ejolson
Re: Advent of Code 2023
Fri Dec 08, 2023 9:15 pm
ejolson wrote:
Wed Dec 06, 2023 9:50 pm
The output on an Intel i3-550 was
$ julia day01.jl
Advent of Code 2023 Day 1 Trebuchet
Part 1 The sum of calibration values is 54968
Part 2 The English calibration value is 54094
Total execution time 0.289618602 seconds.
which includes the just-in-time compilation.
The output on a Pi Zero is
$ julia day01.jl
Total execution time 7.539847265 seconds.
which is slower but noticeably works and produces the correct answer.
Before teaching I had some time so I worked puzzle 2 and obtained
$ julia day02.jl
Advent of Code 2023 Day 2 Cube Conundrum
Part 1 The sum of the IDs is 2600
Part 2 The sum the powers is 86036
Total execution time 6.332537949 seconds.
on the same Pi Zero.
For reference the code was
#=  Advent of Code 2023 Day 2 Cube Conundrum
    Written 2023 by Eric Olson =#
struct DoExit <: Exception
end
function gobble(s::String,m::String)::Tuple{String,Bool}
    if length(s)<length(m)
        return s,false
    end
    if s[1:length(m)]==m
        return s[length(m)+1:end],true
    end
    return s,false
end
function getint(s::String)::Tuple{String,Int}
    n=0
    for i=1:length(s)
        if s[i]>='0'&&s[i]<='9'
            n=n*10+(s[i]-'0')
        else
            return s[i:end],n
        end
    end
    return "",n
end
function getdraw(s::String)::Tuple{String,Vector{Int}}
    r=s
    z=zeros(Int,3)
    while true
        s,n=getint(s)
        if n==0
            return s,z
        end
        if begin s,f=gobble(s," red"); f end
            z[1]=n
        elseif begin s,f=gobble(s," green"); f end
            z[2]=n
        elseif begin s,f=gobble(s," blue"); f end
            z[3]=n
        end
        if begin s,f=gobble(s,", "); !f end
            if length(s)>0
                if begin s,f=gobble(s,"; "); !f end
                    println("$r\nUnable to parse draw!")
                    throw(DoExit())
                end
            end
            return s,z
        end
    end
end
function getgame1(s::String)::Int
    r=s
    if begin s,f=gobble(s,"Game "); !f end
        println("$r\nDid not begin with Game!")
        throw(DoExit())
    end
    if begin s,n=getint(s); n==0 end
        println("$r\nCould not parse game number!")
        throw(DoExit())
    end
    if begin s,f=gobble(s,": "); !f end
        println("$r\nMissing : separator!")
        throw(DoExit())
    end
    while length(s)>0
        s,z=getdraw(s)
        if z[1]>12||z[2]>13||z[3]>14
            return 0
        end
    end
    return n
end
function getgame2(s::String)::Int
    r=s
        throw(DoExit())
    end
        throw(DoExit())
    end
        throw(DoExit())
    end
    zmin=zeros(Int,3)
    while length(s)>0
        s,z=getdraw(s)
        for i=1:3
            if zmin[i]<z[i]
                zmin[i]=z[i]
            end
        end
    end
    return prod(zmin)
end
function partn(data,getgame)
    r=0
    for i=1:length(data)
        r+=getgame(data[i])
    end
    return r
end
function doinit()
    data=[]
    open("day02.txt","r") do fp
        data=readlines(fp)
    end
    p1=partn(data,getgame1)
    p2=partn(data,getgame2)
    println("Part 1 The sum of the IDs is ",p1)
    println("Part 2 The sum the powers is ",p2)
end
function main()
    t=@elapsed try
        println("Advent of Code 2023 Day 2 Cube Conundrum\n")
        doinit()
        throw(DoExit())
    catch r
        if !isa(r,DoExit)
            rethrow(r)
        end
    end
    println("\nTotal execution time ",t," seconds.")
end
main()
Although the end keyword is used as an index, none of the code was written by ChatGPT.
ejolson
Fri Dec 08, 2023 9:21 pm
$ julia day02.jl
The just-in-time compiler runs much faster after warming up. This can be seen when using Julia interactively on the Pi Zero.
