot open shared object file: No such file or directory
Oct 23 00:31:28 pi2-crobe-tuning vncserver-x11-serviced[659]: vncserver-x11-serviced: Server exited with status 127, restarting in 3600s
On 64 bits version (working):
root@pi3-crobe-mamelle:~# ldd /usr/bin/vncserver-x11-core
	linux-vdso.so.1 (0x0000007fb45db000)
	libbcm_host.so.0 => /lib/aarch64-linux-gnu/libbcm_host.so.0 (0x0000007fb3f10000)
	libvcos.so.0 => /lib/aarch64-linux-gnu/libvcos.so.0 (0x0000007fb3ee0000)
	libvchiq_arm.so.0 => /lib/aarch64-linux-gnu/libvchiq_arm.so.0 (0x0000007fb3eb0000)
	libdl.so.2 => /lib/aarch64-linux-gnu/libdl.so.2 (0x0000007fb3e80000)
	librt.so.1 => /lib/aarch64-linux-gnu/librt.so.1 (0x0000007fb3e50000)
	libpthread.so.0 => /lib/aarch64-linux-gnu/libpthread.so.0 (0x0000007fb3e20000)
	libm.so.6 => /lib/aarch64-linux-gnu/libm.so.6 (0x0000007fb3d80000)
	libgcc_s.so.1 => /lib/aarch64-linux-gnu/libgcc_s.so.1 (0x0000007fb3d40000)
	libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x0000007fb3b90000)
	/lib/ld-linux-aarch64.so.1 (0x0000007fb459e000)
EddieWesson
Tue Nov 07, 2023 7:52 pm
Hi there,
Just an idea for the next version of the OS - when switching through with Alt + Tab, I've noticed that it doesn't seem to take into account what program I was using last, it simply flicks through a list of what programs I have open. This means if I'm trying to quickly flick between two applications, e.g. Terminal and Chromium, but I also have a few other windows open I first have to sort through the other windows before I reach Terminal/Chromium, at which point I'll have to cycle through again. Another idea is that I can only see 3 windows at a time - perhaps that could be changed for something similar to what Windows and MacOS do, (it displaying all available options)? Also being able to scroll through the available windows with the arrow keys, scroll wheel, or wasd could be an idea.
Return to “Raspberry Pi OS”
