pol9520
Use Dolphin with Vulkan on RPi5
Fri Dec 08, 2023 5:27 pm
I tried to use Dolphin with Vulkan on Raspberry Pi 5 (Raspberry Pi OS 64 bit) :
  • sudo apt update
    sudo apt install dolphin-emu
    sudo apt install mesa-vulkan-drivers
but I have this error :
Failed to initialize bounding box.
Failed to initialize renderer classes
FIFO shutting down while active
Failed to initialize video backend!
It work using OpenGL.
pol9520
Re: Use Dolphin with Vulkan on RPi5
Sun Dec 10, 2023 6:49 am
I think the version is too old.
I tried to install :
sudo snap install dolphin-emulator --edge
error: snap "dolphin-emulator" is not available on edge for this architecture
      (arm64) but exists on other architectures (amd64).
Taggerpi5
Mon Dec 11, 2023 10:19 am
  • sudo apt update
In the Option, where you can select the renderer "Vulcan" there is a 2nd Option Drop down, where you can chose another Renderer under Vulcan. It is working but way slower than OPENGL.
pol9520
Tue Dec 12, 2023 11:05 am
The second option is "llvmpipe", it use sofware and not hardware, which leads to poor performance.
Return to “Gaming”