$ julia
               _
   _       _ _(_)_     |  Documentation: https://docs.julialang.org
  (_)     | (_) (_)    |
   _ _   _| |_  __ _   |  Type "?" for help, "]?" for Pkg help.
  | | | | | | |/ _` |  |
  | | |_| | | | (_| |  |  Version 1.6.7 (2022-07-19)
 _/ |\__'_|_|_|\__'_|  |
|__/                   |
julia> include("day02.jl")
Total execution time 6.235623485 seconds.
julia> main()
Total execution time 0.077048574 seconds.
julia> main()
Total execution time 0.077007574 seconds.
Note the second and third runs are about 80 times faster than the first.
lurk101
Sat Dec 09, 2023 2:14 am
ejolson wrote:
Fri Dec 08, 2023 4:24 pm
I'd like to generate more data and scale the problem up for lots of the puzzles so the computation is large enough a parallel algorithm could be efficient.
Day 8 run time can be cut in half by multithreading part 2.
hrvoje064
Sat Dec 09, 2023 10:44 am
I got interested in this when I read that you actually asked Chat GPT for solution. So I tried just a quick (pure force) Scheme (Racket) solution for the first (trebuchet) problem.
#lang racket
(require racket/file)
(define (code-sum file)
  (let ((lines
          (map
           (lambda (chr-lst) (map string chr-lst))
           (map string->list (file->lines file #:mode 'text)))))
         (apply + (map f+l lines (map reverse lines)))))
(define (f+l xl yl)
  (let ((left (findf string->number xl))
        (right (findf string->number yl)))
    (cond
      ((and left right) (string->number (string-append left right)))
      (left (string->number (string-append left left)))
      (right (string->number (string-append right right)))
      (else 0))))
As you see just a few maps (inside maps) and two findf. This does not do anything with word numbers, but I dont think that Julia GPT program does either.
hrvoje064
Sat Dec 09, 2023 10:58 am
:roll:
This was too fast, and overly complicated.
#lang racket
  (let ((lines
          (map
(define (f+l xl yl)
    (if left
        0)))
RogerW
Sat Dec 09, 2023 11:38 am
Did anyone else struggle with day 5 part 2? My code works on the test data and part 1 completes but part 2 takes forever. I know it is not hung but the very long ranges of seeds mean it would take hours if not days to complete. Clearly I am missing a shortcut but cannot see it. can anyone point me in the right direction.
#include <iostream>
#include <fstream>
#include <string>
#include <sstream>
#include <list>
#include <tuple>
#include <limits>
const char* filename = "data.txt";
using param_type = unsigned;
using tup_type = std::tuple<param_type,param_type,param_type>;
using map_type = std::list<tup_type>;
std::list<param_type> seeds;
map_type maps[7];
bool sort_tuple(tup_type a, tup_type b)
    return std::get<1>(a) < std::get<1>(b);
void fill_map(std::ifstream& file,map_type& map)
    char buffer[100];
    // get rid of heading
    file.getline(buffer,sizeof(buffer));
    while(true)
        if(buffer[0] < ' ')
            break;
        std::istringstream ss(buffer);
        param_type i1,i2,i3;
        ss >> i1 >> i2 >> i3;
        map.push_back(std::make_tuple(i1,i2,i3));
    // sort works but I have not found a way to take advantage
    map.sort(sort_tuple);
param_type find_location(param_type num,map_type map)
    for(auto& entry : map)
        param_type dest,src,len;
        dest = std::get<0>(entry);
        src = std::get<1>(entry);
        len = std::get<2>(entry);
        if(num >= src && num < src + len)
            return dest + num - src;
    return num;
int part1()
    param_type ret = std::numeric_limits<param_type>::max();
    for(auto s : seeds)
        param_type num = s;
        for(auto& m : maps)
            num = find_location(num,m);
        if(num < ret)
            ret = num;
    return ret;
param_type part2()
    auto i = seeds.begin();
    while(i != seeds.end())
        param_type start,end,x;
        start = *i++;
        end = start + *i++;
        for(x = start; x < end ; x++)
            param_type num = x;
            for(auto& m : maps)
            if(num < ret)
                ret = num;
    return ret;
int main()
    std::ifstream file(filename);
    std::cout << "Advent of code 2023 day 5" << "\n";
    if(file)
        char buffer[300];
        // get rid of "seeds:"
        std::string s;
        ss >> s;
        // get seeds
        param_type i;
        while(!ss.eof())
            ss >> i;
            seeds.push_back(i);
        // skip blank line
        // get 7 maps
        for(auto& map : maps)
            fill_map(file,map);
        std::cout << "Part1 " << part1() << "\n";
        std::cout << "Part2 " << part2() << "\n";
    else
        std::cout << "No file\n";
    return 0;
lurk101
Sat Dec 09, 2023 2:33 pm
Indeed, day 5 part 2 requires a different approach. So, in theory the 1st item in a source range should translate to the least destination, but not all input ranges are fully contained within a translation range. You need to create new translated destination ranges for the parts that do not completely overlap. Do this 7 times, once for each translation table. The final set of destination ranges will contain the least destination. Having done this you should be able to calculate the solution in under 1 millisecond.
