jthjth
Moving from Pi4 to Pi5
Wed Oct 18, 2023 7:58 am
If I setup Bookworm on a Pi4 can I simply move the SD card to a Pi5 (when it arrives) and expect it to boot and work correctly, or should I start with a fresh install?
Re: Moving from Pi4 to Pi5
Wed Oct 18, 2023 8:19 am
Yes.
Unreadable squiggle
jthjth
Wed Oct 18, 2023 10:16 am
Thank you - that's just the sort of answer I was hoping for :)
Wed Oct 18, 2023 10:25 am
I would recommend the 64-bit version of Bookworm for the Pi 4 and Pi 5, as long as you don't plan to run it on a Pi 1, Zero or early Pi 2.
Unreadable squiggle
cct
Mon Oct 23, 2023 12:50 pm
Planning to do this when my PI5 arrives. PI4 is 8GB, full 64 bit distro. Is changing the node name as simple as changing it in raspi-config?
I have had huge problems before on various OS - especially VMS
Chris
Chris
Mon Oct 23, 2023 1:13 pm
Chris
Yes, change the hostname in raspi-config, or edit the files /etc/hostname and /etc/hosts and change it in there. That will do the job in most cases.
Unreadable squiggle
cct
Mon Oct 23, 2023 1:25 pm
Chris
Thanks - thought it would be enough
Chris
Chris
philrandal
Thu Oct 26, 2023 6:41 pm
The answers are almost correct.
However, if you're using the serial port (ttyAMA0):
On Pi 4 and earlier, "enable_uart=1" in /boot/config.txt
On a Pi 5, it is instead "dtparam=uart0=on" instead.
Or use raspi-config to enable it.
That one had me scratching my head until I realised the difference.
Phil
Dana JG
Thu Jan 25, 2024 12:30 am
Hi all. I have a similar question, found and read this thread.
I'm moving my Bitcoin Lightning node from a Pi4 to a Pi5. I assume moving the SSD is fine. I'm using the Pi's for HDMI (monitor), keyboard and mouse (USB).
I plan on a getting new Pi5 chassis and fan.
Anything to be aware of or gotcha's?
Many thanks!
Dana in Oregon
bjtheone
Thu Jan 25, 2024 1:51 pm
Many thanks!
Dana in Oregon
A current OS install (Bookworm) running on a Pi 4 will run without issue on a Pi 5. If you are not powering the Pi 5 with the USB-PD power supply and get the 5V@5A mode, you may need to set the override to get enough current to run the USB connected SSD. Any SSD that runs on a Pi 4 should run on a Pi 5. I built and tested a Bookworm install on a 4B and then moved that install to a Pi 5 without having to change anything.
If the 4B is running Buster or Bullseye, the easy path is to upgrade to Bookworm. There apparently are ways to tweak, at least Bullseye, to run on the Pi 5 but it is most definitely not particularly common or supported.
skamz
Mon Feb 12, 2024 12:47 am
Hi I just want to mention, as someone who just got their Pi 5 in the mail and attempted this, it did NOT work.
I think this is because I upgraded my Debian install to Bookworm and didn't do a fresh install. Apparently if you already have a system that was a fresh Bookworm install then you can switch between 4 and 5.
bjtheone
Mon Feb 12, 2024 3:34 pm
You certainly _can_ upgrade from Buster or Bullseye to Bookworm. Unless you have reasonable Linux skills you likely _shouldn't_ upgrade this way. Given the vast (infinite) number of OS variations, it is very difficult to provide a recipe that will work without issues doing an in place upgrade. For that reason, RPL always recommends starting from a fresh install for new distro releases.
A functional Bookworm install, running on a Pi 4, should run on a Pi 5 without any issues. A clean Bookworm install that was running on a Pi 4 will run on a Pi 5 without issues.
andrewsmith32
Tue Feb 20, 2024 12:35 pm
Sure thing! Upgrading from Buster or Bullseye to Bookworm is possible, but it's not always a smooth ride unless you're pretty good with Linux. It's like trying to upgrade a car while it's still running – things can get messy. It's usually safer to start fresh with a new installation for big updates like this. And if you're moving from a Raspberry Pi 4 to a Pi 5 with Bookworm, don't worry – it should work just fine without any hiccups.
Return to “Raspberry Pi OS”
