VioletGiraffe
How to change desktop resoltion in Raspberry OS Bookworm?
Tue Dec 05, 2023 8:35 am
All the Internet articles show that you can right-click the desktop and adjust display resolution from the context menu, but there's no such option in Bookworm. I can't find it anywhere in the GUI. Did they forget to implement it in the new OS release? IS there a 3rdparty application I can install with apt that allows for adjusting resolution?
Re: How to change desktop resoltion in Raspberry OS Bookworm?
Tue Dec 05, 2023 8:39 am
Try using xrandr or wlr-randr. Start those from a command window.
VioletGiraffe
Tue Dec 05, 2023 9:01 am
Thank you, sir! Both work, wl-randr might be a tad simpler to figure out the first time (both have inconvenient command-line interface).
Would be nice to get a GUI for this eventually :)
UPDATE: this was my mistake all along, the normal "Display Configuration" menu item was missing because this was not a full Raspberry OS install, but a Lite version onto which I installed the desktop manually. Sorry for the confusion (I had no idea this is why some settings were missing, because otherwise I got a completely functional system out of doing this with nothing hinting at an incomplete install).
Last edited by VioletGiraffe on Tue Dec 05, 2023 12:46 pm, edited 2 times in total.
PeterO
Tue Dec 05, 2023 9:04 am
If you are running Wayland+Wayfire (the default) this might help, but I've not tried it myself so YMMV ...
https://github.com/WayfireWM/wayfire/wi ... ion#output
PeterO
Interests: C,Python,PICO,Electronics,Ham Radio (G0DZB),1960s British Computers.
PeterO
Tue Dec 05, 2023 9:06 am
There already is one (it's part of Wayfire Configuration Manager) that RPT don't ship :(
PeterO.
kerry_s
Tue Dec 05, 2023 9:40 am
menu -> preferences -> screen configuration
VioletGiraffe
Tue Dec 05, 2023 10:00 am
Have you actually tried it on the latest RPi OS?
kerry_s
Tue Dec 05, 2023 10:18 am
yes and it works for wayfire
i don't really care for the cascading menus or wayfire.
my setup uses xfce4-appfinder & sway with the panel. my resolution is done in sway, so i have a script to change between the 2 i use.
VioletGiraffe
Tue Dec 05, 2023 10:37 am
That's interesting, the thing is, out of the box there is no such menu item. Is there a package I can install with apt to get the GUI for resolution setting? Without replacing the whole desktop or other desktop-related stuff?
I tried apt install sway and there is such a package, but I'm not sure whether it would make my OS too non-stock (i. e. buggy and hard to support in the future). Either way it's interesting that there is such an option, thanks for the tip.
kerry_s
Tue Dec 05, 2023 10:54 am
:lol:
it should have been there, you most have a bad install.
the package it called arandr
don't install sway, sway is a window manager i replaced wayfire with.
what rpi device are you using.
the rpi4's and up get the new desktop.
the lower end devices get the old desktop.
VioletGiraffe
Tue Dec 05, 2023 11:08 am
UPDATE: arandr works! Amazing, thank you very much! It's just not installed by default :shock:
Oh, right, I forgot to mention. It's Pi 4 and it's a fresh Raspberry OS install through the imager. I also have more than one of these (there's also a CM4), flashed from different PCs, none has display settings GUI. It absolutely is not a bad install or modified OS.
kerry_s
Tue Dec 05, 2023 11:19 am
very strange, in all the installs i've done it's there.
perhaps it's because i don't update during setup, i like to wait till i get to the desktop.
VioletGiraffe
Tue Dec 05, 2023 11:36 am
My bad, then, thank you for that bit of info as well. This is Pi OS Lite converted to desktop with
sudo apt install raspberrypi-ui-mods
I didn't want any extra junk, but I didn't realize this package may not even include screen settings. From now on I know better and will install the full official desktop ROS build when appropriate.
P. S. Why did you switch to sway? Is it better at something?
kerry_s
Tue Dec 05, 2023 11:54 am
i like a tiling desktop.
in stock raspberry you have to ctrl+alt+left or right arrow, i prefer a more auto approach.
just use the recommended next time, there's only thonny / geany /vlc for the extra apps, the rest is standard desktop you find on any install.
most of the time i use an os with a gnome desktop. but i always keep a copy of raspberry i boot up to keep it up to date.
even then i tend to have pop-shell for auto tiling.
if your rpi4 is 4gb you can try out tiling for yourself using pop os.
https://pop.system76.com/
Return to “Raspberry Pi OS”