hrvoje064
Sun Dec 10, 2023 7:41 am
Out of curiosity, I logged in to Advent and got my own "trebuchet" file. Actually the only thing I wanted to test is how long it will take Racket on rpi4b to get the answer. And the result is surprising. My correct result was 55816, but the time reported on rpi4 was 3ms (as in milliseconds)
My improved code (not lazy code like first two posts) is this:
#lang racket
  (let ((lines (map string->list (file->lines file #:mode 'text))))
(define (f+l ll rl)
  (let ((left (findf char-numeric? ll))
        (right (findf char-numeric? rl)))
    (if left
        (string->number (string left right))
        0)))
This is 65% faster than the previous code.
However I do not trust this result on rpi4 of 3ms. I think that the Racket time function resolution is too coarse, on such a short time intervals.
The same Racket code on my 10gen i5 reports 0ms, so that tells me nothing.
Anyway, I ported the code to Chez Scheme, which is a pain, because I had to implement file->lines, and findf functions myself.
From my previous experience Chez runs about 5x faster than Racket, and Chez reported 2.9354606ms.
That does not look OK with the racket result of 0, nor with the rpi4 result of 3. So to test properly, I placed the same test inside a do loop, and spun it 10000 times. That means that actually 10m lines are being processed.
This time Chez reports 4.155s, and Racket reports 8.71s. This is a more realistic result. Not 5x, but this is probably due to my implementations of the 2 key functions, which are built into the Racket. I did not try this on the rpi4.
RogerW
Sun Dec 10, 2023 10:00 am
Thanks for the pointer. I am strill trying to work it out but will get there in the end.
hrvoje064
Sun Dec 10, 2023 3:39 pm
rpi4b manages day1 part 2 Racket code in 15-28ms. My i5 does the same in 3-4ms. So all in all this is a respectable result for pi.
hrvoje064
Mon Dec 11, 2023 7:22 am
RPI4 & Racket code for day 2, part1 & part2
both parts are done in exactly the same time: 14ms each..
lurk101
Mon Dec 11, 2023 2:43 pm
C++ run times, so far
Screenshot 2023-12-11 094123.png (90.41 KiB) Viewed 141309 times
Day 6 is incorrect and should read 0.079 ms. 0.081 ms. 0.08 ms. 0.17 ms.
ejolson
Mon Dec 11, 2023 3:02 pm
Could the differences in timings between the Pi 5 and other Cortex-A76 systems be possibly due to different default option settings in the system compiler?
Edit: Fixed typo to clarify "option settings" in the above.
lurk101
Mon Dec 11, 2023 3:11 pm
Could the differences in timings between the Pi 5 and other Cortex-A76 systems be possibly due to different default opportunities settings in the system compiler?
Not sure what you mean by opportunities? Looking at the gcc code you find that the cortex-a72 and cortex a-76 use the same optimization profile for -O3. It is interesting that the Pi5 outperforms in most cases for single threaded applications. All use the same compiler version:
pi@pi5:~/AoC-2023-cplusplus $ gcc --version
gcc (GCC) 14.0.0 20231210 (experimental)
Copyright (C) 2023 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
ejolson
Mon Dec 11, 2023 5:09 pm
Sorry, my gesture typing failed. That was supposed to be options rather than opportunities. I'll edit the earlier post to make things more clear.
Some operating systems have differences in the defaults for position independent code and security mitigations like enabling the stack protector that could account for 7 to 10 percent. Is the assembler the same in both cases?
ejolson
Mon Dec 11, 2023 5:22 pm
Here my day 3 puzzle solution running on a Pi Zero at 700 MHz.
julia> include("day03.jl")
Advent of Code 2023 Day 3 Gear Ratios
Part 1 The sum of the part numbers is 527446
Part 2 The sum of the gear ratios is 73201705
Total execution time 10.286119573 seconds.
julia> main()
Total execution time 0.099547502 seconds.
julia> main()
Total execution time 0.106823466 seconds.
Again execution is significantly faster after just-in-time warmup.
The Julia code was
#=  Advent of Code 2023 Day 3 Gear Ratios
end
function issymbol(c::Char)::Bool
    if isdigit(c)||c=='.'
        return false
    end
    return true
end
function getpart(s::String)::Tuple{Int,Int}
    n=0
    for i=1:length(s)
            n=n*10+(s[i]-'0')
        else
            return i-1,n
        end
    end
    return length(s),n
end
function mksearch(data)
    m=length(data)
    n=length(data[1])
    z=zeros(Int8,m,n)
    function hflood(i::Int,j::Int)
        if i<1||i>m||j<1||j>n
            return 0
        end
        if !isdigit(data[i][j])||z[i,j]>0
            return 0
        end
        z[i,j]=1
        hflood(i,j-1); hflood(i,j+1)
        return 1
    end
    function asearch(i::Int,j::Int)
        if data[i][j]=='.'||z[i,j]>0
            return
        end
        z[i,j]=hflood(i-1,j-1)+hflood(i-1,j)+hflood(i-1,j+1)+
               hflood(i,j-1)+                hflood(i,j+1)+
               hflood(i+1,j-1)+hflood(i+1,j)+hflood(i+1,j+1)
    end
    return asearch
end
function part1(data,asearch)
    m=length(data)
    n=length(data[1])
    z=asearch.z
    for i=1:m,j=1:n
        if issymbol(data[i][j]) asearch(i,j) end
    end
    s=0
    for i=1:m
        j=1
        while j<=n
            if isdigit(data[i][j])&&z[i,j]>0
                δ,k=getpart(data[i][j:end])
                s+=k; j+=δ
            else
                j+=1
            end
        end
    end
    return s
end
function part2(data,asearch)
    m=length(data)
    n=length(data[1])
    z=asearch.z
    function getgear(i::Int,j::Int)::Int
        if !isdigit(data[i][j])||z[i,j]==0
            return 1
        end
        while j>1
            j-=1
                j+=1; break
            end
        end
        _,k=getpart(data[i][j:end])
        while j<=m&&isdigit(data[i][j])
            z[i,j]=0
            j+=1
        end
        return k
    end
    function getratio(i::Int,j::Int)
        return getgear(i-1,j-1)*getgear(i-1,j)*getgear(i-1,j+1)*
               getgear(i,j-1)*                 getgear(i,j+1)*
               getgear(i+1,j-1)*getgear(i+1,j)*getgear(i+1,j+1)
    end
    s=0
    for i=1:m, j=1:n
        if data[i][j]=='*'&&z[i,j]==2
            r=getratio(i,j)
            z[i,j]=0
            asearch(i,j)
            s+=r
        end
    end
    return s
end
function doinit()
    data=[]
    open("day03.txt","r") do fp
        data=readlines(fp)
    end
    asearch=mksearch(data)
    p1=part1(data,asearch)
    p2=part2(data,asearch)
    println("Part 1 The sum of the part numbers is ",p1)
    println("Part 2 The sum of the gear ratios is ",p2)
end
function main()
    t=@elapsed try
        println("Advent of Code 2023 Day 3 Gear Ratios\n")
        doinit()
        throw(DoExit())
    catch r
        if !isa(r,DoExit)
            rethrow(r)
        end
    end
end
main()
The closures look clumsy to me but Fido's tail is wagging. That means there is no need to worry about how the enclosed z array gets referenced as asearch.z later in the code.
lurk101
Mon Dec 11, 2023 5:28 pm
Not sure.
Pi5
Vulnerabilities:
  Gather data sampling:  Not affected
  Itlb multihit:         Not affected
  L1tf:                  Not affected
  Mds:                   Not affected
  Meltdown:              Not affected
  Mmio stale data:       Not affected
  Retbleed:              Not affected
  Spec rstack overflow:  Not affected
  Spec store bypass:     Not affected
  Spectre v1:            Mitigation; __user pointer sanitization
  Spectre v2:            Mitigation; CSV2, but not BHB
  Srbds:                 Not affected
  Tsx async abort:       Not affected
rock 5b
Vulnerabilities:
  L1tf:                 Not affected
  Mds:                  Not affected
  Srbds:                Not affected
orange pi 5
Vulnerabilities:
  L1tf:                 Not affected
  Mds:                  Not affected
  Srbds:                Not affected
Vulnerabilities all look the same, but the pi 5 is running 6.1 kernels whereas the rockchip are running 5.10.
I imagine the same, but I'd have to look at the disassembled code and that's too much work.
bensimmo
Mon Dec 11, 2023 5:45 pm
You could try the 6.6 Pi kernel that's in testing. (next)
ejolson
Mon Dec 11, 2023 5:52 pm
Is it possible to copy the binaries between systems and have them run?
Here is a comparision of the compile and run cycles for the C++ code
https://raw.githubusercontent.com/lurk1 ... /day03.cpp
to just-in-time compiled Julia.
After creating the file candr as
#!/bin/bash
g++ -O3 -o day03 day03.cpp
exec ./day03 "$@"
running on a Pi 4B at 1500 MHz obtained
$ time ./candr
--- Day 3: Gear Ratios ---
Part 1  - 527446
Part 2  - 73201705
Elapsed - 0.917 ms.
real    0m2.835s
user    0m2.593s
sys 0m0.243s
$ time julia day03.jl
Total execution time 0.826625262 seconds.
real    0m2.270s
user    0m2.190s
sys 0m0.312s
It's possible the algorithms are different, but even so, the execution times are similar.
More detailed results are available with perf.
$ perf stat ./candr
Part 1  - 527446
Part 2  - 73201705
Elapsed - 0.841 ms.
 Performance counter stats for './candr':
          2,848.80 msec task-clock:u                     #    1.000 CPUs utilized
                 0      context-switches:u               #    0.000 /sec
                 0      cpu-migrations:u                 #    0.000 /sec
            23,894      page-faults:u                    #    8.387 K/sec
     3,830,683,708      cycles:u                         #    1.345 GHz
     2,456,487,129      instructions:u                   #    0.64  insn per cycle
   <not supported>      branches:u
        31,405,076      branch-misses:u
       2.849971583 seconds time elapsed
       2.591639000 seconds user
       0.258528000 seconds sys
and
$ perf stat julia day03.jl
Total execution time 0.821978366 seconds.
 Performance counter stats for 'julia day03.jl':
          2,512.55 msec task-clock:u                     #    1.093 CPUs utilized
            39,008      page-faults:u                    #   15.525 K/sec
     3,229,749,954      cycles:u                         #    1.285 GHz
     2,402,085,759      instructions:u                   #    0.74  insn per cycle
        21,582,696      branch-misses:u
       2.299270463 seconds time elapsed
       2.188206000 seconds user
       0.324624000 seconds sys
The C++ compile and run cycle took 2,456,487,129 instructions while Julia took 2,402,085,759 which is a similar number.
lurk101
Mon Dec 11, 2023 7:05 pm
Ah, it seems g++ was using a generic optimization profile and not detecting the actual processor. By forcing the A76 profile with -mtune=cortex-a76 I get slightly improved run times, but Pi5 still outperforms.
ejolson
Mon Dec 11, 2023 9:57 pm
I wonder if explicitly specifying Cortex-A76 tuning would have an effect on the Pi Chart calculations.
viewtopic.php?p=2147572#p2147572
Here is a solution for day 4 running on the Pi Zero:
julia> include("day04.jl")
Advent of Code 2023 Day 4 Scratchcards
Part 1 The total number of points is 17803
Part 2 The total scratchcards at the end is 5554894
Total execution time 7.118361389 seconds.
julia> main()
Total execution time 0.183153032 seconds.
julia> main()
Total execution time 0.181672041 seconds.
I'm pretty impressed the dog developer's ARMv6 port of Julia is managing to run these Julia programs at all. The warm-up-time is slow but performance after that is fine.
For reference the code is
#=  Advent of Code 2023 Day 4 Scratchcards
end
        return s,false
    end
    end
    return s,false
end
function wskip(s::String)::String
    for i=1:length(s)
        if !isspace(s[i])
            return s[i:end]
        end
    end
    return ""
end
    n=0
    for i=1:length(s)
            n=n*10+(s[i]-'0')
        else
            return s[i:end],n
        end
    end
    return "",n
end
function getlist(s::String)::Tuple{String,Vector{Int}}
    u=Int[]
    while length(s)>0
        if begin s,x=getint(s); x==0 end
            return s,u
        end
        s=wskip(s)
        push!(u,x)
    end
    return "",u
end
mutable struct cardspec
    n::Int
    w::Vector{Int}
    v::Vector{Int}
end
function getcard(s::String)::cardspec
    r=s
    if begin s,f=gobble(s,"Card"); !f end
        println("%r\nDid not begin with Card!")
        throw(DoExit())
    end
    s=wskip(s)
        println("$r\nCould not parse card number!")
        throw(DoExit())
    end
    if begin s,f=gobble(s,":"); !f end
        println("%r\nMissing : separator!")
        throw(DoExit())
    end
    s=wskip(s)
    if begin s,w=getlist(s); length(w)==0 end
        println("$r\nCould not parse winning numbers!")
        throw(DoExit())
    end
    if begin s,f=gobble(s,"|"); !f end
        println("%r\nMissing | separator!")
        throw(DoExit())
    end
    s=wskip(s)
    if begin s,v=getlist(s); length(v)==0 end
        println("$r\nCould not parse my numbers!")
        throw(DoExit())
    end
    return cardspec(n,sort(w),sort(v))
end
function getmatches(c::cardspec)::Int
    i=1; j=1; r=0
    while i<=length(c.w)&&j<=length(c.v)
        if c.w[i]<c.v[j]
            i+=1
        elseif c.w[i]>c.v[j]
            j+=1
        else
            r+=1
            i+=1
            j+=1
        end
    end
    return r
end
function getvalue(c::cardspec)::Int
    r=getmatches(c)
    if r==0
        return 0
    else
        return 2^(r-1)
    end
end
function part1(data)::Int
    s=0
        c=getcard(data[i])
        s+=getvalue(c)
    end
    return s
end
function part2(data)::Int
    m=ones(Int,length(data))
    s=0
        c=getcard(data[i])
        r=getmatches(c)
        for j=i+1:i+r
            m[j]+=m[i]
        end
    end
    return sum(m)
end
function doinit()
    data=[]
    open("day04.txt","r") do fp
        data=readlines(fp)
    end
    p1=part1(data)
    p2=part2(data)
    println("Part 1 The total number of points is ",p1)
    println("Part 2 The total scratchcards at the end is ",p2)
end
function main()
    t=@elapsed try
        println("Advent of Code 2023 Day 4 Scratchcards\n")
        doinit()
        throw(DoExit())
    catch r
        if !isa(r,DoExit)
            rethrow(r)
        end
    end
end
main()
Except for the mutable structure there was nothing new. The day 4 puzzle seemed easier than day 3.
lurk101
Tue Dec 12, 2023 12:58 am
They all seemed pretty easy, till I hit day 5 part 2!
ejolson
Tue Dec 12, 2023 5:54 am
I just got to day 5 part 2. The code is stuck in a loop and the dog developer has already gone to sleep. That makes it difficult to delegate part 2. I think I'll go to sleep as well.
hrvoje064
Tue Dec 12, 2023 8:47 am
Day 3: Racket on rpi4b
part 1: 15ms (best)
part 2: 11ms (best)
(This "best" simply means that GC did not kick in that run)
hrvoje064
Tue Dec 12, 2023 1:45 pm
Day 4: Racket on rpi4b
Part 1: 30ms (best)
Part 2: 30ms (best)
Re: speed, (or lack of it), I should explain that in both parts of day 4, unlike day 3 - where I had to use vectors, here I used only lists. With some list surgery in part 2.
Return to “Teaching and learning resources”
